path: root/arch/mips
2011-12-05Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix loss of notification with multi-event perf, x86: Force IBS LVT offset assignment for family 10h perf, x86: Disable PEBS on SandyBridge chips trace_events_filter: Use rcu_assign_pointer() when setting ftrace_event_call->filter perf session: Fix crash with invalid CPU list perf python: Fix undefined symbol problem perf/x86: Enable raw event access to Intel offcore events perf: Don't use -ENOSPC for out of PMU resources perf: Do not set task_ctx pointer in cpuctx if there are no events in the context perf/x86: Fix PEBS instruction unwind oprofile, x86: Fix crash when unloading module (nmi timer mode) oprofile: Fix crash when unloading module (hr timer mode)
2011-11-15Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: lantiq: use export.h in favour of module.h MAINTAINERS: The MIPS git tree has moved. MIPS: Fix build error due to missing inclusion of <linux/export.h>. MIPS: ASID conflict after CPU hotplug MIPS: Octeon: Fix compile error in arch/mips/cavium-octeon/flash_setup.c MIPS: errloongson2_clock: Fix build error by including linux/module.h STAGING: octeon-ethernet: Fix compile error caused by skb_frag_struct change MIPS: Hook up process_vm_readv and process_vm_writev system calls. MIPS: Kernel hangs occasionally during boot. MIPS: Octeon: Mark SMP-IPI interrupt as IRQF_NO_THREAD MIPS: BCM47xx: fix build with GENERIC_GPIO configuration MIPS: NXP: Remove unused source files. MIPS: Yosemite, Emma: Fix off-by-two in arcs_cmdline buffer size check
2011-11-14MIPS: lantiq: use export.h in favour of module.hJohn Crispin
The code located at arch/mips/lantiq/ included module.h to be able to use the EXPORT_SYMBOL* macros. These can now be directly included using export.h. Signed-off-by: John Crispin <blogic@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2937/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-14perf: Don't use -ENOSPC for out of PMU resourcesPeter Zijlstra
People (Linus) objected to using -ENOSPC to signal not having enough resources on the PMU to satisfy the request. Use -EINVAL. Requested-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Stephane Eranian <eranian@google.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: David Daney <david.daney@cavium.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-xv8geaz2zpbjhlx0svmpp28n@git.kernel.org [ merged to newer kernel, fixed up MIPS impact ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-11MIPS: Fix build error due to missing inclusion of <linux/export.h>.Ralf Baechle
2011-11-10MIPS: ASID conflict after CPU hotplugMaksim Rayskiy
I am running SMP Linux 2.6.37-rc1 on BMIPS5000 (single core dual thread) and observe some abnormalities when doing system suspend/resume which I narrowed down to cpu hotplugging. The suspend brings the second thread processor down and then restarts it, after which I see memory corruption in userspace. I started digging and found out that problem occurs because while doing execve() the child process is getting the same ASID as the parent, which obviously corrupts parent's address space. Further digging showed that activate_mm() calls get_new_mmu_context() to get a new ASID, but at this time ASID field in entryHi is 1, and asid_cache(cpu) is 0x100 (it was just reset to ASID_FIRST_VERSION when the secondary TP was booting). So, get_new_mmu_context() increments the asid_cache(cpu) value to 0x101, and thus puts 0x01 into entryHi. The result - ASID field does not get changed as it was supposed to. My solution is very simple - do not reset asid_cache(cpu) on TP warm restart. Patchwork: https://patchwork.linux-mips.org/patch/1797/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-10MIPS: Octeon: Fix compile error in arch/mips/cavium-octeon/flash_setup.cDavid Daney
The parse_mtd_partitions() and mtd_device_register() functions were combined into mtd_device_parse_register(). So call that instead. Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2923/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-10MIPS: errloongson2_clock: Fix build error by including linux/module.hAaro Koskinen
Fix the following compilation failure with v3.2-rc1 by including module.h: CC [M] arch/mips/kernel/cpufreq/loongson2_clock.o arch/mips/kernel/cpufreq/loongson2_clock.c:39:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:39:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:39:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:51:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:51:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:51:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:71:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:71:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:71:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:76:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:76:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:76:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:82:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:82:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:82:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:87:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:87:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:87:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:93:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:93:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:93:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:131:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:131:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:131:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:147:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:147:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:147:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:166:1: error: data definition has no type or storage class [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:166:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL' [-Werror=implicit-int] arch/mips/kernel/cpufreq/loongson2_clock.c:166:1: error: parameter names (without types) in function declaration [-Werror] arch/mips/kernel/cpufreq/loongson2_clock.c:168:15: error: expected declaration specifiers or '...' before string constant arch/mips/kernel/cpufreq/loongson2_clock.c:169:20: error: expected declaration specifiers or '...' before string constant arch/mips/kernel/cpufreq/loongson2_clock.c:170:16: error: expected declaration specifiers or '...' before string constant Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2922/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-09kbuild: Fix missing system calls check on mips.David Daney
Commit 5f7efb4 (Kbuild: append missing-syscalls to the default target list) broke MIPS build. Reported-tested-and-acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-11-09MIPS: Hook up process_vm_readv and process_vm_writev system calls.David Daney
Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2918/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-08MIPS: Kernel hangs occasionally during boot.Al Cooper
The Kernel hangs occasionally during boot after "Calibrating delay loop..". This is caused by the c0_compare_int_usable() routine in cevt-r4k.c returning false which causes the system to disable the timer and hang later. The false return happens because the routine is using a series of four calls to irq_disable_hazard() as a delay while it waits for the timer changes to propagate to the cp0 cause register. On newer MIPS cores, like the 74K, the series of irq_disable_hazard() calls turn into ehb instructions and can take as little as a few clock ticks for all 4 instructions. This is not enough of a delay, so the routine thinks the timer is not working. This fix uses up to a max number of cycle counter ticks for the delay and uses back_to_back_c0_hazard() instead of irq_disable_hazard() to handle the hazard condition between cp0 writes and cp0 reads. Signed-off-by: Al Cooper <alcooperx@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2911/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-08MIPS: Octeon: Mark SMP-IPI interrupt as IRQF_NO_THREADVenkat Subbiah
This is to exclude it from force threading to allow RT patch set to work. And while on this line * Remove IRQF_DISABLED as as this flag is NOOP * Add IRQF_PERCPU as this is a per cpu interrupt. Signed-off-by: Venkat Subbiah <venkat.subbiah@cavium.com> Acked-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org To: linux-rt-users@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2817/ Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-08MIPS: BCM47xx: fix build with GENERIC_GPIO configurationFlorian Fainelli
Since eb9ae7f2 (gpio: fix build error in include/asm-generic/gpio.h) the generic version of gpio.h calls __gpio_{set,get}_value which we do not define. Get rid of asm-generic/gpio.h and define the missing stubs directly for BCM47xx to build. Reported-by: Ralf Baechle <ralf@linux-mips.org> To: linux-mips@linux-mips.org CC: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: https://patchwork.linux-mips.org/patch/2885/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-08MIPS: NXP: Remove unused source files.Ralf Baechle
The NXP code was moved for 2.6.36 but two files survived unused in the old location. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-08MIPS: Yosemite, Emma: Fix off-by-two in arcs_cmdline buffer size checkThomas Jarosch
Cause is a misplaced bracket. The code strlen(buf+1) will be two bytes less than strlen(buf)+1 The +1 is in this code to reserve space for an additional space character. [ralf@linux-mips.org: Thomas' original patch fixed the issue only for Yosemite but the same bug exists also in Emma.] Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Patchwork: https://patchwork.linux-mips.org/patch/2861/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-06Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scsi: drop unused Kconfig symbol pci: drop unused Kconfig symbol stmmac: drop unused Kconfig symbol x86: drop unused Kconfig symbol powerpc: drop unused Kconfig symbols powerpc: 40x: drop unused Kconfig symbol mips: drop unused Kconfig symbols openrisc: drop unused Kconfig symbols arm: at91: drop unused Kconfig symbol samples: drop unused Kconfig symbol m32r: drop unused Kconfig symbol score: drop unused Kconfig symbols sh: drop unused Kconfig symbol um: drop unused Kconfig symbol sparc: drop unused Kconfig symbol alpha: drop unused Kconfig symbol Fix up trivial conflict in drivers/net/ethernet/stmicro/stmmac/Kconfig as per Michal: the STMMAC_DUAL_MAC config variable is still unused and should be deleted.
2011-11-03Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits) MIPS: O32: Provide definition of registers ta0 .. ta3. MIPS: perf: Add Octeon support for hardware perf. MIPS: perf: Add support for 64-bit perf counters. MIPS: perf: Reorganize contents of perf support files. MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c MIPS: Add accessor macros for 64-bit performance counter registers. MIPS: Add probes for more Octeon II CPUs. MIPS: Add more CPU identifiers for Octeon II CPUs. MIPS: XLR, XLS: Add comment for smp setup MIPS: JZ4740: GPIO: Check correct IRQ in demux handler MIPS: JZ4740: GPIO: Simplify IRQ demuxer MIPS: JZ4740: Use generic irq chip MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines MIPS: Alchemy: kill au1xxx.h header MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep MIPS: Alchemy: Redo PCI as platform driver MIPS: Alchemy: more base address cleanup MIPS: Alchemy: rewrite USB platform setup. MIPS: Alchemy: abstract USB block control register access ... Fix up trivial conflicts in: arch/mips/alchemy/devboards/db1x00/platform.c drivers/ide/Kconfig drivers/mmc/host/au1xmmc.c drivers/video/Kconfig sound/mips/Kconfig
2011-11-01Merge branch 'for-linus/i2c-3.2' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/i2c-3.2' of git://git.fluff.org/bjdooks/linux: (47 commits) i2c-s3c2410: Add device tree support i2c-s3c2410: Keep a copy of platform data and use it i2c-nomadik: cosmetic coding style corrections i2c-au1550: dev_pm_ops conversion i2c-au1550: increase timeout waiting for master done i2c-au1550: remove unused ack_timeout i2c-au1550: remove usage of volatile keyword i2c-tegra: __iomem annotation fix i2c-eg20t: Add initialize processing in case i2c-error occurs i2c-eg20t: Fix flag setting issue i2c-eg20t: add stop sequence in case wait-event timeout occurs i2c-eg20t: Separate error processing i2c-eg20t: Fix 10bit access issue i2c-eg20t: Modify returned value s32 to long i2c-eg20t: Fix bus-idle waiting issue i2c-designware: Fix PCI core warning on suspend/resume i2c-designware: Add runtime power management support i2c-designware: Add support for Designware core behind PCI devices. i2c-designware: Push all register reads/writes into the core code. i2c-designware: Support multiple cores using same ISR ...
2011-10-31mips: add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Or else we get lots of variations on this: arch/mips/pci/pci.c:330: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' scattered throughout the build. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: remove needless include of module.h from core kernel files.Paul Gortmaker
None of these files are using modular infrastructure, and build tests reveal that none of these files are really relying on any implicit inclusions via. module.h either. So delete them. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: migrate core kernel file from module.h --> export.hPaul Gortmaker
These files are not modules, but were including module.h only for EXPORT_SYMBOL and/or THIS_MODULE. Now that we have the lightweight export.h, use it in these kinds of cases. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: fix implicit smp.h usage in various files.Paul Gortmaker
We need to call out inclusion of smp.h, or with the module.h cleanup we'll get things like: arch/mips/loongson/common/platform.c:21: error: implicit declaration of function 'smp_processor_id' arch/mips/vr41xx/common/giu.c:84: error: implicit declaration of function 'smp_processor_id' arch/mips/vr41xx/common/rtc.c:85: error: implicit declaration of function 'smp_processor_id' Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: fix implicit use of asm/elf.h in kernel/cpu-probe.cPaul Gortmaker
We are relying on asm/elf.h being present implicitly. Once we clean up the root cause of that, we'll see this, so fix it in advance. arch/mips/kernel/cpu-probe.c: In function 'set_elf_platform': arch/mips/kernel/cpu-probe.c:298: error: '__elf_platform' undeclared (first use in this function) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: drop unused Kconfig symbolsPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-10-29i2c-au1550: remove usage of volatile keywordManuel Lauss
Replace the usage of "volatile"s with register accessor functions. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (549 commits) ALSA: hda - Fix ADC input-amp handling for Cx20549 codec ALSA: hda - Keep EAPD turned on for old Conexant chips ALSA: hda/realtek - Fix missing volume controls with ALC260 ASoC: wm8940: Properly set codec->dapm.bias_level ALSA: hda - Fix pin-config for ASUS W90V ALSA: hda - Fix surround/CLFE headphone and speaker pins order ALSA: hda - Fix typo ALSA: Update the sound git tree URL ALSA: HDA: Add new revision for ALC662 ASoC: max98095: Convert codec->hw_write to snd_soc_write ASoC: keep pointer to resource so it can be freed ASoC: sgtl5000: Fix wrong mask in some snd_soc_update_bits calls ASoC: wm8996: Fix wrong mask for setting WM8996_AIF_CLOCKING_2 ASoC: da7210: Add support for line out and DAC ASoC: da7210: Add support for DAPM ALSA: hda/realtek - Fix DAC assignments of multiple speakers ASoC: Use SGTL5000_LINREG_VDDD_MASK instead of hardcoded mask value ASoC: Set sgtl5000->ldo in ldo_regulator_register ASoC: wm8996: Use SND_SOC_DAPM_AIF_OUT for AIF2 Capture ASoC: wm8994: Use SND_SOC_DAPM_AIF_OUT for AIF3 Capture ...
2011-10-28Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue: (21 commits) leases: fix write-open/read-lease race nfs: drop unnecessary locking in llseek ext4: replace cut'n'pasted llseek code with generic_file_llseek_size vfs: add generic_file_llseek_size vfs: do (nearly) lockless generic_file_llseek direct-io: merge direct_io_walker into __blockdev_direct_IO direct-io: inline the complete submission path direct-io: separate map_bh from dio direct-io: use a slab cache for struct dio direct-io: rearrange fields in dio/dio_submit to avoid holes direct-io: fix a wrong comment direct-io: separate fields only used in the submission path from struct dio vfs: fix spinning prevention in prune_icache_sb vfs: add a comment to inode_permission() vfs: pass all mask flags check_acl and posix_acl_permission vfs: add hex format for MAY_* flag values vfs: indicate that the permission functions take all the MAY_* flags compat: sync compat_stats with statfs. vfs: add "device" tag to /proc/self/mountstats cleanup: vfs: small comment fix for block_invalidatepage ... Fix up trivial conflict in fs/gfs2/file.c (llseek changes)
2011-10-28compat: sync compat_stats with statfs.Eric W. Biederman
This was found by inspection while tracking a similar bug in compat_statfs64, that has been fixed in mainline since decemeber. - This fixes a bug where not all of the f_spare fields were cleared on mips and s390. - Add the f_flags field to struct compat_statfs - Copy f_flags to userspace in case someone cares. - Use __clear_user to copy the f_spare field to userspace to ensure that all of the elements of f_spare are cleared. On some architectures f_spare is has 5 ints and on some architectures f_spare only has 4 ints. Which makes the previous technique of clearing each int individually broken. I don't expect anyone actually uses the old statfs system call anymore but if they do let them benefit from having the compat and the native version working the same. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-10-26Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (79 commits) TTY: serial_core: Fix crash if DCD drop during suspend tty/serial: atmel_serial: bootconsole removed from auto-enumerates Revert "TTY: call tty_driver_lookup_tty unconditionally" tty/serial: atmel_serial: add device tree support tty/serial: atmel_serial: auto-enumerate ports tty/serial: atmel_serial: whitespace and braces modifications tty/serial: atmel_serial: change platform_data variable name tty/serial: RS485 bindings for device tree TTY: call tty_driver_lookup_tty unconditionally TTY: pty, release tty in all ptmx_open fail paths TTY: make tty_add_file non-failing TTY: drop driver reference in tty_open fail path 8250_pci: Fix kernel panic when pch_uart is disabled h8300: drivers/serial/Kconfig was moved parport_pc: release IO region properly if unsupported ITE887x card is found tty: Support compat_ioctl get/set termios_locked hvc_console: display printk messages on console. TTY: snyclinkmp: forever loop in tx_load_dma_buffer() tty/n_gsm: avoid fifo overflow in gsm_dlci_data_output tty/n_gsm: fix a bug in gsm_dlci_data_output (adaption = 2 case) ... Fix up Conflicts in: - drivers/tty/serial/8250_pci.c Trivial conflict with removed duplicate device ID - drivers/tty/serial/atmel_serial.c Annoying silly conflict between "specify the port num via platform_data" and other changes to atmel_console_init
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
2011-10-24MIPS: O32: Provide definition of registers ta0 .. ta3.Ralf Baechle
Later IRIX versions provide them in <sys/regdef.h> and gas also accepts $ta0 .. $ta3 since binutils 2.18 so Linux should do the same for source compatibility.
2011-10-24MIPS: perf: Add Octeon support for hardware perf.David Daney
Enable hardware counters for Octeon, and add the corresponding event mappings. Signed-off-by: David Daney <david.daney@cavium.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2790/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: perf: Add support for 64-bit perf counters.David Daney
The hard coded constants are moved to struct mips_pmu. All counter register access move to the read_counter and write_counter function pointers, which are set to either 32-bit or 64-bit access methods at initialization time. Many of the function pointers in struct mips_pmu were not needed as there was only a single implementation, these were removed. I couldn't figure out what made struct cpu_hw_events.msbs[] at all useful, so I removed it too. Some functions and other declarations were reordered to reduce the need for forward declarations. Signed-off-by: David Daney <david.daney@cavium.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2792/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: perf: Reorganize contents of perf support files.David Daney
The contents of arch/mips/kernel/perf_event.c and arch/mips/kernel/perf_event_mipsxx.c were divided in a seemingly ad hoc manner, with the first including the second. I moved all the hardware counter support code to perf_event_mipsxx.c and removed the gating #ifdefs to the Kconfig and Makefile. Now perf_event.c contains only the callchain support, everything else is in perf_event_mipsxx.c There are no code changes, only moving of functions from one file to the other, or removing empty unneeded functions. Signed-off-by: David Daney <david.daney@cavium.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Dezhong Diao <dediao@cisco.com> Cc: Gabor Juhos <juhosg@openwrt.org> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2791/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.cDavid Daney
Get rid of a bunch of useless inline declarations, and join a bunch of improperly split lines. Signed-off-by: David Daney <david.daney@cavium.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2793/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: Add accessor macros for 64-bit performance counter registers.David Daney
Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2789/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: Add probes for more Octeon II CPUs.David Daney
Detect cn61XX, cn66XX and cn68XX CPUs in cpu_probe_cavium(). Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2777/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: Add more CPU identifiers for Octeon II CPUs.David Daney
The CPU identifiers for cn68XX, cn66XX and cn61XX are known, so add them. Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2776/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: XLR, XLS: Add comment for smp setupHillf Danton
It seems that BSP could be setup twice, but the nlm_cpu_ready array is only set for ASPs in smpboot.S, not including BSP. Signed-off-by: Hillf Danton <dhillf@gmail.com> Cc: "Jayachandran C." <jayachandranc@netlogicmicro.com> Cc: LKML <linux-kernel@vger.kernel.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2695/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>,
2011-10-24MIPS: JZ4740: GPIO: Check correct IRQ in demux handlerLars-Peter Clausen
Check the trigger direction for the triggered IRQ instead of the parent IRQ. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: http://patchwork.linux-mips.org/patch/2433/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: JZ4740: GPIO: Simplify IRQ demuxerLars-Peter Clausen
We already know the base IRQ for a GPIO chip, so there is no need to recalculate it in the demux handler. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: Lars-Peter Clausen <lars@metafoo.de> Patchwork: http://patchwork.linux-mips.org/patch/2432/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: JZ4740: Use generic irq chipLars-Peter Clausen
Use the generic irq chip framework to implement the jz4740 INTC and GPIO irq chips. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2434/ Patchwork: https://patchwork.linux-mips.org/patch/2771/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: Alchemy: remove all CONFIG_SOC_AU1??? definesManuel Lauss
Now that no driver any longer depends on the CONFIG_SOC_AU1??? symbols, it's time to get rid of them: Move some of the platform devices to the boards which can use them, Rename a few (unused) constants in the header, Replace them with MIPS_ALCHEMY in the various Kconfig files. Finally delete them altogether from the Alchemy Kconfig file. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2707/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: Alchemy: kill au1xxx.h headerManuel Lauss
No longer required Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2705/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> delete mode 100644 arch/mips/include/asm/mach-au1x00/au1xxx.h
2011-10-24MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? definesManuel Lauss
This patch gets rid of all CONFIG_SOC_AU1XXX defines in DMA/DBDMA-related code. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2704/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header depManuel Lauss
au1xxx-ide uses defines from the pb1200/db1200 headers: get DBDMA ID through platform resource information, hardcode register spacing. The only 2 users of this driver (and the only boards it can really work on realiably) use the same register layout. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: linux-ide@vger.kernel.org To: Linux-MIPS <linux-mips@linux-mips.org> Cc: linux-ide@vger.kernel.org Acked-by: David S. Miller <davem@davemloft.net> Patchwork: https://patchwork.linux-mips.org/patch/2716/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: Alchemy: Redo PCI as platform driverManuel Lauss
- Rewrite Alchemy PCI support as a platform driver. - Fixup boards which have PCI. Run-tested on DB1500 and DB1550. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2706/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> delete mode 100644 arch/mips/alchemy/common/pci.c delete mode 100644 arch/mips/pci/fixup-au1000.c delete mode 100644 arch/mips/pci/ops-au1000.c create mode 100644 arch/mips/pci/pci-alchemy.c
2011-10-24MIPS: Alchemy: more base address cleanupManuel Lauss
remove all redundant peripheral base address defines, fix all affected boards and drivers. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2700/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
