path: root/arch/mips
2010-10-30Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (82 commits) mtd: fix build error in m25p80.c mtd: Remove redundant mutex from mtd_blkdevs.c MTD: Fix wrong check register_blkdev return value Revert "mtd: cleanup Kconfig dependencies" mtd: cfi_cmdset_0002: make sector erase command variable mtd: cfi_cmdset_0002: add CFI detection for SST 38VF640x chips mtd: cfi_util: add support for switching SST 39VF640xB chips into QRY mode mtd: cfi_cmdset_0001: use defined value of P_ID_INTEL_PERFORMANCE instead of hardcoded one block2mtd: dubious assignment P4080/mtd: Fix the freescale lbc issue with 36bit mode P4080/eLBC: Make Freescale elbc interrupt common to elbc devices mtd: phram: use KBUILD_MODNAME mtd: OneNAND: S5PC110: Fix double call suspend & resume function mtd: nand: fix MTD_MODE_RAW writes jffs2: use kmemdup mtd: sm_ftl: cosmetic, use bool when possible mtd: r852: remove useless pci powerup/down from suspend/resume routines mtd: blktrans: fix a race vs kthread_stop mtd: blktrans: kill BKL mtd: allow to unload the mtdtrans module if its block devices aren't open ... Fix up trivial whitespace-introduced conflict in drivers/mtd/mtdchar.c
2010-10-30Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git Conflicts: drivers/mtd/mtd_blkdevs.c Merge Grant's device-tree bits so that we can apply the subsequent fixes. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-29ftrace/MIPS: Enable C Version of recordmcountWu Zhangjin
Selects HAVE_C_RECORDMCOUNT to use the C version of the recordmcount intead of the old Perl Version of recordmcount. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> LKML-Reference: <bb99009a9ac79d3f55a8c8bf1c8bd2bc0e1f160e.1288176026.git.wuzhangjin@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Make TASK_SIZE reflect proper size for both 32 and 64 bit processes.David Daney
The TASK_SIZE macro should reflect the size of a user process virtual address space. Previously for 64-bit kernels, this was not the case. The immediate cause of pain was in hugetlbfs/inode.c:hugetlb_get_unmapped_area() where 32-bit processes trying to mmap a huge page would be served a page with an address outside of the 32-bit address range. But there are other uses of TASK_SIZE in the kernel as well that would like an accurate value. The new definition is nice because it now makes TASK_SIZE and TASK_SIZE_OF() yield the same value for any given process. For 32-bit kernels there should be no change, although I did factor out some code in asm/processor.h that became identical for the 32-bit and 64-bit cases. __UA_LIMIT is now set to ~((1 << SEGBITS) - 1) for 64-bit kernels. This should eliminate the possibility of getting a AddressErrorException in the kernel for addresses that pass the access_ok() test. With the patch applied, I can still run o32, n32 and n64 processes, and have an o32 shell fork/exec both n32 and n64 processes. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1701/
2010-10-29MIPS: Allow UserLocal on MIPS_R1 processorsKevin Cernekee
Some MIPS32R1 processors implement UserLocal (RDHWR $29) to accelerate programs that make extensive use of thread-local storage. Therefore, setting up the HWRENA register should not depend on cpu_has_mips_r2. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org
2010-10-29MIPS: Honor L2 bypass bitKevin Cernekee
On many of the newer MIPS32 cores, CP0 CONFIG2 bit 12 (L2B) indicates that the L2 cache is disabled and therefore Linux should not attempt to use it. [Ralf: Moved the code added by Kevin's original patch into a separate function that can easily be replaced for platforms that need more a different probe.] Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: linux-mips@linux-mips.org> Cc: <linux-kernel@vger.kernel.org> Patchwork: https://patchwork.linux-mips.org/patch/1723/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Add BMIPS CP0 register definitionsKevin Cernekee
Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: mbizon@freebox.fr Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Tested-by: Florian Fainelli <ffainelli@freebox.fr> Patchwork: https://patchwork.linux-mips.org/patch/1708/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2010-10-29MIPS: Add BMIPS processor types to KconfigKevin Cernekee
[v2: add "VIPER" marketing name for BMIPS4350] Add processor feature definitions for BMIPS3300, BMIPS4350, BMIPS4380, and BMIPS5000. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: mbizon@freebox.fr Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Tested-by: Florian Fainelli <ffainelli@freebox.fr> Patchwork: https://patchwork.linux-mips.org/patch/1716/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2010-10-29MIPS: Decouple BMIPS CPU support from bcm47xx/bcm63xx SoC codeKevin Cernekee
BMIPS processor cores are used in 50+ different chipsets spread across 5+ product lines. In many cases the chipsets do not share the same peripheral register layouts, the same register blocks, the same interrupt controllers, the same memory maps, or much of anything else. But, across radically different SoCs that share nothing more than the same BMIPS CPU, a few things are still mostly constant: SMP operations Access to performance counters DMA cache coherency quirks Cache and memory bus configuration So, it makes sense to treat each BMIPS processor type as a generic "building block," rather than tying it to a specific SoC. This makes it easier to support a large number of BMIPS-based chipsets without unnecessary duplication of code, and provides the infrastructure needed to support BMIPS-proprietary features. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: mbizon@freebox.fr Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Tested-by: Florian Fainelli <ffainelli@freebox.fr> Patchwork: https://patchwork.linux-mips.org/patch/1706/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2010-10-29MIPS: Add support for hardware performance events (mipsxx)Deng-Cheng Zhu
This patch adds the mipsxx Perf-events support based on the skeleton. Generic hardware events and cache events are now fully implemented for the 24K/34K/74K/1004K cores. To support other cores in mipsxx (such as R10000/SB1), the generic hardware event tables and cache event tables need to be filled out. To support other CPUs which have different PMU than mipsxx, such as RM9000 and LOONGSON2, the additional files perf_event_$cpu.c need to be created. Raw event is an important part of Perf-events. It helps the user collect performance data for events that are not listed as the generic hardware events and cache events but ARE supported by the CPU's PMU. This patch also adds this feature for mipsxx 24K/34K/74K/1004K. For how to use it, please refer to processor core software user's manual and the comments for mipsxx_pmu_map_raw_event() for more details. Please note that this is a "precise" implementation, which means the kernel will check whether the requested raw events are supported by this CPU and which hardware counters can be assigned for them. To test the functionality of Perf-event, you may want to compile the tool "perf" for your MIPS platform. You can refer to the following URL: http://www.linux-mips.org/archives/linux-mips/2010-10/msg00126.html You also need to customize the CFLAGS and LDFLAGS in tools/perf/Makefile for your libs, includes, etc. In case you encounter the boot failure in SMVP kernel on multi-threading CPUs, you may take a look at: http://www.linux-mips.org/git?p=linux-mti.git;a=commitdiff;h=5460815027d802697b879644c74f0e8365254020 Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: jamie.iles@picochip.com Cc: ddaney@caviumnetworks.com Cc: matt@console-pimps.org Patchwork: https://patchwork.linux-mips.org/patch/1689/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> create mode 100644 arch/mips/kernel/perf_event_mipsxx.c
2010-10-29MIPS: Perf-events: Add callchain supportDeng-Cheng Zhu
Adds callchain support for MIPS Perf-events. For more info on this feature, please refer to tools/perf/Documentation/perf-report.txt and tools/perf/design.txt. Currently userspace callchain data is not recorded, because we do not have a safe way to do this. Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Acked-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: jamie.iles@picochip.com Cc: matt@console-pimps.org Patchwork: https://patchwork.linux-mips.org/patch/1690/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: add support for hardware performance events (skeleton)Deng-Cheng Zhu
This patch provides the skeleton of the HW perf event support. To enable this feature, we can not choose the SMTC kernel; Oprofile should be disabled; kernel performance events be selected. Then we can enable it in Kernel type menu. Oprofile for MIPS platforms initializes irq at arch init time. Currently we do not change this logic to allow PMU reservation. If a platform has EIC, we can use the irq base and perf counter irq offset defines for the interrupt controller in specific init_hw_perf_events(). Based on this skeleton patch, the 3 different kinds of MIPS PMU, namely, mipsxx/loongson2/rm9000, can be supported by adding corresponding lower level C files at the bottom. The suggested names of these files are perf_event_mipsxx.c/perf_event_loongson2.c/perf_event_rm9000.c. So, for example, we can do this by adding "#include perf_event_mipsxx.c" at the bottom of perf_event.c. In addition, PMUs with 64bit counters are also considered in this patch. Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: jamie.iles@picochip.com Cc: ddaney@caviumnetworks.com Cc: matt@console-pimps.org Patchwork: https://patchwork.linux-mips.org/patch/1688/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: add support for software performance eventsDeng-Cheng Zhu
Software events are required as part of the measurable stuff by the Linux performance counter subsystem. Here is the list of events added by this patch: PERF_COUNT_SW_PAGE_FAULTS PERF_COUNT_SW_PAGE_FAULTS_MIN PERF_COUNT_SW_PAGE_FAULTS_MAJ PERF_COUNT_SW_ALIGNMENT_FAULTS PERF_COUNT_SW_EMULATION_FAULTS Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: jamie.iles@picochip.com Acked-by: David Daney <ddaney@caviumnetworks.com> Reviewed-by: Matt Fleming <matt@console-pimps.org> Patchwork: https://patchwork.linux-mips.org/patch/1686/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: define local_xchg from xchg_local to atomic_long_xchgDeng-Cheng Zhu
Perf-events is now using local_t helper functions internally. There is a use of local_xchg(). On MIPS, this is defined to xchg_local() which is missing in asm/system.h. This patch re-defines local_xchg() in asm/local.h to atomic_long_xchg(). Then Perf-events can pass the build. Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: jamie.iles@picochip.com Cc: ddaney@caviumnetworks.com Cc: matt@console-pimps.org Patchwork: https://patchwork.linux-mips.org/patch/1687/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: AR7: Add support for Titan (TNETV10xx) SoC variantFlorian Fainelli
Add support for Titan TNETV1050,1055,1056,1060 variants. This SoC is almost completely identical to AR7 except on a few points: - a second bank of gpios is available - vlynq0 on titan is vlynq1 on ar7 - different PHY addresses for cpmac0 This SoC can be found on commercial products like the Linksys WRTP54G Original patch by Xin with improvments by Florian. Signed-off-by: Xin Zhen <xlonestar2000@aim.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/1563/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2010-10-29MIPS: AR7: Initialize GPIO earlierFlorian Fainelli
In order to detect the Titan variant, we must initialize GPIOs earlier since detection relies on some GPIO values to be set. Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/1562/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2010-10-29MIPS: Add platform device and Kconfig for Octeon USB EHCI / OHCIDavid Daney
Declare that OCTEON reference boards have both OHCI and EHCI. Add platform devices for the corresponding hardware. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-usb@vger.kernel.org To: dbrownell@users.sourceforge.net Patchwork: http://patchwork.linux-mips.org/patch/1676/ Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Add register definitions for EHCI / OHCI USB glue logic.David Daney
The EHCI and OHCI blocks connection to the I/O bus is controlled by these registers. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-usb@vger.kernel.org To: dbrownell@users.sourceforge.net Patchwork: http://patchwork.linux-mips.org/patch/1674/ Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> create mode 100644 arch/mips/include/asm/octeon/cvmx-uctlx-defs.h
2010-10-29MIPS: Octeon: Apply CN63XXP1 errata workarounds.David Daney
The CN63XXP1 needs a couple of workarounds to ensure memory is not written in unexpected ways. All PREF with hints in the range 0-4,6-24 are replaced with PREF 28. We pass a flag to the assembler to cover compiler generated code, and patch uasm for the dynamically generated code. The write buffer threshold is reduced to 4. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1672/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Use I/O clock rate for calculations.David Daney
The I2C and UARTS are clocked by the I/O clock, use its rate for these devices. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1670/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Add octeon_get_io_clock_rate() for cn63xxDavid Daney
Starting with cn63xx Octeon I/O blocks are clocked at a different rate than the CPU. Add a new function octeon_get_io_clock_rate() that yields the I/O clock rate. Also rearrange octeon_get_clock_rate() to get the value from the saved sysinfo structure. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1671/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Remove bogus code from octeon_get_clock_rate()David Daney
We can run with any simulator clock rate. Get rid of the code overriding it to 6MHz. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1669/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Scale Octeon2 clocks in octeon_init_cvmcount()David Daney
The per-CPU clocks are synchronized from IPD_CLK_COUNT, on cn63XX it must be scaled by the clock frequency ratio. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1667/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Enable Read Inhibit / eXecute Inhibit on Octeon II.David Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1666/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Probe for Octeon II CPUs.David Daney
The OCTEON II ISA extends the original OCTEON ISA, so give it its own __elf_platform string so optimized libraries can be selected in userspace. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1665/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Handle Octeon II caches.David Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1664/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Add identifiers for Octeon II CPUs.David Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1662/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Update L2 Cache code for CN63XXDavid Daney
The CN63XX has a different L2 cache architecture. Update the helper functions to reflect this. Some joining of split lines was also done to improve readability, as well as reformatting of comments. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1663/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Add cn63XX to Octeon chip detection macros.David Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1661/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Update register definitions for CN63XX chipsDavid Daney
The CN63XX is a new 6-CPU SOC based on the new OCTEON II CPU cores. Join some lines back together. This makes some of them exceed 80 columns, but they are uninteresting and this unclutters things. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1668/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Rewrite DMA mapping functions.David Daney
All Octeon chips can support more than 4GB of RAM. Also due to how Octeon PCI is setup, even some configurations with less than 4GB of RAM will have portions that are not accessible from 32-bit devices. Enable the swiotlb code to handle the cases where a device cannot directly do DMA. This is a complete rewrite of the Octeon DMA mapping code. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1639/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Add a platform hook for swiotlb setup.David Daney
This allows platforms that are using the swiotlb to initialize it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1638/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Convert DMA to use dma-mapping-common.hDavid Daney
Use asm-generic/dma-mapping-common.h to handle all DMA mapping operations and establish a default get_dma_ops() that forwards all operations to the existing code. Augment dev_archdata to carry a pointer to the struct dma_map_ops, allowing DMA operations to be overridden on a per device basis. Currently this is never filled in, so the default dma_map_ops are used. A follow-on patch sets this for Octeon PCI devices. Also initialize the dma_debug system as it is now used if it is configured. Includes fixes by Kevin Cernekee <cernekee@gmail.com>. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1637/ Patchwork: http://patchwork.linux-mips.org/patch/1678/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: ip32, ip27, jazz: Make static functions in dma-coherence.h inline.David Daney
Any function defined in a header file should be inline. This helps us avoid 'unused' compiler warnings when we include the files in more places in subsequent patches. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1636/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Select ZONE_DMA32David Daney
Give us a nice place to allocate coherent DMA memory for 32-bit devices. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1635/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Adjust top of DMA32 zone.David Daney
On OCTEON, we reserve the last 256MB of 32-bit PCI address space, mapping the RAM in this region at a high DMA address. This makes memory in this region unavailable for 32-bit DMA. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1634/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Allow MAX_DMA32_PFN to be overridden.David Daney
DMA mapping may reduce the usable physical address range usable for 32-bit DMA. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1633/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Octeon: Set dma_masks for octeon_mgmt device.David Daney
This allows follow-on patches to dma mapping functions to work with the octeon mgmt device.. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1632/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: IRQ: Add stackoverflow detectionFrom: jiang.adam@gmail.com
Add stackoverflow detection to mips arch Signed-off-by: Adam Jiang <jiang.adam@gmail.com> Cc: dmitri.vorobiev@movial.com Cc: wuzhangjin@gmail.com Cc: ddaney@caviumnetworks.com Cc: peterz@infradead.org Cc: fweisbec@gmail.com Cc: tj@kernel.org Cc: tglx@linutronix.de Cc: mingo@elte.hu Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1559/ Patchwork: https://patchwork.linux-mips.org/patch/1651/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Kconfig cleanupThomas Gleixner
arch/mips/Kconfig already sets GENERIC_HARDIRQS_NO__DO_IRQ unconditionally. Remove the redundant select from the Loongson Kconfig. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Remove wait argument of r4k_on_each_cpuRalf Baechle
All callers were passing in 1 anyway. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: More detailed description of r4k_on_each_cpuRalf Baechle
2010-10-29MIPS: Get rid of branches to .subsections.Ralf Baechle
It was a nice optimization - on paper at least. In practice it results in branches that may exceed the maximum legal range for a branch. We can fight that problem with -ffunction-sections but -ffunction-sections again is incompatible with -pg used by the function tracer. By rewriting the loop around all simple LL/SC blocks to C we reduce the amount of inline assembler and at the same time allow GCC to often fill the branch delay slots with something sensible or whatever else clever optimization it may have up in its sleeve. With this optimization gone we also no longer need -ffunction-sections, so drop it. This optimization was originally introduced in 2.6.21, commit 5999eca25c1fd4b9b9aca7833b04d10fe4bc877d (linux-mips.org) rsp. f65e4fa8e0c6022ad58dc88d1b11b12589ed7f9f (kernel.org). Original fix for the issues which caused me to pull this optimization by Paul Gortmaker <paul.gortmaker@windriver.com>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-27mips: remove dma64_addr_t usageFUJITA Tomonori
dma64_addr_t looks pointless (at least there is no point that an architecture has the own dma64_addr_t typedef). dma_addr_t is set to 32 or 64 bits appropriately. You can use u64 at places where you know that 64 bit address is always necessary. Let's use u64 instead for mips. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: cleanup arch_ptrace() on MIPSNamhyung Kim
Use new 'addrp', 'datavp' and 'datalp' variables in order to remove unnecessary castings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27mm: fix race in kunmap_atomic()Peter Zijlstra
Christoph reported a nice splat which illustrated a race in the new stack based kmap_atomic implementation. The problem is that we pop our stack slot before we're completely done resetting its state -- in particular clearing the PTE (sometimes that's CONFIG_DEBUG_HIGHMEM). If an interrupt happens before we actually clear the PTE used for the last slot, that interrupt can reuse the slot in a dirty state, which triggers a BUG in kmap_atomic(). Fix this by introducing kmap_atomic_idx() which reports the current slot index without actually releasing it and use that to find the PTE and delay the _pop() until after we're completely done. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Christoph Hellwig <hch@infradead.org> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: stack based kmap_atomic()Peter Zijlstra
Keep the current interface but ignore the KM_type and use a stack based approach. The advantage is that we get rid of crappy code like: #define __KM_PTE \ (in_nmi() ? KM_NMI_PTE : \ in_irq() ? KM_IRQ_PTE : \ KM_PTE0) and in general can stop worrying about what context we're in and what kmap slots might be appropriate for that. The downside is that FRV kmap_atomic() gets more expensive. For now we use a CPP trick suggested by Andrew: #define kmap_atomic(page, args...) __kmap_atomic(page) to avoid having to touch all kmap_atomic() users in a single patch. [ not compiled on: - mn10300: the arch doesn't actually build with highmem to begin with ] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
