path: root/arch/mn10300/include
2011-03-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300 * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: MN10300: gcc 4.6 vs am33 inline assembly MN10300: Deprecate gdbstub MN10300: Allow KGDB to use the MN10300 serial ports MN10300: Emulate single stepping in KGDB on MN10300 MN10300: Generalise kernel debugger kernel halt, reboot or power off hook KGDB: Notify GDB of machine halt, reboot or power off MN10300: Use KGDB MN10300: Create generic kernel debugger hooks MN10300: Create general kernel debugger cache flushing MN10300: Introduce a general config option for kernel debugger hooks MN10300: The icache invalidate functions should disable the icache first MN10300: gdbstub: Restrict single-stepping to non-preemptable non-SMP configs
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23MN10300: gcc 4.6 vs am33 inline assemblyRichard Henderson
GCC 4.6 explicitly represents the MDR register. It may be accessed via the "z" constraint. Perhaps more importantly, it tracks when the MDR register is clobbered and uses the RETF instruction if the incoming value is still valid. Thus it is important to (at least) clobber the MDR register in relevant inline assembly fragments, lest RETF be used incorrectly. The only instances I could find are here. There are reads of the MDR register in kernel/gdb-stub.c, but that's harmless. Although, frankly, __builtin_return_address(0) might be a better thing in those cases. Certainly MDR isn't going to contain anything else that might be useful... Signed-off-by: Richard Henderson <rth@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: NUMA aware alloc_thread_info_node()Eric Dumazet
Add a node parameter to alloc_thread_info(), and change its name to alloc_thread_info_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18MN10300: Emulate single stepping in KGDB on MN10300David Howells
Emulate single stepping in KGDB on MN10300 by way of temporary breakpoint insertion. These breakpoints are never actually seen by KGDB, and will overlay KGDB's own breakpoints. The breakpoints are removed by switch_to() and reinstalled on switching back so that if preemption occurs, the preempting task doesn't hit them (though it will still hit KGDB's regular breakpoints). If KGDB is reentered for any reason, then the single step breakpoint is completely erased and must be set again by the debugger. We take advantage of the fact that KGDB will effectively halt all other CPUs whilst this CPU is single-stepping to avoid SMP problems. If the single-stepping task is preempted and killed without KGDB being reinvoked, then the breakpoint(s) will be cleared and KGDB will be jumped back into. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Use KGDBDavid Howells
2011-03-18MN10300: Create generic kernel debugger hooksDavid Howells
Create generic kernel debugger hooks in the MN10300 arch and make gdbstub use them. This is a preparation for KGDB support. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Create general kernel debugger cache flushingDavid Howells
Create general kernel debugger cache flushing for MN10300 and get rid of the old stuff that gdbstub was using. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Introduce a general config option for kernel debugger hooksDavid Howells
Introduce a general config option for kernel debugger hooks so that both gdbstub and kgdb can use it and add a header file for both debuggers to use. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Remove unused mn10300_intc_* functionsThomas Gleixner
No users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-14MN10300: atomic_read() should ensure it emits a loadDavid Howells
atomic_read() needs to ensure that it emits a load (which it can do by using ACCESS_ONCE()). Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-14MN10300: Proper use of macros get_user() in the case of incremented pointersTkhai Kirill
Using __get_user_check(x, ptr++, size) leads to double increment of pointer. This macro uses the macro get_user directly, which itself is used in this way (get_user(x, ptr++)) in some functions of the kernel. The patch fixes the error. Reported-by: Tkhai Kirill <tkhai@yandex.ru> Signed-off-by: David Howells <dhowells@redhat.com>
2010-12-03MN10300: Implement asm/syscall.hDavid Howells
Implement asm/syscall.h for the MN10300 arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: (44 commits) MN10300: Save frame pointer in thread_info struct rather than global var MN10300: Change "Matsushita" to "Panasonic". MN10300: Create a defconfig for the ASB2364 board MN10300: Update the ASB2303 defconfig MN10300: ASB2364: Add support for SMSC911X and SMC911X MN10300: ASB2364: Handle the IRQ multiplexer in the FPGA MN10300: Generic time support MN10300: Specify an ELF HWCAP flag for MN10300 Atomic Operations Unit support MN10300: Map userspace atomic op regs as a vmalloc page MN10300: And Panasonic AM34 subarch and implement SMP MN10300: Delete idle_timestamp from irq_cpustat_t MN10300: Make various interrupt priority settings configurable MN10300: Optimise do_csum() MN10300: Implement atomic ops using atomic ops unit MN10300: Make the FPU operate in non-lazy mode under SMP MN10300: SMP TLB flushing MN10300: Use the [ID]PTEL2 registers rather than [ID]PTEL for TLB control MN10300: Make the use of PIDR to mark TLB entries controllable MN10300: Rename __flush_tlb*() to local_flush_tlb*() MN10300: AM34 erratum requires MMUCTR read and write on exception entry ...
2010-10-27mm: fix race in kunmap_atomic()Peter Zijlstra
Christoph reported a nice splat which illustrated a race in the new stack based kmap_atomic implementation. The problem is that we pop our stack slot before we're completely done resetting its state -- in particular clearing the PTE (sometimes that's CONFIG_DEBUG_HIGHMEM). If an interrupt happens before we actually clear the PTE used for the last slot, that interrupt can reuse the slot in a dirty state, which triggers a BUG in kmap_atomic(). Fix this by introducing kmap_atomic_idx() which reports the current slot index without actually releasing it and use that to find the PTE and delay the _pop() until after we're completely done. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Christoph Hellwig <hch@infradead.org> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27MN10300: Save frame pointer in thread_info struct rather than global varDavid Howells
Save the current exception frame pointer in the thread_info struct rather than in a global variable as the latter makes SMP tricky, especially when preemption is also enabled. This also replaces __frame with current_frame() and rearranges header file inclusions to make it all compile. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com>
2010-10-27MN10300: ASB2364: Add support for SMSC911X and SMC911XAkira Takeuchi
Add support for SMSC911X and SMC911X for the ASB2364 unit. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: steve.glendinning@smsc.com cc: netdev@vger.kernel.org
2010-10-27MN10300: ASB2364: Handle the IRQ multiplexer in the FPGADavid Howells
Handle the IRQ multiplexer in the FPGA by implementing a cascade interrupt driver for it. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Generic time supportMark Salter
Implement generic time support for MN10300. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Specify an ELF HWCAP flag for MN10300 Atomic Operations Unit supportMark Salter
Use an ELF HWCAP flag to indicate to the process that the CPU provides LL/SC equivalent atomic operations unit support in addition to BSET/BCLR. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Map userspace atomic op regs as a vmalloc pageMark Salter
The AM34 processor has an atomic operation that's the equivalent of LL/SC on other architectures. However, rather than being done through a pair of instructions, it's driven by writing to a pair of memory-mapped CPU control registers. One set of these registers (AARU/ADRU/ASRU) is available for use by userspace, but for userspace to access them a PTE must be set up to cover the region. This is done by dedicating the first vmalloc region page to this purpose, setting the permissions on its PTE such that userspace can access the page. glibc is hardcoded to expect the registers to be there. The way atomic ops are done through these registers is straightforward: (1) Write the address of the word you wish to access into AARU. This causes the CPU to go and fetch that word and load it into ADRU. The status bits are also cleared in ASRU. (2) The current data value is read from the ADRU register and modified. (3) To alter the data in RAM, the revised data is written back to the ADRU register, which causes the CPU to attempt to write it back. (4) The ASRU.RW flag (ASRU read watch), ASRU.LW flag (bus lock watch), ASRU.IW (interrupt watch) and the ASRU.BW (bus error watch) flags then must be checked to confirm that the operation wasn't aborted. If any of the watches have been set to true, the operation was aborted. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: And Panasonic AM34 subarch and implement SMPAkira Takeuchi
Implement the Panasonic MN10300 AM34 CPU subarch and implement SMP support for MN10300. Also implement support for the MN2WS0060 processor and the ASB2364 evaluation board which are AM34 based. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Delete idle_timestamp from irq_cpustat_tAkira Takeuchi
Delete idle_timestamp from irq_cpustat_t as it's an unread relic. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Make various interrupt priority settings configurableAkira Takeuchi
Make the settings of interrupt priorities used by various services configurable at run time. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Implement atomic ops using atomic ops unitMark Salter
Implement atomic ops using the atomic ops unit available in the AM34 CPU. This allows the equivalent of the LL/SC instructions to be found on other CPUs. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Make the FPU operate in non-lazy mode under SMPAkira Takeuchi
Make the FPU operate in non-lazy mode under SMP so that when the process that is currently using the FPU migrates to a different CPU, we don't have to ping its previous CPU to flush the FPU context. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: SMP TLB flushingAkira Takeuchi
Implement global TLB flushing for MN10300. This will be used by the AM34 which is SMP capable. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Use the [ID]PTEL2 registers rather than [ID]PTEL for TLB controlAkira Takeuchi
Use the [ID]PTEL2 registers rather than [ID]PTEL for TLB control as the bits are a more suitable layout. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Make the use of PIDR to mark TLB entries controllableAkira Takeuchi
Make controllable the use of the PIDR register to mark TLB entries as belonging to particular processes. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Rename __flush_tlb*() to local_flush_tlb*()David Howells
Rename __flush_tlb*() to local_flush_tlb*() as it's more appropriate, and ready to differentiate local from global TLB flushes when SMP is introduced. Whilst we're at it, get rid of __flush_tlb_global() and make local_flush_tlb_page() take an mm_struct pointer rather than VMA pointer. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Allow some cacheflushes to be avoided if cache snooping is availableDavid Howells
The AM34 core is able to do cache snooping, and so can skip some of the cache flushing. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: SMP: Differentiate local cache flushingAkira Takeuchi
Differentiate local cache flushing from global cache flushing so that they can be done differently on SMP systems. Rename the cache functions from: mn10300_[id]cache_*() to: mn10300_[id]_localcache_*() and on a UP system, assign the global labels to the local labels. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Cacheflush functions should take unsigned long addressesAkira Takeuchi
The functions that perform cache flushing should take addresses of unsigned long type, not unsigned int. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Reorder asm/cacheflush.h to put primitives firstDavid Howells
Reorder asm/cacheflush.h to put arch primitives first, before the main functions so that the main functions can be inline asm rather than #defines when non-trivial. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Provide a MN10300_CACHE_ENABLED config optionDavid Howells
Provide a MN10300_CACHE_ENABLED config option as inverted logic of MN10300_CACHE_DISABLED to make things simpler. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Remove monitor/JTAG functionsAkira Takeuchi
Remove the monitor trap function and the set_jtag_stub function as they're not really necessary. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Add CPU register bits for AM34Akira Takeuchi
Add CPU register declarations for the AM34 subarch. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Don't hard code the cacheline size in register defsAkira Takeuchi
Don't hard code the cacheline size in the cache control register definitions. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Move DMA engine control reg defs to MN103E010 processor directoryAkira Takeuchi
Move the DMA engine control register definitions to the MN103E010 processor directory so that the MN2WS0050 processor can have its own. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Provide the functions to fully disable maskable interruptsAkira Takeuchi
The local_irq_disable() function and co. merely raise the interrupt mask on the MN10300 arch to exclude normal interrupts. This still lets other, higher priority maskable interrupts through, such as are used to service gdbstub's serial port and the MN10300 on-chip serial port virtual FIFOs. Provide functions to allow the maskable interrupts to be fully disabled, which will exclude those interrupts. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Add reads[bwl]() and writes[bwl]()Akira Takeuchi
Add reads[bwl]() and writes[bwl]() for MN10300. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Don't cast away the volatile in test_bit()Akira Takeuchi
Don't cast away the volatile in test_bit()'s parameter when we change its type from const volatile void * so that we can dereference it. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27bitops: Change the bitmap index from int to unsigned long [mn10300]Justin Chen
Change the index to unsigned long in all bitops for [mn10300] Signed-off-by: Justin Chen <justin.chen@hp.com> Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: stack based kmap_atomic()Peter Zijlstra
Keep the current interface but ignore the KM_type and use a stack based approach. The advantage is that we get rid of crappy code like: #define __KM_PTE \ (in_nmi() ? KM_NMI_PTE : \ in_irq() ? KM_IRQ_PTE : \ KM_PTE0) and in general can stop worrying about what context we're in and what kmap slots might be appropriate for that. The downside is that FRV kmap_atomic() gets more expensive. For now we use a CPP trick suggested by Andrew: #define kmap_atomic(page, args...) __kmap_atomic(page) to avoid having to touch all kmap_atomic() users in a single patch. [ not compiled on: - mn10300: the arch doesn't actually build with highmem to begin with ] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits) serial8250: ratelimit "too much work" error serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster serial: abstraction for 8250 legacy ports serial/imx: check that the buffer is non-empty before sending it out serial: mfd: add more baud rates support jsm: Remove the uart port on errors Alchemy: Add UART PM methods. 8250: allow platforms to override PM hook. altera_uart: Don't use plain integer as NULL pointer altera_uart: Fix missing prototype for registering an early console altera_uart: Fixup type usage of port flags altera_uart: Make it possible to use Altera UART and 8250 ports together altera_uart: Add support for different address strides altera_uart: Add support for getting mapbase and IRQ from resources altera_uart: Add support for polling mode (IRQ-less) serial: Factor out uart_poll_timeout() from 8250 driver serial: mark the 8250 driver as maintained serial: 8250: Don't delay after transmitter is ready. tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver vcs: invoke the vt update callback when /dev/vcs* is written to ...
