The symbol is an orphan, get rid of it.
Signed-off-by: Richard Weinberger <richard@nod.at>
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Remove an outdated reference to "most personal computers" having only one
CPU, and change the use of "singleprocessor" and "single processor" in
CONFIG_SMP's documentation to "uniprocessor" across all arches where that
documentation is present.
Signed-off-by: Robert Graffham <psquid@psquid.net>
We've switched over every architecture that supports SMP to it, so
remove the new useless config variable.
Cc: Jan Kara <jack@suse.cz>
After the last architecture switched to generic hard irqs the config
options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code
for !CONFIG_GENERIC_HARDIRQS can be removed.
Original posting:
http://lkml.kernel.org/r/20121214184202.F54094D9@kernel.stglabs.ibm.com
Several architectures have similar stack debugging config options.
They all pretty much do the same thing, some with slightly
differing help text.
This patch changes the architectures to instead enable a Kconfig
boolean, and then use that boolean in the generic Kconfig.debug
to present the actual menu option. This removes a bunch of
duplication and adds consistency across arches.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Reviewed-by: H. Peter Anvin <hpa@zytor.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [for tile]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS")
I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where
needed. I am not sure what I was thinking. Instead, just directly
select VIRT_TO_BUS where it is needed.
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures
that already provide virt_to_bus().
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: <linux-arch@vger.kernel.org>
__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
mn10300 doesn't provide its own atomic64 implementation, so it should pull
in the generic one.
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module signing support from Rusty Russell:
"module signing is the highlight, but it's an all-over David Howells frenzy..."
Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG.
* 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits)
X.509: Fix indefinite length element skip error handling
X.509: Convert some printk calls to pr_devel
asymmetric keys: fix printk format warning
MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking
MODSIGN: Make mrproper should remove generated files.
MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs
MODSIGN: Use the same digest for the autogen key sig as for the module sig
MODSIGN: Sign modules during the build process
MODSIGN: Provide a script for generating a key ID from an X.509 cert
MODSIGN: Implement module signature checking
MODSIGN: Provide module signing public keys to the kernel
MODSIGN: Automatically generate module signing keys if missing
MODSIGN: Provide Kconfig options
MODSIGN: Provide gitignore and make clean rules for extra files
MODSIGN: Add FIPS policy
module: signature checking hook
X.509: Add a crypto key parser for binary (DER) X.509 certificates
MPILIB: Provide a function to read raw data into an MPI
X.509: Add an ASN.1 decoder
X.509: Add simple ASN.1 grammar compiler
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela,
ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version
into asm-generic/module.h for all arches bar MIPS.
Also, use the generic definition mod_arch_specific where possible.
To this end, I've defined three new config bools:
(*) HAVE_MOD_ARCH_SPECIFIC
Arches define this if they don't want to use the empty generic
mod_arch_specific struct.
(*) MODULES_USE_ELF_RELA
Arches define this if their modules can contain RELA records. This causes
the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be
defined by the arch rather than have the core emit an error message.
Arches define this if their modules can contain REL records. This causes
the Elf_Rel mapping to be emitted and allows apply_relocate() to be
Note that it is possible to allow both REL and RELA records: m68k and mips are
two arches that do this.
With this, some arch asm/module.h files can be deleted entirely and replaced
with a generic-y marker in the arch Kbuild file.
Additionally, I have removed the bits from m32r and score that handle the
unsupported type of relocation record as that's now handled centrally.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Rather than #define the options manually in the architecture code, add
Kconfig options for them and select them there instead. This also allows
us to select the compat IPC version parsing automatically for platforms
using the old compat IPC interface.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Sigh, I missed to check which architecture Kconfig files actually
include the core Kconfig file. There are a few which did not. So we
broke them.
Instead of adding the includes to those, we are better off to move the
include to init/Kconfig like we did already with irqs and others.
This does not change anything for the architectures using the old
style periodic timer mode. It just solves the build wreckage there.
For those architectures which use the clock events infrastructure it
moves the include of the core Kconfig file to "General setup" which is
a way more logical place than having it at random locations specified
by the architecture specific Kconfigs.
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Anna-Maria Gleixner <anna-maria@glx-um.de>
Signed-off-by: Anna-Maria Gleixner <anna-maria@glx-um.de>
Link: http://lkml.kernel.org/r/20120518163106.201635926@glx-um.de
ARCH_HAS_NMI_WATCHDOG is a macro defined by arch, but config
HARDLOCKUP_DETECTOR depends on it. This is wrong, ARCH_HAS_NMI_WATCHDOG
has to be a Kconfig config, and arch's need it should select it
explicitly.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Don Zickus <dzickus@redhat.com>
The pci_iomap variant that arch/mn10300/unit-asb2305/pci-iomap.c
uses differs from the generic one in that it does
not use ioremap_nocache for PCI addresses.
However, it turns out that PCI addresses are
automatically noncached, so switching to ioremap_nocache
and to the generic implementation is safe.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
time, s390: Get rid of compile warning
dw_apb_timer: constify clocksource name
time: Cleanup old CONFIG_GENERIC_TIME references that snuck in
time: Change jiffies_to_clock_t() argument type to unsigned long
alarmtimers: Fix error handling
clocksource: Make watchdog reset lockless
posix-cpu-timers: Cure SMP accounting oddities
s390: Use direct ktime path for s390 clockevent device
clockevents: Add direct ktime programming function
clockevents: Make minimum delay adjustments configurable
nohz: Remove "Switched to NOHz mode" debugging messages
proc: Consider NO_HZ when printing idle and iowait times
nohz: Make idle/iowait counter update conditional
nohz: Fix update_ts_time_stat idle accounting
cputime: Clean up cputime_to_usecs and usecs_to_cputime macros
alarmtimers: Rework RTC device selection using class interface
alarmtimers: Add try_to_cancel functionality
alarmtimers: Add more refined alarm state tracking
alarmtimers: Remove period from alarm structure
alarmtimers: Remove interval cap limit hack
Awhile back I removed all the CONFIG_GENERIC_TIME referecnes as
the last of the non-GENERIC_TIME arches were converted.
However, due to the functionality being important and around for
awhile, there apparently were some out of tree hardware enablement
patches that used it and have since been merged.
This patch removes the remaining instances of GENERIC_TIME.
Singed-off-by: John Stultz <john.stultz@linaro.org>
There are numerous broken references to Documentation files (in other
Documentation files, in comments, etc.). These broken references are
caused by typo's in the references, and by renames or removals of the
Documentation files. Some broken references are simply odd.
Fix these broken references, sometimes by dropping the irrelevant text
they were part of.
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
Create generic kernel debugger hooks in the MN10300 arch and make gdbstub use
them. This is a preparation for KGDB support.
Introduce a general config option for kernel debugger hooks so that both
gdbstub and kgdb can use it and add a header file for both debuggers to use.
All chips converted.
Select HAVE_GENERIC_HARDIRQS rather than GENERIC_HARDIRQS in MN10300's main
Kconfig file to avoid this warning:
warning: (MN10300) selects GENERIC_HARDIRQS which has unmet direct dependencies (HAVE_GENERIC_HARDIRQS)
mn10300 implements clocksource and clockevents and selects them
unconditionally in Kconfig. Remove the stale code which seems to be a
leftover of the conversion. Cleanup the configuration switches as well.
Acked-by: John Stultz <johnstul@us.ibm.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Mark Salter <msalter@redhat.com>
No functional change.
All architectures are finally converted. Remove the cruft.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Jeff Dike <jdike@addtoit.com>
For arch which needs USE_GENERIC_SMP_HELPERS, it has to select
USE_GENERIC_SMP_HELPERS, rather than leaving a choice to user, since they
don't provide their own implementions.
Also, move on_each_cpu() to kernel/smp.c, it is strange to put it in
kernel/softirq.c.
For arch which doesn't use USE_GENERIC_SMP_HELPERS, e.g. blackfin, only
on_each_cpu() is compiled.
Signed-off-by: Amerigo Wang <amwang@redhat.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits)
kbuild: convert `arch/tile' to the kconfig mainmenu upgrade
README: cite nconfig
Revert "kconfig: Temporarily disable dependency warnings"
kconfig: Use PATH_MAX instead of 128 for path buffer sizes.
kconfig: Fix realloc usage()
kconfig: Propagate const
kconfig: Don't go out from read config loop when you read new symbol
kconfig: fix menuconfig on debian lenny
kbuild: migrate all arch to the kconfig mainmenu upgrade
kconfig: expand file names
kconfig: use the file's name of sourced file
kconfig: constify file name
kconfig: don't emit warning upon rootmenu's prompt redefinition
kconfig: replace KERNELVERSION usage by the mainmenu's prompt
kconfig: delay gconf window initialization
kconfig: expand by default the rootmenu's prompt
kconfig: add a symbol string expansion helper
kconfig: regen parser
kconfig: implement the `mainmenu' directive
kconfig: allow PACKAGE to be defined on the compiler's command-line
Fix up trivial conflict in arch/mn10300/Kconfig
Change externally visible "Matsushita" instances to "Panasonic" throughout the
MN10300 arch code.
Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com>
Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com>
Add support for SMSC911X and SMC911X for the ASB2364 unit.
cc: steve.glendinning@smsc.com
cc: netdev@vger.kernel.org
Implement generic time support for MN10300.
Signed-off-by: Mark Salter <msalter@redhat.com>
Implement the Panasonic MN10300 AM34 CPU subarch and implement SMP support for
MN10300. Also implement support for the MN2WS0060 processor and the ASB2364
evaluation board which are AM34 based.
Make the settings of interrupt priorities used by various services configurable
at run time.
Make the FPU operate in non-lazy mode under SMP so that when the process that
is currently using the FPU migrates to a different CPU, we don't have to ping
its previous CPU to flush the FPU context.
Make controllable the use of the PIDR register to mark TLB entries as belonging
to particular processes.
An AM34 erratum requires MMUCTR read and write on entry to certain exceptions,
prior to EPSW.NMID being cleared to allow NMIs to happen.
The AM34 core is able to do cache snooping, and so can skip some of the cache
flushing.
Split the cache bits out of arch/mn10300/Kconfig as they're quite complex.
Add CPU register declarations for the AM34 subarch.
Differentiate AM33_2 and AM33_3 CPU cores in configuration. The MN103E010
processor contains an AM33_2 core.
Whilst we're at it, prepare for AM34-based stuff by declaring AM34_2 too.
