path: root/arch/mn10300/Makefile
2010-10-27MN10300: And Panasonic AM34 subarch and implement SMPAkira Takeuchi
Implement the Panasonic MN10300 AM34 CPU subarch and implement SMP support for MN10300. Also implement support for the MN2WS0060 processor and the ASB2364 evaluation board which are AM34 based. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-01-11mn10300: objcopy flags fixMark Salter
The gcc-4.2.1 based toolchain for MN10300 adds some new note sections which need to be stripped from the binary image. This patch takes care of that. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-10Separate out the proc- and unit-specific header directories from the generalDavid Howells
MN10300 arch headers and place them instead in the same directories as contain the .c files for the processor and unit implementations. This permits the symlinks include/asm/proc and include/asm/unit to be dispensed with. This does, however, require that #include <asm/proc/xxx.h> be converted to #include <proc/xxx.h> and similarly for asm/unit -> unit. Signed-off-by: David Howells <dhowells@redhat.com>
2009-04-10Move arch headers from include/asm-mn10300/ to arch/mn10300/include/asm/.David Howells
2008-02-08mn10300: add the MN10300/AM33 architecture to the kernelDavid Howells
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the kernel. This patch also adds board support for the ASB2303 with the ASB2308 daughter board, and the ASB2305. The only processor supported is the MN103E010, which is an AM33v2 core plus on-chip devices. [akpm@linux-foundation.org: nuke cvs control strings] Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com> Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
