path: root/arch/mips
2013-09-26MIPS: ath79: Fix ar933x watchdog clockFelix Fietkau
commit a1191927ace7e6f827132aa9e062779eb3f11fa5 upstream. The watchdog device on the AR933x is connected to the AHB clock, however the current code uses the reference clock. Due to the wrong rate, the watchdog driver can't calculate correct register values for a given timeout value and the watchdog unexpectedly restarts the system. The code uses the wrong value since the initial commit 04225e1d227c8e68d685936ecf42ac175fec0e54 (MIPS: ath79: add AR933X specific clock init) The patch fixes the code to use the correct clock rate to avoid the problem. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5777/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20MIPS: Rewrite pfn_valid to work in modules, too.Ralf Baechle
Upstream commit 8b9232141bf40788cce31f893c13f344ec31ee66. This fixes: MODPOST 393 modules ERROR: "min_low_pfn" [arch/mips/kvm/kvm.ko] undefined! make[3]: *** [__modpost] Error 1 It would have been possible to just export min_low_pfn but in the end pfn_valid should return 1 for any pfn argument for which a struct page exists so using min_low_pfn was wrong anyway. [Backport to 3.4 kernel. Applies cleanly on top of current 3.4 patch queue, and fixes "make ARCH=mips allmodconfig; make ARCH=mips" build problem. - Guenter] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20MIPS: Expose missing pci_io{map,unmap} declarationsMarkos Chandras
commit 78857614104a26cdada4c53eea104752042bf5a1 upstream. The GENERIC_PCI_IOMAP does not depend on CONFIG_PCI so move it to the CONFIG_MIPS symbol so it's always selected for MIPS. This fixes the missing pci_iomap declaration for MIPS. Moreover, the pci_iounmap function was not defined in the io.h header file if the CONFIG_PCI symbol is not set, but it should since MIPS is not using CONFIG_GENERIC_IOMAP. This fixes the following problem on a allyesconfig: drivers/net/ethernet/3com/3c59x.c:1031:2: error: implicit declaration of function 'pci_iomap' [-Werror=implicit-function-declaration] drivers/net/ethernet/3com/3c59x.c:1044:3: error: implicit declaration of function 'pci_iounmap' [-Werror=implicit-function-declaration] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Acked-by: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5478/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17MIPS: Fix poweroff failure when HOTPLUG_CPU configured.Huacai Chen
commit 8add1ecb81f541ef2fcb0b85a5470ad9ecfb4a84 upstream. When poweroff machine, kernel_power_off() call disable_nonboot_cpus(). And if we have HOTPLUG_CPU configured, disable_nonboot_cpus() is not an empty function but attempt to actually disable the nonboot cpus. Since system state is SYSTEM_POWER_OFF, play_dead() won't be called and thus disable_nonboot_cpus() hangs. Therefore, we make this patch to avoid poweroff failure. Signed-off-by: Huacai Chen <chenhc@lemote.com> Signed-off-by: Hongliang Tao <taohl@lemote.com> Signed-off-by: Hua Yan <yanh@lemote.com> Cc: Yong Zhang <yong.zhang@windriver.com> Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/4211/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21mips,kgdb: fix recursive page fault with CONFIG_KPROBESJason Wessel
commit f0a996eeeda214f4293e234df33b29bec003b536 upstream. This fault was detected using the kgdb test suite on boot and it crashes recursively due to the fact that CONFIG_KPROBES on mips adds an extra die notifier in the page fault handler. The crash signature looks like this: kgdbts:RUN bad memory access test KGDB: re-enter exception: ALL breakpoints killed Call Trace: [<807b7548>] dump_stack+0x20/0x54 [<807b7548>] dump_stack+0x20/0x54 The fix for now is to have kgdb return immediately if the fault type is DIE_PAGE_FAULT and allow the kprobe code to decide what is supposed to happen. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13kbuild: Fix gcc -x syntaxJean Delvare
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream. The correct syntax for gcc -x is "gcc -x assembler", not "gcc -xassembler". Even though the latter happens to work, the former is what is documented in the manual page and thus what gcc wrappers such as icecream do expect. This isn't a cosmetic change. The missing space prevents icecream from recognizing compilation tasks it can't handle, leading to silent kernel miscompilations. Besides me, credits go to Michael Matz and Dirk Mueller for investigating the miscompilation issue and tracking it down to this incorrect -x parameter syntax. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02MIPS: mm: Add compound tail page _mapcount when mappedJovi Zhang
commit af89fa3986b9d034a286544ab1ed95096496a2f9 upstream. See commit b6999b191 which did the same modification for x86's mm/gup, Quote from commit b6999b191: "If compound pages are used and the page is a tail page, gup_huge_pmd() increases _mapcount to record tail page are mapped while gup_huge_pud does not do that." [ralf@linux-mips.org: fixed rejects caused by the original patch getting linewrapped.] Signed-off-by: Jovi Zhang <boojovi@gmail.com> Cc: Youquan Song <youquan.song@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Patchwork: https://patchwork.linux-mips.org/patch/4291/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09posix_types.h: Cleanup stale __NFDBITS and related definitionsJosh Boyer
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream. Recently, glibc made a change to suppress sign-conversion warnings in FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the kernel's definition of __NFDBITS if applications #include <linux/types.h> after including <sys/select.h>. A build failure would be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2 flags to gcc. It was suggested that the kernel should either match the glibc definition of __NFDBITS or remove that entirely. The current in-kernel uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no uses of the related __FDELT and __FDMASK defines. Given that, we'll continue the cleanup that was started with commit 8b3d1cda4f5f ("posix_types: Remove fd_set macros") and drop the remaining unused macros. Additionally, linux/time.h has similar macros defined that expand to nothing so we'll remove those at the same time. Reported-by: Jeff Law <law@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> [ .. and fix up whitespace as per akpm ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-29MIPS: Properly align the .data..init_task section.David Daney
commit 7b1c0d26a8e272787f0f9fcc5f3e8531df3b3409 upstream. Improper alignment can lead to unbootable systems and/or random crashes. [ralf@linux-mips.org: This is a lond standing bug since 6eb10bc9e2deab06630261cd05c4cb1e9a60e980 (kernel.org) rsp. c422a10917f75fd19fa7fe070aaaa23e384dae6f (lmo) [MIPS: Clean up linker script using new linker script macros.] so dates back to 2.6.32.] Signed-off-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3881/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10MIPS: BCM63XX: Add missing include for bcm63xx_gpio.hJonas Gorski
commit 442209f31dafef9fde852858e1ce566b675b720d upstream. bcm63xx_gpio.h uses macros defined in bcm63xx_cpu.h without including it, leading to the following build failure: CC [M] drivers/mmc/core/cd-gpio.o In file included from arch/mips/include/asm/mach-bcm63xx/gpio.h:4:0, from arch/mips/include/asm/gpio.h:4, from include/linux/gpio.h:30, from drivers/mmc/core/cd-gpio.c:12: arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h: In function 'bcm63xx_gpio_count': arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:10:2: error: implicit declaration of function 'bcm63xx_get_cpu_id' arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:11:7: error: 'BCM6358_CPU_ID' undeclared (first use in this function) arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:11:7: note: each undeclared identifier is reported only once for each function it appears in arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:13:7: error: 'BCM6338_CPU_ID' undeclared (first use in this function) arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:15:7: error: 'BCM6345_CPU_ID' undeclared (first use in this function) arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:17:7: error: 'BCM6368_CPU_ID' undeclared (first use in this function) arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:19:7: error: 'BCM6348_CPU_ID' undeclared (first use in this function) make[7]: *** [drivers/mmc/core/cd-gpio.o] Error 1 Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com> Cc: linux-mips@linux-mips.org Cc: Maxime Bizon <mbizon@freebox.fr> Cc: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27MIPS: Remove get_current_pgd().David Daney
It is unused in the tree. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3557/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-04-27MIPS: ath79: fix AR933X WMAC reset codeGabor Juhos
The current code puts the built-in WMAC device of the AR933X SoCs into reset instead of starting it. This causes a hard lock on AR933X based boards when the wireless driver tries to access the device. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: stable@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3484/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-04-27MIPS: JZ4740: Fix the JZ4740_IRQ_DMA macroAntony Pavlov
Signed-off-by: Antony Pavlov <antonynpavlov@gmail.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3459/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-04-27MIPS: Use set_current_blocked() and block_sigmask()Matt Fleming
As described in e6fa16ab ("signal: sigprocmask() should do retarget_shared_pending()") the modification of current->blocked is incorrect as we need to check whether the signal we're about to block is pending in the shared queue. Also, use the new helper function introduced in commit 5e6292c0f28f ("signal: add block_sigmask() for adding sigmask to current->blocked") which centralises the code for updating current->blocked after successfully delivering a signal and reduces the amount of duplicate code across architectures. In the past some architectures got this code wrong, so using this helper function should stop that from happening again. Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Signed-off-by: Matt Fleming <matt.fleming@intel.com> Patchwork: https://patchwork.linux-mips.org/patch/3363/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-04-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA mapping branch from Marek Szyprowski: "Short summary for the whole series: A few limitations have been identified in the current dma-mapping design and its implementations for various architectures. There exist more than one function for allocating and freeing the buffers: currently these 3 are used dma_{alloc, free}_coherent, dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent. For most of the systems these calls are almost equivalent and can be interchanged. For others, especially the truly non-coherent ones (like ARM), the difference can be easily noticed in overall driver performance. Sadly not all architectures provide implementations for all of them, so the drivers might need to be adapted and cannot be easily shared between different architectures. The provided patches unify all these functions and hide the differences under the already existing dma attributes concept. The thread with more references is available here: http://www.spinics.net/lists/linux-sh/msg09777.html These patches are also a prerequisite for unifying DMA-mapping implementation on ARM architecture with the common one provided by dma_map_ops structure and extending it with IOMMU support. More information is available in the following thread: http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819 More works on dma-mapping framework are planned, especially in the area of buffer sharing and managing the shared mappings (together with the recently introduced dma_buf interface: commit d15bd7ee445d "dma-buf: Introduce dma buffer sharing mechanism"). The patches in the current set introduce a new alloc/free methods (with support for memory attributes) in dma_map_ops structure, which will later replace dma_alloc_coherent and dma_alloc_writecombine functions." People finally started piping up with support for merging this, so I'm merging it as the last of the pending stuff from the merge window. Looks like pohmelfs is going to wait for 3.5 and more external support for merging. * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: common: DMA-mapping: add NON-CONSISTENT attribute common: DMA-mapping: add WRITE_COMBINE attribute common: dma-mapping: introduce mmap method common: dma-mapping: remove old alloc_coherent and free_coherent methods Hexagon: adapt for dma_map_ops changes Unicore32: adapt for dma_map_ops changes Microblaze: adapt for dma_map_ops changes SH: adapt for dma_map_ops changes Alpha: adapt for dma_map_ops changes SPARC: adapt for dma_map_ops changes PowerPC: adapt for dma_map_ops changes MIPS: adapt for dma_map_ops changes X86 & IA64: adapt for dma_map_ops changes common: dma-mapping: introduce generic alloc() and free() methods
2012-04-02Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Pull cpumask cleanups from Rusty Russell: "(Somehow forgot to send this out; it's been sitting in linux-next, and if you don't want it, it can sit there another cycle)" I'm a sucker for things that actually delete lines of code. Fix up trivial conflict in arch/arm/kernel/kprobes.c, where Rusty fixed a user of &cpu_online_map to be cpu_online_mask, but that code got deleted by commit b21d55e98ac2 ("ARM: 7332/1: extract out code patch function from kprobes"). * tag 'for-linus' of git://github.com/rustyrussell/linux: cpumask: remove old cpu_*_map. documentation: remove references to cpu_*_map. drivers/cpufreq/db8500-cpufreq: remove references to cpu_*_map. remove references to cpu_*_map in arch/
2012-03-30Merge tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6Linus Torvalds
Pull MTD changes from David Woodhouse: - Artem's cleanup of the MTD API continues apace. - Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst others. - More work on DiskOnChip G3, new driver for DiskOnChip G4. - Clean up debug/warning printks in JFFS2 to use pr_<level>. Fix up various trivial conflicts, largely due to changes in calling conventions for things like dmaengine_prep_slave_sg() (new inline wrapper to hide new parameter, clashing with rewrite of previously last parameter that used to be an 'append' flag, and is now a bitmap of 'unsigned long flags'). (Also some header file fallout - like so many merges this merge window - and silly conflicts with sparse fixes) * tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits) mtd: docg3 add protection against concurrency mtd: docg3 refactor cascade floors structure mtd: docg3 increase write/erase timeout mtd: docg3 fix inbound calculations mtd: nand: gpmi: fix function annotations mtd: phram: fix section mismatch for phram_setup mtd: unify initialization of erase_info->fail_addr mtd: support ONFI multi lun NAND mtd: sm_ftl: fix typo in major number. mtd: add device-tree support to spear_smi mtd: spear_smi: Remove default partition information from driver mtd: Add device-tree support to fsmc_nand mtd: fix section mismatch for doc_probe_device mtd: nand/fsmc: Remove sparse warnings and errors mtd: nand/fsmc: Add DMA support mtd: nand/fsmc: Access the NAND device word by word whenever possible mtd: nand/fsmc: Use dev_err to report error scenario mtd: nand/fsmc: Use devm routines mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform mtd: fsmc_nand: add pm callbacks to support hibernation ...
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull arch/tile (really asm-generic) update from Chris Metcalf: "These are a couple of asm-generic changes that apply to tile." * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: compat: use sys_sendfile64() implementation for sendfile syscall [PATCH v3] ipc: provide generic compat versions of IPC syscalls
2012-03-29Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 updates from Ingo Molnar. This touches some non-x86 files due to the sanitized INLINE_SPIN_UNLOCK config usage. Fixed up trivial conflicts due to just header include changes (removing headers due to cpu_idle() merge clashing with the <asm/system.h> split). * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/apic/amd: Be more verbose about LVT offset assignments x86, tls: Off by one limit check x86/ioapic: Add io_apic_ops driver layer to allow interception x86/olpc: Add debugfs interface for EC commands x86: Merge the x86_32 and x86_64 cpu_idle() functions x86/kconfig: Remove CONFIG_TR=y from the defconfigs x86: Stop recursive fault in print_context_stack after stack overflow x86/io_apic: Move and reenable irq only when CONFIG_GENERIC_PENDING_IRQ=y x86/apic: Add separate apic_id_valid() functions for selected apic drivers locking/kconfig: Simplify INLINE_SPIN_UNLOCK usage x86/kconfig: Update defconfigs x86: Fix excessive MSR print out when show_msr is not specified
2012-03-29documentation: remove references to cpu_*_map.Rusty Russell
This has been obsolescent for a while, fix documentation and misc comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-29remove references to cpu_*_map in arch/Rusty Russell
This has been obsolescent for a while; time for the final push. In adjacent context, replaced old cpus_* with cpumask_*. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net> (arch/sparc) Acked-by: Chris Metcalf <cmetcalf@tilera.com> (arch/tile) Cc: user-mode-linux-devel@lists.sourceforge.net Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: sparclinux@vger.kernel.org
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Delete all instances of asm/system.hDavid Howells
Delete all instances of asm/system.h as they should be redundant by this point. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2012-03-28MIPS: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core MIPS architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> [added missing changes to arch/mips/cavium-octeon/dma-octeon.c, fixed attrs argument in dma-mapping.h] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-03-27mtd: do not use plain 0 as NULLArtem Bityutskiy
The first 3 arguments of 'mtd_device_parse_register()' are pointers, but many callers pass '0' instead of 'NULL'. Fix this globally. Thanks to coccinelle for making it easy to do with the following semantic patch: @@ expression mtd, types, parser_data, parts, nr_parts; @@ ( -mtd_device_parse_register(mtd, 0, parser_data, parts, nr_parts) +mtd_device_parse_register(mtd, NULL, parser_data, parts, nr_parts) | -mtd_device_parse_register(mtd, types, 0, parts, nr_parts) +mtd_device_parse_register(mtd, types, NULL, parts, nr_parts) | -mtd_device_parse_register(mtd, types, parser_data, 0, nr_parts) +mtd_device_parse_register(mtd, types, parser_data, NULL, nr_parts) ) Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-24Merge tag 'bug-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/bug.h> cleanup from Paul Gortmaker: "The changes shown here are to unify linux's BUG support under the one <linux/bug.h> file. Due to historical reasons, we have some BUG code in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in linux/kernel.h predates the addition of linux/bug.h, but old code in kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h was including <asm/bug.h> to pseudo link them. This has caused confusion[1] and general yuck/WTF[2] reactions. Here is an example that violates the principle of least surprise: CC lib/string.o lib/string.c: In function 'strlcat': lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON' make[2]: *** [lib/string.o] Error 1 $ $ grep linux/bug.h lib/string.c #include <linux/bug.h> $ We've included <linux/bug.h> for the BUG infrastructure and yet we still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh - very confusing for someone who is new to kernel development. With the above in mind, the goals of this changeset are: 1) find and fix any include/*.h files that were relying on the implicit presence of BUG code. 2) find and fix any C files that were consuming kernel.h and hence relying on implicitly getting some/all BUG code. 3) Move the BUG related code living in kernel.h to <linux/bug.h> 4) remove the asm/bug.h from kernel.h to finally break the chain. During development, the order was more like 3-4, build-test, 1-2. But to ensure that git history for bisect doesn't get needless build failures introduced, the commits have been reorderd to fix the problem areas in advance. [1] https://lkml.org/lkml/2012/1/3/90 [2] https://lkml.org/lkml/2012/1/17/414" Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul and linux-next. * tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: kernel.h: doesn't explicitly use bug.h, so don't include it. bug: consolidate BUILD_BUG_ON with other bug code BUG: headers with BUG/BUG_ON etc. need linux/bug.h bug.h: add include of it to various implicit C users lib: fix implicit users of kernel.h for TAINT_WARN spinlock: macroize assert_spin_locked to avoid bug.h dependency x86: relocate get/set debugreg fcns to include/asm/debugreg.
2012-03-23Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge second batch of patches from Andrew Morton: - various misc things - core kernel changes to prctl, exit, exec, init, etc. - kernel/watchdog.c updates - get_maintainer - MAINTAINERS - the backlight driver queue - core bitops code cleanups - the led driver queue - some core prio_tree work - checkpatch udpates - largeish crc32 update - a new poll() feature for the v4l guys - the rtc driver queue - fatfs - ptrace - signals - kmod/usermodehelper updates - coredump - procfs updates * emailed from Andrew Morton <akpm@linux-foundation.org>: (141 commits) seq_file: add seq_set_overflow(), seq_overflow() proc-ns: use d_set_d_op() API to set dentry ops in proc_ns_instantiate(). procfs: speed up /proc/pid/stat, statm procfs: add num_to_str() to speed up /proc/stat proc: speed up /proc/stat handling fs/proc/kcore.c: make get_sparsemem_vmemmap_info() static coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMP coredump: remove VM_ALWAYSDUMP flag kmod: make __request_module() killable kmod: introduce call_modprobe() helper usermodehelper: ____call_usermodehelper() doesn't need do_exit() usermodehelper: kill umh_wait, renumber UMH_* constants usermodehelper: implement UMH_KILLABLE usermodehelper: introduce umh_complete(sub_info) usermodehelper: use UMH_WAIT_PROC consistently signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/ signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig() signal: cosmetic, s/from_ancestor_ns/force/ in prepare_signal() paths signal: give SEND_SIG_FORCED more power to beat SIGNAL_UNKILLABLE Hexagon: use set_current_blocked() and block_sigmask() ...
2012-03-23coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMPJason Baron
Since we no longer need the VM_ALWAYSDUMP flag, let's use the freed bit for 'VM_NODUMP' flag. The idea is is to add a new madvise() flag: MADV_DONTDUMP, which can be set by applications to specifically request memory regions which should not dump core. The specific application I have in mind is qemu: we can add a flag there that wouldn't dump all of guest memory when qemu dumps core. This flag might also be useful for security sensitive apps that want to absolutely make sure that parts of memory are not dumped. To clear the flag use: MADV_DODUMP. [akpm@linux-foundation.org: s/MADV_NODUMP/MADV_DONTDUMP/, s/MADV_CLEAR_NODUMP/MADV_DODUMP/, per Roland] [akpm@linux-foundation.org: fix up the architectures which broke] Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Avi Kivity <avi@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23coredump: remove VM_ALWAYSDUMP flagJason Baron
The motivation for this patchset was that I was looking at a way for a qemu-kvm process, to exclude the guest memory from its core dump, which can be quite large. There are already a number of filter flags in /proc/<pid>/coredump_filter, however, these allow one to specify 'types' of kernel memory, not specific address ranges (which is needed in this case). Since there are no more vma flags available, the first patch eliminates the need for the 'VM_ALWAYSDUMP' flag. The flag is used internally by the kernel to mark vdso and vsyscall pages. However, it is simple enough to check if a vma covers a vdso or vsyscall page without the need for this flag. The second patch then replaces the 'VM_ALWAYSDUMP' flag with a new 'VM_NODUMP' flag, which can be set by userspace using new madvise flags: 'MADV_DONTDUMP', and unset via 'MADV_DODUMP'. The core dump filters continue to work the same as before unless 'MADV_DONTDUMP' is set on the region. The qemu code which implements this features is at: http://people.redhat.com/~jbaron/qemu-dump/qemu-dump.patch In my testing the qemu core dump shrunk from 383MB -> 13MB with this patch. I also believe that the 'MADV_DONTDUMP' flag might be useful for security sensitive apps, which might want to select which areas are dumped. This patch: The VM_ALWAYSDUMP flag is currently used by the coredump code to indicate that a vma is part of a vsyscall or vdso section. However, we can determine if a vma is in one these sections by checking it against the gate_vma and checking for a non-NULL return value from arch_vma_name(). Thus, freeing a valuable vma bit. Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-23locking/kconfig: Simplify INLINE_SPIN_UNLOCK usageRaghavendra K T
Get rid of INLINE_SPIN_UNLOCK entirely replacing it with UNINLINE_SPIN_UNLOCK instead of the reverse meaning. Whoever wants to change the default spinlock inlining behavior and uninline the spinlocks for some weird reason, such as spinlock debugging, paravirt etc. can now all just select UNINLINE_SPIN_UNLOCK Original discussion at: https://lkml.org/lkml/2012/3/21/357 Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Chris Zankel <chris@zankel.net> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/20120322095502.30866.75756.sendpatchset@codeblue [ tidied up the changelog a bit ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-22Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull updates of sound stuff from Takashi Iwai: "Here is the first big update chunk of sound stuff for 3.4-rc1. In the common sound infrastructure, there are a few changes for dynamic PCM support (used in ASoC) and a few clean-ups. Majority of changes are found, as usual, in HD-audio and ASoC. Some highlights of HD-audio changes: - All the long-standing static quirk codes for Realtek codec were finally removed by fixing and extending the Realtek auto-parser. - The mute-LED control is standardized over all HD-audio codec drivers using the extended vmaster hook. - The vmaster slave mixer elements are initialized to 0dB as default so that the user won't be annoyed by the silent output after updates, e.g. due to the additions of new elements. - Other many fix-ups for the misc HD-audio devices. In the ASoC side, this is a very active release, including a quite a few framework enhancements. Some highlights: - Support for widgets not associated with a CODEC, an important part of the dynamic PCM framework. - A library factoring out the common code shared by dmaengine based DMA drivers contributed by Lars-Peter Clausen. This will save a lot of code and make it much easier to deploy enhancements to dmaengine. - Support for binary controls, used for providing runtime configuration of algorithm coefficients. - A new DAPM widget type for regulator supplies allowing drivers for devices that can power down unused supplies while active to do without any per-driver code. - DAPM widgets for DAIs, initially giving a speed boost for playback startup and shutdown and also the basis for CODEC<->CODEC DAI link support. - Support for specifying the number of significant bits on audio interfaces, useful for allowing applications to know how much effort to put into generating data for a larger sample format. - Conversion of the FSI driver used on some SH processors to DMAEngine. - Conversion of EP93xx drivers to DMAEngine. - New CODEC drivers for Maxim MAX9768 and Wolfson Microelectronics WM2200. - Move audmux driver from arc/arm to sound/soc - McBSP move from arch/ to sound/ and updates Also, a few small updates and fixes for other drivers like au88x0, ymfpci, USB 6fire, USB usx2yaudio are included." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (446 commits) ASoC: wm8994: Provide VMID mode control and fix default sequence ASoC: wm8994: Add missing break in resume ASoC: wm_hubs: Don't actively manage LINEOUT_VMID_BUF ASoC: pxa-ssp: atomically set stream active masks ASoC: fsl: p1022ds: tell the WM8776 codec driver that it's the master ASoC: Samsung: Added to support mono recording ALSA: hda - Fix build with CONFIG_PM=n ALSA: au88x0 - Avoid possible Oops at unbinding ALSA: usb-audio - Fix build error by consitification of rate list ASoC: core: Fix obscure leak of runtime array ALSA: pcm - Avoid GFP_ATOMIC in snd_pcm_link() ALSA: pcm: Constify the list in snd_pcm_hw_constraint_list ASoC: wm8996: Add 44.1kHz support ALSA: hda - Fix build of patch_sigmatel.c without CONFIG_SND_HDA_POWER_SAVE ASoC: mx27vis-aic32x4: Convert it to platform driver ALSA: hda - fix printing of high HDMI sample rates ALSA: ymfpci - Fix legacy registers on S3/S4 resume ALSA: control - Fixe a trailing white space error ALSA: hda - Add expose_enum_ctl flag to snd_hda_add_vmaster_hook() ALSA: hda - Add "Mute-LED Mode" enum control ...
2012-03-21Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull irq_domain support for all architectures from Grant Likely: "Generialize powerpc's irq_host as irq_domain This branch takes the PowerPC irq_host infrastructure (reverse mapping from Linux IRQ numbers to hardware irq numbering), generalizes it, renames it to irq_domain, and makes it available to all architectures. Originally the plan has been to create an all-new irq_domain implementation which addresses some of the powerpc shortcomings such as not handling 1:1 mappings well, but doing that proved to be far more difficult and invasive than generalizing the working code and refactoring it in-place. So, this branch rips out the 'new' irq_domain and replaces it with the modified powerpc version (in a fully bisectable way of course). It converts all users over to the new API and makes irq_domain selectable on any architecture. No architecture is forced to enable irq_domain, but the infrastructure is required for doing OpenFirmware style irq translations. It will even work on SPARC even though SPARC has it's own mechanism for translating irqs at boot time. MIPS, microblaze, embedded x86 and c6x are converted too. The resulting irq_domain code is probably still too verbose and can be optimized more, but that can be done incrementally and is a task for follow-on patches." * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: (31 commits) dt: fix twl4030 for non-dt compile on x86 mfd: twl-core: Add IRQ_DOMAIN dependency devicetree: Add empty of_platform_populate() for !CONFIG_OF_ADDRESS (sparc) irq_domain: Centralize definition of irq_dispose_mapping() irq_domain/mips: Allow irq_domain on MIPS irq_domain/x86: Convert x86 (embedded) to use common irq_domain ppc-6xx: fix build failure in flipper-pic.c and hlwd-pic.c irq_domain/microblaze: Convert microblaze to use irq_domains irq_domain/powerpc: Replace custom xlate functions with library functions irq_domain/powerpc: constify irq_domain_ops irq_domain/c6x: Use library of xlate functions irq_domain/c6x: constify irq_domain structures irq_domain/c6x: Convert c6x to use generic irq_domain support. irq_domain: constify irq_domain_ops irq_domain: Create common xlate functions that device drivers can use irq_domain: Remove irq_domain_add_simple() irq_domain: Remove 'new' irq_domain in favour of the ppc one mfd: twl-core.c: Fix the number of interrupts managed by twl4030 of/address: add empty static inlines for !CONFIG_OF irq_domain: Add support for base irq and hwirq in legacy mappings ...
2012-03-21Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull kmap_atomic cleanup from Cong Wang. It's been in -next for a long time, and it gets rid of the (no longer used) second argument to k[un]map_atomic(). Fix up a few trivial conflicts in various drivers, and do an "evil merge" to catch some new uses that have come in since Cong's tree. * 'kmap_atomic' of git://github.com/congwang/linux: (59 commits) feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] drbd: remove the second argument of k[un]map_atomic() zcache: remove the second argument of k[un]map_atomic() gma500: remove the second argument of k[un]map_atomic() dm: remove the second argument of k[un]map_atomic() tomoyo: remove the second argument of k[un]map_atomic() sunrpc: remove the second argument of k[un]map_atomic() rds: remove the second argument of k[un]map_atomic() net: remove the second argument of k[un]map_atomic() mm: remove the second argument of k[un]map_atomic() lib: remove the second argument of k[un]map_atomic() power: remove the second argument of k[un]map_atomic() kdb: remove the second argument of k[un]map_atomic() udf: remove the second argument of k[un]map_atomic() ubifs: remove the second argument of k[un]map_atomic() squashfs: remove the second argument of k[un]map_atomic() reiserfs: remove the second argument of k[un]map_atomic() ocfs2: remove the second argument of k[un]map_atomic() ntfs: remove the second argument of k[un]map_atomic() ...
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-20Merge tag 'usb-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usbLinus Torvalds
Pull USB merge for 3.4-rc1 from Greg KH: "Here's the big USB merge for the 3.4-rc1 merge window. Lots of gadget driver reworks here, driver updates, xhci changes, some new drivers added, usb-serial core reworking to fix some bugs, and other various minor things. There are some patches touching arch code, but they have all been acked by the various arch maintainers." * tag 'usb-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (302 commits) net: qmi_wwan: add support for ZTE MF820D USB: option: add ZTE MF820D usb: gadget: f_fs: Remove lock is held before freeing checks USB: option: make interface blacklist work again usb/ub: deprecate & schedule for removal the "Low Performance USB Block" driver USB: ohci-pxa27x: add clk_prepare/clk_unprepare calls USB: use generic platform driver on ath79 USB: EHCI: Add a generic platform device driver USB: OHCI: Add a generic platform device driver USB: ftdi_sio: new PID: LUMEL PD12 USB: ftdi_sio: add support for FT-X series devices USB: serial: mos7840: Fixed MCS7820 device attach problem usb: Don't make USB_ARCH_HAS_{XHCI,OHCI,EHCI} depend on USB_SUPPORT. usb gadget: fix a section mismatch when compiling g_ffs with CONFIG_USB_FUNCTIONFS_ETH USB: ohci-nxp: Remove i2c_write(), use smbus USB: ohci-nxp: Support for LPC32xx USB: ohci-nxp: Rename symbols from pnx4008 to nxp USB: OHCI-HCD: Rename ohci-pnx4008 to ohci-nxp usb: gadget: Kconfig: fix typo for 'different' usb: dwc3: pci: fix another failure path in dwc3_pci_probe() ...
2012-03-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes for v3.4 from Ingo Molnar * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) printk: Make it compile with !CONFIG_PRINTK sched/x86: Fix overflow in cyc2ns_offset sched: Fix nohz load accounting -- again! sched: Update yield() docs printk/sched: Introduce special printk_sched() for those awkward moments sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancer sched: Cleanup cpu_active madness sched: Fix load-balance wreckage sched: Clean up parameter passing of proc_sched_autogroup_set_nice() sched: Ditch per cgroup task lists for load-balancing sched: Rename load-balancing fields sched: Move load-balancing arguments into helper struct sched/rt: Do not submit new work when PI-blocked sched/rt: Prevent idle task boosting sched/wait: Add __wake_up_all_locked() API sched/rt: Document scheduler related skip-resched-check sites sched/rt: Use schedule_preempt_disabled() sched/rt: Add schedule_preempt_disabled() sched/rt: Do not throttle when PI boosting sched/rt: Keep period timer ticking when rt throttling is active ...
2012-03-20highmem: kill all __kmap_atomic()Cong Wang
[swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-20mips: remove the second argument of k[un]map_atomic()Cong Wang
2012-03-15USB: use generic platform driver on ath79Hauke Mehrtens
The ath79 usb driver doesn't do anything special and is now converted to the generic ehci and ohci driver. This was tested on a TP-Link TL-WR1043ND (AR9132) Acked-by: Gabor Juhos <juhosg@openwrt.org> CC: Imre Kaloz <kaloz@openwrt.org> CC: linux-mips@linux-mips.org CC: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-15[PATCH v3] ipc: provide generic compat versions of IPC syscallsChris Metcalf
When using the "compat" APIs, architectures will generally want to be able to make direct syscalls to msgsnd(), shmctl(), etc., and in the kernel we would want them to be handled directly by compat_sys_xxx() functions, as is true for other compat syscalls. However, for historical reasons, several of the existing compat IPC syscalls do not do this. semctl() expects a pointer to the fourth argument, instead of the fourth argument itself. msgsnd(), msgrcv() and shmat() expect arguments in different order. This change adds an ARCH_WANT_OLD_COMPAT_IPC config option that can be set to preserve this behavior for ports that use it (x86, sparc, powerpc, s390, and mips). No actual semantics are changed for those architectures, and there is only a minimal amount of code refactoring in ipc/compat.c. Newer architectures like tile (and perhaps future architectures such as arm64 and unicore64) should not select this option, and thus can avoid having any IPC-specific code at all in their architecture-specific compat layer. In the same vein, if this option is not selected, IPC_64 mode is assumed, since that's what the <asm-generic> headers expect. The workaround code in "tile" for msgsnd() and msgrcv() is removed with this change; it also fixes the bug that shmat() and semctl() were not being properly handled. Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-03-13Merge tag 'v3.3-rc7' into sched/coreIngo Molnar
Merge reason: merge back final fixes, prepare for the merge window. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-12Merge branch 'perf/hw-branch-sampling' into perf/coreIngo Molnar
Merge reason: The 'perf record -b' hardware branch sampling feature is ready for upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-12Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: We are going to queue up a dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2012-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/vmxnet3/vmxnet3_drv.c Small vmxnet3 conflict with header size bug fix in 'net'. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-05MIPS: BCM47XX: provide sprom to bcma busHauke Mehrtens
On SoCs the sprom is often stored in nvram in the flashchip. This patch registers a sprom fallback callback handler in bcma and provides the sprom needed for this device. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
