commit 32eb12a6c11034867401d56b012e3c15d5f8141e upstream.
Flush the KVM entry code from the icache on all CPUs, not just the one
that built the entry code.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: "Radim Krčmář" <rkrcmar@redhat.com>
Cc: linux-mips@linux-mips.org
Cc: kvm@vger.kernel.org
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 4c881451d3017033597ea186cf79ae41a73e1ef8 upstream.
On 64-bit kernels, MIPS KVM will clear CP0_Status.UX to prevent the
guest (running in user mode) from accessing the 64-bit memory segments.
However the previous value of CP0_Status.UX is never restored when
exiting from the guest.
If the user process uses 64-bit addressing (the n64 ABI) this can result
in address error exceptions from the kernel if it needs to deliver a
signal before returning to user mode, as the kernel will need to write a
sigframe to high user addresses on the user stack which are disallowed
by CP0_Status.UX=0.
This is fixed by explicitly setting SX and UX again when exiting from
the guest, and explicitly clearing those bits when returning to the
guest. Having the SX and UX bits set when handling guest exits (rather
than only when exiting to userland) will be helpful when we support VZ,
since we shouldn't need to directly read or write guest memory, so it
will be valid for cache management IPIs to access host user addresses.
commit 84d77d3f06e7e8dea057d10e8ec77ad71f721be3 upstream.
It is the reasonable expectation that if an executable file is not
readable there will be no way for a user without special privileges to
read the file. This is enforced in ptrace_attach but if ptrace
is already attached before exec there is no enforcement for read-only
executables.
As the only way to read such an mm is through access_process_vm
spin a variant called ptrace_access_vm that will fail if the
target process is not being ptraced by the current process, or
the current process did not have sufficient privileges when ptracing
began to read the target processes mm.
In the ptrace implementations replace access_process_vm by
ptrace_access_vm. There remain several ptrace sites that still use
access_process_vm as they are reading the target executables
instructions (for kernel consumption) or register stacks. As such it
does not appear necessary to add a permission check to those calls.
This bug has always existed in Linux.
Fixes: v1.0
Reported-by: Andy Lutomirski <luto@amacapital.net>
The hardware documentation says bit 11:10 are used for the GPE
frequency selection. Fix the mask in the define to match these bits.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Reviewed-by: Thomas Langer <thomas.langer@intel.com>
Cc: john@phrozen.org
Patchwork: https://patchwork.linux-mips.org/patch/14648/
The sync_cmos_clock function in kernel/time/ntp.c first tries to update
the internal clock of the cpu by calling the "update_persistent_clock64"
architecture specific function. If this returns -ENODEV, it then tries
to update an external RTC using "rtc_set_ntp_time".
On the mips architecture, the weak implementation of the underlying
function would return 0 if it wasn't overridden. This meant that the
sync_cmos_clock function would never try to update an external RTC
(if both CONFIG_GENERIC_CMOS_UPDATE and CONFIG_RTC_SYSTOHC are
configured)
Returning -ENODEV instead, means that an external RTC will be tried.
Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz>
Reviewed-by: Richard Laing <richard.laing@alliedtelesis.co.nz>
Reviewed-by: Scott Parlane <scott.parlane@alliedtelesis.co.nz>
Reviewed-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Patchwork: https://patchwork.linux-mips.org/patch/14649/
Since commit 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing
continuation lines") the output from __do_page_fault on MIPS has been
pretty unreadable due to the lack of KERN_CONT markers. Use pr_cont
to provide the appropriate markers & restore the expected output.
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/14544/
Since MIPSr6 the Wired register is split into 2 fields, with the upper
16 bits of the register indicating a limit on the value that the wired
entry count in the bottom 16 bits of the register can take. This means
that simply reading the wired register doesn't get us a valid TLB entry
index any longer, and we instead need to retrieve only the lower 16 bits
of the register. Introduce a new num_wired_entries() function which does
this on MIPSr6 or higher and simply returns the value of the wired
register on older architecture revisions, and make use of it when
reading the number of wired entries.
Since commit e710d6668309 ("MIPS: tlb-r4k: If there are wired entries,
don't use TLBINVF") we have been using a non-zero number of wired
entries to determine whether we should avoid use of the tlbinvf
instruction (which would invalidate wired entries) and instead loop over
TLB entries in local_flush_tlb_all(). This loop begins with the number
of wired entries, or before this patch some large bogus TLB index on
MIPSr6 systems. Thus since the aforementioned commit some MIPSr6 systems
with FTLBs have been prone to leaving stale address translations in the
FTLB & crashing in various weird & wonderful ways when we later observe
the wrong memory.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Matt Redfearn <matt.redfearn@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14557/
Pull KVM updates from Paolo Bonzini:
"One NULL pointer dereference, and two fixes for regressions introduced
during the merge window.
The rest are fixes for MIPS, s390 and nested VMX"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
kvm: x86: Check memopp before dereference (CVE-2016-8630)
kvm: nVMX: VMCLEAR an active shadow VMCS after last use
KVM: x86: drop TSC offsetting kvm_x86_ops to fix KVM_GET/SET_CLOCK
KVM: x86: fix wbinvd_dirty_mask use-after-free
kvm/x86: Show WRMSR data is in hex
kvm: nVMX: Fix kernel panics induced by illegal INVEPT/INVVPID types
KVM: document lock orders
KVM: fix OOPS on flush_work
KVM: s390: Fix STHYI buffer alignment for diag224
KVM: MIPS: Precalculate MMIO load resume PC
KVM: MIPS: Make ERET handle ERL before EXL
KVM: MIPS: Fix lazy user ASID regenerate for SMP
When low memory doesn't reach HIGHMEM_START (e.g. up to 256MB at PA=0 is
common) and highmem is present above HIGHMEM_START (e.g. on Malta the
RAM overlayed by the IO region is aliased at PA=0x90000000), max_low_pfn
will be initially calculated very large and then clipped down to
HIGHMEM_START.
This causes crashes when reading /sys/kernel/mm/page_idle/bitmap
(i.e. CONFIG_IDLE_PAGE_TRACKING=y) when highmem is disabled. pfn_valid()
will compare against max_mapnr which is derived from max_low_pfn when
there is no highend_pfn set up, and will return true for PFNs right up
to HIGHMEM_START, even though they are beyond the end of low memory and
no page structs will actually exist for these PFNs.
This is fixed by skipping high memory regions when initially calculating
max_low_pfn if highmem is disabled, so it doesn't get clipped too high.
We also clip regions which overlap the highmem boundary when highmem is
disabled, so that max_pfn doesn't extend into highmem either.
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14490/
Complement commit 80cbfad79096 ("MIPS: Correct MIPS I FP context
layout") and correct the way Floating Point General registers are stored
in a signal context with MIPS I hardware.
Use the S.D and L.D assembly macros to have pairs of SWC1 instructions
and pairs of LWC1 instructions produced, respectively, in an arrangement
which makes the memory representation of floating-point data passed
compatible with that used by hardware SDC1 and LDC1 instructions, where
available, regardless of the hardware endianness used. This matches the
layout used by r4k_fpu.S, ensuring run-time compatibility for MIPS I
software across all o32 hardware platforms.
Define an EX2 macro to handle exceptions from both hardware instructions
implicitly produced from S.D and L.D assembly macros.
Signed-off-by: Maciej W. Rozycki <macro@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14477/
Fix a regression introduced with commit 2db9ca0a3551 ("MIPS: Use struct
mips_abi offsets to save FP context") for MIPS I/I FP signal contexts,
by converting save/restore code to the updated internal API. Start FGR
offsets from 0 rather than SC_FPREGS from $a0 and use $a1 rather than
the offset of SC_FPC_CSR from $a0 for the Floating Point Control/Status
Register (FCSR).
Document the new internal API and adjust assembly code formatting for
consistency.
Patchwork: https://patchwork.linux-mips.org/patch/14476/
Complement commit e50c0a8fa60d ("Support the MIPS32 / MIPS64 DSP ASE.")
and remove the Floating Point Implementation Register (FIR) from the FP
register set recorded in a signal context with MIPS I processors too, in
line with the change applied to r4k_fpu.S.
The `sc_fpc_eir' slot is unused according to our current ABI and the FIR
register is read-only and always directly accessible from user software.
[ralf@linux-mips.org: This is also required because the next commit depends
on it.]
Patchwork: https://patchwork.linux-mips.org/patch/14475/
Complement commit 0ae8dceaebe3 ("Merge with 2.3.10.") and use the local
`fault' handler to recover from FP sigcontext access violation faults,
like corresponding code does in r4k_fpu.S. The `bad_stack' handler is
in syscall.c and is not suitable here as we want to propagate the error
condition up through the caller rather than killing the thread outright.
Patchwork: https://patchwork.linux-mips.org/patch/14474/
Sanitize FCSR Cause bit handling, following a trail of past attempts:
* commit 4249548454f7 ("MIPS: ptrace: Fix FP context restoration FCSR
regression"),
* commit 443c44032a54 ("MIPS: Always clear FCSR cause bits after
emulation"),
* commit 64bedffe4968 ("MIPS: Clear [MSA]FPE CSR.Cause after
notify_die()"),
* commit b1442d39fac2 ("MIPS: Prevent user from setting FCSR cause
bits"),
* commit b54d2901517d ("Properly handle branch delay slots in connection
with signals.").
Specifically do not mask these bits out in ptrace(2) processing and send
a SIGFPE signal instead whenever a matching pair of an FCSR Cause and
Enable bit is seen as execution of an affected context is about to
resume. Only then clear Cause bits, and even then do not clear any bits
that are set but masked with the respective Enable bits. Adjust Cause
bit clearing throughout code likewise, except within the FPU emulator
proper where they are set according to IEEE 754 exceptions raised as the
operation emulated executed. Do so so that any IEEE 754 exceptions
subject to their default handling are recorded like with operations
executed by FPU hardware.
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14460/
Complement commit ac9ad83bc318 ("MIPS: prevent FP context set via ptrace
being discarded") and also initialize the FP context whenever FCSR alone
is written with a PTRACE_POKEUSR request addressing FPC_CSR, rather than
along with the full FPU register set in the case of the PTRACE_SETFPREGS
request.
Patchwork: https://patchwork.linux-mips.org/patch/14459/
continuation lines") the output from TLB dumps on MIPS has been
pretty unreadable due to the lack of KERN_CONT markers. Use pr_cont to
Continuation is also used for the second line of each TLB entry printed
in dump_tlb.c even though it has a newline, since it is a continuation
of the interpretation of the same TLB entry. For example:
[ 46.371884] Index: 0 pgmask=16kb va=77654000 asid=73 gid=00
[ri=0 xi=0 pa=ffc18000 c=5 d=0 v=1 g=0] [ri=0 xi=0 pa=ffc1c000 c=5 d=0 v=1 g=0]
[ 46.385380] Index: 12 pgmask=16kb va=004b4000 asid=73 gid=00
[ri=0 xi=0 pa=00000000 c=0 d=0 v=0 g=0] [ri=0 xi=0 pa=ffb00000 c=5 d=1 v=1 g=0]
Cc: Maciej W. Rozycki <macro@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14444/
continuation lines") the output from __show_regs() on MIPS has been
provide the appropriate markers & restore the expected register output.
Patchwork: https://patchwork.linux-mips.org/patch/14432/
continuation lines") the output from show_code on MIPS has been
Patchwork: https://patchwork.linux-mips.org/patch/14431/
continuation lines") the output from show_stacktrace on MIPS has been
provide the appropriate markers & restore the expected output. Also
start a new line with printk such that the presence of timing
information does not interfere with output.
Patchwork: https://patchwork.linux-mips.org/patch/14430/
continuation lines") the output from show_backtrace on MIPS has been
Patchwork: https://patchwork.linux-mips.org/patch/14429/
Changes introduced to arch/mips/Makefile for the generic kernel resulted
in build errors when making a compressed image if platform-y has multiple
values, like this:
make[2]: *** No rule to make target `alchemy/'.
make[1]: *** [vmlinuz] Error 2
make[1]: Target `_all' not remade because of errors.
make: *** [sub-make] Error 2
make: Target `_all' not remade because of errors.
Fix this by quoting $(platform-y) as it is passed to the Makefile in
arch/mips/boot/compressed/Makefile
Reported-by: kernelci.org bot <bot@kernelci.org>
Link: https://storage.kernelci.org/next/next-20161017/mips-gpr_defconfig/build.log
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14405/
The KASLR code requires that the plat_get_fdt() function return the
address of the device tree, and it must be available early in the boot,
before prom_init() is called. Move the code determining the address of
the device tree into plat_get_fdt, and call that from prom_init().
The fdt pointer will be set up by plat_get_fdt() called from
relocate_kernel initially and once the relocated kernel has started,
prom_init() will use it again to determine the address in the relocated
image.
Fixes: eed0eabd12ef ("MIPS: generic: Introduce generic DT-based board support")
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14415/
If platform code returns a NULL pointer to the FDT, initial_boot_params
will not get set to a valid pointer and attempting to find the /chosen
node in it will cause a NULL pointer dereference and the kernel to crash
immediately on startup - with no output to the console.
Fix this by checking that initial_boot_params is valid before using it.
Fixes: 405bc8fd12f5 ("MIPS: Kernel: Implement KASLR using CONFIG_RELOCATABLE")
Cc: stable@vger.kernel.org # 4.7+
Patchwork: https://patchwork.linux-mips.org/patch/14414/
Commit 10b6ea0959de ("MIPS: Malta: Use syscon-reboot driver to reboot")
converted the Malta board to use the generic syscon-reboot driver to
handle reboots, but incorrectly used the value 0x4d rather than 0x42 as
the magic to write to the reboot register.
I also incorrectly believed that syscon/regmap would default to native
endianness, but this isn't the case. Force this by specifying with a
native-endian property in the devicetree.
Fixes: 10b6ea0959de ("MIPS: Malta: Use syscon-reboot driver to reboot")
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Maciej W. Rozycki <macro@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14396/
Provide a default implementation of mips_cpc_default_phys_base() which
simply returns 0, and adjust mips_cpc_phys_base() to allow for
mips_cpc_default_phys_base() returning 0. This allows kernels which
include CPC support to be built without platform code & simply ignore
the CPC if it wasn't already enabled by the bootloader.
This fixes link failures such as the following from generic defconfigs:
arch/mips/built-in.o: In function `mips_cpc_phys_base':
arch/mips/kernel/mips-cpc.c:47: undefined reference to `mips_cpc_default_phys_base'
[ralf@linux-mips.org: changed prototype for coding style compliance.]
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/14401/
The advancing of the PC when completing an MMIO load is done before
re-entering the guest, i.e. before restoring the guest ASID. However if
the load is in a branch delay slot it may need to access guest code to
read the prior branch instruction. This isn't safe in TLB mapped code at
the moment, nor in the future when we'll access unmapped guest segments
using direct user accessors too, as it could read the branch from host
user memory instead.
Therefore calculate the resume PC in advance while we're still in the
right context and save it in the new vcpu->arch.io_pc (replacing the no
longer needed vcpu->arch.pending_load_cause), and restore it on MMIO
completion.
Fixes: e685c689f3a8 ("KVM/MIPS32: Privileged instruction/target branch emulation.")
Cc: "Radim Krčmář <rkrcmar@redhat.com>
Cc: <stable@vger.kernel.org> # 3.10.x-
The ERET instruction to return from exception is used for returning from
exception level (Status.EXL) and error level (Status.ERL). If both bits
are set however we should be returning from ERL first, as ERL can
interrupt EXL, for example when an NMI is taken. KVM however checks EXL
first.
Fix the order of the checks to match the pseudocode in the instruction
set manual.
kvm_mips_check_asids() runs before entering the guest and performs lazy
regeneration of host ASID for guest usermode, using last_user_gasid to
track the last guest ASID in the VCPU that was used by guest usermode on
any host CPU.
last_user_gasid is reset after performing the lazy ASID regeneration on
the current CPU, and by kvm_arch_vcpu_load() if the host ASID for guest
usermode is regenerated due to staleness (to cancel outstanding lazy
ASID regenerations). Unfortunately neither case handles SMP hosts
correctly:
- When the lazy ASID regeneration is performed it should apply to all
CPUs (as last_user_gasid does), so reset the ASID on other CPUs to
zero to trigger regeneration when the VCPU is next loaded on those
CPUs.
- When the ASID is found to be stale on the current CPU, we should not
cancel lazy ASID regenerations globally, so drop the reset of
last_user_gasid altogether here.
Both cases would require a guest ASID change and two host CPU migrations
(and in the latter case one of the CPUs to start a new ASID cycle)
before guest usermode could potentially access stale user pages from a
previously running ASID in the same VCPU.
Fixes: 25b08c7fb0e4 ("KVM: MIPS: Invalidate TLB by regenerating ASIDs")
Pull KVM fixes from Radim Krčmář:
"ARM:
- avoid livelock when walking guest page tables
- fix HYP mode static keys without CC_HAVE_ASM_GOTO
MIPS:
- fix a build error without TRACEPOINTS_ENABLED
s390:
- reject a malformed userspace configuration
x86:
- suppress a warning without CONFIG_CPU_FREQ
- initialize whole irq_eoi array"
arm/arm64: KVM: Map the BSS at HYP
arm64: KVM: Take S1 walks into account when determining S2 write faults
KVM: s390: reject invalid modes for runtime instrumentation
kvm: x86: memset whole irq_eoi
kvm/x86: Fix unused variable warning in kvm_timer_init()
KVM: MIPS: Add missing uaccess.h include
Merge the gup_flags cleanups from Lorenzo Stoakes:
"This patch series adjusts functions in the get_user_pages* family such
that desired FOLL_* flags are passed as an argument rather than
implied by flags.
The purpose of this change is to make the use of FOLL_FORCE explicit
so it is easier to grep for and clearer to callers that this flag is
being used. The use of FOLL_FORCE is an issue as it overrides missing
VM_READ/VM_WRITE flags for the VMA whose pages we are reading
from/writing to, which can result in surprising behaviour.
The patch series came out of the discussion around commit 38e088546522
("mm: check VMA flags to avoid invalid PROT_NONE NUMA balancing"),
which addressed a BUG_ON() being triggered when a page was faulted in
with PROT_NONE set but having been overridden by FOLL_FORCE.
do_numa_page() was run on the assumption the page _must_ be one marked
for NUMA node migration as an actual PROT_NONE page would have been
dealt with prior to this code path, however FOLL_FORCE introduced a
situation where this assumption did not hold.
See
https://marc.info/?l=linux-mm&m=147585445805166
for the patch proposal"
Additionally, there's a fix for an ancient bug related to FOLL_FORCE and
FOLL_WRITE by me.
[ This branch was rebased recently to add a few more acked-by's and
reviewed-by's ]
* gup_flag-cleanups:
mm: replace access_process_vm() write parameter with gup_flags
mm: replace access_remote_vm() write parameter with gup_flags
mm: replace __access_remote_vm() write parameter with gup_flags
mm: replace get_user_pages_remote() write/force parameters with gup_flags
mm: replace get_user_pages() write/force parameters with gup_flags
mm: replace get_vaddr_frames() write/force parameters with gup_flags
mm: replace get_user_pages_locked() write/force parameters with gup_flags
mm: replace get_user_pages_unlocked() write/force parameters with gup_flags
mm: remove write/force parameters from __get_user_pages_unlocked()
mm: remove write/force parameters from __get_user_pages_locked()
mm: remove gup_flags FOLL_WRITE games from __get_user_pages()
This removes the 'write' argument from access_process_vm() and replaces
it with 'gup_flags' as use of this function previously silently implied
FOLL_FORCE, whereas after this patch callers explicitly pass this flag.
We make this explicit as use of FOLL_FORCE can result in surprising
behaviour (and hence bugs) within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
MIPS KVM uses user memory accessors but mips.c doesn't directly include
uaccess.h, so include it now.
This wasn't too much of a problem before v4.9-rc1 as asm/module.h
included asm/uaccess.h, however since commit 29abfbd9cbba ("mips:
separate extable.h, switch module.h to it") this is no longer the case.
This resulted in build failures when trace points were disabled, as
trace/define_trace.h includes trace/trace_events.h only ifdef
TRACEPOINTS_ENABLED, which goes on to include asm/uaccess.h via a couple
of other headers.
Fixes: 29abfbd9cbba ("mips: separate extable.h, switch module.h to it")
This removes the 'write' and 'force' use from get_user_pages_unlocked()
and replaces them with 'gup_flags' to make the use of FOLL_FORCE
explicit in callers as use of this flag can result in surprising
Pull MIPS updates from Ralf Baechle:
"This is the main MIPS pull request for 4.9:
MIPS core arch code:
- traps: 64bit kernels should read CP0_EBase 64bit
- traps: Convert ebase to KSEG0
- c-r4k: Drop bc_wback_inv() from icache flush
- c-r4k: Split user/kernel flush_icache_range()
- cacheflush: Use __flush_icache_user_range()
- uprobes: Flush icache via kernel address
- KVM: Use __local_flush_icache_user_range()
- c-r4k: Fix flush_icache_range() for EVA
- Fix -mabi=64 build of vdso.lds
- VDSO: Drop duplicated -I*/-E* aflags
- tracing: move insn_has_delay_slot to a shared header
- tracing: disable uprobe/kprobe on compact branch instructions
- ptrace: Fix regs_return_value for kernel context
- Squash lines for simple wrapper functions
- Move identification of VP(E) into proc.c from smp-mt.c
- Add definitions of SYNC barrierstype values
- traps: Ensure full EBase is written
- tlb-r4k: If there are wired entries, don't use TLBINVF
- Sanitise coherentio semantics
- dma-default: Don't check hw_coherentio if device is non-coherent
- Support per-device DMA coherence
- Adjust MIPS64 CAC_BASE to reflect Config.K0
- Support generating Flattened Image Trees (.itb)
- generic: Introduce generic DT-based board support
- generic: Convert SEAD-3 to a generic board
- Enable hardened usercopy
- Don't specify STACKPROTECTOR in defconfigs
Octeon:
- Delete dead code and files across the platform.
- Change to use all memory into use by default.
- Rename upper case variables in setup code to lowercase.
- Delete legacy hack for broken bootloaders.
- Leave maintaining the link state to the actual ethernet/PHY drivers.
- Add DTS for D-Link DSR-500N.
- Fix PCI interrupt routing on D-Link DSR-500N.
Pistachio:
- Remove ANDROID_TIMED_OUTPUT from defconfig
TX39xx:
- Move GPIO setup from .mem_setup() to .arch_init()
- Convert to Common Clock Framework
TX49xx:
txx9wdt:
- Add missing clock (un)prepare calls for CCF
BMIPS:
- Add PW, GPIO SDHCI and NAND device node names
- Support APPENDED_DTB
- Add missing bcm97435svmb to DT_NONE
- Rename bcm96358nb4ser to bcm6358-neufbox4-sercom
- Add DT examples for BCM63268, BCM3368 and BCM6362
- Add support for BCM3368 and BCM6362
PCI
- Reduce stack frame usage
- Use struct list_head lists
- Support for CONFIG_PCI_DOMAINS_GENERIC
- Make pcibios_set_cache_line_size an initcall
- Inline pcibios_assign_all_busses
- Split pci.c into pci.c & pci-legacy.c
- Introduce CONFIG_PCI_DRIVERS_LEGACY
- Support generic drivers
CPC
- Convert bare 'unsigned' to 'unsigned int'
- Avoid lock when MIPS CM >= 3 is present
GIC:
- Delete unused file smp-gic.c
mt7620:
- Delete unnecessary assignment for the field "owner" from PCI
BCM63xx:
- Let clk_disable() return immediately if clk is NULL
pm-cps:
- Change FSB workaround to CPU blacklist
- Update comments on barrier instructions
- Use MIPS standard lightweight ordering barrier
- Use MIPS standard completion barrier
- Remove selection of sync types
- Add MIPSr6 CPU support
- Support CM3 changes to Coherence Enable Register
SMP:
- Wrap call to mips_cpc_lock_other in mips_cm_lock_other
- Introduce mechanism for freeing and allocating IPIs
cpuidle:
- cpuidle-cps: Enable use with MIPSr6 CPUs.
SEAD3:
- Rewrite to use DT and generic kernel feature.
USB:
- host: ehci-sead3: Remove SEAD-3 EHCI code
FBDEV:
- cobalt_lcdfb: Drop SEAD3 support
dt-bindings:
- Document a binding for simple ASCII LCDs
auxdisplay:
- img-ascii-lcd: driver for simple ASCII LCD displays
irqchip i8259:
- i8259: Add domain before mapping parent irq
- i8259: Allow platforms to override poll function
- i8259: Remove unused i8259A_irq_pending
Malta:
- Rewrite to use DT
of/platform:
- Probe "isa" busses by default
CM:
- Print CM error reports upon bus errors
Module:
- Migrate exception table users off module.h and onto extable.h
- Make various drivers explicitly non-modular:
- Audit and remove any unnecessary uses of module.h
mailmap:
- Canonicalize to Qais' current email address.
Documentation:
- MIPS supports HAVE_REGS_AND_STACK_ACCESS_API
Loongson1C:
- Add CPU support for Loongson1C
- Add board support
- Add defconfig
- Add RTC support for Loongson1C board
All this except one Documentation fix has sat in linux-next and has
survived Imagination's automated build test system"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (127 commits)
Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_API
MIPS: ptrace: Fix regs_return_value for kernel context
MIPS: VDSO: Drop duplicated -I*/-E* aflags
MIPS: Fix -mabi=64 build of vdso.lds
MIPS: Enable hardened usercopy
MIPS: generic: Convert SEAD-3 to a generic board
MIPS: Support generating Flattened Image Trees (.itb)
MIPS: Adjust MIPS64 CAC_BASE to reflect Config.K0
MIPS: Print CM error reports upon bus errors
MIPS: Support per-device DMA coherence
MIPS: dma-default: Don't check hw_coherentio if device is non-coherent
MIPS: Sanitise coherentio semantics
MIPS: PCI: Support generic drivers
MIPS: PCI: Introduce CONFIG_PCI_DRIVERS_LEGACY
MIPS: PCI: Split pci.c into pci.c & pci-legacy.c
MIPS: PCI: Inline pcibios_assign_all_busses
MIPS: PCI: Make pcibios_set_cache_line_size an initcall
MIPS: PCI: Support for CONFIG_PCI_DOMAINS_GENERIC
MIPS: PCI: Use struct list_head lists
Signed-off-by: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14380/
Currently regs_return_value always negates reg[2] if it determines
the syscall has failed, but when called in kernel context this check is
invalid and may result in returning a wrong value.
This fixes errors reported by CONFIG_KPROBES_SANITY_TEST
Fixes: d7e7528bcd45 ("Audit: push audit success and retcode into arch ptrace.h")
Cc: stable@vger.kernel.org # 3.3+
Patchwork: https://patchwork.linux-mips.org/patch/14381/
Pull uaccess.h prepwork from Al Viro:
"Preparations to tree-wide switch to use of linux/uaccess.h (which,
obviously, will allow to start unifying stuff for real). The last step
there, ie
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
`git grep -l "$PATT"|grep -v ^include/linux/uaccess.h`
is not taken here - I would prefer to do it once just before or just
after -rc1. However, everything should be ready for it"
* 'work.uaccess2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
remove a stray reference to asm/uaccess.h in docs
sparc64: separate extable_64.h, switch elf_64.h to it
score: separate extable.h, switch module.h to it
x86: separate extable.h, switch sections.h to it
remove stray include of asm/uaccess.h from cacheflush.h
mn10300: remove a bogus processor.h->uaccess.h include
xtensa: split uaccess.h into C and asm sides
bonding: quit messing with IOCTL
kill __kernel_ds_p off
mn10300: finish verify_area() off
frv: move HAVE_ARCH_UNMAPPED_AREA to pgtable.h
exceptions: detritus removal
Kernel source files need not include <linux/kconfig.h> explicitly
because the top Makefile forces to include it with:
-include $(srctree)/include/linux/kconfig.h
This commit removes explicit includes except the following:
* arch/s390/include/asm/facilities_src.h
* tools/testing/radix-tree/linux/kernel.h
These two are used for host programs.
Link: http://lkml.kernel.org/r/1473656164-11929-1-git-send-email-yamada.masahiro@socionext.com
Daniel Walker reported problems which happens when
crash_kexec_post_notifiers kernel option is enabled
(https://lkml.org/lkml/2015/6/24/44).
In that case, smp_send_stop() is called before entering kdump routines
which assume other CPUs are still online. As the result, kdump
routines fail to save other CPUs' registers. Additionally for MIPS
OCTEON, it misses to stop the watchdog timer.
To fix this problem, call a new kdump friendly function,
crash_smp_send_stop(), instead of the smp_send_stop() when
crash_kexec_post_notifiers is enabled. crash_smp_send_stop() is a
weak function, and it just call smp_send_stop(). Architecture
codes should override it so that kdump can work appropriately.
This patch provides MIPS version.
Fixes: f06e5153f4ae (kernel/panic.c: add "crash_kexec_post_notifiers" option)
Link: http://lkml.kernel.org/r/20160810080950.11028.28000.stgit@sysi4-13.yrl.intra.hitachi.co.jp
Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
Reported-by: Daniel Walker <dwalker@fifo99.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Baoquan He <bhe@redhat.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Xunlei Pang <xpang@redhat.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: David Daney <david.daney@cavium.com>
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: "Steven J. Hill" <steven.hill@cavium.com>
Cc: Corey Minyard <cminyard@mvista.com>
The aflags-vdso is based on ccflags-vdso, which already contains the -I*
and -EL/-EB flags from KBUILD_CFLAGS, but those flags are needlessly
added again to aflags-vdso.
Drop the duplication.
Reported-by: Maciej W. Rozycki <macro@imgtec.com>
Reviewed-by: Maciej W. Rozycki <macro@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14369/
The native ABI vDSO linker script vdso.lds is built by preprocessing
vdso.lds.S, with the native -mabi flag passed in to get the correct ABI
definitions. Unfortunately however certain toolchains choke on -mabi=64
without a corresponding compatible -march flag, for example:
cc1: error: ‘-march=mips32r2’ is not compatible with the selected ABI
scripts/Makefile.build:338: recipe for target 'arch/mips/vdso/vdso.lds' failed
Fix this by including ccflags-vdso in the KBUILD_CPPFLAGS for vdso.lds,
which includes the appropriate -march flag.
Fixes: ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
Cc: stable@vger.kernel.org # 4.4.x-
Patchwork: https://patchwork.linux-mips.org/patch/14368/
Pull protection keys syscall interface from Thomas Gleixner:
"This is the final step of Protection Keys support which adds the
syscalls so user space can actually allocate keys and protect memory
areas with them. Details and usage examples can be found in the
documentation.
The mm side of this has been acked by Mel"
* 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/pkeys: Update documentation
x86/mm/pkeys: Do not skip PKRU register if debug registers are not used
x86/pkeys: Fix pkeys build breakage for some non-x86 arches
x86/pkeys: Add self-tests
x86/pkeys: Allow configuration of init_pkru
x86/pkeys: Default to a restrictive init PKRU
pkeys: Add details of system call use to Documentation/
generic syscalls: Wire up memory protection keys syscalls
x86: Wire up protection keys system calls
x86/pkeys: Allocation/free syscalls
x86/pkeys: Make mprotect_key() mask off additional vm_flags
mm: Implement new pkey_mprotect() system call
x86/pkeys: Add fault handling for PF_PK page fault bit
Enable CONFIG_HARDENED_USERCOPY checks for MIPS, calling check_object
size in all of copy_{to,from}_user(), __copy_{to,from}_user() &
__copy_{to,from}_user_inatomic().
Patchwork: https://patchwork.linux-mips.org/patch/14371/
The declarations of arch-specific functions have been moved to a common
header in commit 3820b4d2789f ('uprobes: Move function declarations out
of arch'), but MIPS and S390 has added them to their own trees later.
Remove the unnecessary duplicates.
Link: http://lkml.kernel.org/r/1472804384-17830-1-git-send-email-marcin.nowakowski@imgtec.com
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Patch series "improvements to the nmi_backtrace code" v9.
This patch series modifies the trigger_xxx_backtrace() NMI-based remote
backtracing code to make it more flexible, and makes a few small
improvements along the way.
The motivation comes from the task isolation code, where there are
scenarios where we want to be able to diagnose a case where some cpu is
about to interrupt a task-isolated cpu. It can be helpful to see both
where the interrupting cpu is, and also an approximation of where the
cpu that is being interrupted is. The nmi_backtrace framework allows us
to discover the stack of the interrupted cpu.
I've tested that the change works as desired on tile, and build-tested
x86, arm, mips, and sparc64. For x86 I confirmed that the generic
cpuidle stuff as well as the architecture-specific routines are in the
new cpuidle section. For arm, mips, and sparc I just build-tested it
and made sure the generic cpuidle routines were in the new cpuidle
section, but I didn't attempt to figure out which the platform-specific
idle routines might be. That might be more usefully done by someone
with platform experience in follow-up patches.
This patch (of 4):
Currently you can only request a backtrace of either all cpus, or all
cpus but yourself. It can also be helpful to request a remote backtrace
of a single cpu, and since we want that, the logical extension is to
support a cpumask as the underlying primitive.
This change modifies the existing lib/nmi_backtrace.c code to take a
cpumask as its basic primitive, and modifies the linux/nmi.h code to use
the new "cpumask" method instead.
The existing clients of nmi_backtrace (arm and x86) are converted to
using the new cpumask approach in this change.
The other users of the backtracing API (sparc64 and mips) are converted
to use the cpumask approach rather than the all/allbutself approach.
The mips code ignored the "include_self" boolean but with this change it
will now also dump a local backtrace if requested.
Link: http://lkml.kernel.org/r/1472487169-14923-2-git-send-email-cmetcalf@mellanox.com
Reviewed-by: Aaron Tomlin <atomlin@redhat.com>
Reviewed-by: Petr Mladek <pmladek@suse.com>
This came to light when implementing native 64-bit atomics for ARCv2.
The atomic64 self-test code uses CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE
to check whether atomic64_dec_if_positive() is available. It seems it
was needed when not every arch defined it. However as of current code
the Kconfig option seems needless
- for CONFIG_GENERIC_ATOMIC64 it is auto-enabled in lib/Kconfig and a
generic definition of API is present lib/atomic64.c
- arches with native 64-bit atomics select it in arch/*/Kconfig and
define the API in their headers
So I see no point in keeping the Kconfig option
Compile tested for:
- blackfin (CONFIG_GENERIC_ATOMIC64)
- x86 (!CONFIG_GENERIC_ATOMIC64)
- ia64
Link: http://lkml.kernel.org/r/1473703083-8625-3-git-send-email-vgupta@synopsys.com
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Zhaoxiu Zeng <zhaoxiu.zeng@gmail.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Ming Lin <ming.l@ssi.samsung.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
We get 1 warning when building kernel with W=1:
drivers/char/mem.c:220:12: warning: no previous prototype for 'phys_mem_access_prot_allowed' [-Wmissing-prototypes]
int __weak phys_mem_access_prot_allowed(struct file *file,
In fact, its declaration is spreading to several header files in
different architecture, but need to be declare in common header file.
So this patch moves phys_mem_access_prot_allowed() to pgtable.h.
Link: http://lkml.kernel.org/r/1473751597-12139-1-git-send-email-baoyou.xie@linaro.org
Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Pull KVM updates from Radim Krčmář:
"All architectures:
- move `make kvmconfig` stubs from x86
- use 64 bits for debugfs stats
ARM:
- Important fixes for not using an in-kernel irqchip
- handle SError exceptions and present them to guests if appropriate
- proxying of GICV access at EL2 if guest mappings are unsafe
- GICv3 on AArch32 on ARMv8
- preparations for GICv3 save/restore, including ABI docs
- cleanups and a bit of optimizations
MIPS:
- A couple of fixes in preparation for supporting MIPS EVA host
kernels
- MIPS SMP host & TLB invalidation fixes
PPC:
- Fix the bug which caused guests to falsely report lockups
- other minor fixes
- a small optimization
s390:
- Lazy enablement of runtime instrumentation
- up to 255 CPUs for nested guests
- rework of machine check deliver
- cleanups and fixes
x86:
- IOMMU part of AMD's AVIC for vmexit-less interrupt delivery
- Hyper-V TSC page
- per-vcpu tsc_offset in debugfs
- accelerated INS/OUTS in nVMX
- cleanups and fixes"
* tag 'kvm-4.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (140 commits)
KVM: MIPS: Drop dubious EntryHi optimisation
KVM: MIPS: Split kernel/user ASID regeneration
KVM: MIPS: Drop other CPU ASIDs on guest MMU changes
KVM: arm/arm64: vgic: Don't flush/sync without a working vgic
KVM: arm64: Require in-kernel irqchip for PMU support
KVM: PPC: Book3s PR: Allow access to unprivileged MMCR2 register
KVM: PPC: Book3S PR: Support 64kB page size on POWER8E and POWER8NVL
KVM: PPC: Book3S: Remove duplicate setting of the B field in tlbie
KVM: PPC: BookE: Fix a sanity check
KVM: PPC: Book3S HV: Take out virtual core piggybacking code
KVM: PPC: Book3S: Treat VTB as a per-subcore register, not per-thread
ARM: gic-v3: Work around definition of gic_write_bpr1
KVM: nVMX: Fix the NMI IDT-vectoring handling
KVM: VMX: Enable MSR-BASED TPR shadow even if APICv is inactive
KVM: nVMX: Fix reload apic access page warning
kvmconfig: add virtio-gpu to config fragment
config: move x86 kvm_guest.config to a common location
arm64: KVM: Remove duplicating init code for setting VMID
ARM: KVM: Support vgic-v3
Convert the MIPS SEAD-3 board support to be a generic board, supported
by generic kernels.
Because the SEAD-3 boot protocol was defined long ago and we don't want
to force a switch to the UHI protocol, SEAD-3 is added as a legacy board
which is detected by reading the REVISION register. This may technically
not be a valid memory read & future work will include attempting to
handle that gracefully. In practice since SEAD-3 is the only legacy
board supported by the generic kernel so far the read will only happen
on SEAD-3 boards, and even once Malta is converted the same REVISION
register exists there too. Other boards such as Boston, Ci20 & Ci40 will
use the UHI boot protocol & thus not run any of the legacy board detect
functions.
Patchwork: https://patchwork.linux-mips.org/patch/14354/
