git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull strscpy string copy function implementation from Chris Metcalf.
Chris sent this during the merge window, but I waffled back and forth on
the pull request, which is why it's going in only now.
The new "strscpy()" function is definitely easier to use and more secure
than either strncpy() or strlcpy(), both of which are horrible nasty
interfaces that have serious and irredeemable problems.
strncpy() has a useless return value, and doesn't NUL-terminate an
overlong result. To make matters worse, it pads a short result with
zeroes, which is a performance disaster if you have big buffers.
strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking
the insane NUL padding, but having a differently broken return value
which returns the original length of the source string. Which means
that it will read characters past the count from the source buffer, and
you have to trust the source to be properly terminated. It also makes
error handling fragile, since the test for overflow is unnecessarily
subtle.
strscpy() avoids both these problems, guaranteeing the NUL termination
(but not excessive padding) if the destination size wasn't zero, and
making the overflow condition very obvious by returning -E2BIG. It also
doesn't read past the size of the source, and can thus be used for
untrusted source data too.
So why did I waffle about this for so long?
Every time we introduce a new-and-improved interface, people start doing
these interminable series of trivial conversion patches.
And every time that happens, somebody does some silly mistake, and the
conversion patch to the improved interface actually makes things worse.
Because the patch is mindnumbing and trivial, nobody has the attention
span to look at it carefully, and it's usually done over large swatches
of source code which means that not every conversion gets tested.
So I'm pulling the strscpy() support because it *is* a better interface.
But I will refuse to pull mindless conversion patches. Use this in
places where it makes sense, but don't do trivial patches to fix things
that aren't actually known to be broken.
* 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tile: use global strscpy() rather than private copy
string: provide strscpy()
Make asm/word-at-a-time.h available on all architectures
Pull locking and atomic updates from Ingo Molnar:
"Main changes in this cycle are:
- Extend atomic primitives with coherent logic op primitives
(atomic_{or,and,xor}()) and deprecate the old partial APIs
(atomic_{set,clear}_mask())
The old ops were incoherent with incompatible signatures across
architectures and with incomplete support. Now every architecture
supports the primitives consistently (by Peter Zijlstra)
- Generic support for 'relaxed atomics':
- _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return()
- atomic_read_acquire()
- atomic_set_release()
This came out of porting qwrlock code to arm64 (by Will Deacon)
- Clean up the fragile static_key APIs that were causing repeat bugs,
by introducing a new one:
DEFINE_STATIC_KEY_TRUE(name);
DEFINE_STATIC_KEY_FALSE(name);
which define a key of different types with an initial true/false
value.
Then allow:
static_branch_likely()
static_branch_unlikely()
to take a key of either type and emit the right instruction for the
case. To be able to know the 'type' of the static key we encode it
in the jump entry (by Peter Zijlstra)
- Static key self-tests (by Jason Baron)
- qrwlock optimizations (by Waiman Long)
- small futex enhancements (by Davidlohr Bueso)
- ... and misc other changes"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits)
jump_label/x86: Work around asm build bug on older/backported GCCs
locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations
locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h
locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics
locking/qrwlock: Implement queue_write_unlock() using smp_store_release()
locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition
locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t'
locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication
locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations
locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic
locking/static_keys: Make verify_keys() static
jump label, locking/static_keys: Update docs
locking/static_keys: Provide a selftest
jump_label: Provide a self-test
s390/uaccess, locking/static_keys: employ static_branch_likely()
x86, tsc, locking/static_keys: Employ static_branch_likely()
locking/static_keys: Add selftest
locking/static_keys: Add a new static_key interface
locking/static_keys: Rework update logic
locking/static_keys: Add static_key_{en,dis}able() helpers
This adds ioremap_uc() only for architectures that do not
include asm-generic.h/io.h as that already provides a default
definition for them for both cases where you have CONFIG_MMU
and you do not, and because of this, the number of architectures
this patch address is less than the architectures that the
ioremap_wt() patch addressed, "arch/*/io.h: Add ioremap_wt() to
all architectures").
In order to reduce the number of architectures we have to
modify by adding new architecture IO APIs we'll have to review
the architectures in this patch, see why they can't add
asm-generic.h/io.h or issues that would be created by doing
so and then spread a consistent inclusion of this header
towards the end of their own header. For instance arch/metag
includes the asm-generic/io.h *before* the ioremap*()
definitions, this should be the other way around but only
once we have guard wrappers for the non-MMU case also for
asm-generic/io.h.
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Abhilash Kesavan <a.kesavan@samsung.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Kyle McMartin <kyle@redhat.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Peter Hurley <peter@hurleysoftware.com>
Cc: Rob Herring <robh@kernel.org>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: linux-am33-list@redhat.com
Cc: linux-m68k@lists.linux-m68k.org
Cc: linux-sh@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20150728181713.GB30479@wotan.suse.de
Move the now generic definitions of atomic_{set,clear}_mask() into
linux/atomic.h to avoid endless and pointless repetition.
Also, provide an atomic_andnot() wrapper for those few archs that can
implement that.
Implement atomic logic ops -- atomic_{or,xor,and}.
These will replace the atomic_{set,clear}_mask functions that are
available on some archs.
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty
header file (mm-arch-hooks.h) for every architecture, even those which
doesn't need to define mm hooks.
As suggested by Geert Uytterhoeven, this could be cleaned through the use
of a generic header file included via each per architecture
asm/include/Kbuild file.
The PowerPC architecture is not impacted here since this architecture has
to defined the arch_remap MM hook.
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Added the x86 implementation of word-at-a-time to the
generic version, which previously only supported big-endian.
Omitted the x86-specific load_unaligned_zeropad(), which in
any case is also not present for the existing BE-only
implementation of a word-at-a-time, and is only used under
CONFIG_DCACHE_WORD_ACCESS.
Added as a "generic-y" to the Kbuilds of all architectures
that didn't previously have it.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here's the tty and serial driver patches for 4.2-rc1.
A number of individual driver updates, some code cleanups, and other
minor things, full details in the shortlog.
All have been in linux-next for a while with no reported issues"
* tag 'tty-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (152 commits)
Doc: serial-rs485.txt: update RS485 driver interface
Doc: tty.txt: remove mention of the BKL
MAINTAINERS: tty: add serial docs directory
serial: sprd: check for NULL after calling devm_clk_get
serial: 8250_pci: Correct uartclk for xr17v35x expansion chips
serial: 8250_pci: Add support for 12 port Exar boards
serial: 8250_uniphier: add bindings document for UniPhier UART
serial: core: cleanup in uart_get_baud_rate()
serial: stm32-usart: Add STM32 USART Driver
tty/serial: kill off set_irq_flags usage
tty: move linux/gsmmux.h to uapi
doc: dt: add documentation for nxp,lpc1850-uart
serial: 8250: add LPC18xx/43xx UART driver
serial: 8250_uniphier: add UniPhier serial driver
serial: 8250_dw: support ACPI platforms with integrated DMA engine
serial: of_serial: check the return value of clk_prepare_enable()
serial: of_serial: use devm_clk_get() instead of clk_get()
serial: earlycon: Add support for big-endian MMIO accesses
serial: sirf: use hrtimer for data rx
serial: sirf: correct the fifo empty_bit
Pull asm/scatterlist.h removal from Jens Axboe:
"We don't have any specific arch scatterlist anymore, since parisc
finally switched over. Kill the include"
* 'for-4.2/sg' of git://git.kernel.dk/linux-block:
remove scatterlist.h generation from arch Kbuild files
remove <asm/scatterlist.h>
CRIU is recreating the process memory layout by remapping the checkpointee
memory area on top of the current process (criu). This includes remapping
the vDSO to the place it has at checkpoint time.
However some architectures like powerpc are keeping a reference to the
vDSO base address to build the signal return stack frame by calling the
vDSO sigreturn service. So once the vDSO has been moved, this reference
is no more valid and the signal frame built later are not usable.
This patch serie is introducing a new mm hook framework, and a new
arch_remap hook which is called when mremap is done and the mm lock still
hold. The next patch is adding the vDSO remap and unmap tracking to the
powerpc architecture.
This patch (of 3):
This patch introduces a new set of header file to manage mm hooks:
- per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h)
- a generic header (include/linux/mm-arch-hooks.h)
The architecture which need to overwrite a hook as to redefine it in its
header file, while architecture which doesn't need have nothing to do.
The default hooks are defined in the generic header and are used in the
case the architecture is not defining it.
In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should
be moved here.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v4.2 merge window:
Enumeration
- Move pci_ari_enabled() to global header (Alex Williamson)
- Account for ARI in _PRT lookups (Alex Williamson)
- Remove unused pci_scan_bus_parented() (Yijing Wang)
Resource management
- Use host bridge _CRS info on systems with >32 bit addressing (Bjorn Helgaas)
- Use host bridge _CRS info on Foxconn K8M890-8237A (Bjorn Helgaas)
- Fix pci_address_to_pio() conversion of CPU address to I/O port (Zhichang Yuan)
- Add pci_bus_addr_t (Yinghai Lu)
PCI device hotplug
- Wait for pciehp command completion where necessary (Alex Williamson)
- Drop pointless ACPI-based "slot detection" check (Rafael J. Wysocki)
- Check ignore_hotplug for all downstream devices (Rafael J. Wysocki)
- Propagate the "ignore hotplug" setting to parent (Rafael J. Wysocki)
- Inline pciehp "handle event" functions into the ISR (Bjorn Helgaas)
- Clean up pciehp debug logging (Bjorn Helgaas)
Power management
- Remove redundant PCIe port type checking (Yijing Wang)
- Add dev->has_secondary_link to track downstream PCIe links (Yijing Wang)
- Use dev->has_secondary_link to find downstream links for ASPM (Yijing Wang)
- Drop __pci_disable_link_state() useless "force" parameter (Bjorn Helgaas)
- Simplify Clock Power Management setting (Bjorn Helgaas)
Virtualization
- Add ACS quirks for Intel 9-series PCH root ports (Alex Williamson)
- Add function 1 DMA alias quirk for Marvell 9120 (Sakari Ailus)
MSI
- Disable MSI at enumeration even if kernel doesn't support MSI (Michael S. Tsirkin)
- Remove unused pci_msi_off() (Bjorn Helgaas)
- Rename msi_set_enable(), msix_clear_and_set_ctrl() (Michael S. Tsirkin)
- Export pci_msi_set_enable(), pci_msix_clear_and_set_ctrl() (Michael S. Tsirkin)
- Drop pci_msi_off() calls during probe (Michael S. Tsirkin)
APM X-Gene host bridge driver
- Add APM X-Gene v1 PCIe MSI/MSIX termination driver (Duc Dang)
- Add APM X-Gene PCIe MSI DTS nodes (Duc Dang)
- Disable Configuration Request Retry Status for v1 silicon (Duc Dang)
- Allow config access to Root Port even when link is down (Duc Dang)
Broadcom iProc host bridge driver
- Allow override of device tree IRQ mapping function (Hauke Mehrtens)
- Add BCMA PCIe driver (Hauke Mehrtens)
- Directly add PCI resources (Hauke Mehrtens)
- Free resource list after registration (Hauke Mehrtens)
Freescale i.MX6 host bridge driver
- Add speed change timeout message (Troy Kisky)
- Rename imx6_pcie_start_link() to imx6_pcie_establish_link() (Bjorn Helgaas)
Freescale Layerscape host bridge driver
- Use dw_pcie_link_up() consistently (Bjorn Helgaas)
- Factor out ls_pcie_establish_link() (Bjorn Helgaas)
Marvell MVEBU host bridge driver
- Remove mvebu_pcie_scan_bus() (Yijing Wang)
NVIDIA Tegra host bridge driver
- Remove tegra_pcie_scan_bus() (Yijing Wang)
Synopsys DesignWare host bridge driver
- Consolidate outbound iATU programming functions (Jisheng Zhang)
- Use iATU0 for cfg and IO, iATU1 for MEM (Jisheng Zhang)
- Add support for x8 links (Zhou Wang)
- Wait for link to come up with consistent style (Bjorn Helgaas)
- Use pci_scan_root_bus() for simplicity (Yijing Wang)
TI DRA7xx host bridge driver
Miscellaneous
- Include <linux/pci.h>, not <asm/pci.h> (Bjorn Helgaas)
- Remove unnecessary #includes of <asm/pci.h> (Bjorn Helgaas)
- Remove unused pcibios_select_root() (again) (Bjorn Helgaas)
- Remove unused pci_dma_burst_advice() (Bjorn Helgaas)
- xen/pcifront: Don't use deprecated function pci_scan_bus_parented() (Arnd Bergmann)"
* tag 'pci-v4.2-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (58 commits)
PCI: pciehp: Inline the "handle event" functions into the ISR
PCI: pciehp: Rename queue_interrupt_event() to pciehp_queue_interrupt_event()
PCI: pciehp: Make queue_interrupt_event() void
PCI: xgene: Allow config access to Root Port even when link is down
PCI: xgene: Disable Configuration Request Retry Status for v1 silicon
PCI: pciehp: Clean up debug logging
x86/PCI: Use host bridge _CRS info on systems with >32 bit addressing
PCI: imx6: Add #define PCIE_RC_LCSR
PCI: imx6: Use "u32", not "uint32_t"
PCI: Remove unused pci_scan_bus_parented()
PCI: imx6: Add speed change timeout message
PCI/ASPM: Simplify Clock Power Management setting
PCI: designware: Wait for link to come up with consistent style
PCI: layerscape: Factor out ls_pcie_establish_link()
PCI: layerscape: Use dw_pcie_link_up() consistently
PCI: dra7xx: Use dw_pcie_link_up() consistently
x86/PCI: Use host bridge _CRS info on Foxconn K8M890-8237A
PCI: pciehp: Wait for hotplug command completion where necessary
PCI: Remove unused pci_dma_burst_advice()
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
The main changes in this cycle were:
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
a6c140969b46 ("Delete pcibios_select_root") removed pcibios_select_root().
But a7db50405216 ("PCI: remove pcibios_scan_all_fns()") added a few copies
back, probably with some incorrect merge conflict resolutions.
Remove the still-unused pcibios_select_root() definitions.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Add ioremap_wt() to all arch-specific asm/io.h headers which
define ioremap_wc() locally. These headers do not include
<asm-generic/iomap.h>. Some of them include <asm-generic/io.h>,
but ioremap_wt() is defined for consistency since they define
all ioremap_xxx locally.
In all architectures without Write-Through support, ioremap_wt()
is defined indentical to ioremap_nocache().
frv and m68k already have ioremap_writethrough(). On those we
add ioremap_wt() indetical to ioremap_writethrough() and defines
ARCH_HAS_IOREMAP_WT in both architectures.
The ioremap_wt() interface is exported to drivers.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Cc: Elliott@hp.com
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: jgross@suse.com
Cc: konrad.wilk@oracle.com
Cc: linux-mm <linux-mm@kvack.org>
Cc: linux-nvdimm@lists.01.org
Cc: stefan.bader@canonical.com
Cc: yigal@plexistor.com
Link: http://lkml.kernel.org/r/1433436928-31903-9-git-send-email-bp@alien8.de
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
The existing code relies on pagefault_disable() implicitly disabling
preemption, so that no schedule will happen between kmap_atomic() and
kunmap_atomic().
Let's make this explicit, to prepare for pagefault_disable() not
touching preemption anymore.
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: schwidefsky@de.ibm.com
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-5-git-send-email-dahi@linux.vnet.ibm.com
Remove CONFIG_SERIAL_DETECT_IRQ and CONFIG_SERIAL_MANY_PORTS, and
substitute all references to the proper 8250 Kconfig options. Now, the
actual Kconfig dependencies are not hidden when reading the code and
static analyzers are less confused.
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
We don't have any arch specific scatterlist now that parisc switched over
to the generic one.
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull second batch of devicetree updates from Rob Herring:
"As Grant mentioned in the first devicetree pull request, here is the
2nd batch of DT changes for 4.1. The main remaining item here is the
endianness bindings and related 8250 driver support.
- DT endianness specification bindings
- big-endian 8250 serial support
- DT overlay unittest updates
- various DT doc updates
- compile fixes for OF_IRQ=n"
* tag 'devicetree-for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
frv: add io{read,write}{16,32}be functions
mn10300: add io{read,write}{16,32}be functions
Documentation: DT bindings: add doc for Altera's SoCFPGA platform
of: base: improve of_get_next_child() kernel-doc
Doc: dt: arch_timer: discourage clock-frequency use
of: unittest: overlay: Keep track of created overlays
of/fdt: fix allocation size for device node path
serial: of_serial: Support big-endian register accesses
serial: 8250: Add support for big-endian MMIO accesses
of: Document {little,big,native}-endian bindings
of/fdt: Add endianness helper function for early init code
of: Add helper function to check MMIO register endianness
of/fdt: Remove "reg" data prints from early_init_dt_scan_memory
of: add vendor prefix for Artesyn
of: Add dummy of_irq_to_resource_table() for IRQ_OF=n
of: OF_IRQ should depend on IRQ_DOMAIN
These functions are used in various drivers, including the latest
version of the 8250 driver. The latter causes the following build failure.
drivers/tty/serial/8250/8250_core.c: In function 'mem32be_serial_out':
drivers/tty/serial/8250/8250_core.c:456:2: error:
implicit declaration of function 'iowrite32be'
drivers/tty/serial/8250/8250_core.c: In function 'mem32be_serial_in':
drivers/tty/serial/8250/8250_core.c:462:2: error:
implicit declaration of function 'ioread32be'
Cc: Kevin Cernekee <cernekee@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Fixes: c627f2ceb692 ("serial: 8250: Add support for big-endian MMIO
accesses")
Signed-off-by: Rob Herring <robh@kernel.org>
As execution domain support is gone we can remove
signal translation from the signal code and remove
exec_domain from thread_info.
Signed-off-by: Richard Weinberger <richard@nod.at>
Core mm expects __PAGETABLE_{PUD,PMD}_FOLDED to be defined if these page
table levels folded. Usually, these defines are provided by
<asm-generic/pgtable-nopmd.h> and <asm-generic/pgtable-nopud.h>.
But some architectures fold page table levels in a custom way. They
need to define these macros themself. This patch adds missing defines.
The patch fixes mm->nr_pmds underflow and eliminates dead __pmd_alloc()
and __pud_alloc() on architectures without these page table levels.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
LKP has triggered a compiler warning after my recent patch "mm: account
pmd page tables to the process":
mm/mmap.c: In function 'exit_mmap':
>> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default]
The code:
> 2857 WARN_ON(mm_nr_pmds(mm) >
2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT);
In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has
the same type -- int. PUD_SHIFT.
I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned
long. On every arch for consistency.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
We've replaced remap_file_pages(2) implementation with emulation. Nobody
creates non-linear mapping anymore.
This patch also increases the number of bits availble for swap offset.
Kim Phillips reported following build failure.
LD init/built-in.o
mm/built-in.o: In function `free_pages_prepare':
mm/page_alloc.c:770: undefined reference to `.kernel_map_pages'
mm/built-in.o: In function `prep_new_page':
mm/page_alloc.c:933: undefined reference to `.kernel_map_pages'
mm/built-in.o: In function `map_pages':
mm/compaction.c:61: undefined reference to `.kernel_map_pages'
make: *** [vmlinux] Error 1
Reason for this problem is that commit 031bc5743f15
("mm/debug-pagealloc: make debug-pagealloc boottime configurable")
forgot to remove the old declaration of kernel_map_pages() for some
architectures. This patch removes them to fix build failure.
Reported-by: Kim Phillips <kim.phillips@freescale.com>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Pull networking updates from David Miller:
1) New offloading infrastructure and example 'rocker' driver for
offloading of switching and routing to hardware.
This work was done by a large group of dedicated individuals, not
limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend,
Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu
2) Start making the networking operate on IOV iterators instead of
modifying iov objects in-situ during transfers. Thanks to Al Viro
and Herbert Xu.
3) A set of new netlink interfaces for the TIPC stack, from Richard
Alpe.
4) Remove unnecessary looping during ipv6 routing lookups, from Martin
KaFai Lau.
5) Add PAUSE frame generation support to gianfar driver, from Matei
Pavaluca.
6) Allow for larger reordering levels in TCP, which are easily
achievable in the real world right now, from Eric Dumazet.
7) Add a variable of napi_schedule that doesn't need to disable cpu
interrupts, from Eric Dumazet.
8) Use a doubly linked list to optimize neigh_parms_release(), from
Nicolas Dichtel.
9) Various enhancements to the kernel BPF verifier, and allow eBPF
programs to actually be attached to sockets. From Alexei
Starovoitov.
10) Support TSO/LSO in sunvnet driver, from David L Stevens.
11) Allow controlling ECN usage via routing metrics, from Florian
Westphal.
12) Remote checksum offload, from Tom Herbert.
13) Add split-header receive, BQL, and xmit_more support to amd-xgbe
driver, from Thomas Lendacky.
14) Add MPLS support to openvswitch, from Simon Horman.
15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen
Klassert.
16) Do gro flushes on a per-device basis using a timer, from Eric
Dumazet. This tries to resolve the conflicting goals between the
desired handling of bulk vs. RPC-like traffic.
17) Allow userspace to ask for the CPU upon what a packet was
received/steered, via SO_INCOMING_CPU. From Eric Dumazet.
18) Limit GSO packets to half the current congestion window, from Eric
Dumazet.
19) Add a generic helper so that all drivers set their RSS keys in a
consistent way, from Eric Dumazet.
20) Add xmit_more support to enic driver, from Govindarajulu
Varadarajan.
21) Add VLAN packet scheduler action, from Jiri Pirko.
22) Support configurable RSS hash functions via ethtool, from Eyal
Perry.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits)
Fix race condition between vxlan_sock_add and vxlan_sock_release
net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header
net/mlx4: Add support for A0 steering
net/mlx4: Refactor QUERY_PORT
net/mlx4_core: Add explicit error message when rule doesn't meet configuration
net/mlx4: Add A0 hybrid steering
net/mlx4: Add mlx4_bitmap zone allocator
net/mlx4: Add a check if there are too many reserved QPs
net/mlx4: Change QP allocation scheme
net/mlx4_core: Use tasklet for user-space CQ completion events
net/mlx4_core: Mask out host side virtualization features for guests
net/mlx4_en: Set csum level for encapsulated packets
be2net: Export tunnel offloads only when a VxLAN tunnel is created
gianfar: Fix dma check map error when DMA_API_DEBUG is enabled
cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call
net: fec: only enable mdio interrupt before phy device link up
net: fec: clear all interrupt events to support i.MX6SX
net: fec: reset fep link status in suspend function
net: sock: fix access via invalid file descriptor
net: introduce helper macro for_each_cmsghdr
As there are now no remaining users of arch_fast_hash(), lets kill
it entirely.
This basically reverts commit 71ae8aac3e19 ("lib: introduce arch
optimized hash library") and follow-up work, that is f.e., commit
237217546d44 ("lib: hash: follow-up fixups for arch hash"),
commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for
asm-generic/hash.h") and last but not least commit 6a02652df511
("perf tools: Fix include for non x86 architectures").
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
introduce new setsockopt() command:
setsockopt(sock, SOL_SOCKET, SO_ATTACH_BPF, &prog_fd, sizeof(prog_fd))
where prog_fd was received from syscall bpf(BPF_PROG_LOAD, attr, ...)
and attr->prog_type == BPF_PROG_TYPE_SOCKET_FILTER
setsockopt() calls bpf_prog_get() which increments refcnt of the program,
so it doesn't get unloaded while socket is using the program.
The same eBPF program can be attached to multiple sockets.
User task exit automatically closes socket which calls sk_filter_uncharge()
which decrements refcnt of eBPF program
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
write{b,w,l}_relaxed are implemented by some architectures in order to
permit memory-mapped I/O accesses with weaker barrier semantics than the
non-relaxed variants.
This patch adds dummy macros for the write accessors to mn10300, in the
same vein as the dummy definitions for the relaxed read accessors.
Pull arch atomic cleanups from Ingo Molnar:
"This is a series kept separate from the main locking tree, which
cleans up and improves various details in the atomics type handling:
- Remove the unused atomic_or_long() method
- Consolidate and compress atomic ops implementations between
architectures, to reduce linecount and to make it easier to add new
ops.
- Rewrite generic atomic support to only require cmpxchg() from an
architecture - generate all other methods from that"
* 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read()
locking, mips: Fix atomics
locking, sparc64: Fix atomics
locking,arch: Rewrite generic atomic support
locking,arch,xtensa: Fold atomic_ops
locking,arch,sparc: Fold atomic_ops
locking,arch,sh: Fold atomic_ops
locking,arch,powerpc: Fold atomic_ops
locking,arch,parisc: Fold atomic_ops
locking,arch,mn10300: Fold atomic_ops
locking,arch,mips: Fold atomic_ops
locking,arch,metag: Fold atomic_ops
locking,arch,m68k: Fold atomic_ops
locking,arch,m32r: Fold atomic_ops
locking,arch,ia64: Fold atomic_ops
locking,arch,hexagon: Fold atomic_ops
locking,arch,cris: Fold atomic_ops
locking,arch,avr32: Fold atomic_ops
locking,arch,arm64: Fold atomic_ops
locking,arch,arm: Fold atomic_ops
The nohz full code needs irq work to trigger its own interrupt so that
the subsystem can work even when the tick is stopped.
Lets introduce arch_irq_work_has_interrupt() that archs can override to
tell about their support for this ability.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Many of the atomic op implementations are the same except for one
instruction; fold the lot into a few CPP macros and reduce LoC.
This also prepares for easy addition of new ops.
Link: http://lkml.kernel.org/r/20140508135852.605324173@infradead.org
There's no need to have an architecture version of scatterlist.h if the
only thing the file does is include asm-generic/scatterlist.h. Switch to
the asm-generic versions directly.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Cc: Chen Liqin <liqin.linux@gmail.com>,
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
The arch_mutex_cpu_relax() function, introduced by 34b133f, is
hacky and ugly. It was added a few years ago to address the fact
that common cpu_relax() calls include yielding on s390, and thus
impact the optimistic spinning functionality of mutexes. Nowadays
we use this function well beyond mutexes: rwsem, qrwlock, mcs and
lockref. Since the macro that defines the call is in the mutex header,
any users must include mutex.h and the naming is misleading as well.
This patch (i) renames the call to cpu_relax_lowlatency ("relax, but
only if you can do it with very low latency") and (ii) defines it in
each arch's asm/processor.h local header, just like for regular cpu_relax
functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax,
and thus we can take it out of mutex.h. While this can seem redundant,
I believe it is a good choice as it allows us to move out arch specific
logic from generic locking primitives and enables future(?) archs to
transparently define it, similarly to System Z.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Bharat Bhushan <r65777@freescale.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Joseph Myers <joseph@codesourcery.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Qiaowei Ren <qiaowei.ren@intel.com>
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Stratos Karafotis <stratosk@semaphore.gr>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Vasily Kulikov <segoon@openwall.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: adi-buildroot-devel@lists.sourceforge.net
Cc: linux390@de.ibm.com
Cc: linux-alpha@vger.kernel.org
Cc: linux-c6x-dev@linux-c6x.org
Cc: linux-cris-kernel@axis.com
Cc: linux-hexagon@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: linux@lists.openrisc.net
Cc: linux-m32r-ja@ml.linux-m32r.org
Cc: linux-m32r@ml.linux-m32r.org
Cc: linux-metag@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net
sys_sgetmask and sys_ssetmask are obsolete system calls no longer
supported in libc.
This patch replaces architecture related __ARCH_WANT_SYS_SGETMAX by expert
mode configuration.That option is enabled by default for those
architectures.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull core locking updates from Ingo Molnar:
"The main changes in this cycle were:
- reduced/streamlined smp_mb__*() interface that allows more usecases
and makes the existing ones less buggy, especially in rarer
architectures
- add rwsem implementation comments
- bump up lockdep limits"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits)
rwsem: Add comments to explain the meaning of the rwsem's count field
lockdep: Increase static allocations
arch: Mass conversion of smp_mb__*()
arch,doc: Convert smp_mb__*()
arch,xtensa: Convert smp_mb__*()
arch,x86: Convert smp_mb__*()
arch,tile: Convert smp_mb__*()
arch,sparc: Convert smp_mb__*()
arch,sh: Convert smp_mb__*()
arch,score: Convert smp_mb__*()
arch,s390: Convert smp_mb__*()
arch,powerpc: Convert smp_mb__*()
arch,parisc: Convert smp_mb__*()
arch,openrisc: Convert smp_mb__*()
arch,mn10300: Convert smp_mb__*()
arch,mips: Convert smp_mb__*()
arch,metag: Convert smp_mb__*()
arch,m68k: Convert smp_mb__*()
arch,m32r: Convert smp_mb__*()
arch,ia64: Convert smp_mb__*()
pcibios_penalize_isa_irq() is only implemented by x86 now, and legacy ISA
is not used by some architectures. Make pcibios_penalize_isa_irq() a
__weak function to simplify the code. This removes the need for new
platforms to add stub implementations of pcibios_penalize_isa_irq().
[bhelgaas: changelog, comments]
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
mn10300 fully relies on asm-generic/barrier.h and therefore its
smp_mb() is barrier(). We can use the default implementation.
Link: http://lkml.kernel.org/n/tip-wotyeoj99h1dpojjeest2jbk@git.kernel.org
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Many architectures have a stub cputime.h that only include the default
cputime.h
Lets remove the useless headers, we only need to mention that we want
the default headers on the Kbuild files.
Cc: Archs <linux-arch@vger.kernel.org>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
This patch allows each architecture to add its specific assembly optimized
arch_mcs_spin_lock_contended and arch_mcs_spinlock_uncontended for
MCS lock and unlock functions.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Scott J Norton <scott.norton@hp.com>
Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Cc: AswinChandramouleeswaran <aswin@hp.com>
Cc: George Spelvin <linux@horizon.com>
Cc: Rik vanRiel <riel@redhat.com>
Cc: MichelLespinasse <walken@google.com>
Cc: Alex Shi <alex.shi@linaro.org>
Cc: "Figo.zhang" <figo1802@gmail.com>
Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: Matthew R Wilcox <matthew.r.wilcox@intel.com>
Link: http://lkml.kernel.org/r/1390347382.3138.67.camel@schen9-DESK
alphabetical order
We perform a clean up of the Kbuid files in each architecture.
We order the files in each Kbuild in alphabetical order
by running the below script.
for i in arch/*/include/asm/Kbuild
do
cat $i | gawk '/^generic-y/ {
i = 3;
do {
for (; i <= NF; i++) {
if ($i == "\\") {
getline;
i = 1;
continue;
if ($i != "")
hdr[$i] = $i;
break;
} while (1);
next;
print $0;
END {
n = asort(hdr);
for (i = 1; i <= n; i++)
print "generic-y += " hdr[i];
}' > ${i}.sorted;
mv ${i}.sorted $i;
done
[ Fixed build bug. ]
1) BPF debugger and asm tool by Daniel Borkmann.
2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann.
3) Correct reciprocal_divide and update users, from Hannes Frederic
Sowa and Daniel Borkmann.
4) Currently we only have a "set" operation for the hw timestamp socket
ioctl, add a "get" operation to match. From Ben Hutchings.
5) Add better trace events for debugging driver datapath problems, also
from Ben Hutchings.
6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we
have a small send and a previous packet is already in the qdisc or
device queue, defer until TX completion or we get more data.
7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko.
8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel
Borkmann.
9) Share IP header compression code between Bluetooth and IEEE802154
layers, from Jukka Rissanen.
10) Fix ipv6 router reachability probing, from Jiri Benc.
11) Allow packets to be captured on macvtap devices, from Vlad Yasevich.
12) Support tunneling in GRO layer, from Jerry Chu.
13) Allow bonding to be configured fully using netlink, from Scott
Feldman.
14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can
already get the TCI. From Atzm Watanabe.
15) New "Heavy Hitter" qdisc, from Terry Lam.
16) Significantly improve the IPSEC support in pktgen, from Fan Du.
17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom
Herbert.
18) Add Proportional Integral Enhanced packet scheduler, from Vijay
Subramanian.
19) Allow openvswitch to mmap'd netlink, from Thomas Graf.
20) Key TCP metrics blobs also by source address, not just destination
address. From Christoph Paasch.
21) Support 10G in generic phylib. From Andy Fleming.
22) Try to short-circuit GRO flow compares using device provided RX
hash, if provided. From Tom Herbert.
The wireless and netfilter folks have been busy little bees too.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits)
net/cxgb4: Fix referencing freed adapter
ipv6: reallocate addrconf router for ipv6 address when lo device up
fib_frontend: fix possible NULL pointer dereference
rtnetlink: remove IFLA_BOND_SLAVE definition
rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info
qlcnic: update version to 5.3.55
qlcnic: Enhance logic to calculate msix vectors.
qlcnic: Refactor interrupt coalescing code for all adapters.
qlcnic: Update poll controller code path
qlcnic: Interrupt code cleanup
qlcnic: Enhance Tx timeout debugging.
qlcnic: Use bool for rx_mac_learn.
bonding: fix u64 division
rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC
sfc: Use the correct maximum TX DMA ring size for SFC9100
Add Shradha Shah as the sfc driver maintainer.
net/vxlan: Share RX skb de-marking and checksum checks with ovs
tulip: cleanup by using ARRAY_SIZE()
ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called
net/cxgb4: Don't retrieve stats during recovery
For user space packet capturing libraries such as libpcap, there's
currently only one way to check which BPF extensions are supported
by the kernel, that is, commit aa1113d9f85d ("net: filter: return
-EINVAL if BPF_S_ANC* operation is not supported"). For querying all
extensions at once this might be rather inconvenient.
Therefore, this patch introduces a new option which can be used as
an argument for getsockopt(), and allows one to obtain information
about which BPF extensions are supported by the current kernel.
As David Miller suggests, we do not need to define any bits right
now and status quo can just return 0 in order to state that this
versions supports SKF_AD_PROTOCOL up to SKF_AD_PAY_OFFSET. Later
additions to BPF extensions need to add their bits to the
bpf_tell_extensions() function, as documented in the comment.
Signed-off-by: Michal Sekletar <msekleta@redhat.com>
Reviewed-by: Daniel Borkmann <dborkman@redhat.com>
