commit a923a2676e60683aee46aa4b93c30aff240ac20d upstream.
Fix assembly errors like:
{standard input}: Assembler messages:
{standard input}:287: Error: opcode not supported on this processor: mips3 (mips3) `dins $10,$7,32,32'
{standard input}:680: Error: opcode not supported on this processor: mips3 (mips3) `dins $10,$7,32,32'
{standard input}:1274: Error: opcode not supported on this processor: mips3 (mips3) `dins $12,$9,32,32'
{standard input}:2175: Error: opcode not supported on this processor: mips3 (mips3) `dins $10,$7,32,32'
make[1]: *** [scripts/Makefile.build:277: mm/highmem.o] Error 1
with code produced from `__cmpxchg64' for MIPS64r2 CPU configurations
using CONFIG_32BIT and CONFIG_PHYS_ADDR_T_64BIT.
This is due to MIPS_ISA_ARCH_LEVEL downgrading the assembly architecture
to `r4000' i.e. MIPS III for MIPS64r2 configurations, while there is a
block of code containing a DINS MIPS64r2 instruction conditionalized on
MIPS_ISA_REV >= 2 within the scope of the downgrade.
The assembly architecture override code pattern has been put there for
LL/SC instructions, so that code compiles for configurations that select
a processor to build for that does not support these instructions while
still providing run-time support for processors that do, dynamically
switched by non-constant `cpu_has_llsc'. It went in with linux-mips.org
commit aac8aa7717a2 ("Enable a suitable ISA for the assembler around
ll/sc so that code builds even for processors that don't support the
instructions. Plus minor formatting fixes.") back in 2005.
Fix the problem by wrapping these instructions along with the adjacent
SYNC instructions only, following the practice established with commit
cfd54de3b0e4 ("MIPS: Avoid move psuedo-instruction whilst using
MIPS_ISA_LEVEL") and commit 378ed6f0e3c5 ("MIPS: Avoid using .set mips0
to restore ISA"). Strictly speaking the SYNC instructions do not have
to be wrapped as they are only used as a Loongson3 erratum workaround,
so they will be enabled in the assembler by default, but do this so as
to keep code consistent with other places.
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Maciej W. Rozycki <macro@orcam.me.uk>
Fixes: c7e2d71dda7a ("MIPS: Fix set_pte() for Netlogic XLR using cmpxchg64()")
Cc: stable@vger.kernel.org # v5.1+
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
[ Upstream commit 18b8f5b6fc53d097cadb94a93d8d6566ba88e389 ]
mips_cm_error_report() extracts the cause and other cause from the error
register using shifts. This works fine for the former, as it is stored
in the top bits, and the shift will thus remove all non-related bits.
However, the latter is stored in the bottom bits, hence thus needs masking
to get rid of non-related bits. Without such masking, using it as an
index into the cm2_causes[] array will lead to an out-of-bounds access,
probably causing a crash.
Fix this by using FIELD_GET() instead. Bite the bullet and convert all
MIPS CM handling to the bitfield API, to improve readability and safety.
Fixes: 3885c2b463f6a236 ("MIPS: CM: Add support for reporting CM cache errors")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Jiaxun Yang <jiaxun.yang@flygoat.com>
[ Upstream commit 7f3b3c2bfa9c93ab9b5595543496f570983dc330 ]
mach/loongson64 fails to build when the FPU support is disabled:
arch/mips/loongson64/cop2-ex.c:45:15: error: implicit declaration of function ‘__is_fpu_owner’; did you mean ‘is_fpu_owner’? [-Werror=implicit-function-declaration]
arch/mips/loongson64/cop2-ex.c:98:30: error: ‘struct thread_struct’ has no member named ‘fpu’
arch/mips/loongson64/cop2-ex.c:99:30: error: ‘struct thread_struct’ has no member named ‘fpu’
arch/mips/loongson64/cop2-ex.c:131:43: error: ‘struct thread_struct’ has no member named ‘fpu’
arch/mips/loongson64/cop2-ex.c:137:38: error: ‘struct thread_struct’ has no member named ‘fpu’
arch/mips/loongson64/cop2-ex.c:203:30: error: ‘struct thread_struct’ has no member named ‘fpu’
arch/mips/loongson64/cop2-ex.c:219:30: error: ‘struct thread_struct’ has no member named ‘fpu’
arch/mips/loongson64/cop2-ex.c:283:38: error: ‘struct thread_struct’ has no member named ‘fpu’
arch/mips/loongson64/cop2-ex.c:301:38: error: ‘struct thread_struct’ has no member named ‘fpu’
Fixes: ef2f826c8f2f ("MIPS: Loongson-3: Enable the COP2 usage")
Suggested-by: Huacai Chen <chenhuacai@kernel.org>
Reviewed-by: Huacai Chen <chenhuacai@kernel.org>
Reported-by: k2ci robot <kernel-bot@kylinos.cn>
Signed-off-by: Jackie Liu <liuyun01@kylinos.cn>
[ Upstream commit 5ca9ce2ba4d5884cd94d1a856c675ab1242cd242 ]
Different SoCs have a different number of channels, e.g .:
* amazon-se has 10 channels,
* danube+ar9 have 20 channels,
* vr9 has 28 channels,
* ar10 has 24 channels.
We can read the ID register and, depending on the reported
number of channels, reset the appropriate number of channels.
Signed-off-by: Aleksander Jan Bajkowski <olek2@wp.pl>
[ Upstream commit c12aa581f6d5e80c3c3675ab26a52c2b3b62f76e ]
Reading the DMA registers immediately after the reset causes
Data Bus Error. Adding a small delay fixes this issue.
commit 95bf9d646c3c3f95cb0be7e703b371db8da5be68 upstream.
When an instruction to save or restore a register from the stack fails
in _save_fp_context or _restore_fp_context return with -EFAULT. This
change was made to r2300_fpu.S[1] but it looks like it got lost with
the introduction of EX2[2]. This is also what the other implementation
of _save_fp_context and _restore_fp_context in r4k_fpu.S does, and
what is needed for the callers to be able to handle the error.
Furthermore calling do_exit(SIGSEGV) from bad_stack is wrong because
it does not terminate the entire process it just terminates a single
thread.
As the changed code was the only caller of arch/mips/kernel/syscall.c:bad_stack
remove the problematic and now unused helper function.
Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Cc: Maciej Rozycki <macro@orcam.me.uk>
Cc: linux-mips@vger.kernel.org
[1] 35938a00ba86 ("MIPS: Fix ISA I FP sigcontext access violation handling")
[2] f92722dc4545 ("MIPS: Correct MIPS I FP sigcontext layout")
Fixes: f92722dc4545 ("MIPS: Correct MIPS I FP sigcontext layout")
Acked-by: Maciej W. Rozycki <macro@orcam.me.uk>
Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Link: https://lkml.kernel.org/r/20211020174406.17889-5-ebiederm@xmission.com
commit 37cb28ec7d3a36a5bace7063a3dba633ab110f8b upstream.
The conditional branch instructions on MIPS use 18-bit signed offsets
allowing for a branch range of 128 KBytes (backward and forward).
However, this limit is not observed by the cBPF JIT compiler, and so
the JIT compiler emits out-of-range branches when translating certain
cBPF programs. A specific example of such a cBPF program is included in
the "BPF_MAXINSNS: exec all MSH" test from lib/test_bpf.c that executes
anomalous machine code containing incorrect branch offsets under JIT.
Furthermore, this issue can be abused to craft undesirable machine
code, where the control flow is hijacked to execute arbitrary Kernel
code.
The following steps can be used to reproduce the issue:
# echo 1 > /proc/sys/net/core/bpf_jit_enable
# modprobe test_bpf test_name="BPF_MAXINSNS: exec all MSH"
This should produce multiple warnings from build_bimm() similar to:
WARNING: CPU: 0 PID: 209 at arch/mips/mm/uasm-mips.c:210 build_insn+0x558/0x590
Micro-assembler field overflow
Modules linked in: test_bpf(+)
CPU: 0 PID: 209 Comm: modprobe Not tainted 5.14.3 #1
Stack : 00000000 807bb824 82b33c9c 801843c0 00000000 00000004 00000000 63c9b5ee
82b33af4 80999898 80910000 80900000 82fd6030 00000001 82b33a98 82087180
00000000 00000000 80873b28 00000000 000000fc 82b3394c 00000000 2e34312e
6d6d6f43 809a180f 809a1836 6f6d203a 80900000 00000001 82b33bac 80900000
00027f80 00000000 00000000 807bb824 00000000 804ed790 001cc317 00000001
Call Trace:
[<80108f44>] show_stack+0x38/0x118
[<807a7aac>] dump_stack_lvl+0x5c/0x7c
[<807a4b3c>] __warn+0xcc/0x140
[<807a4c3c>] warn_slowpath_fmt+0x8c/0xb8
[<8011e198>] build_insn+0x558/0x590
[<8011e358>] uasm_i_bne+0x20/0x2c
[<80127b48>] build_body+0xa58/0x2a94
[<80129c98>] bpf_jit_compile+0x114/0x1e4
[<80613fc4>] bpf_prepare_filter+0x2ec/0x4e4
[<8061423c>] bpf_prog_create+0x80/0xc4
[<c0a006e4>] test_bpf_init+0x300/0xba8 [test_bpf]
[<8010051c>] do_one_initcall+0x50/0x1d4
[<801c5e54>] do_init_module+0x60/0x220
[<801c8b20>] sys_finit_module+0xc4/0xfc
[<801144d0>] syscall_common+0x34/0x58
---[ end trace a287d9742503c645 ]---
Then the anomalous machine code executes:
=> 0xc0a18000: addiu sp,sp,-16
0xc0a18004: sw s3,0(sp)
0xc0a18008: sw s4,4(sp)
0xc0a1800c: sw s5,8(sp)
0xc0a18010: sw ra,12(sp)
0xc0a18014: move s5,a0
0xc0a18018: move s4,zero
0xc0a1801c: move s3,zero
# __BPF_STMT(BPF_LDX | BPF_B | BPF_MSH, 0)
0xc0a18020: lui t6,0x8012
0xc0a18024: ori t4,t6,0x9e14
0xc0a18028: li a1,0
0xc0a1802c: jalr t4
0xc0a18030: move a0,s5
0xc0a18034: bnez v0,0xc0a1ffb8 # incorrect branch offset
0xc0a18038: move v0,zero
0xc0a1803c: andi s4,s3,0xf
0xc0a18040: b 0xc0a18048
0xc0a18044: sll s4,s4,0x2
0xc0a1ffa0: lui t6,0x8012
0xc0a1ffa4: ori t4,t6,0x9e14
0xc0a1ffa8: li a1,0
0xc0a1ffac: jalr t4
0xc0a1ffb0: move a0,s5
0xc0a1ffb4: bnez v0,0xc0a1ffb8 # incorrect branch offset
0xc0a1ffb8: move v0,zero
0xc0a1ffbc: andi s4,s3,0xf
0xc0a1ffc0: b 0xc0a1ffc8
0xc0a1ffc4: sll s4,s4,0x2
0xc0a1ffc8: lui t6,0x8012
0xc0a1ffcc: ori t4,t6,0x9e14
0xc0a1ffd0: li a1,0
0xc0a1ffd4: jalr t4
0xc0a1ffd8: move a0,s5
0xc0a1ffdc: bnez v0,0xc0a3ffb8 # correct branch offset
0xc0a1ffe0: move v0,zero
0xc0a1ffe4: andi s4,s3,0xf
0xc0a1ffe8: b 0xc0a1fff0
0xc0a1ffec: sll s4,s4,0x2
# epilogue
0xc0a3ffb8: lw s3,0(sp)
0xc0a3ffbc: lw s4,4(sp)
0xc0a3ffc0: lw s5,8(sp)
0xc0a3ffc4: lw ra,12(sp)
0xc0a3ffc8: addiu sp,sp,16
0xc0a3ffcc: jr ra
0xc0a3ffd0: nop
To mitigate this issue, we assert the branch ranges for each emit call
that could generate an out-of-range branch.
Fixes: 36366e367ee9 ("MIPS: BPF: Restore MIPS32 cBPF JIT")
Fixes: c6610de353da ("MIPS: net: Add BPF JIT")
Signed-off-by: Piotr Krysiuk <piotras@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Tested-by: Johan Almbladh <johan.almbladh@anyfinetworks.com>
Acked-by: Johan Almbladh <johan.almbladh@anyfinetworks.com>
Cc: Paul Burton <paulburton@kernel.org>
Link: https://lore.kernel.org/bpf/20210915160437.4080-1-piotras@gmail.com
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
commit 36366e367ee93ced84fddb8fae6675e12985f5a4 upstream.
Commit 716850ab104d ("MIPS: eBPF: Initial eBPF support for MIPS32
architecture.") enabled our eBPF JIT for MIPS32 kernels, whereas it has
previously only been availailable for MIPS64. It was my understanding at
the time that the BPF test suite was passing & JITing a comparable
number of tests to our cBPF JIT [1], but it turns out that was not the
case.
The eBPF JIT has a number of problems on MIPS32:
- Most notably various code paths still result in emission of MIPS64
instructions which will cause reserved instruction exceptions & kernel
panics when run on MIPS32 CPUs.
- The eBPF JIT doesn't account for differences between the O32 ABI used
by MIPS32 kernels versus the N64 ABI used by MIPS64 kernels. Notably
arguments beyond the first 4 are passed on the stack in O32, and this
is entirely unhandled when JITing a BPF_CALL instruction. Stack space
must be reserved for arguments even if they all fit in registers, and
the callee is free to assume that stack space has been reserved for
its use - with the eBPF JIT this is not the case, so calling any
function can result in clobbering values on the stack & unpredictable
behaviour. Function arguments in eBPF are always 64-bit values which
is also entirely unhandled - the JIT still uses a single (32-bit)
register per argument. As a result all function arguments are always
passed incorrectly when JITing a BPF_CALL instruction, leading to
kernel crashes or strange behavior.
- The JIT attempts to bail our on use of ALU64 instructions or 64-bit
memory access instructions. The code doing this at the start of
build_one_insn() incorrectly checks whether BPF_OP() equals BPF_DW,
when it should really be checking BPF_SIZE() & only doing so when
BPF_CLASS() is one of BPF_{LD,LDX,ST,STX}. This results in false
positives that cause more bailouts than intended, and that in turns
hides some of the problems described above.
- The kernel's cBPF->eBPF translation makes heavy use of 64-bit eBPF
instructions that the MIPS32 eBPF JIT bails out on, leading to most
cBPF programs not being JITed at all.
Until these problems are resolved, revert the removal of the cBPF JIT
performed by commit 716850ab104d ("MIPS: eBPF: Initial eBPF support for
MIPS32 architecture."). Together with commit f8fffebdea75 ("MIPS: BPF:
Disable MIPS32 eBPF JIT") this restores MIPS32 BPF JIT behavior back to
the same state it was prior to the introduction of the broken eBPF JIT
support.
[1] https://lore.kernel.org/linux-mips/MWHPR2201MB13583388481F01A422CE7D66D4410@MWHPR2201MB1358.namprd22.prod.outlook.com/
Signed-off-by: Paul Burton <paulburton@kernel.org>
Fixes: 716850ab104d ("MIPS: eBPF: Initial eBPF support for MIPS32 architecture.")
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Hassan Naveed <hnaveed@wavecomp.com>
Cc: Tony Ambardar <itugrok@yahoo.com>
Cc: bpf@vger.kernel.org
Cc: netdev@vger.kernel.org
[ Upstream commit 4b92d4add5f6dcf21275185c997d6ecb800054cd ]
DEFINE_SMP_CALL_CACHE_FUNCTION() was usefel before the CPU hotplug rework
to ensure that the cache related functions are called on the upcoming CPU
because the notifier itself could run on any online CPU.
The hotplug state machine guarantees that the callbacks are invoked on the
upcoming CPU. So there is no need to have this SMP function call
obfuscation. That indirection was missed when the hotplug notifiers were
converted.
This also solves the problem of ARM64 init_cache_level() invoking ACPI
functions which take a semaphore in that context. That's invalid as SMP
function calls run with interrupts disabled. Running it just from the
callback in context of the CPU hotplug thread solves this.
Fixes: 8571890e1513 ("arm64: Add support for ACPI based firmware tables")
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Will Deacon <will@kernel.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: https://lore.kernel.org/r/871r69ersb.ffs@tglx
[ Upstream commit bea6a94a279bcbe6b2cde348782b28baf12255a5 ]
Starting with following patch MIPS Malta is not able to boot:
| commit 79edff12060fe7772af08607eff50c0e2486c5ba
| Author: Rob Herring <robh@kernel.org>
| scripts/dtc: Update to upstream version v1.6.0-51-g183df9e9c2b9
The reason is the alignment test added to the fdt_ro_probe_(). To fix
this issue, we need to make sure that fdt_buf is aligned.
Since the dtc patch was designed to uncover potential issue, I handle
initial MIPS Malta patch as initial bug.
Fixes: e81a8c7dabac ("MIPS: Malta: Setup RAM regions via DT")
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
commit f5e81d1117501546b7be050c5fbafa6efd2c722c upstream.
In case of JITs, each of the JIT backends compiles the BPF nospec instruction
/either/ to a machine instruction which emits a speculation barrier /or/ to
/no/ machine instruction in case the underlying architecture is not affected
by Speculative Store Bypass or has different mitigations in place already.
This covers both x86 and (implicitly) arm64: In case of x86, we use 'lfence'
instruction for mitigation. In case of arm64, we rely on the firmware mitigation
as controlled via the ssbd kernel parameter. Whenever the mitigation is enabled,
it works for all of the kernel code with no need to provide any additional
instructions here (hence only comment in arm64 JIT). Other archs can follow
as needed. The BPF nospec instruction is specifically targeting Spectre v4
since i) we don't use a serialization barrier for the Spectre v1 case, and
ii) mitigation instructions for v1 and v4 might be different on some archs.
The BPF nospec is required for a future commit, where the BPF verifier does
annotate intermediate BPF programs with speculation barriers.
Co-developed-by: Piotr Krysiuk <piotras@gmail.com>
Co-developed-by: Benedict Schlueter <benedict.schlueter@rub.de>
Signed-off-by: Benedict Schlueter <benedict.schlueter@rub.de>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[OP: - adjusted context for 5.4
- apply riscv changes to /arch/riscv/net/bpf_jit_comp.c]
commit 9a936d6c3d3d6c33ecbadf72dccdb567b5cd3c72 upstream.
Correct big-endian accesses to the CBUS UART, a Malta on-board discrete
TI16C550C part wired directly to the system controller's device bus, and
do not use byte swapping with the 32-bit accesses to the device.
The CBUS is used for devices such as the boot flash memory needed early
on in system bootstrap even before PCI has been initialised. Therefore
it uses the system controller's device bus, which follows the endianness
set with the CPU, which means no byte-swapping is ever required for data
accesses to CBUS, unlike with PCI.
The CBUS UART uses the UPIO_MEM32 access method, that is the `readl' and
`writel' MMIO accessors, which on the MIPS platform imply byte-swapping
with PCI systems. Consequently the wrong byte lane is accessed with the
big-endian configuration and the UART is not correctly accessed.
As it happens the UPIO_MEM32BE access method makes use of the `ioread32'
and `iowrite32' MMIO accessors, which still use `readl' and `writel'
respectively, however they byte-swap data passed, effectively cancelling
swapping done with the accessors themselves and making it suitable for
the CBUS UART.
Make the CBUS UART switch between UPIO_MEM32 and UPIO_MEM32BE then,
based on the endianness selected. With this change in place the device
is correctly recognised with big-endian Malta at boot, along with the
Super I/O devices behind PCI:
Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
printk: console [ttyS0] disabled
serial8250.0: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
printk: console [ttyS0] enabled
printk: bootconsole [uart8250] disabled
serial8250.0: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
serial8250.0: ttyS2 at MMIO 0x1f000900 (irq = 20, base_baud = 230400) is a 16550A
Fixes: e7c4782f92fc ("[MIPS] Put an end to <asm/serial.h>'s long and annyoing existence")
Cc: stable@vger.kernel.org # v2.6.23+
Reviewed-by: Philippe Mathieu-Daudé <f4bug@amsat.org>
Link: https://lore.kernel.org/r/alpine.DEB.2.21.2106260524430.37803@angie.orcam.me.uk
[ Upstream commit 28bbbb9875a35975904e46f9b06fa689d051b290 ]
When cross compiling a MIPS kernel on a BSD based HOSTCC leads
to errors like
SYNC include/config/auto.conf.cmd - due to: .config
egrep: empty (sub)expression
UPD include/config/kernel.release
HOSTCC scripts/dtc/dtc.o - due to target missing
It turns out that egrep uses this egrep pattern:
(|MINOR_|PATCHLEVEL_)
This is not valid syntax or gives undefined results according
to POSIX 9.5.3 ERE Grammar
https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap09.html
It seems to be silently accepted by the Linux egrep implementation
while a BSD host complains.
Such patterns can be replaced by a transformation like
"(|p1|p2)" -> "(p1|p2)?"
Fixes: 48c35b2d245f ("[MIPS] There is no __GNUC_MAJOR__")
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
This reverts commit 002d8b395fa1c0679fc3c3e68873de6c1cc300a2 which is
commit ed914d48b6a1040d1039d371b56273d422c0081e upstream.
Commit b2b29d6d011944 (mm: account PMD tables like PTE tables) is
introduced between v5.9 and v5.10, so this fix (commit 002d8b395fa1)
should NOT apply to any pre-5.10 branch.
Signed-off-by: Huang Pei <huangpei@loongson.cn>
[ Upstream commit 47ce8527fbba145a7723685bc9a27d9855e06491 ]
Accessing raw timers (currently only CLOCK_MONOTONIC_RAW) through VDSO
doesn't return the correct time when using the GIC as clock source.
The address of the GIC mapped page is in this case not calculated
correctly. The GIC mapped page is calculated from the VDSO data by
subtracting PAGE_SIZE:
void *get_gic(const struct vdso_data *data) {
return (void __iomem *)data - PAGE_SIZE;
However, the data pointer is not page aligned for raw clock sources.
This is because the VDSO data for raw clock sources (CS_RAW = 1) is
stored after the VDSO data for coarse clock sources (CS_HRES_COARSE = 0).
Therefore, only the VDSO data for CS_HRES_COARSE is page aligned:
| vd[CS_RAW] | ---+
| vd[CS_HRES_COARSE] | |
+--------------------+ | -PAGE_SIZE
| GIC mapped page | <--+
When __arch_get_hw_counter() is called with &vd[CS_RAW], get_gic returns
the wrong address (somewhere inside the GIC mapped page). The GIC counter
values are not returned which results in an invalid time.
Fixes: a7f4df4e21dd ("MIPS: VDSO: Add implementations of gettimeofday() and clock_gettime()")
Signed-off-by: Martin Fäcknitz <faecknitz@hotsplots.de>
[ Upstream commit 97e488073cfca0eea84450169ca4cbfcc64e33e3 ]
Use DISABLE_BRANCH_PROFILING for arch/mips/boot/compressed/decompress.o
to prevent linkage errors.
mips64-linux-ld: arch/mips/boot/compressed/decompress.o: in function `LZ4_decompress_fast_extDict':
decompress.c:(.text+0x8c): undefined reference to `ftrace_likely_update'
mips64-linux-ld: decompress.c:(.text+0xf4): undefined reference to `ftrace_likely_update'
mips64-linux-ld: decompress.c:(.text+0x200): undefined reference to `ftrace_likely_update'
mips64-linux-ld: decompress.c:(.text+0x230): undefined reference to `ftrace_likely_update'
mips64-linux-ld: decompress.c:(.text+0x320): undefined reference to `ftrace_likely_update'
mips64-linux-ld: arch/mips/boot/compressed/decompress.o:decompress.c:(.text+0x3f4): more undefined references to `ftrace_likely_update' follow
Fixes: e76e1fdfa8f8 ("lib: add support for LZ4-compressed kernel")
Cc: Kyungsik Lee <kyungsik.lee@lge.com>
[ Upstream commit cddc40f5617e53f97ef019d5b29c1bd6cbb031ec ]
My series to clean up the unaligned access implementation
across architectures caused some mips randconfig builds to
fail with:
mips64-linux-ld: arch/mips/boot/compressed/decompress.o: in function `decompress_kernel':
decompress.c:(.text.decompress_kernel+0x54): undefined reference to `__bswapsi2'
It turns out that this problem has already been fixed for the XZ
decompressor but now it also shows up in (at least) LZO and LZ4. From my
analysis I concluded that the compiler could always have emitted those
calls, but the different implementation allowed it to make otherwise
better decisions about not inlining the byteswap, which results in the
link error when the out-of-line code is missing.
While it could be addressed by adding it to the two decompressor
implementations that are known to be affected, but as this only adds
112 bytes to the kernel, the safer choice is to always add them.
Fixes: c50ec6787536 ("MIPS: zboot: Fix the build with XZ compression on older GCC versions")
Fixes: 0652035a5794 ("asm-generic: unaligned: remove byteshift helpers")
Link: https://lore.kernel.org/linux-mm/202106301304.gz2wVY9w-lkp@intel.com/
Link: https://lore.kernel.org/linux-mm/202106260659.TyMe8mjr-lkp@intel.com/
Link: https://lore.kernel.org/linux-mm/202106172016.onWT6Tza-lkp@intel.com/
Link: https://lore.kernel.org/linux-mm/202105231743.JJcALnhS-lkp@intel.com/
This is _not_ an upstream commit and just for 5.4.y only.
kernel test robot reported a 5.4.y build issue found by randconfig [1]
after backporting commit 89b158635ad7 ("lib/lz4: explicitly support
in-place decompression"") due to "undefined reference to `memmove'".
However, upstream and 5.10 LTS seem fine. After digging further,
I found commit a510b616131f ("MIPS: Add support for ZSTD-compressed
kernels") introduced memmove() occasionally and it has been included
since v5.10.
This partially cherry-picks the memmove() part of commit a510b616131f
to fix the reported build regression since we don't need the whole
patch for 5.4 LTS at all.
[1] https://lore.kernel.org/r/202107070120.6dOj1kB7-lkp@intel.com/
Fixes: defcc2b5e54a ("lib/lz4: explicitly support in-place decompression") # 5.4.y
Signed-off-by: Gao Xiang <hsiangkao@linux.alibaba.com>
[ Upstream commit c994a3ec7ecc8bd2a837b2061e8a76eb8efc082b ]
Clang's integrated assembler only accepts these instructions when the
cpu is set to mips32r5. With this change, we can assemble
malta_defconfig with Clang via `make LLVM_IAS=1`.
Link: https://github.com/ClangBuiltLinux/linux/issues/763
Reported-by: Dmitry Golovin <dima@golovin.in>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
[ Upstream commit 6817c944430d00f71ccaa9c99ff5b0096aeb7873 ]
The cause of the problem is as follows:
1. when cat /sys/devices/system/memory/memory0/valid_zones,
test_pages_in_a_zone() will be called.
2. test_pages_in_a_zone() finds the zone according to stat_pfn = 0.
The smallest pfn of the numa node in the mips architecture is 128,
and the page corresponding to the previous 0~127 pfn is not
initialized (page->flags is 0xFFFFFFFF)
3. The nid and zonenum obtained using page_zone(pfn_to_page(0)) are out
of bounds in the corresponding array,
&NODE_DATA(page_to_nid(page))->node_zones[page_zonenum(page)],
access to the out-of-bounds zone member variables appear abnormal,
resulting in Oops.
Therefore, it is necessary to keep the page between 0 and the minimum
pfn to prevent Oops from appearing.
Signed-off-by: zhanglianjie <zhanglianjie@uniontech.com>
[ Upstream commit ed914d48b6a1040d1039d371b56273d422c0081e ]
This fixes Page Table accounting bug.
MIPS is the ONLY arch just defining __HAVE_ARCH_PMD_ALLOC_ONE alone.
Since commit b2b29d6d011944 (mm: account PMD tables like PTE tables),
"pmd_free" in asm-generic with PMD table accounting and "pmd_alloc_one"
in MIPS without PMD table accounting causes PageTable accounting number
negative, which read by global_zone_page_state(), always returns 0.
[ Upstream commit 33ae8f801ad8bec48e886d368739feb2816478f2 ]
If multiple threads are accessing the same huge page at the same
time, hugetlb_cow will be called if one thread write the COW huge
page. And function huge_ptep_clear_flush is called to notify other
threads to clear the huge pte tlb entry. The other threads clear
the huge pte tlb entry and reload it from page table, the reload
huge pte entry may be old.
This patch fixes this issue on mips platform, and it clears huge
pte entry before notifying other threads to flush current huge
page entry, it is similar with other architectures.
Signed-off-by: Bibo Mao <maobibo@loongson.cn>
[ Upstream commit cf02ce742f09188272bcc8b0e62d789eb671fc4c ]
When 32-bit MIPS huge page support is enabled, we halve the number of
pointers a PTE page holds, making its last half go to waste.
Correspondingly, we should halve the number of kmap entries, as we just
initialized only a single pte table for that in pagetable_init().
Fixes: 35476311e529 ("MIPS: Add partial 32-bit huge page support")
Signed-off-by: Wei Li <liwei391@huawei.com>
commit e607ff630c6053ecc67502677c0e50053d7892d4 upstream.
With the latest mkimage from U-Boot 2021.04, the generic defconfigs no
longer build, failing with:
/usr/bin/mkimage: verify_header failed for FIT Image support with exit code 1
This is expected after the linked U-Boot commits because '@' is
forbidden in the node names due to the way that libfdt treats nodes with
the same prefix but different unit addresses.
Switch the '@' in the node name to '-'. Drop the unit addresses from the
hash and kernel child nodes because there is only one node so they do
not need to have a number to differentiate them.
Link: https://source.denx.de/u-boot/u-boot/-/commit/79af75f7776fc20b0d7eb6afe1e27c00fdb4b9b4
Link: https://source.denx.de/u-boot/u-boot/-/commit/3f04db891a353f4b127ed57279279f851c6b4917
Suggested-by: Simon Glass <sjg@chromium.org>
Signed-off-by: Nathan Chancellor <nathan@kernel.org>
[nathan: Backport to 5.4, only apply to .its.S files that exist]
[ Upstream commit 78cf0eb926cb1abeff2106bae67752e032fe5f3e ]
When update the latest mainline kernel with the following three configs,
the kernel hangs during startup:
(1) CONFIG_FUNCTION_GRAPH_TRACER=y
(2) CONFIG_PREEMPT_TRACER=y
(3) CONFIG_FTRACE_STARTUP_TEST=y
When update the latest mainline kernel with the above two configs (1)
and (2), the kernel starts normally, but it still hangs when execute
the following command:
echo "function_graph" > /sys/kernel/debug/tracing/current_tracer
Without CONFIG_PREEMPT_TRACER=y, the above two kinds of kernel hangs
disappeared, so it seems that CONFIG_PREEMPT_TRACER has some influences
with function_graph tracer at the first glance.
I use ejtag to find out the epc address is related with preempt_enable()
in the file arch/mips/lib/mips-atomic.c, because function tracing can
trace the preempt_{enable,disable} calls that are traced, replace them
with preempt_{enable,disable}_notrace to prevent function tracing from
going into an infinite loop, and then it can fix the kernel hang issue.
By the way, it seems that this commit is a complement and improvement of
commit f93a1a00f2bd ("MIPS: Fix crash that occurs when function tracing
is enabled").
Signed-off-by: Tiezhu Yang <yangtiezhu@loongson.cn>
[ Upstream commit fef532ea0cd871afab7d9a7b6e9da99ac2c24371 ]
rt2880_wdt.c uses (well, attempts to use) rt_sysc_membase. However,
when this watchdog driver is built as a loadable module, there is a
build error since the rt_sysc_membase symbol is not exported.
Export it to quell the build error.
ERROR: modpost: "rt_sysc_membase" [drivers/watchdog/rt2880_wdt.ko] undefined!
Fixes: 473cf939ff34 ("watchdog: add ralink watchdog driver")
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: John Crispin <john@phrozen.org>
Cc: linux-watchdog@vger.kernel.org
Acked-by: Guenter Roeck <linux@roeck-us.net>
[ Upstream commit ff4cff962a7eedc73e54b5096693da7f86c61346 ]
board-xxs1500.c references 2 functions without declaring them, so add
the header file to placate the build.
../arch/mips/alchemy/board-xxs1500.c: In function 'board_setup':
../arch/mips/alchemy/board-xxs1500.c:56:2: error: implicit declaration of function 'alchemy_gpio1_input_enable' [-Werror=implicit-function-declaration]
56 | alchemy_gpio1_input_enable();
../arch/mips/alchemy/board-xxs1500.c:57:2: error: implicit declaration of function 'alchemy_gpio2_enable'; did you mean 'alchemy_uart_enable'? [-Werror=implicit-function-declaration]
57 | alchemy_gpio2_enable();
Fixes: 8e026910fcd4 ("MIPS: Alchemy: merge GPR/MTX-1/XXS1500 board code into single files")
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Acked-by: Manuel Lauss <manuel.lauss@gmail.com>
commit 25ab14cbe9d1b66fda44c71a2db7582a31b6f5cd upstream.
Remove the inline asm with a DIVU instruction from `__div64_32' and use
plain C code for the intended DIVMOD calculation instead. GCC is smart
enough to know that both the quotient and the remainder are calculated
with single DIVU, so with ISAs up to R5 the same instruction is actually
produced with overall similar code.
For R6 compiled code will work, but separate DIVU and MODU instructions
will be produced, which are also interlocked, so scalar implementations
will likely not perform as well as older ISAs with their asynchronous MD
unit. Likely still faster then the generic algorithm though.
This removes a compilation error for R6 however where the original DIVU
instruction is not supported anymore and the MDU accumulator registers
have been removed and consequently GCC complains as to a constraint it
cannot find a register for:
In file included from ./include/linux/math.h:5,
from ./include/linux/kernel.h:13,
from mm/page-writeback.c:15:
./include/linux/math64.h: In function 'div_u64_rem':
./arch/mips/include/asm/div64.h:76:17: error: inconsistent operand constraints in an 'asm'
76 | __asm__("divu $0, %z1, %z2" \
./include/asm-generic/div64.h:245:25: note: in expansion of macro '__div64_32'
245 | __rem = __div64_32(&(n), __base); \
./include/linux/math64.h:91:22: note: in expansion of macro 'do_div'
91 | *remainder = do_div(dividend, divisor);
This has passed correctness verification with test_div64 and reduced the
module's average execution time down to 1.0404s from 1.0445s with R3400
@40MHz. The module's MIPS I machine code has also shrunk by 12 bytes or
3 instructions.
commit c1d337d45ec0a802299688e17d568c4e3a585895 upstream.
We already check the high part of the divident against zero to avoid the
costly DIVU instruction in that case, needed to reduce the high part of
the divident, so we may well check against the divisor instead and set
the high part of the quotient to zero right away. We need to treat the
high part the divident in that case though as the remainder that would
be calculated by the DIVU instruction we avoided.
module's average execution time down to 1.0445s and 0.2619s from 1.0668s
and 0.2629s respectively for an R3400 CPU @40MHz and a 5Kc CPU @160MHz.
commit c49f71f60754acbff37505e1d16ca796bf8a8140 upstream.
Our current MIPS platform `__div64_32' handler is inactive, because it
is incorrectly only enabled for 64-bit configurations, for which generic
`do_div' code does not call it anyway.
The handler is not suitable for being called from there though as it
only calculates 32 bits of the quotient under the assumption the 64-bit
divident has been suitably reduced. Code for such reduction used to be
there, however it has been incorrectly removed with commit c21004cd5b4c
("MIPS: Rewrite <asm/div64.h> to work with gcc 4.4.0."), which should
have only updated an obsoleted constraint for an inline asm involving
$hi and $lo register outputs, while possibly wiring the original MIPS
variant of the `do_div' macro as `__div64_32' handler for the generic
`do_div' implementation
Correct the handler as follows then:
- Revert most of the commit referred, however retaining the current
formatting, except for the final two instructions of the inline asm
sequence, which the original commit missed. Omit the original 64-bit
parts though.
- Rename the original `do_div' macro to `__div64_32'. Use the combined
`x' constraint referring to the MD accumulator as a whole, replacing
the original individual `h' and `l' constraints used for $hi and $lo
registers respectively, of which `h' has been obsoleted with GCC 4.4.
Update surrounding code accordingly.
We have since removed support for GCC versions before 4.9, so no need
for a special arrangement here; GCC has supported the `x' constraint
since forever anyway, or at least going back to 1991.
- Rename the `__base' local variable in `__div64_32' to `__radix' to
avoid a conflict with a local variable in `do_div'.
- Actually enable this code for 32-bit rather than 64-bit configurations
by qualifying it with BITS_PER_LONG being 32 instead of 64. Include
<asm/bitsperlong.h> for this macro rather than <linux/types.h> as we
don't need anything else.
- Finally include <asm-generic/div64.h> last rather than first.
module's average execution time down to 1.0668s and 0.2629s from 2.1529s
and 0.5647s respectively for an R3400 CPU @40MHz and a 5Kc CPU @160MHz.
For a reference 64-bit `do_div' code where we have the DDIVU instruction
available to do the whole calculation right away averages at 0.0660s for
the latter CPU.
Fixes: c21004cd5b4c ("MIPS: Rewrite <asm/div64.h> to work with gcc 4.4.0.")
Reported-by: Huacai Chen <chenhuacai@kernel.org>
Cc: stable@vger.kernel.org # v2.6.30+
[ Upstream commit 3ecb9dc1581eebecaee56decac70e35365260866 ]
Mirror commit aeba3731b150 ("powerpc/pci: Fix IO space breakage after
of_pci_range_to_resource() change").
Most MIPS platforms do not define PCI_IOBASE, nor implement
pci_address_to_pio(). Moreover, IO_SPACE_LIMIT is 0xffff for most MIPS
platforms. of_pci_range_to_resource passes the _start address_ of the IO
range into pci_address_to_pio, which then checks it against
IO_SPACE_LIMIT and fails, because for MIPS platforms that use
pci-legacy (pci-lantiq, pci-rt3883, pci-mt7620), IO ranges start much
higher than 0xffff.
In fact, pci-mt7621 in staging already works around this problem, see
commit 09dd629eeabb ("staging: mt7621-pci: fix io space and properly set
resource limits")
So just stop using of_pci_range_to_resource, which does not work for
MIPS.
Fixes PCI errors like:
pci_bus 0000:00: root bus resource [io 0xffffffff]
Fixes: 0b0b0893d49b ("of/pci: Fix the conversion of IO ranges into IO resources")
Signed-off-by: Ilya Lipnitskiy <ilya.lipnitskiy@gmail.com>
Cc: Liviu Dudau <Liviu.Dudau@arm.com>
[ Upstream commit cde58b861a1d365568588adda59d42351c0c4ad3 ]
Commit a23c4134955e added the clock controller nodes, incorrectly changing the
syscon-reboot nodes addresses.
Fixes: a23c4134955e ("MIPS: BMIPS: add clock controller nodes")
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
commit 8e98b697006d749d745d3b174168a877bb96c500 upstream.
pci_fixup_irqs() used to call pcibios_map_irq on every PCI device, which
for RT2880 included bus 0 slot 0. After pci_fixup_irqs() got removed,
only slots/funcs with devices attached would be called. While arguably
the right thing, that left no chance for this driver to ever initialize
slot 0, effectively bricking PCI and USB on RT2880 devices such as the
Belkin F5D8235-4 v1.
Slot 0 configuration needs to happen after PCI bus enumeration, but
before any device at slot 0x11 (func 0 or 1) is talked to. That was
determined empirically by testing on a Belkin F5D8235-4 v1 device. A
minimal BAR 0 config write followed by read, then setting slot 0
PCI_COMMAND to MASTER | IO | MEMORY is all that seems to be required for
proper functionality.
Tested by ensuring that full- and high-speed USB devices get enumerated
on the Belkin F5D8235-4 v1 (with an out of tree DTS file from OpenWrt).
Fixes: 04c81c7293df ("MIPS: PCI: Replace pci_fixup_irqs() call with host bridge IRQ mapping hooks")
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Tobias Wolf <dev-NTEO@vplace.de>
Cc: <stable@vger.kernel.org> # v4.14+
commit c15b99ae2ba9ea30da3c7cd4765b8a4707e530a6 upstream.
Upstream a long-standing OpenWrt patch [0] that fixes MT7620 PCIe PLL
lock check. The existing code checks the wrong register bit: PPLL_SW_SET
is not defined in PPLL_CFG1 and bit 31 of PPLL_CFG1 is marked as reserved
in the MT7620 Programming Guide. The correct bit to check for PLL lock
is PPLL_LD (bit 23).
Also reword the error message for clarity.
Without this change it is unlikely that this driver ever worked with
mainline kernel.
[0]: https://lists.infradead.org/pipermail/lede-commits/2017-July/004441.html
Cc: linux-mediatek@lists.infradead.org
commit 1d7ba0165d8206ac073f7ac3b14fc0836b66eae7 upstream.
From [1]
"GCC 10 (PR 91233) won't silently allow registers that are not
architecturally available to be present in the clobber list anymore,
resulting in build failure for mips*r6 targets in form of:
.../sysdep.h:146:2: error: the register ‘lo’ cannot be clobbered in ‘asm’ for the current target
146 | __asm__ volatile ( \
This is because base R6 ISA doesn't define hi and lo registers w/o DSP
extension. This patch provides the alternative clobber list for r6 targets
that won't include those registers."
Since kernel 5.4 and mips support for generic vDSO [2], the kernel fail to
build for mips r6 cpus with gcc 10 for the same reason as glibc.
[1] https://sourceware.org/git/?p=glibc.git;a=commit;h=020b2a97bb15f807c0482f0faee2184ed05bcad8
[2] '24640f233b46 ("mips: Add support for generic vDSO")'
Signed-off-by: Romain Naour <romain.naour@gmail.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 3c0be5849259b729580c23549330973a2dd513a2 upstream.
We have assembly implementations of strcpy(), strncpy(), strcmp() &
strncmp() which:
- Are simple byte-at-a-time loops with no particular optimizations. As
a comment in the code describes, they're "rather naive".
- Offer no clear performance advantage over the generic C
implementations - in microbenchmarks performed by Alexander Lobakin
the asm functions sometimes win & sometimes lose, but generally not
by large margins in either direction.
- Don't support 64-bit kernels, where we already make use of the
generic C implementations.
- Tend to bloat kernel code size due to inlining.
- Don't support CONFIG_FORTIFY_SOURCE.
- Won't support nanoMIPS without rework.
For all of these reasons, delete the asm implementations & make use of
the generic C implementations for 32-bit kernels just like we already do
for 64-bit kernels.
Signed-off-by: Paul Burton <paul.burton@mips.com>
URL: https://lore.kernel.org/linux-mips/a2a35f1cf58d6db19eb4af9b4ae21e35@dlink.ru/
Cc: Alexander Lobakin <alobakin@dlink.ru>
commit 76d7fff22be3e4185ee5f9da2eecbd8188e76b2c upstream.
Commit ee67855ecd9d ("MIPS: vdso: Allow clang's --target flag in VDSO
cflags") allowed the '--target=' flag from the main Makefile to filter
through to the vDSO. However, it did not bring any of the other clang
specific flags for controlling the integrated assembler and the GNU
tools locations (--prefix=, --gcc-toolchain=, and -no-integrated-as).
Without these, we will get a warning (visible with tinyconfig):
arch/mips/vdso/elf.S:14:1: warning: DWARF2 only supports one section per
compilation unit
.pushsection .note.Linux, "a",@note ; .balign 4 ; .long 2f - 1f ; .long
4484f - 3f ; .long 0 ; 1:.asciz "Linux" ; 2:.balign 4 ; 3:
arch/mips/vdso/elf.S:34:2: warning: DWARF2 only supports one section per
compilation unit
.section .mips_abiflags, "a"
All of these flags are bundled up under CLANG_FLAGS in the main Makefile
and exported so that they can be added to Makefiles that set their own
CFLAGS. Use this value instead of filtering out '--target=' so there is
no warning and all of the tools are properly used.
Fixes: ee67855ecd9d ("MIPS: vdso: Allow clang's --target flag in VDSO cflags")
Link: https://github.com/ClangBuiltLinux/linux/issues/1256
Reported-by: Anders Roxell <anders.roxell@linaro.org>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Tested-by: Anders Roxell <anders.roxell@linaro.org>
[nc: Fix conflict due to lack of 99570c3da96a in 5.4]
[ Upstream commit 894ef530012fb5078466efdfb2c15d8b2f1565cd ]
Commit 866b6a89c6d1 ("MIPS: Add DWARF unwinding to assembly") added
-fno-asynchronous-unwind-tables to KBUILD_CFLAGS to prevent compiler
from emitting .eh_frame symbols.
However, as MIPS heavily uses CFI, that's not enough. Use the
approach taken for x86 (as it also uses CFI) and explicitly put CFI
symbols into the .debug_frame section (except for VDSO).
This allows us to drop .eh_frame from DISCARDS as it's no longer
being generated.
Fixes: 866b6a89c6d1 ("MIPS: Add DWARF unwinding to assembly")
Suggested-by: Kees Cook <keescook@chromium.org>
Signed-off-by: Alexander Lobakin <alobakin@pm.me>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit c6f2a9e17b9bef7677caddb1626c2402f3e9d2bd ]
When building xway_defconfig with clang:
arch/mips/lantiq/irq.c:305:48: error: use of logical '&&' with constant
operand [-Werror,-Wconstant-logical-operand]
if ((irq == LTQ_ICU_EBU_IRQ) && (module == 0) && LTQ_EBU_PCC_ISTAT)
arch/mips/lantiq/irq.c:305:48: note: use '&' for a bitwise operation
arch/mips/lantiq/irq.c:305:48: note: remove constant to silence this
warning
1 error generated.
Explicitly compare the constant LTQ_EBU_PCC_ISTAT against 0 to fix the
warning. Additionally, remove the unnecessary parentheses as this is a
simple conditional statement and shorthand '== 0' to '!'.
Fixes: 3645da0276ae ("OF: MIPS: lantiq: implement irq_domain support")
Link: https://github.com/ClangBuiltLinux/linux/issues/807
[ Upstream commit c58734eee6a2151ba033c0dcb31902c89e310374 ]
When building with clang, the following section mismatch warning occurs:
WARNING: modpost: vmlinux.o(.text+0x24490): Section mismatch in
reference from the function r4k_cache_init() to the function
.init.text:loongson2_sc_init()
This should have been fixed with commit ad4fddef5f23 ("mips: fix Section
mismatch in reference") but it was missed. Remove the improper __init
annotation like that commit did.
Fixes: 078a55fc824c ("MIPS: Delete __cpuinit/__CPUINIT usage from MIPS code")
Link: https://github.com/ClangBuiltLinux/linux/issues/787
commit 8ac7c87acdcac156670f9920c8acbd84308ff4b1 upstream.
MIPS uses its own declaration of rwdata, and thus it should be kept
in sync with the asm-generic one. Currently PAGE_ALIGNED_DATA() is
missing from the linker script, which emits the following ld
warnings:
mips-alpine-linux-musl-ld: warning: orphan section
`.data..page_aligned' from `arch/mips/kernel/vdso.o' being placed
in section `.data..page_aligned'
`.data..page_aligned' from `arch/mips/vdso/vdso-image.o' being placed
Add the necessary declaration, so the mentioned structures will be
placed in vmlinux as intended:
ffffffff80630580 D __end_once
ffffffff80630580 D __start___dyndbg
ffffffff80630580 D __start_once
ffffffff80630580 D __stop___dyndbg
ffffffff80634000 d mips_vdso_data
ffffffff80638000 d vdso_data
ffffffff80638580 D _gp
ffffffff8063c000 T __init_begin
ffffffff8063c000 D _edata
ffffffff8063c000 T _sinittext
ffffffff805a4000 D __end_init_task
ffffffff805a4000 D __nosave_begin
ffffffff805a4000 D __nosave_end
ffffffff805a4000 d mips_vdso_data
ffffffff805a8000 d vdso_data
ffffffff805ac000 D mmlist_lock
ffffffff805ac080 D tasklist_lock
Fixes: ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
Cc: stable@vger.kernel.org # 4.4+
commit 69e976831cd53f9ba304fd20305b2025ecc78eab upstream.
LLVM-built Linux triggered a boot hangup with KASLR enabled.
arch/mips/kernel/relocate.c:get_random_boot() uses linux_banner,
which is a string constant, as a random seed, but accesses it
as an array of unsigned long (in rotate_xor()).
When the address of linux_banner is not aligned to sizeof(long),
such access emits unaligned access exception and hangs the kernel.
Use PTR_ALIGN() to align input address to sizeof(long) and also
align down the input length to prevent possible access-beyond-end.
Fixes: 405bc8fd12f5 ("MIPS: Kernel: Implement KASLR using CONFIG_RELOCATABLE")
Cc: stable@vger.kernel.org # 4.7+
Tested-by: Nathan Chancellor <natechancellor@gmail.com>
commit 4d4f9c1a17a3480f8fe523673f7232b254d724b7 upstream.
The compressed payload is not necesarily 4-byte aligned, at least when
compiling with Clang. In that case, the 4-byte value appended to the
compressed payload that corresponds to the uncompressed kernel image
size must be read using get_unaligned_le32().
This fixes Clang-built kernels not booting on MIPS (tested on a Ingenic
JZ4770 board).
Fixes: b8f54f2cde78 ("MIPS: ZBOOT: copy appended dtb to the end of the kernel")
Cc: <stable@vger.kernel.org> # v4.7
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
commit 5b058973d3205578aa6c9a71392e072a11ca44ef upstream.
When building mips tinyconfig with clang the following warning show up:
arch/mips/lib/uncached.c:45:6: warning: variable 'sp' is uninitialized when used here [-Wuninitialized]
if (sp >= (long)CKSEG0 && sp < (long)CKSEG2)
arch/mips/lib/uncached.c:40:18: note: initialize the variable 'sp' to silence this warning
register long sp __asm__("$sp");
= 0
1 warning generated.
Rework to make an explicit inline move, instead of the non-standard use
of specifying registers for local variables. This is what's written
from the gcc-10 manual [1] about specifying registers for local
variables:
"6.47.5.2 Specifying Registers for Local Variables
"The only supported use for this feature is to specify registers for
input and output operands when calling Extended 'asm' (*note Extended
Asm::). [...]".
[1] https://docs.w3cub.com/gcc~10/local-register-variables
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org>
commit ad4fddef5f2345aa9214e979febe2f47639c10d9 upstream.
When building mips tinyconfig with clang the following error show up:
WARNING: modpost: vmlinux.o(.text+0x1940c): Section mismatch in reference from the function r4k_cache_init() to the function .init.text:loongson3_sc_init()
The function r4k_cache_init() references
the function __init loongson3_sc_init().
This is often because r4k_cache_init lacks a __init
annotation or the annotation of loongson3_sc_init is wrong.
Remove marked __init from function loongson3_sc_init(),
mips_sc_probe_cm3(), and mips_sc_probe().
[ Upstream commit d121f125af22a16f0f679293756d28a9691fa46d ]
Linux doesn't own the memory immediately after the kernel image. On Octeon
bootloader places a shared structure right close after the kernel _end,
refer to "struct cvmx_bootinfo *octeon_bootinfo" in cavium-octeon/setup.c.
If check_kernel_sections_mem() rounds the PFNs up, first memblock_alloc()
inside early_init_dt_alloc_memory_arch() <= device_tree_init() returns
memory block overlapping with the above octeon_bootinfo structure, which
is being overwritten afterwards.
Fixes: a94e4f24ec83 ("MIPS: init: Drop boot_mem_map")
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
[ Upstream commit 3a5fe2fb9635c43359c9729352f45044f3c8df6b ]
When BCM47XX_BCMA is enabled and BCMA_DRIVER_PCI is disabled, it results
in the following Kbuild warning:
WARNING: unmet direct dependencies detected for BCMA_DRIVER_PCI_HOSTMODE
Depends on [n]: MIPS [=y] && BCMA_DRIVER_PCI [=n] && PCI_DRIVERS_LEGACY [=y] && BCMA [=y]=y
Selected by [y]:
- BCM47XX_BCMA [=y] && BCM47XX [=y] && PCI [=y]
The reason is that BCM47XX_BCMA selects BCMA_DRIVER_PCI_HOSTMODE without
depending on or selecting BCMA_DRIVER_PCI while BCMA_DRIVER_PCI_HOSTMODE
depends on BCMA_DRIVER_PCI. This can also fail building the kernel.
Honor the kconfig dependency to remove unmet direct dependency warnings
and avoid any potential build failures.
Fixes: c1d1c5d4213e ("bcm47xx: add support for bcma bus")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=209879
Signed-off-by: Necip Fazil Yildiran <fazilyildiran@gmail.com>
[ Upstream commit cef397038167ac15d085914493d6c86385773709 ]
Stefan Agner reported a bug when using zsram on 32-bit Arm machines
with RAM above the 4GB address boundary:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = a27bd01c
[00000000] *pgd=236a0003, *pmd=1ffa64003
Internal error: Oops: 207 [#1] SMP ARM
Modules linked in: mdio_bcm_unimac(+) brcmfmac cfg80211 brcmutil raspberrypi_hwmon hci_uart crc32_arm_ce bcm2711_thermal phy_generic genet
CPU: 0 PID: 123 Comm: mkfs.ext4 Not tainted 5.9.6 #1
Hardware name: BCM2711
PC is at zs_map_object+0x94/0x338
LR is at zram_bvec_rw.constprop.0+0x330/0xa64
pc : [<c0602b38>] lr : [<c0bda6a0>] psr: 60000013
sp : e376bbe0 ip : 00000000 fp : c1e2921c
r10: 00000002 r9 : c1dda730 r8 : 00000000
r7 : e8ff7a00 r6 : 00000000 r5 : 02f9ffa0 r4 : e3710000
r3 : 000fdffe r2 : c1e0ce80 r1 : ebf979a0 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 30c5383d Table: 235c2a80 DAC: fffffffd
Process mkfs.ext4 (pid: 123, stack limit = 0x495a22e6)
Stack: (0xe376bbe0 to 0xe376c000)
As it turns out, zsram needs to know the maximum memory size, which
is defined in MAX_PHYSMEM_BITS when CONFIG_SPARSEMEM is set, or in
MAX_POSSIBLE_PHYSMEM_BITS on the x86 architecture.
The same problem will be hit on all 32-bit architectures that have a
physical address space larger than 4GB and happen to not enable sparsemem
and include asm/sparsemem.h from asm/pgtable.h.
After the initial discussion, I suggested just always defining
MAX_POSSIBLE_PHYSMEM_BITS whenever CONFIG_PHYS_ADDR_T_64BIT is
set, or provoking a build error otherwise. This addresses all
configurations that can currently have this runtime bug, but
leaves all other configurations unchanged.
I looked up the possible number of bits in source code and
datasheets, here is what I found:
- on ARC, CONFIG_ARC_HAS_PAE40 controls whether 32 or 40 bits are used
- on ARM, CONFIG_LPAE enables 40 bit addressing, without it we never
support more than 32 bits, even though supersections in theory allow
up to 40 bits as well.
- on MIPS, some MIPS32r1 or later chips support 36 bits, and MIPS32r5
XPA supports up to 60 bits in theory, but 40 bits are more than
anyone will ever ship
- On PowerPC, there are three different implementations of 36 bit
addressing, but 32-bit is used without CONFIG_PTE_64BIT
- On RISC-V, the normal page table format can support 34 bit
addressing. There is no highmem support on RISC-V, so anything
above 2GB is unused, but it might be useful to eventually support
CONFIG_ZRAM for high pages.
Fixes: 61989a80fb3a ("staging: zsmalloc: zsmalloc memory allocation library")
Fixes: 02390b87a945 ("mm/zsmalloc: Prepare to variable MAX_PHYSMEM_BITS")
Reviewed-by: Stefan Agner <stefan@agner.ch>
Tested-by: Stefan Agner <stefan@agner.ch>
Acked-by: Mike Rapoport <rppt@linux.ibm.com>
Link: https://lore.kernel.org/linux-mm/bdfa44bf1c570b05d6c70898e2bbb0acf234ecdf.1604762181.git.stefan@agner.ch/
[ Upstream commit ac3b57adf87ad9bac7e33ca26bbbb13fae1ed62b ]
If the clk_register fails, we should free h before
function returns to prevent memleak.
Fixes: 474402291a0ad ("MIPS: Alchemy: clock framework integration of onchip clocks")
Signed-off-by: Zhang Qilong <zhangqilong3@huawei.com>
[ Upstream commit 31b4d8e172f614adc53ddecb4b6b2f6411a49b84 ]
MIPS should export its local version of "has_transparent_hugepage"
so that loadable modules (dax) can use it.
Fixes this build error:
ERROR: modpost: "has_transparent_hugepage" [drivers/dax/dax.ko] undefined!
Fixes: fd8cfd300019 ("arch: fix has_transparent_hugepage()")
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Vishal Verma <vishal.l.verma@intel.com>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: linux-nvdimm@lists.01.org
