This reverts commit c85acbf72786a5901a2170b2145761ed7cf06429 which is
commit e4849aff1e169b86c561738daf8ff020e9de1011 upstream
Guenter writes:
Upstream commit e4849aff1e16 ("MIPS: SiByte: Enable swiotlb for SWARM,
LittleSur and BigSur") results in build failures in v4.4.y and v4.14.y.
make bigsur_defconfig:
warning: (SIBYTE_SWARM && SIBYTE_SENTOSA && SIBYTE_BIGSUR && SWIOTLB_XEN && AMD_IOMMU) selects SWIOTLB which has unmet direct dependencies (CAVIUM_OCTEON_SOC || MACH_LOONGSON64 && CPU_LOONGSON3 || NLM_XLP_BOARD || NLM_XLR_BOARD)
and the actual build:
lib/swiotlb.o: In function `swiotlb_tbl_map_single':
(.text+0x1c0): undefined reference to `iommu_is_span_boundary'
Makefile:1021: recipe for target 'vmlinux' failed
Reported-by: Guenter Roeck <linux@roeck-us.net>
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Paul Burton <paul.burton@mips.com>
Cc: linux-mips@linux-mips.org
Cc: Sasha Levin <sashal@kernel.org>
[ Upstream commit e4849aff1e169b86c561738daf8ff020e9de1011 ]
The Broadcom SiByte BCM1250, BCM1125, and BCM1125H SOCs have an onchip
DRAM controller that supports memory amounts of up to 16GiB, and due to
how the address decoder has been wired in the SOC any memory beyond 1GiB
is actually mapped starting from 4GiB physical up, that is beyond the
32-bit addressable limit[1]. Consequently if the maximum amount of
memory has been installed, then it will span up to 19GiB.
Many of the evaluation boards we support that are based on one of these
SOCs have their memory soldered and the amount present fits in the
32-bit address range. The BCM91250A SWARM board however has actual DIMM
slots and accepts, depending on the peripherals revision of the SOC, up
to 4GiB or 8GiB of memory in commercially available JEDEC modules[2].
I believe this is also the case with the BCM91250C2 LittleSur board.
This means that up to either 3GiB or 7GiB of memory requires 64-bit
addressing to access.
I believe the BCM91480B BigSur board, which has the BCM1480 SOC instead,
accepts at least as much memory, although I have no documentation or
actual hardware available to verify that.
Both systems have PCI slots installed for use by any PCI option boards,
including ones that only support 32-bit addressing (additionally the
32-bit PCI host bridge of the BCM1250, BCM1125, and BCM1125H SOCs limits
addressing to 32-bits), and there is no IOMMU available. Therefore for
PCI DMA to work in the presence of memory beyond enable swiotlb for the
affected systems.
All the other SOC onchip DMA devices use 40-bit addressing and therefore
can address the whole memory, so only enable swiotlb if PCI support and
support for DMA beyond 4GiB have been both enabled in the configuration
of the kernel.
This shows up as follows:
Broadcom SiByte BCM1250 B2 @ 800 MHz (SB1 rev 2)
Board type: SiByte BCM91250A (SWARM)
Determined physical RAM map:
memory: 000000000fe7fe00 @ 0000000000000000 (usable)
memory: 000000001ffffe00 @ 0000000080000000 (usable)
memory: 000000000ffffe00 @ 00000000c0000000 (usable)
memory: 0000000087fffe00 @ 0000000100000000 (usable)
software IO TLB: mapped [mem 0xcbffc000-0xcfffc000] (64MB)
in the bootstrap log and removes failures like these:
defxx 0000:02:00.0: dma_direct_map_page: overflow 0x0000000185bc6080+4608 of device mask ffffffff bus mask 0
fddi0: Receive buffer allocation failed
fddi0: Adapter open failed!
IP-Config: Failed to open fddi0
defxx 0000:09:08.0: dma_direct_map_page: overflow 0x0000000185bc6080+4608 of device mask ffffffff bus mask 0
fddi1: Receive buffer allocation failed
fddi1: Adapter open failed!
IP-Config: Failed to open fddi1
when memory beyond 4GiB is handed out to devices that can only do 32-bit
addressing.
This updates commit cce335ae47e2 ("[MIPS] 64-bit Sibyte kernels need
DMA32.").
References:
[1] "BCM1250/BCM1125/BCM1125H User Manual", Revision 1250_1125-UM100-R,
Broadcom Corporation, 21 Oct 2002, Section 3: "System Overview",
"Memory Map", pp. 34-38
[2] "BCM91250A User Manual", Revision 91250A-UM100-R, Broadcom
Corporation, 18 May 2004, Section 3: "Physical Description",
"Supported DRAM", p. 23
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
[paul.burton@mips.com: Remove GPL text from dma.c; SPDX tag covers it]
Signed-off-by: Paul Burton <paul.burton@mips.com>
Patchwork: https://patchwork.linux-mips.org/patch/21108/
References: cce335ae47e2 ("[MIPS] 64-bit Sibyte kernels need DMA32.")
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Allow the boot_secondary SMP op to return an error to __cpu_up(), which
will in turn return it to its caller.
This will allow SMP implementations to return errors quickly in cases
they they know have failed, rather than relying upon __cpu_up()
eventually timing out waiting for the cpu_running completion.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/17014/
smp_ops providers do not modify their ops structures, so they should be
made const for robustness. Since currently the MIPS kernel is not mapped
with memory protection, this does not in itself provide any security
benefit, but it still makes sense to make this change.
There are also slight code size efficincies from the structure being
made read-only, saving 128 bytes of kernel text on a
pistachio_defconfig.
Before:
7187239 1772752 470224 9430215 8fe4c7 vmlinux
After:
7187111 1772752 470224 9430087 8fe447 vmlinux
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Cc: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Kevin Cernekee <cernekee@gmail.com>
Cc: Doug Ledford <dledford@redhat.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Joe Perches <joe@perches.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Steven J. Hill <steven.hill@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/16784/
This fixes the following modpost error:
ERROR: "periph_rev" [drivers/net/ethernet/broadcom/sb1250-mac.ko] undefined!
<linux/sched/task_stack.h>
Split out the task->stack related functionality, which is not really
part of the core scheduler APIs.
Only keep task_thread_info() because it's used by sched.h.
Update the code that uses those facilities.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task_stack.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. In the case of
some code where it is modular, we can extend that to also include
files that are building basic support functionality but not related
to loading or registering the final module; such files also have
no need whatsoever for module.h
The advantage in removing such instances is that module.h itself
sources about 15 other headers; adding significantly to what we feed
cpp, and it can obscure what headers we are effectively using.
Since module.h might have been the implicit source for init.h
(for __init) and for export.h (for EXPORT_SYMBOL) we consider each
instance for the presence of either and replace/add as needed.
Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code.
Build coverage of all the mips defconfigs revealed the module.h
header was masking a couple of implicit include instances, so
we add the appropriate headers there.
Cc: David Daney <david.daney@cavium.com>
Cc: John Crispin <john@phrozen.org>
Cc: "Steven J. Hill" <steven.hill@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/15131/
[james.hogan@imgtec.com: Preserve sort order where it already exists]
Signed-off-by: James Hogan <james.hogan@imgtec.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Commit 6793f55cbc84 ("MIPS: sibyte: Amend dependencies for
SIBYTE_BUS_WATCHER") changed the dependencies for
SIBYTE_BUS_WATCHER to make it visible only if SIBYTE_BCM112X
or SIBYTE_SB1250 are enabled.
In the code in arch/mips/sibyte/common/bus_watcher, however,
a #if defined() check suggests that this functionality should
also be available for SIBYTE_BCM1x55 and SIBYTE_BCM1x80.
Make it selectable by extending the dependencies of
SIBYTE_BUS_WATCHER in arch/mips/sibyte/Kconfig.
Reported-by: Jonas Rabenstein <jonas.rabenstein@studium.uni-erlangen.de>
Signed-off-by: Andreas Ruprecht <andreas.ruprecht@fau.de>
Cc: valentinrothberg@gmail.com
Cc: stefan.hengelein@fau.de
Cc: pebolle@tiscali.nl
Patchwork: https://patchwork.linux-mips.org/patch/10736/
The majority of SMP platforms handle their IPIs through do_IRQ()
which calls irq_{enter/exit}(). When a call function IPI is received,
smp_call_function_interrupt() is called which also calls
irq_{enter,exit}(), meaning irq_count is raised twice.
When tick broadcasting is used (which is implemented via a call
function IPI), this incorrectly causes all CPU idle time on the core
receiving broadcast ticks to be accounted as time spent servicing
IRQs, as account_process_tick() will account as such if irq_count is
greater than 1. This results in 100% CPU usage being reported on a
core which receives its ticks via broadcast.
This patch removes the SMP smp_call_function_interrupt() wrapper which
calls irq_{enter,exit}(). Platforms which handle their IPIs through
do_IRQ() now call generic_smp_call_function_interrupt() directly to
avoid incrementing irq_count a second time. Platforms which don't
(loongson, sgi-ip27, sibyte) call generic_smp_call_function_interrupt()
wrapped in irq_{enter,exit}().
Signed-off-by: Alex Smith <alex.smith@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/10770/
Pass 1 parts had a number of significant erratas and were only available
in small numbers and under NDA. Full support also required the use of a
special toolchain that kept branches properly aligned. These workarounds
were never upstreamed and the only toolchain known to have them is
Montavista's GCC 3.0-based toolchain which completly obsoleted if not
useless these days.
So now that automated testing has tripped over the user of the
-msb1-pass1-workarounds option, rather than fixing it remove support for
pass 1 parts.
Probably nobody will notice. I seem to own the last know pass 1 board
and I haven't noticed another one in the wild in the past decade, at
least.
While at it, rename it because in drivers/irqchip no longer every CPU is
a MIPS.
Based on the spatch
expression e;
- return (e);
+ return e;
with heavy hand editing because some of the changes are either whitespace
or identation only or result in excessivly long lines.
Fixes the following randconfig build problem:
arch/mips/built-in.o: In function `show_cpuinfo':
proc.c:(.text+0xde84): undefined reference to `get_system_type'
arch/mips/built-in.o: In function `sb1250_setup':
(.init.text+0x428): undefined reference to `get_system_type'
arch/mips/built-in.o: In function `setup_arch':
(.init.text+0x178c): undefined reference to `plat_mem_setup'
Makefile:930: recipe for target 'vmlinux' failed
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/8106/
Nothing was using the method and there isn't any need for this hook. This
leaves smp_cpus_done() empty for the moment.
As suggested by Paul Bolle <pebolle@tiscali.nl>.
There are two checks for CONFIG_SIBYTE_BCM1480_PROF in the tree since
v2.6.15. The related Kconfig symbol has never been added to the tree. So
these checks have always evaluated to false. Besides, one of these
checks guards a call of sbprof_cpu_intr(). But that function is not
defined. Remove all this.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Patchwork: https://patchwork.linux-mips.org/patch/6981/
The [user space] interface does not filter out offline cpus. It merily
guarantees that the mask contains at least one online cpu.
So the selector in the irq chip implementation needs to make sure to
pick only an online cpu because otherwise:
Offline Core 1
Set affinity to 0xe (is valid due to online mask 0xd)
cpumask_first will pick core 1, which is offline
Link: http://lkml.kernel.org/r/20140304203100.744800502@linutronix.de
Let the core do the irq_desc resolution.
No functional change.
Cc: mips <inux-mips@linux-mips.org>
Link: http://lkml.kernel.org/r/20140223212737.517340416@linutronix.de
Now that we have a CONFIG_PANIC_TIMEOUT=x setting, remove the
mips settings. The default is 0, which means don't reboot on
panic.
Acked-by: Shinya Kuribayashi <skuribay@pobox.com>
Signed-off-by: Jason Baron <jbaron@akamai.com>
Cc: benh@kernel.crashing.org
Cc: paulus@samba.org
Cc: mpe@ellerman.id.au
Cc: felipe.contreras@gmail.com
Link: http://lkml.kernel.org/r/d19dc75fca343ec5d9ada75a1400f57330021976.1385418410.git.jbaron@akamai.com
Replace hardcoded CP0 PRId and CP1 FPIR register access masks throughout.
The change does not touch places that use shifted or partial masks.
Patchwork: https://patchwork.linux-mips.org/patch/5838/
commit 3747069b25e419f6b51395f48127e9812abc3596 upstream.
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
and are flagged as __cpuinit -- so if we remove the __cpuinit from
the arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
related content into no-ops as early as possible, since that will get
rid of these warnings. In any case, they are temporary and harmless.
Here, we remove all the MIPS __cpuinit from C code and __CPUINIT
from asm files. MIPS is interesting in this respect, because there
are also uasm users hiding behind their own renamed versions of the
__cpuinit macros.
[1] https://lkml.org/lkml/2013/5/20/589
[ralf@linux-mips.org: Folded in Paul's followup fix.]
Patchwork: https://patchwork.linux-mips.org/patch/5494/
Patchwork: https://patchwork.linux-mips.org/patch/5495/
Patchwork: https://patchwork.linux-mips.org/patch/5509/
This that should have been fixed but weren't, way to much, intrusive
and late.
Fixes the following build problem:
mips-linux-gnu-ld:arch/mips/kernel/vmlinux.lds:253: syntax error
because VMLINUX_LOAD_ADDRESS was an empty string for that platform
so the vmlinux.lds.S created an invalid section entry on line 50.
Acked-by: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: sibyte-users@bitmover.com
Patchwork: https://patchwork.linux-mips.org/patch/5548/
SIBYTE_BUS_WATCHER is only visible if CONFIG_SIBYTE_BCM112X
or CONFIG_SIBYTE_SB1250 is selected according to the
arch/mips/sibyte/Makefile.
This fixes the following build problem:
arch/mips/mm/cerr-sb1.c:254: undefined reference to `check_bus_watcher'
Patchwork: https://patchwork.linux-mips.org/patch/5482/
CC arch/mips/sibyte/bcm1480/bus_watcher.o
CHK kernel/config_data.h
arch/mips/sibyte/bcm1480/bus_watcher.c: In function ‘check_bus_watcher’:
arch/mips/sibyte/bcm1480/bus_watcher.c:86:82: error: ‘A_SCD_BUS_ERR_STATUS_DEBUG’ undeclared (first use in this function)
arch/mips/sibyte/bcm1480/bus_watcher.c:86:82: note: each undeclared identifier is reported only once for each function it appears in
make[3]: *** [arch/mips/sibyte/bcm1480/bus_watcher.o] Error 1
make[2]: *** [arch/mips/sibyte/bcm1480] Error 2
make[1]: *** [arch/mips/sibyte] Error 2
make: *** [arch/mips] Error 2
The register moved around though it's otherwise the same but because of
the changed address it now also has a different name.
Patchwork: https://patchwork.linux-mips.org/patch/5514/
Reported-by: Markos Chandras <markos.chandras@imgtec.com>
It's needed for the TASK_INTERRUPTIBLE definition.
arch/mips/sibyte/common/sb_tbprof.c:235:4: error: 'TASK_INTERRUPTIBLE'
[ralf@linux-mips.org: Ideally sched.h should be included into the actual
user of TASK_INTERRUPTIBLE, <linux/wait.h> but that seems way too risky
that close to a release.]
Patchwork: https://patchwork.linux-mips.org/patch/5479/
arch/mips/sibyte/sb1250/bus_watcher.c: In function 'sibyte_bw_int':
arch/mips/sibyte/sb1250/bus_watcher.c:179:7: error: unused variable 'bw_buf'
[-Werror=unused-variable]
Patchwork: https://patchwork.linux-mips.org/patch/5481/
Cc: stable@vger.kernel.org
Don't use create_proc_read_entry() as that is deprecated, but rather use
proc_create_data() and seq_file instead.
cc: Ralf Baechle <ralf@linux-mips.org>
cc: linux-mips@linux-mips.org
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
With the upcoming merge of the ARC architecture there is a small likelyhood
of conflicting use for the CONFIG_ARC config symbol. Rename it to
CONFIG_FW_ARC. Also rename CONFIG_ARC32 to CONFIG_FW_ARC32, CONFIG_ARC64
to CONFIG_FW_ARC64.
For consistence also rename CONFIG_SNIPROM to CONFIG_FW_SNIPROM and
CONFIG_CFE to CONFIG_FW_CFE.
This has been obsolescent for a while, fix documentation and
misc comments.
This has been obsolescent for a while; time for the final push.
In adjacent context, replaced old cpus_* with cpumask_*.
Acked-by: David S. Miller <davem@davemloft.net> (arch/sparc)
Acked-by: Chris Metcalf <cmetcalf@tilera.com> (arch/tile)
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-hexagon@vger.kernel.org
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Helge Deller <deller@gmx.de>
Cc: sparclinux@vger.kernel.org
Disintegrate asm/system.h for MIPS.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
SIBYTE_CFE got killed in commit 05f94eebd5 ("MIPS: Sibyte: Remove
standalone kernel support"). This means that since v2.6.31 there is no
Kconfig symbol SIBYTE_CFE. The select statement for that symbol is a
nop. Drop it.
Commit d6d5d5c4a (MIPS: Sibyte: Convert to new irq_chip functions)
removed the mask function which breaks irq_shutdown(). Restore it.
Reported-by: Matt Turner <mattst88@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/2460/
Tested-by: Matt Turner <mattst88@gmail.com>
For future rework of try_to_wake_up() we'd like to push part of that
function onto the CPU the task is actually going to run on.
In order to do so we need a generic callback from the existing scheduler IPI.
This patch introduces such a generic callback: scheduler_ipi() and
implements it as a NOP.
BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions!
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reviewed-by: Frank Rowand <frank.rowand@am.sony.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
Scripted with coccinelle.
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2205/
To: Jiri Kosina <trivial@kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/1756/
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
