path: root/arch/mips
2011-03-14MIPS: Alchemy: Fix reset for MTX-1 and XXS1500Florian Fainelli
Since commit 32fd6901 (MIPS: Alchemy: get rid of common/reset.c) Alchemy-based boards use their own reset function. For MTX-1 and XXS1500, the reset function pokes at the BCSR.SYSTEM_RESET register, but this does not work. According to Bruno Randolf, this was not tested when written. Previously, the generic au1000_restart() routine called the board specific reset function, which for MTX-1 and XXS1500 did not work, but finally made a jump to the reset vector, which really triggers a system restart. Fix reboot for both targets by jumping to the reset vector. Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2093/ Acked-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: MTX-1: Make au1000_eth probe all PHY addressesFlorian Fainelli
When au1000_eth probes the MII bus for PHY address, if we do not set au1000_eth platform data's phy_search_highest_address, the MII probing logic will exit early and will assume a valid PHY is found at address 0. For MTX-1, the PHY is at address 31, and without this patch, the link detection/speed/duplex would not work correctly. CC: stable@kernel.org Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2111/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Jz4740: Add HAVE_CLKMaurus Cuelenaere
Jz4740 supports the clock framework but doesn't have HAVE_CLK defined, so define it! Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2112/ Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Move idle task creation to work queueMaksim Rayskiy
To avoid forking usermode thread when creating an idle task, move fork_idle to a work queue. If kernel starts with maxcpus= option which does not bring all available cpus online at boot time, idle tasks for offline cpus are not created. If later offline cpus are hotplugged through sysfs, __cpu_up is called in the context of the user task, and fork_idle copies its non-zero mm pointer. This causes BUG() in per_cpu_trap_init. This also avoids issues with resource limits of the CPU writing to sysfs, containers, maybe others. Signed-off-by: Maksim Rayskiy <mrayskiy@broadcom.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2070/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Use unsigned delta for right shift in event updateDeng-Cheng Zhu
Leverage the commit for ARM by Will Deacon: - 446a5a8b1eb91a6990e5c8fe29f14e7a95b69132 ARM: 6205/1: perf: ensure counter delta is treated as unsigned Hardware performance counters on ARM are 32-bits wide but atomic64_t variables are used to represent counter data in the hw_perf_event structure. The armpmu_event_update function right-shifts a signed 64-bit delta variable and adds the result to the event count. This can lead to shifting in sign-bits if the MSB of the 32-bit counter value is set. This results in perf output such as: Performance counter stats for 'sleep 20': 18446744073460670464 cycles <-- 0xFFFFFFFFF12A6000 7783773 instructions # 0.000 IPC 465 context-switches 161 page-faults 1172393 branches 20.154242147 seconds time elapsed This patch ensures that the delta value is treated as unsigned so that the right shift sets the upper bits to zero. Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: a.p.zijlstra@chello.nl To: fweisbec@gmail.com To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: wuzhangjin@gmail.com Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com Patchwork: http://patchwork.linux-mips.org/patch/2015/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Work with the new callchain interfaceDeng-Cheng Zhu
This is the MIPS part of the following commits by Frederic Weisbecker: - f72c1a931e311bb7780fee19e41a89ac42cab50e perf: Factorize callchain context handling Store the kernel and user contexts from the generic layer instead of archs, this gathers some repetitive code. - 56962b4449af34070bb1994621ef4f0265eed4d8 perf: Generalize some arch callchain code - Most archs use one callchain buffer per cpu, except x86 that needs to deal with NMIs. Provide a default perf_callchain_buffer() implementation that x86 overrides. - Centralize all the kernel/user regs handling and invoke new arch handlers from there: perf_callchain_user() / perf_callchain_kernel() That avoid all the user_mode(), current->mm checks and so... - Invert some parameters in perf_callchain_*() helpers: entry to the left, regs to the right, following the traditional (dst, src). - 70791ce9ba68a5921c9905ef05d23f62a90bc10c perf: Generalize callchain_store() callchain_store() is the same on every archs, inline it in perf_event.h and rename it to perf_callchain_store() to avoid any collision. This removes repetitive code. - c1a65932fd7216fdc9a0db8bbffe1d47842f862c perf: Drop unappropriate tests on arch callchains Drop the TASK_RUNNING test on user tasks for callchains as this check doesn't seem to make any sense. Also remove the tests for !current that is not supposed to happen and current->pid as this should be handled at the generic level, with exclude_idle attribute. Reported-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: a.p.zijlstra@chello.nl To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: dengcheng.zhu@gmail.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com Patchwork: http://patchwork.linux-mips.org/patch/2014/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Fix event check in validate_event()Deng-Cheng Zhu
Ignore events that are in off/error state or belong to a different PMU. This patch originates from the following commit for ARM by Will Deacon: - 65b4711ff513767341aa1915c822de6ec0de65cb ARM: 6352/1: perf: fix event validation The validate_event function in the ARM perf events backend has the following problems: 1.) Events that are disabled count towards the cost. 2.) Events associated with other PMUs [for example, software events or breakpoints] do not count towards the cost, but do fail validation, causing the group to fail. This patch changes validate_event so that it ignores events in the PERF_EVENT_STATE_OFF state or that are scheduled for other PMUs. Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: a.p.zijlstra@chello.nl To: fweisbec@gmail.com To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: wuzhangjin@gmail.com Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: dengcheng.zhu@gmail.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com Cc: ddaney@caviumnetworks.com Patchwork: http://patchwork.linux-mips.org/patch/2013/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Work with the new PMU interfaceDeng-Cheng Zhu
This is the MIPS part of the following commits by Peter Zijlstra: - a4eaf7f14675cb512d69f0c928055e73d0c6d252 perf: Rework the PMU methods Replace pmu::{enable,disable,start,stop,unthrottle} with pmu::{add,del,start,stop}, all of which take a flags argument. The new interface extends the capability to stop a counter while keeping it scheduled on the PMU. We replace the throttled state with the generic stopped state. This also allows us to efficiently stop/start counters over certain code paths (like IRQ handlers). It also allows scheduling a counter without it starting, allowing for a generic frozen state (useful for rotating stopped counters). The stopped state is implemented in two different ways, depending on how the architecture implemented the throttled state: 1) We disable the counter: a) the pmu has per-counter enable bits, we flip that b) we program a NOP event, preserving the counter state 2) We store the counter state and ignore all read/overflow events For MIPSXX, the stopped state is implemented in the way of 1.b as above. - 33696fc0d141bbbcb12f75b69608ea83282e3117 perf: Per PMU disable Changes perf_disable() into perf_pmu_disable(). - 24cd7f54a0d47e1d5b3de29e2456bfbd2d8447b7 perf: Reduce perf_disable() usage Since the current perf_disable() usage is only an optimization, remove it for now. This eases the removal of the __weak hw_perf_enable() interface. - b0a873ebbf87bf38bf70b5e39a7cadc96099fa13 perf: Register PMU implementations Simple registration interface for struct pmu, this provides the infrastructure for removing all the weak functions. - 51b0fe39549a04858001922919ab355dee9bdfcf perf: Deconstify struct pmu sed -ie 's/const struct pmu\>/struct pmu/g' `git grep -l "const struct pmu\>"` Reported-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: a.p.zijlstra@chello.nl To: fweisbec@gmail.com To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: wuzhangjin@gmail.com Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: dengcheng.zhu@gmail.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com Cc: ddaney@caviumnetworks.com Patchwork: http://patchwork.linux-mips.org/patch/2012/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Work with irq_workDeng-Cheng Zhu
This is the MIPS part of the following commit by Peter Zijlstra: - e360adbe29241a0194e10e20595360dd7b98a2b3 irq_work: Add generic hardirq context callbacks Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. For MIPSXX, we need to call irq_work_run() at the tail of the perf IRQ handler as described above. Reported-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: fweisbec@gmail.com To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com, Patchwork: http://patchwork.linux-mips.org/patch/2011/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Fix always CONFIG_LOONGSON_UART_BASE=yYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2055/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Loongson: Fix potentially wrong string handlingStefan Weil
This error was reported by cppcheck: arch/mips/loongson/common/machtype.c:56: error: Dangerous usage of 'str' (strncpy doesn't always 0-terminate it) If strncpy copied MACHTYPE_LEN bytes, the destination string str was not terminated. The patch adds one more byte to str and makes sure that this byte is always 0. Signed-off-by: Stefan Weil <weil@mail.berlios.de> Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Arnaud Patard <apatard@mandriva.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2053/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Fix GCC-4.6 'set but not used' warning in arch/mips/mm/init.cDavid Daney
Under some combinations of CONFIG_*, lastpfn in page_is_ram is 'set but not used'. Mark it as __maybe_unused to quiet the warning/error. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2033/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Fix GCC-4.6 'set but not used' warning in ieee754int.hDavid Daney
GCC-4.6 can find more unused code than previous versions could. In the case of arch/mips/math-emu/ieee754int.h, the COMPXSP and COMPXDP macros are used in several places, but a couple of them leave xs unused. The easiest thing to do is mark it as __maybe_unused to quiet the warning. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2032/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Remove unused code from arch/mips/kernel/syscall.cDavid Daney
The variable arg3 in _sys_sysmips() is unused. Remove it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2034/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Fix GCC-4.6 'set but not used' warning in signal*.cDavid Daney
GCC-4.6 can find more unused code than previous versions could. In the case of protected_restore_fp_context{,32}, the variable tmp is really used. Its use is tricky in that we really care about the side effects of the __put_user() calls. So we must mark tmp with __maybe_unused to quiet the warning. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2035/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: MSP: Fix MSP71xx bpci interrupt handler return valueAnoop P A
Signed-off-by: Anoop P A <anoop.pa@gmail.com> To: Ben Hutchings <ben@decadent.org.uk> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1804/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Select R4K timer lib for all MSP platformsAnoop P A
Signed-off-by: Anoop P A <anoop.pa@gmail.com> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1803/ Tested-by: Shane McDonald <mcdonald.shane@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Loongson: Remove ad-hoc cmdline defaultRobert Millan
Loongson builds have an ad-hoc cmdline default of "console=ttyS0,115200 root=/dev/hda1". These settings come from a vendor; I remember builds from Lemote branch requiring a "console=tty" override in order to get a working console. At least on Yeeloong, they're particularly useless: there's no external serial port, and the IDE drive is now recognised as /dev/sda. Signed-off-by: Robert Millan <rmh@gnu.org> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1759/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Clear the correct flag in sysmips(MIPS_FIXADE, ...).Stefan Oberhumer
The sysmips(MIPS_FIXADE, ...) case contains an obvious copy-and-paste error in the handling of the TIF_LOGADE flag. Fix that Patchwork: https://patchwork.linux-mips.org/patch/1997/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Add an unreachable return statement to satisfy buggy GCCs.David Daney
It was reported that GCC-4.3.3 (with CodeSourcery extensions) fails without this. Reported-by: Jonas Gorski <jonas.gorski@gmail.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2010/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Tracing: Fix set_graph_function of function graph tracerWu Zhangjin
trace.func should be set to the recorded ip of the mcount calling site in the __mcount_loc section to filter the function entries configured through the tracing/set_graph_function interface, but before, this is set to the self_ra(the return address of mcount), which has made set_graph_function not work as expected. This fixes it via calculating the right recorded ip in the __mcount_loc section and assign it to trace.func. Reported-by: Zhiping Zhong <xzhong86@163.com> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2017/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS, Tracing: Clean up ftrace_make_nop()Wu Zhangjin
This moves the comments out of ftrace_make_nop() and cleans it. At the same time, a macro MCOUNT_OFFSET_INSNS is defined for sharing with the next patch. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2008/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS, Tracing: Clean up prepare_ftrace_return()Wu Zhangjin
The old prepare_ftrace_return() for MIPS is confused and have introduced some problem. This patch cleans up the names of the arguments, variables and related functions. For MIPS, the 2nd argument of prepare_ftrace_return() is not really the 'selfpc' described in ftrace-design.txt but instead it is the self return address. This did break the compatibility of the generic interface but really reduced one unneeded calculation for to get the current function name, the parent return address and the self return address are enough, no need to tranform the self return address to the self address. But set_graph_function of function graph tracer is an exception, it does need the 2nd argument of prepare_ftrace_return() as 'selfpc', for it will use 'selfpc' to match user's configuration of function graph entries, but in reality, it doesn't need the 'selfpc' but the recorded ip address of the mcount calling site in the __mcount_loc section. So, the 2nd argument of prepare_ftrace_return() is not important, the real requirement is the right recorded ip address should be calculated and assign to trace.func, this will be fixed in the next patches. Reported-by: Zhiping Zhong <xzhong86@163.com> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2007/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS, Tracing: Substitute in_kernel_space() for in_module()Wu Zhangjin
The old in_module() may not work in some situations(e.g. when module & kernel are in the same address space when CONFIG_MAPPED_KERNEL=y), The in_kernel_space() is more generic and it is also easy to be implemented via cloning the existing core_kernel_text(), so, replace the in_module() with in_kernel_space(). Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2005/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS, Tracing: Speed up function graph tracerWu Zhangjin
This simply moves the "ip-=4" statement down to the end of the do { ... } while (...); loop, which reduces one unneeded subtration and the subsequent memory loading and comparison. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2006/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS: Replace deprecated spinlock initializationThomas Gleixner
SPIN_LOCK_UNLOCK is deprecated. Use the lockdep capable variant instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2025/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-01-21genirq: Remove __do_IRQThomas Gleixner
All architectures are finally converted. Remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Michal Simek <monstr@monstr.eu> Acked-by: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-18Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (26 commits) MIPS: Malta: enable Cirrus FB console MIPS: add CONFIG_VIRTUALIZATION for virtio support MIPS: Implement __read_mostly MIPS: ath79: add common WMAC device for AR913X based boards MIPS: ath79: Add initial support for the Atheros AP81 reference board MIPS: ath79: add common SPI controller device SPI: Add SPI controller driver for the Atheros AR71XX/AR724X/AR913X SoCs MIPS: ath79: add common GPIO buttons device MIPS: ath79: add common watchdog device MIPS: ath79: add common GPIO LEDs device MIPS: ath79: add initial support for the Atheros PB44 reference board MIPS: ath79: utilize the MIPS multi-machine support MIPS: ath79: add GPIOLIB support MIPS: Add initial support for the Atheros AR71XX/AR724X/AR931X SoCs MIPS: jump label: Add MIPS support. MIPS: Use WARN() in uasm for better diagnostics. MIPS: Optimize TLB handlers for Octeon CPUs MIPS: Add LDX and LWX instructions to uasm. MIPS: Use BBIT instructions in TLB handlers MIPS: Declare uasm bbit0 and bbit1 functions. ...
2011-01-18MIPS: Malta: enable Cirrus FB consoleAurelien Jarno
While most users of a physical Malta board are using the serial port as the console, a lot of QEMU users would prefer to interact with a graphical console. Enable the Cirrus FB support in the Malta default configuration to make that possible. Note that the default console will still be the serial port, users have to pass "console=tty0" to the kernel to use the Cirrus FB. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2001/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: add CONFIG_VIRTUALIZATION for virtio supportAurelien Jarno
Add CONFIG_VIRTUALIZATION to the MIPS architecture and include the the virtio code there. Used to enable the virtio drivers under QEMU. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2002/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Implement __read_mostlyDavid Daney
Just do what everyone else is doing by placing __read_mostly things in the .data.read_mostly section. mips_io_port_base can not be read-only (const) and writable (__read_mostly) at the same time. One of them has to go, so I chose to eliminate the __read_mostly. It will still get stuck in a portion of memory that is not adjacent to things that are written, and thus not be on a dirty cache line, for whatever that is worth. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1702/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common WMAC device for AR913X based boardsGabor Juhos
Add common platform_device and helper code to make the registration of the built-in wireless MAC easier on the Atheros AR9130/AR9132 based boards. Also register the WMAC device on the AR81 board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Imre Kaloz <kaloz@openwrt.org>, Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1962/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: Add initial support for the Atheros AP81 reference boardGabor Juhos
Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1952/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common SPI controller deviceGabor Juhos
Several boards are using the built-in SPI controller of the AR71XX/AR724X/AR913X SoCs. This patch adds common platform_device and helper code to register it. Additionally, the patch registers the SPI bus on the PB44 board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1956/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18SPI: Add SPI controller driver for the Atheros AR71XX/AR724X/AR913X SoCsGabor Juhos
The Atheros AR71XX/AR724X/AR913X SoCs have a built-in SPI controller. This patch implements a driver for that. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: spi-devel-general@lists.sourceforge.net Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: linux-mips@linux-mips.org Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1960/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common GPIO buttons deviceGabor Juhos
Almost all boards have one or more push buttons connected to GPIO lines. This patch adds common code to register a platform_device for them. The patch also adds support for the buttons on the PB44 board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1954/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common watchdog deviceGabor Juhos
All supported SoCs have a built-in hardware watchdog driver. This patch registers a platform_device for that to make it usable. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1955/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common GPIO LEDs deviceGabor Juhos
Almost all boards have one or more LEDs connected to GPIO lines. This patch adds common code to register a platform_device for them. The patch also adds support for the LEDs on the PB44 board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1953/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add initial support for the Atheros PB44 reference boardGabor Juhos
Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1950/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: utilize the MIPS multi-machine supportGabor Juhos
Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1949/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add GPIOLIB supportGabor Juhos
This patch implements generic GPIO routines for the built-in GPIO controllers of the Atheros AR71XX/AR724X/AR913X SoCs. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1948/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add initial support for the Atheros AR71XX/AR724X/AR931X SoCsGabor Juhos
This patch adds initial support for various Atheros SoCs based on the MIPS 24Kc core. The following models are supported at the moment: - AR7130 - AR7141 - AR7161 - AR9130 - AR9132 - AR7240 - AR7241 - AR7242 The current patch contains minimal support only, but the resulting kernel can boot into user-space with using of an initramfs image on various boards which are using these SoCs. Support for more built-in devices and individual boards will be implemented in further patches. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1947/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: jump label: Add MIPS support.David Daney
In order not to be left behind, we add jump label support for MIPS. Tested on 64-bit big endian (Octeon), and 32-bit little endian (malta/qemu). Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jason Baron <jbaron@redhat.com> Patchwork: https://patchwork.linux-mips.org/patch/1923/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use WARN() in uasm for better diagnostics.David Daney
On the off chance that uasm ever warns about overflow, there is no way to know what the offending instruction is. Change the printks to WARNs, so we can get a nice stack trace. It has the added benefit of being much more noticeable than the short single line warning message, so is less likely to be ignored. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1905/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Optimize TLB handlers for Octeon CPUsDavid Daney
Octeon can use scratch registers in the TLB handlers. Octeon II can use LDX instructions. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1904/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add LDX and LWX instructions to uasm.David Daney
Needed by Octeon II optimized TLB handlers. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Pachwork: https://patchwork.linux-mips.org/patch/1903/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use BBIT instructions in TLB handlersDavid Daney
If the CPU supports BBIT0 and BBIT1, use them in TLB handlers as they are more efficient than an AND followed by an branch and then restoring the clobbered register. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1873/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Declare uasm bbit0 and bbit1 functions.David Daney
these are already defined, but declaring them allow them to be used outside of uasm.c. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1872/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use C0_KScratch (if present) to hold PGD pointer.David Daney
Decide at runtime to use either Context or KScratch to hold the PGD pointer. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1876/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
