[ Upstream commit 12051b318bc3ce5b42d6d786191008284b067d83 ]
The code in question is modifying a variable declared const through
pointer manipulation. Such code is explicitly undefined behavior, and
is the lone issue preventing malta_defconfig from booting when built
with Clang:
If an attempt is made to modify an object defined with a const-qualified
type through use of an lvalue with non-const-qualified type, the
behavior is undefined.
LLVM is removing such assignments. A simple fix is to not declare
variables const that you plan on modifying. Limiting the scope would be
a better method of preventing unwanted writes to such a variable.
Further, the code in question mentions "compiler bugs" without any links
to bug reports, so it is difficult to know if the issue is resolved in
GCC. The patch was authored in 2006, which would have been GCC 4.0.3 or
4.1.1. The minimal supported version of GCC in the Linux kernel is
currently 4.6.
For what its worth, there was UB before the commit in question, it just
added a barrier and got lucky IRT codegen. I don't think there's any
actual compiler bugs related, just runtime bugs due to UB.
Link: https://github.com/ClangBuiltLinux/linux/issues/610
Fixes: 966f4406d903 ("[MIPS] Work around bad code generation for <asm/io.h>.")
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Debugged-by: Nathan Chancellor <natechancellor@gmail.com>
Suggested-by: Eli Friedman <efriedma@quicinc.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Tested-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Paul Burton <paul.burton@mips.com>
Cc: ralf@linux-mips.org
Cc: jhogan@kernel.org
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Hassan Naveed <hnaveed@wavecomp.com>
Cc: Stephen Kitt <steve@sk2.org>
Cc: Serge Semin <fancer.lancer@gmail.com>
Cc: Mike Rapoport <rppt@linux.ibm.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: linux-mips@vger.kernel.org
Cc: clang-built-linux@googlegroups.com
[ Upstream commit 682fee802843b332f9c51ffc8e062de5ff773f2e ]
Trying to register the DSP platform device results in a null pointer
access:
[ 0.124184] CPU 0 Unable to handle kernel paging request at virtual address 00000000, epc == 804e305c, ra == 804e6f20
[ 0.135208] Oops[#1]:
[ 0.137514] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.87
[ 0.197117] epc : 804e305c bcm63xx_dsp_register+0x80/0xa4
[ 0.202838] ra : 804e6f20 board_register_devices+0x258/0x390
This happens because it tries to copy the passed platform data over the
platform_device's unpopulated platform_data.
Since this code has been broken since its submission, no driver was ever
submitted for it, and apparently nobody was using it, just remove it
instead of trying to fix it.
Fixes: e7300d04bd08 ("MIPS: BCM63xx: Add support for the Broadcom BCM63xx family of SOCs.")
Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: linux-mips@linux-mips.org
Cc: James Hogan <jhogan@kernel.org>
[ Upstream commit a4a3893114a41e365274d5fab5d9ff5acc235ff0 ]
__sanitizer_cov_trace_pc() is not linked in and causing link
failure if KCOV_INSTRUMENT is enabled. Fix this by disabling
instrumentation for compressed image.
Signed-off-by: Jouni Hogander <jouni.hogander@unikie.com>
Signed-off-by: Paul Burton <paulburton@kernel.org>
Cc: Lukas Bulwahn <lukas.bulwahn@gmail.com>
[ Upstream commit 3b1313eb32c499d46dc4c3e896d19d9564c879c4 ]
Report L1 caches as shared per core; L2 - per cluster.
This fixes "perf" that went crazy if shared_cpu_map attribute not
reported on sysfs, in form of
/sys/devices/system/cpu/cpu*/cache/index*/shared_cpu_list
/sys/devices/system/cpu/cpu*/cache/index*/shared_cpu_map
Signed-off-by: Vladimir Kondratiev <vladimir.kondratiev@intel.com>
[ Upstream commit e49e6f6db04e915dccb494ae10fa14888fea6f89 ]
All BPF JIT compilers except RISC-V's and MIPS' enforce a 33-tail calls
limit at runtime. In addition, a test was recently added, in tailcalls2,
to check this limit.
This patch updates the tail call limit in MIPS' JIT compiler to allow
33 tail calls.
Fixes: b6bd53f9c4e8 ("MIPS: Add missing file for eBPF JIT.")
Reported-by: Mahshid Khezri <khezri.mahshid@gmail.com>
Signed-off-by: Paul Chaignon <paul.chaignon@orange.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Link: https://lore.kernel.org/bpf/b8eb2caac1c25453c539248e56ca22f74b5316af.1575916815.git.paul.chaignon@gmail.com
commit bbcc5672b0063b0e9d65dc8787a4f09c3b5bb5cc upstream.
Declaring __current_thread_info as a global register variable has the
effect of preventing GCC from saving & restoring its value in cases
where the ABI would typically do so.
To quote GCC documentation:
> If the register is a call-saved register, call ABI is affected: the
> register will not be restored in function epilogue sequences after the
> variable has been assigned. Therefore, functions cannot safely return
> to callers that assume standard ABI.
When our position independent VDSO is built for the n32 or n64 ABIs all
functions it exposes should be preserving the value of $gp/$28 for their
caller, but in the presence of the __current_thread_info global register
variable GCC stops doing so & simply clobbers $gp/$28 when calculating
the address of the GOT.
In cases where the VDSO returns success this problem will typically be
masked by the caller in libc returning & restoring $gp/$28 itself, but
that is by no means guaranteed. In cases where the VDSO returns an error
libc will typically contain a fallback path which will now fail
(typically with a bad memory access) if it attempts anything which
relies upon the value of $gp/$28 - eg. accessing anything via the GOT.
One fix for this would be to move the declaration of
__current_thread_info inside the current_thread_info() function,
demoting it from global register variable to local register variable &
avoiding inadvertently creating a non-standard calling ABI for the VDSO.
Unfortunately this causes issues for clang, which doesn't support local
register variables as pointed out by commit fe92da0f355e ("MIPS: Changed
current_thread_info() to an equivalent supported by both clang and GCC")
which introduced the global register variable before we had a VDSO to
worry about.
Instead, fix this by continuing to use the global register variable for
the kernel proper but declare __current_thread_info as a simple extern
variable when building the VDSO. It should never be referenced, and will
cause a link error if it is. This resolves the calling convention issue
for the VDSO without having any impact upon the build of the kernel
itself for either clang or gcc.
Fixes: ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
Reported-by: Jason A. Donenfeld <Jason@zx2c4.com>
Reviewed-by: Jason A. Donenfeld <Jason@zx2c4.com>
Tested-by: Jason A. Donenfeld <Jason@zx2c4.com>
Cc: Christian Brauner <christian.brauner@canonical.com>
Cc: Vincenzo Frascino <vincenzo.frascino@arm.com>
Cc: <stable@vger.kernel.org> # v4.4+
[ Upstream commit 3ed6751bb8fa89c3014399bb0414348499ee202a ]
With CONFIG_MIPS_VA_BITS_48=y the build fails miserably:
CC arch/mips/kernel/asm-offsets.s
In file included from arch/mips/include/asm/pgtable.h:644,
from include/linux/mm.h:99,
from arch/mips/kernel/asm-offsets.c:15:
include/asm-generic/pgtable.h:16:2: error: #error CONFIG_PGTABLE_LEVELS is not consistent with __PAGETABLE_{P4D,PUD,PMD}_FOLDED
include/asm-generic/pgtable.h:390:28: error: unknown type name 'p4d_t'; did you mean 'pmd_t'?
static inline int p4d_same(p4d_t p4d_a, p4d_t p4d_b)
pmd_t
[ ... more such errors ... ]
scripts/Makefile.build:99: recipe for target 'arch/mips/kernel/asm-offsets.s' failed
make[2]: *** [arch/mips/kernel/asm-offsets.s] Error 1
This happens because when CONFIG_MIPS_VA_BITS_48 enables 4th level of the
page tables, but neither pgtable-nop4d.h nor 5level-fixup.h are included to
cope with the 5th level.
Replace #ifdef conditions around includes of the pgtable-nop{m,u}d.h with
explicit CONFIG_PGTABLE_LEVELS and add include of 5level-fixup.h for the
case when CONFIG_PGTABLE_LEVELS==4
Signed-off-by: Mike Rapoport <rppt@linux.ibm.com>
Cc: linux-mm@kvack.org
Cc: Mike Rapoport <rppt@kernel.org>
[ Upstream commit 1c6121c39677175bd372076020948e184bad4b6b ]
cn58xx is compatible with cn50xx, so use the latter.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[paul.burton@mips.com: s/cn52xx/cn50xx/ in commit message.]
[ Upstream commit 2cf1c8933dd93088cfb5f8f58b3bb9bbdf1781b9 ]
Use correct type for fdt_property nameoff field.
Patchwork: https://patchwork.linux-mips.org/patch/21204/
[ Upstream commit 756d6d836dbfb04a5a486bc2ec89397aa4533737 ]
The LittleSur board is marked for high memory support and therefore
clearly must provide a way to have enough memory installed for some to
be present outside the low 4GiB physical address range. With the memory
map of the BCM1250 SOC it has been built around it means over 1GiB of
actual DRAM, as only the first 1GiB is mapped in the low 4GiB physical
address range[1].
Complement commit cce335ae47e2 ("[MIPS] 64-bit Sibyte kernels need
DMA32.") then and also enable ZONE_DMA32 for LittleSur.
References:
[1] "BCM1250/BCM1125/BCM1125H User Manual", Revision 1250_1125-UM100-R,
Broadcom Corporation, 21 Oct 2002, Section 3: "System Overview",
"Memory Map", pp. 34-38
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/21107/
Fixes: cce335ae47e2 ("[MIPS] 64-bit Sibyte kernels need DMA32.")
[ Upstream commit a6da4d6fdf8bd512c98d3ac7f1d16bc4bb282919 ]
We can rely on the system kernel and the dump capture kernel themselves in
memory usage.
Being restrictive with 512MB limit may cause kexec tool failure on some
platforms.
Tested-by: Rachel Mozes <rachel.mozes@intel.com>
Reported-by: Rachel Mozes <rachel.mozes@intel.com>
Signed-off-by: Dengcheng Zhu <dzhu@wavecomp.com>
Patchwork: https://patchwork.linux-mips.org/patch/20568/
Cc: pburton@wavecomp.com
[ Upstream commit c6e1241a82e6e74d1ae5cc34581dab2ffd6022d0 ]
if device_register return error, iounmap should be called, also iounmap
need to call before put_device.
Signed-off-by: Ding Xiang <dingxiang@cmss.chinamobile.com>
Reviewed-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Patchwork: https://patchwork.linux-mips.org/patch/20476/
[ Upstream commit feef7918667b84f9d5653c501542dd8d84ae32af ]
Setting GPIO 21 high seems to be required to enable power to USB ports
on the WNDR3400v3. As there is already similar code for WNR3500L,
make the existing USB power GPIO code generic and use that.
Acked-by: Hauke Mehrtens <hauke@hauke-m.de>
Patchwork: https://patchwork.linux-mips.org/patch/20259/
Cc: Rafał Miłecki <zajec5@gmail.com>
commit 8a38dacf87180738d42b058334c951eba15d2d47 upstream.
The Ethernet Switch core mask was set to 0, causing the switch core to
be not reset on BCM6368 on boot. Provide the proper mask so the switch
core gets reset to a known good state.
Fixes: 799faa626c71 ("MIPS: BCM63XX: add core reset helper")
Cc: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
[ Upstream commit e4f5cb1a9b27c0f94ef4f5a0178a3fde2d3d0e9e ]
The vectors span more than one byte, so mark them as arrays.
Fixes the following build error when building when using GCC 8.3:
In file included from ./include/linux/string.h:19,
from ./include/linux/bitmap.h:9,
from ./include/linux/cpumask.h:12,
from ./arch/mips/include/asm/processor.h:15,
from ./arch/mips/include/asm/thread_info.h:16,
from ./include/linux/thread_info.h:38,
from ./include/asm-generic/preempt.h:5,
from ./arch/mips/include/generated/asm/preempt.h:1,
from ./include/linux/preempt.h:81,
from ./include/linux/spinlock.h:51,
from ./include/linux/mmzone.h:8,
from ./include/linux/bootmem.h:8,
from arch/mips/bcm63xx/prom.c:10:
arch/mips/bcm63xx/prom.c: In function 'prom_init':
./arch/mips/include/asm/string.h:162:11: error: '__builtin_memcpy' forming offset [2, 32] is out of the bounds [0, 1] of object 'bmips_smp_movevec' with type 'char' [-Werror=array-bounds]
__ret = __builtin_memcpy((dst), (src), __len); \
arch/mips/bcm63xx/prom.c:97:3: note: in expansion of macro 'memcpy'
memcpy((void *)0xa0000200, &bmips_smp_movevec, 0x20);
In file included from arch/mips/bcm63xx/prom.c:14:
./arch/mips/include/asm/bmips.h:80:13: note: 'bmips_smp_movevec' declared here
extern char bmips_smp_movevec;
Fixes: 18a1eef92dcd ("MIPS: BMIPS: Introduce bmips.h")
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit efcb529694c3b707dc0471b312944337ba16e4dd ]
Use ARRAY_SIZE to caluculate the top of the o32 stack.
Signed-off-by: Thomas Bogendoerfer <tbogendoerfer@suse.de>
[ Upstream commit 46f1619500d022501a4f0389f9f4c349ab46bb86 ]
Commit ac7c3e4ff401 ("compiler: enable CONFIG_OPTIMIZE_INLINING
forcibly") allows compiler to uninline functions marked as 'inline'.
In cace of __xchg this would cause to reference function
__xchg_called_with_bad_pointer, which is an error case
for catching bugs and will not happen for correct code, if
__xchg is inlined.
Reviewed-by: Philippe Mathieu-Daudé <f4bug@amsat.org>
[ Upstream commit 88356d09904bc606182c625575237269aeece22e ]
In cace of cmpxchg this would cause to reference function
__cmpxchg_called_with_bad_pointer, which is a error case
__cmpxchg is inlined.
[paul.burton@mips.com: s/__cmpxchd/__cmpxchg in subject]
commit b42aa3fd5957e4daf4b69129e5ce752a2a53e7d6 upstream.
build_restore_pagemask() will restore the value of register $1/$at when
its restore_scratch argument is non-zero, and aims to do so by filling a
branch delay slot. Commit 0b24cae4d535 ("MIPS: Add missing EHB in mtc0
-> mfc0 sequence.") added an EHB instruction (Execution Hazard Barrier)
prior to restoring $1 from a KScratch register, in order to resolve a
hazard that can result in stale values of the KScratch register being
observed. In particular, P-class CPUs from MIPS with out of order
execution pipelines such as the P5600 & P6600 are affected.
Unfortunately this EHB instruction was inserted in the branch delay slot
causing the MFC0 instruction which performs the restoration to no longer
execute along with the branch. The result is that the $1 register isn't
actually restored, ie. the TLB refill exception handler clobbers it -
which is exactly the problem the EHB is meant to avoid for the P-class
CPUs.
Similarly build_get_pgd_vmalloc() will restore the value of $1/$at when
its mode argument equals refill_scratch, and suffers from the same
problem.
Fix this by in both cases moving the EHB earlier in the emitted code.
There's no reason it needs to immediately precede the MFC0 - it simply
needs to be between the MTC0 & MFC0.
This bug only affects Cavium Octeon systems which use
build_fast_tlb_refill_handler().
Fixes: 0b24cae4d535 ("MIPS: Add missing EHB in mtc0 -> mfc0 sequence.")
Cc: Dmitry Korotin <dkorotin@wavecomp.com>
Cc: stable@vger.kernel.org # v3.15+
[ Upstream commit 25b69a889b638b0b7e51e2c4fe717a66bec0e566 ]
'exit' functions should be marked as __exit, not __init.
Fixes: 85cc028817ef ("mips: make loongsoon serial driver explicitly modular")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Cc: chenhc@lemote.com
Cc: kernel-janitors@vger.kernel.org
[ Upstream commit 0889d07f3e4b171c453b2aaf2b257f9074cdf624 ]
It is two registers each of 4 byte.
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Pengutronix Kernel Team <kernel@pengutronix.de>
Cc: devicetree@vger.kernel.org
commit 2f2b4fd674cadd8c6b40eb629e140a14db4068fd upstream.
GCC 9.x automatically enables support for Loongson MMI instructions when
using some -march= flags, and then errors out when -msoft-float is
specified with:
cc1: error: ‘-mloongson-mmi’ must be used with ‘-mhard-float’
The kernel shouldn't be using these MMI instructions anyway, just as it
doesn't use floating point instructions. Explicitly disable them in
order to fix the build with GCC 9.x.
Fixes: 3702bba5eb4f ("MIPS: Loongson: Add GCC 4.4 support for Loongson2E")
Fixes: 6f7a251a259e ("MIPS: Loongson: Add basic Loongson 2F support")
Fixes: 5188129b8c9f ("MIPS: Loongson-3: Improve -march option and move it to Platform")
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Jiaxun Yang <jiaxun.yang@flygoat.com>
Cc: stable@vger.kernel.org # v2.6.32+
commit 015664d15270a112c2371d812f03f7c579b35a73 upstream.
The Rio500 kernel driver has not been used by Rio500 owners since 2001
not long after the rio500 project added support for a user-space USB stack
through the very first versions of usbdevfs and then libusb.
Support for the kernel driver was removed from the upstream utilities
in 2008:
https://gitlab.freedesktop.org/hadess/rio500/commit/943f624ab721eb8281c287650fcc9e2026f6f5db
Cc: Cesar Miquel <miquel@df.uba.ar>
Signed-off-by: Bastien Nocera <hadess@hadess.net>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/6251c17584d220472ce882a3d9c199c401a51a71.camel@hadess.net
[ Upstream commit c59ae0a1055127dd3828a88e111a0db59b254104 ]
clang warns:
arch/mips/mm/tlbex.c:634:19: error: use of logical '&&' with constant
operand [-Werror,-Wconstant-logical-operand]
if (cpu_has_rixi && _PAGE_NO_EXEC) {
arch/mips/mm/tlbex.c:634:19: note: use '&' for a bitwise operation
arch/mips/mm/tlbex.c:634:19: note: remove constant to silence this
warning
1 error generated.
Explicitly cast this value to a boolean so that clang understands we
intend for this to be a non-zero value.
Fixes: 00bf1c691d08 ("MIPS: tlbex: Avoid placing software PTE bits in Entry* PFN fields")
Link: https://github.com/ClangBuiltLinux/linux/issues/609
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
commit 0648e50e548d881d025b9419a1a168753c8e2bf7 upstream.
The MIPS VDSO build currently doesn't provide the -msoft-float flag to
the compiler as the kernel proper does. This results in an attempt to
use the compiler's default floating point configuration, which can be
problematic in cases where this is incompatible with the target CPU's
-march= flag. For example decstation_defconfig fails to build using
toolchains in which gcc was configured --with-fp-32=xx with the
following error:
LDS arch/mips/vdso/vdso.lds
cc1: error: '-march=r3000' requires '-mfp32'
make[2]: *** [scripts/Makefile.build:379: arch/mips/vdso/vdso.lds] Error 1
The kernel proper avoids this error because we build with the
-msoft-float compiler flag, rather than using the compiler's default.
Pass this flag through to the VDSO build so that it too becomes agnostic
to the toolchain's floating point configuration.
Note that this is filtered out from KBUILD_CFLAGS rather than simply
always using -msoft-float such that if we switch the kernel to use
-mno-float in the future the VDSO will automatically inherit the change.
The VDSO doesn't actually include any floating point code, and its
.MIPS.abiflags section is already manually generated to specify that
it's compatible with any floating point ABI. As such this change should
have no effect on the resulting VDSO, apart from fixing the build
failure for affected toolchains.
Reported-by: Kevin Hilman <khilman@baylibre.com>
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Kevin Hilman <khilman@baylibre.com>
References: https://lore.kernel.org/linux-mips/1477843551-21813-1-git-send-email-linux@roeck-us.net/
References: https://kernelci.org/build/id/5c4e4ae059b5142a249ad004/logs/
Cc: stable@vger.kernel.org # v4.4+
commit 351fdddd366245c0fb4636f32edfb4198c8d6b8c upstream.
VDSO code should not be using smp_processor_id(), since it is executed
in user mode.
Introduce a VDSO-specific path which will cause a compile-time
or link-time error (depending upon support for __compiletime_error) if
the VDSO ever incorrectly attempts to use smp_processor_id().
[Matt Redfearn <matt.redfearn@imgtec.com>: Move before change to
smp_processor_id in series]
Signed-off-by: Matt Redfearn <matt.redfearn@mips.com>
Patchwork: https://patchwork.linux-mips.org/patch/17932/
This reverts commit c85acbf72786a5901a2170b2145761ed7cf06429 which is
commit e4849aff1e169b86c561738daf8ff020e9de1011 upstream
Guenter writes:
Upstream commit e4849aff1e16 ("MIPS: SiByte: Enable swiotlb for SWARM,
LittleSur and BigSur") results in build failures in v4.4.y and v4.14.y.
make bigsur_defconfig:
warning: (SIBYTE_SWARM && SIBYTE_SENTOSA && SIBYTE_BIGSUR && SWIOTLB_XEN && AMD_IOMMU) selects SWIOTLB which has unmet direct dependencies (CAVIUM_OCTEON_SOC || MACH_LOONGSON64 && CPU_LOONGSON3 || NLM_XLP_BOARD || NLM_XLR_BOARD)
and the actual build:
lib/swiotlb.o: In function `swiotlb_tbl_map_single':
(.text+0x1c0): undefined reference to `iommu_is_span_boundary'
Makefile:1021: recipe for target 'vmlinux' failed
Cc: Paul Burton <paul.burton@mips.com>
Cc: Sasha Levin <sashal@kernel.org>
[ Upstream commit b8bea8a5e5d942e62203416ab41edecaed4fda02 ]
Because CONFIG_OF defined for MIPS, cacheinfo attempts to fill information
from DT, ignoring data filled by architecture routine. This leads to error
reported
cacheinfo: Unable to detect cache hierarchy for CPU 0
Way to fix this provided in
commit fac51482577d ("drivers: base: cacheinfo: fix x86 with
CONFIG_OF enabled")
Utilize same mechanism to report that cacheinfo set by architecture
specific function
Signed-off-by: Vladimir Kondratiev <vladimir.kondratiev@linux.intel.com>
[ Upstream commit a07e3324538a989b7cdbf2c679be6a7f9df2544f ]
i8253 clocksource needs a free running timer. This could only
be used, if i8253 clockevent is set up as periodic.
commit fa9dd599b4dae841924b022768354cfde9affecb upstream.
Having a pure_initcall() callback just to permanently enable BPF
JITs under CONFIG_BPF_JIT_ALWAYS_ON is unnecessary and could leave
a small race window in future where JIT is still disabled on boot.
Since we know about the setting at compilation time anyway, just
initialize it properly there. Also consolidate all the individual
bpf_jit_enable variables into a single one and move them under one
location. Moreover, don't allow for setting unspecified garbage
values on them.
Acked-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[bwh: Backported to 4.14 as dependency of commit 2e4a30983b0f
"bpf: restrict access to core bpf sysctls":
- Adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit ba1bc0fcdeaf3bf583c1517bd2e3e29cf223c969 ]
The modification of EXIN register doesn't clean the bitfield before
the writing of a new value. After a few modifications the bitfield would
accumulate only '1's.
Signed-off-by: Petr Cvek <petrcvekcz@gmail.com>
Cc: hauke@hauke-m.de
Cc: john@phrozen.org
Cc: openwrt-devel@lists.openwrt.org
Cc: pakahmar@hotmail.com
commit 1323c3b72a987de57141cabc44bf9cd83656bc70 upstream.
The pin mappings introduced in commit 636f8ba67fb6
("MIPS: JZ4740: Qi LB60: Add pinctrl configuration for several drivers")
are completely wrong. The pinctrl driver name is incorrect, and the
function and group fields are swapped.
Fixes: 636f8ba67fb6 ("MIPS: JZ4740: Qi LB60: Add pinctrl configuration for several drivers")
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
Cc: od@zcrc.me
[ Upstream commit 1196364f21ffe5d1e6d83cafd6a2edb89404a3ae ]
calc_vmlinuz_load_addr.c requires SZ_64K to be defined for alignment
purposes. It included "../../../../include/linux/sizes.h" to define
that size, however "sizes.h" tries to include <linux/const.h> which
assumes linux system headers. These may not exist eg. the following
error was encountered when building Linux for OpenWrt under macOS:
In file included from arch/mips/boot/compressed/calc_vmlinuz_load_addr.c:16:
arch/mips/boot/compressed/../../../../include/linux/sizes.h:11:10: fatal error: 'linux/const.h' file not found
Change makefile to force building on local linux headers instead of
system headers. Also change eye-watering relative reference in include
file spec.
Thanks to Jo-Philip Wich & Petr Štetiar for assistance in tracking this
down & fixing.
Suggested-by: Jo-Philipp Wich <jo@mein.io>
Signed-off-by: Petr Štetiar <ynezz@true.cz>
Signed-off-by: Kevin Darbyshire-Bryant <ldir@darbyshire-bryant.me.uk>
[ Upstream commit db13a5ba2732755cf13320f3987b77cf2a71e790 ]
While trying to get the uart with parity working I found setting even
parity enabled odd parity insted. Fix the register settings to match
the datasheet of AR9331.
A similar patch was created by 8devices, but not sent upstream.
https://github.com/8devices/openwrt-8devices/commit/77c5586ade3bb72cda010afad3f209ed0c98ea7c
Signed-off-by: Stefan Hellermann <stefan@the2masters.de>
commit 1287533d3d95d5ad8b02773733044500b1be06bc upstream.
When building BPF code using "clang -target bpf -c", clang does not
define __linux__.
To build BPF IR decoders the include linux/lirc.h is needed which
includes linux/types.h. Currently this workaround is needed:
https://git.linuxtv.org/v4l-utils.git/commit/?id=dd3ff81f58c4e1e6f33765dc61ad33c48ae6bb07
This check might otherwise be useful to stop users from using a non-linux
compiler, but if you're doing that you are going to have a lot more
trouble anyway.
Signed-off-by: Sean Young <sean@mess.org>
Patchwork: https://patchwork.linux-mips.org/patch/21149/
Cc: Hauke Mehrtens <hauke@hauke-m.de>
commit 0b24cae4d535045f4c9e177aa228d4e97bad212c upstream.
Add a missing EHB (Execution Hazard Barrier) in mtc0 -> mfc0 sequence.
Without this execution hazard barrier it's possible for the value read
back from the KScratch register to be the value from before the mtc0.
Reproducible on P5600 & P6600.
The hazard is documented in the MIPS Architecture Reference Manual Vol.
III: MIPS32/microMIPS32 Privileged Resource Architecture (MD00088), rev
6.03 table 8.1 which includes:
Producer | Consumer | Hazard
mtc0 | mfc0 | any coprocessor 0 register
Signed-off-by: Dmitry Korotin <dkorotin@wavecomp.com>
- Commit message tweaks.
- Add Fixes tags.
- Mark for stable back to v3.15 where P5600 support was introduced.]
Fixes: 3d8bfdd03072 ("MIPS: Use C0_KScratch (if present) to hold PGD pointer.")
Fixes: 829dcc0a956a ("MIPS: Add MIPS P5600 probe support")
commit d6ed083f5cc621e15c15b56c3b585fd524dbcb0f upstream.
The bounds check used the uninitialized variable vaddr, it should use
the given parameter kaddr instead. When using the uninitialized value
the compiler assumed it to be 0 and optimized this function to just
return 0 in all cases.
This should make the function check the range of the given address and
only do the page map check in case it is in the expected range of
virtual addresses.
Fixes: 074a1e1167af ("MIPS: Bounds check virt_addr_valid")
Cc: stable@vger.kernel.org # v4.12+
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Cc: f4bug@amsat.org
Cc: ysu@wavecomp.com
Cc: jcristau@debian.org
[ Upstream commit 02eec6c9fc0cb13169cc97a6139771768791f92b ]
In nlm_fmn_send() we have a loop which attempts to send a message
multiple times in order to handle the transient failure condition of a
lack of available credit. When examining the status register to detect
the failure we check for a condition that can never be true, which falls
foul of gcc 8's -Wtautological-compare:
In file included from arch/mips/netlogic/common/irq.c:65:
./arch/mips/include/asm/netlogic/xlr/fmn.h: In function 'nlm_fmn_send':
./arch/mips/include/asm/netlogic/xlr/fmn.h:304:22: error: bitwise
comparison always evaluates to false [-Werror=tautological-compare]
if ((status & 0x2) == 1)
If the path taken if this condition were true all we do is print a
message to the kernel console. Since failures seem somewhat expected
here (making the console message questionable anyway) and the condition
has clearly never evaluated true we simply remove it, rather than
attempting to fix it to check status correctly.
Patchwork: https://patchwork.linux-mips.org/patch/20174/
Cc: Ganesan Ramalingam <ganesanr@broadcom.com>
Cc: Jayachandran C <jnair@caviumnetworks.com>
Cc: John Crispin <john@phrozen.org>
[ Upstream commit f532beeeff0c0a3586cc15538bc52d249eb19e7c ]
Fixes gcc '-Wunused-but-set-variable' warning:
arch/mips/kernel/uprobes.c: In function 'arch_uprobe_pre_xol':
arch/mips/kernel/uprobes.c:115:17: warning: variable 'epc' set but not used [-Wunused-but-set-variable]
It's never used since introduction in
commit 40e084a506eb ("MIPS: Add uprobes support.")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Cc: <ralf@linux-mips.org>
Cc: <jhogan@kernel.org>
Cc: <linux-kernel@vger.kernel.org>
Cc: <linux-mips@vger.kernel.org>
This reverts commit 9547d81ac3bc0d2b9729a28e7dd610007144a837 which is
commit a1e8783db8e0d58891681bc1e6d9ada66eae8e20 upstream.
Petr writes:
Karl has reported to me today, that he's experiencing weird
reboot hang on his devices with 4.9.180 kernel and that he has
bisected it down to my backported patch.
I would like to kindly ask you for removal of this patch. This
patch should be reverted from all stable kernels up to 5.1,
because perf counters were not broken on those kernels, and this
patch won't work on the ath79 legacy IRQ code anyway, it needs
new irqchip driver which was enabled on ath79 with commit
51fa4f8912c0 ("MIPS: ath79: drop legacy IRQ code").
Reported-by: Petr Štetiar <ynezz@true.cz>
Cc: Kevin 'ldir' Darbyshire-Bryant <ldir@darbyshire-bryant.me.uk>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Jason Cooper <jason@lakedaemon.net>
commit e4f2d1af7163becb181419af9dece9206001e0a6 upstream.
The pistachio platform uses the U-Boot bootloader & generally boots a
kernel in the uImage format. As such it's useful to build one when
building the kernel, but to do so currently requires the user to
manually specify a uImage target on the make command line.
Make uImage.gz the pistachio platform's default build target, so that
the default is to build a kernel image that we can actually boot on a
board such as the MIPS Creator Ci40.
Marked for stable backport as far as v4.1 where pistachio support was
introduced. This is primarily useful for CI systems such as kernelci.org
which will benefit from us building a suitable image which can then be
booted as part of automated testing, extending our test coverage to the
affected stable branches.
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
URL: https://groups.io/g/kernelci/message/388
Cc: stable@vger.kernel.org # v4.1+
commit 074a1e1167afd82c26f6d03a9a8b997d564bb241 upstream.
The virt_addr_valid() function is meant to return true iff
virt_to_page() will return a valid struct page reference. This is true
iff the address provided is found within the unmapped address range
between PAGE_OFFSET & MAP_BASE, but we don't currently check for that
condition. Instead we simply mask the address to obtain what will be a
physical address if the virtual address is indeed in the desired range,
shift it to form a PFN & then call pfn_valid(). This can incorrectly
return true if called with a virtual address which, after masking,
happens to form a physical address corresponding to a valid PFN.
For example we may vmalloc an address in the kernel mapped region
starting a MAP_BASE & obtain the virtual address:
addr = 0xc000000000002000
When masked by virt_to_phys(), which uses __pa() & in turn CPHYSADDR(),
we obtain the following (bogus) physical address:
addr = 0x2000
In a common system with PHYS_OFFSET=0 this will correspond to a valid
struct page which should really be accessed by virtual address
PAGE_OFFSET+0x2000, causing virt_addr_valid() to incorrectly return 1
indicating that the original address corresponds to a struct page.
This is equivalent to the ARM64 change made in commit ca219452c6b8
("arm64: Correctly bounds check virt_addr_valid").
This fixes fallout when hardened usercopy is enabled caused by the
related commit 517e1fbeb65f ("mm/usercopy: Drop extra
is_vmalloc_or_module() check") which removed a check for the vmalloc
range that was present from the introduction of the hardened usercopy
feature.
References: ca219452c6b8 ("arm64: Correctly bounds check virt_addr_valid")
References: 517e1fbeb65f ("mm/usercopy: Drop extra is_vmalloc_or_module() check")
Reported-by: Julien Cristau <jcristau@debian.org>
Tested-by: YunQiang Su <ysu@wavecomp.com>
URL: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=929366
Cc: Yunqiang Su <ysu@wavecomp.com>
commit a86cb413f4bf273a9d341a3ab2c2ca44e12eb317 upstream.
KVM_CAP_MAX_VCPU_ID is currently always reporting KVM_MAX_VCPU_ID on all
architectures. However, on s390x, the amount of usable CPUs is determined
during runtime - it is depending on the features of the machine the code
is running on. Since we are using the vcpu_id as an index into the SCA
structures that are defined by the hardware (see e.g. the sca_add_vcpu()
function), it is not only the amount of CPUs that is limited by the hard-
ware, but also the range of IDs that we can use.
Thus KVM_CAP_MAX_VCPU_ID must be determined during runtime on s390x, too.
So the handling of KVM_CAP_MAX_VCPU_ID has to be moved from the common
code into the architecture specific code, and on s390x we have to return
the same value here as for KVM_CAP_MAX_VCPUS.
This problem has been discovered with the kvm_create_max_vcpus selftest.
With this change applied, the selftest now passes on s390x, too.
Reviewed-by: Andrew Jones <drjones@redhat.com>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Signed-off-by: Thomas Huth <thuth@redhat.com>
Message-Id: <20190523164309.13345-9-thuth@redhat.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
[ Upstream commit c61c7def1fa0a722610d89790e0255b74f3c07dd ]
Commit ea7e0480a4b6 ("MIPS: VDSO: Always map near top of user memory")
set VDSO_RANDOMIZE_SIZE to 256MB for 64bit kernel. But take a look at
arch/mips/mm/mmap.c we can see that MIN_GAP is 128MB, which means the
mmap_base may be at (user_address_top - 128MB). This make the stack be
surrounded by mmaped areas, then stack expanding fails and causes a
segmentation fault. Therefore, VDSO_RANDOMIZE_SIZE should be less than
MIN_GAP and this patch reduce it to 64MB.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Fixes: ea7e0480a4b6 ("MIPS: VDSO: Always map near top of user memory")
Patchwork: https://patchwork.linux-mips.org/patch/20910/
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Cc: Huacai Chen <chenhuacai@gmail.com>
[ Upstream commit a1e8783db8e0d58891681bc1e6d9ada66eae8e20 ]
Currently it's not possible to use perf on ath79 due to genirq flags
mismatch happening on static virtual IRQ 13 which is used for
performance counters hardware IRQ 5.
On TP-Link Archer C7v5:
CPU0
2: 0 MIPS 2 ath9k
4: 318 MIPS 4 19000000.eth
7: 55034 MIPS 7 timer
8: 1236 MISC 3 ttyS0
12: 0 INTC 1 ehci_hcd:usb1
13: 0 gpio-ath79 2 keys
14: 0 gpio-ath79 5 keys
15: 31 AR724X PCI 1 ath10k_pci
$ perf top
genirq: Flags mismatch irq 13. 00014c83 (mips_perf_pmu) vs. 00002003 (keys)
On TP-Link Archer C7v4:
CPU0
4: 0 MIPS 4 19000000.eth
5: 7135 MIPS 5 1a000000.eth
7: 98379 MIPS 7 timer
8: 30 MISC 3 ttyS0
12: 90028 INTC 0 ath9k
13: 5520 INTC 1 ehci_hcd:usb1
14: 4623 INTC 2 ehci_hcd:usb2
15: 32844 AR724X PCI 1 ath10k_pci
16: 0 gpio-ath79 16 keys
23: 0 gpio-ath79 23 keys
$ perf top
genirq: Flags mismatch irq 13. 00014c80 (mips_perf_pmu) vs. 00000080 (ehci_hcd:usb1)
This problem is happening, because currently statically assigned virtual
IRQ 13 for performance counters is not claimed during the initialization
of MIPS PMU during the bootup, so the IRQ subsystem doesn't know, that
this interrupt isn't available for further use.
So this patch fixes the issue by simply booking hardware IRQ 5 for MIPS PMU.
Tested-by: Kevin 'ldir' Darbyshire-Bryant <ldir@darbyshire-bryant.me.uk>
Acked-by: John Crispin <john@phrozen.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
[ Upstream commit ab8a6d821179ab9bea1a9179f535ccba6330c1ed ]
KGDB_call_nmi_hook is called by other cpu through smp call.
MIPS smp call is processed in ipi irq handler and regs is saved in
handle_int.
So kgdb_call_nmi_hook get regs by get_irq_regs and regs will be passed
to kgdb_cpu_enter.
Signed-off-by: Chong Qiao <qiaochong@loongson.cn>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Acked-by: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Cc: QiaoChong <qiaochong@loongson.cn>
commit 79b4a9cf0e2ea8203ce777c8d5cfa86c71eae86e upstream.
Commit 4c21b8fd8f14 (MIPS: seccomp: Handle indirect system calls (o32))
added indirect syscall detection for O32 processes running on MIPS64,
but it did not work correctly for big endian kernel/processes. The
reason is that the syscall number is loaded from ARG1 using the lw
instruction while this is a 64-bit value, so zero is loaded instead of
the syscall number.
Fix the code by using the ld instruction instead. When running a 32-bit
processes on a 64 bit CPU, the values are properly sign-extended, so it
ensures the value passed to syscall_trace_enter is correct.
Recent systemd versions with seccomp enabled whitelist the getpid
syscall for their internal processes (e.g. systemd-journald), but call
it through syscall(SYS_getpid). This fix therefore allows O32 big endian
systems with a 64-bit kernel to run recent systemd versions.
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Cc: <stable@vger.kernel.org> # v3.15+
commit 47c25036b60f27b86ab44b66a8861bcf81cde39b upstream.
Insert Branch instruction instead of NOP to make sure assembler don't
patch code in forbidden slot. In jump label function, it might
be possible to patch Control Transfer Instructions(CTIs) into
forbidden slot, which will generate Reserved Instruction exception
in MIPS release 6.
Signed-off-by: Archer Yan <ayan@wavecomp.com>
Reviewed-by: Paul Burton <paul.burton@mips.com>
- Add MIPS prefix to subject.
- Mark for stable from v4.0, which introduced r6 support, onwards.]
Cc: stable@vger.kernel.org # v4.0+
commit 3f0a53bc6482fb09770982a8447981260ea258dc upstream.
This fixes booting with the combination of CONFIG_RELOCATABLE=y
and CONFIG_MIPS_ELF_APPENDED_DTB=y.
Sections that appear after the relocation table are not relocated
on system boot (except .bss, which has special handling).
With CONFIG_MIPS_ELF_APPENDED_DTB, the dtb is part of the
vmlinux ELF, so it must be relocated together with everything else.
Fixes: 069fd766271d ("MIPS: Reserve space for relocation table")
Signed-off-by: Yasha Cherikovsky <yasha.che3@gmail.com>
Cc: stable@vger.kernel.org # v4.7+
commit 5f5f67da9781770df0403269bc57d7aae608fecd upstream.
Timekeeping IRQs from CS5536 MFGPT are routed to i8259, which then
triggers the "cascade" IRQ on MIPS CPU. Without IRQF_NO_SUSPEND in
cascade_irqaction, MFGPT interrupts will be masked in suspend mode,
and the machine would be unable to resume once suspended.
Previously, MIPS IRQs were not disabled properly, so the original
code appeared to work. Commit a3e6c1eff5 ("MIPS: IRQ: Fix disable_irq on
CPU IRQs") uncovers the bug. To fix it, add IRQF_NO_SUSPEND to
cascade_irqaction.
This commit is functionally identical to 0add9c2f1cff ("MIPS:
Loongson-3: Add IRQF_NO_SUSPEND to Cascade irqaction"), but it forgot
to apply the same fix to Loongson2.
Signed-off-by: Yifeng Li <tomli@tomli.me>
Cc: stable@vger.kernel.org # v3.19+
