path: root/arch/mips/sni
2010-10-07MIPS: Add missing #inclusions of <linux/irq.h>David Howells
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should really include it. Note that this can replace #inclusions of <asm/irq.h>. This is required for the patch to sort out irqflags handling function naming to compile on MIPS. The problem is that these files require access to things like setup_irq() - which isn't available by #including <linux/interrupt.h> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: SNI: Migrate to new platform makefile style.Ralf Baechle
2010-02-27MIPS: SNI: Convert sni_rm200_i8259A_lock to raw spinlock.Ralf Baechle
2010-02-27MIPS: Make various locks static.Ralf Baechle
2010-02-10MIPS: SNI: Correct NULL testJulia Lawall
Test the value that was just allocated rather than the previously tested one. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ expression *x; expression e; identifier l; @@ if (x == NULL || ...) { ... when forall return ...; } ... when != goto l; when != x = e when != &x *x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org To: kernel-janitors@vger.kernel.org Patchwork: http://patchwork.linux-mips.org/patch/945/ Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Move several variables from .bss to .init.dataDmitri Vorobiev
Several static uninitialized variables are used in the scope of __init functions but are themselves not marked as __initdata. This patch is to put those variables to where they belong and to reduce the memory footprint a little bit. Also, a couple of lines with spaces instead of tabs were fixed. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/698/ Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Fixup last users of irq_chip->typename Thomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org To: LKML <linux-kernel@vger.kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Patchwork: http://patchwork.linux-mips.org/patch/661/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-11-02MIPS: Add IRQF_TIMER flag for timer interruptsWu Zhangjin
Along the lines of d6c585a4342a2ff627a29f9aea77c5ed4cd76023, add IRQF_TIMER flag for all timer interrupts This ensures that timer interrupts won't be disabled on suspend and not threaded for PREEMPT_RT. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-15timekeeping: Increase granularity of read_persistent_clock()Martin Schwidefsky
The persistent clock of some architectures (e.g. s390) have a better granularity than seconds. To reduce the delta between the host clock and the guest clock in a virtualized system change the read_persistent_clock function to return a struct timespec. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.013873340@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-15mips: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: linux-mips@linux-mips.org Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: oprofile: Thou shalt not call __exit functions from __init functions cpumask: remove the now-obsoleted pcibus_to_cpumask(): generic cpumask: remove cpumask_t from core cpumask: convert rcutorture.c cpumask: use new cpumask_ functions in core code. cpumask: remove references to struct irqaction's mask field. cpumask: use mm_cpumask() wrapper: kernel/fork.c cpumask: use set_cpu_active in init/main.c cpumask: remove node_to_first_cpu cpumask: fix seq_bitmap_*() functions. cpumask: remove dangerous CPU_MASK_ALL_PTR, &CPU_MASK_ALL
2009-03-30MIPS: Enable GENERIC_HARDIRQS_NO__DO_IRQ for all platformsRalf Baechle
__do_IRQ() is deprecated and will go away. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30cpumask: remove references to struct irqaction's mask field.Rusty Russell
Impact: cleanup It's unused, since about 1995. So remove all initialization of it in preparation for actually removing the field. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-07-15[MIPS] Remove obsolete isa_slot_offsetMaciej W. Rozycki
The isa_slot_offset variable and its __ISA_IO_base macro is not used anywhere anymore. It does not look like a decent interface per today's standards either. Remove both including all places of initialization. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] RM: Collected changesThomas Bogendoerfer
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part is the splitting of the EISA and onboard ISA of the RM200, which makes the EISA bus on the RM200 look like on other RMs. - 64bit kernel support - system type detection is now common for big and little endian - moved sniprom code to arch/mips/fw - added call_o32 function to arch/mips/fw/lib, which uses a private stack for calling prom functions - fix problem with ISA interrupts, which makes using PIT clockevent possible Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Cleanup pcspeaker platform device registration.Ralf Baechle
Move registration into the actual platform code instead of making a desparate attempt at sharing the hand full of likes of code in pcspeaker.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] SNI: s/achknowledge/acknowledge/Maciej W. Rozycki
2007-11-02[MIPS] SNI: register a02r clockevent; don't use PIT timerThomas Bogendoerfer
Register A20R clockevent. Remove PIT timer setup because it doesn't work Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] SNI: Convert a20r timer to clockevent device.Ralf Baechle
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19[MIPS] Kill duplicated setup_irq() for cp0 timerAtsushi Nemoto
Also many plat_timer_setup() can be killed too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] i8253 PIT clocksource and clockevent driversRalf Baechle
Derived from the i386 variant with a few x86 complexities chopped off. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Move ARC code into arch/mips/fw/arcAurelien Jarno
Move the ARC code to arch/mips/fw/arc from arch/mips/arc. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] SNI: remove unused pcimt_scache.cYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] SNI: Remove unneeded sni_machine_haltYoichi Yuasa
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-07-24[MIPS] SNI: snipromThomas Bogendoerfer
- fix compile error due to missing #include - fix section mismatch warning Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-12[MIPS] RM: Use only phyiscal address for 82596 and 53c710Thomas Bogendoerfer
Use physical address for 82596 and 53c710 base address Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] SNI RM updatesThomas Bogendoerfer
- use RTC_CLASS instead of GEN_RTC - get rid of ds1216 in favour of a RTC_CLASS driver - use correct console device for older RM400 - use physical addresses for 82596 device - use 128 byte L1 cache line size (this is needed because most of the SNI caches are using 128 L2 cache lines) Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-06-06[MIPS] Fix VGA corruption on RM300CThomas Bogendoerfer
... by setting DRAM config to 2MB (SNI always used that size). This also fixes video dram size detection in cirrusfb. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-06-06[MIPS] RM300: Fix MMIO problems by marking the PCI INT ACK region busyThomas Bogendoerfer
2007-05-08Replace deprecated SA_xxx interrupt flagsThomas Gleixner
Fix the last users of the deprecated SA_xxx interrupt flags. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27[MIPS] Change PCI host bridge setup/resourcesThomas Bogendoerfer
PCI host bridge setup for SNI RM machines with PCI is quite broken, now that Linux does it's resource setup own its own. It will use IO addresses, which are needed by the EISA config detection and assigns PCI memory addresses, which overlap with ISA legacy addresses (video ram). Below is a patch, which changes the way how the PCI memory addresses are used and sets the minimum IO address to give enough IO space for 8 EISA slots). This patch needs the other PCI resource change, I've posted. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-19[MIPS] Misc fixes for plat_irq_dispatch functionsThiemo Seufer
o adds missing ST0_IM masks, which caused the logging of valid interrupts as spurious o stops pnx8550 to log every interrupt as spurious o adds cause register masks for ip22/ip32, which caused handling of masked interrupts o removes some superfluous parentheses in the SNI interrupt code Signed-Off-By: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] SNI: MIPS_CPU_IRQ_BASE cleanupThomas Bogendoerfer
Use MIPS_CPU_IRQ_BASE instead of own define. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Many Makefiles in arch/mips have EXTRA_AFLAGS := $(CFLAGS) line. This is redundant while AFLAGS contains $(cflags-y) and any options only listed in CFLAGS (not in cflags-y) should be unnecessary for asm sources. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-18[MIPS] Support for several more SNI RM models.Thomas Bogendoerfer
2007-02-06[MIPS] use name instead of typename for each irq_chipAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] Eleminate interrupt migration helper use.Ralf Baechle
> #define hw_interrupt_type irq_chip > typedef struct irq_chip hw_irq_controller; > #define no_irq_type no_irq_chip > typedef struct irq_desc irq_desc_t; Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
