path: root/arch/mn10300/mm
2013-11-15mn10300: add missing pgtable_page_ctor/dtor callsKirill A. Shutemov
It will fix NR_PAGETABLE accounting. It's also required if the arch is going ever support split ptl. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12arch: mm: pass userspace fault flag to generic fault handlerJohannes Weiner
Unlike global OOM handling, memory cgroup code will invoke the OOM killer in any OOM situation because it has no way of telling faults occuring in kernel context - which could be handled more gracefully - from user-triggered faults. Pass a flag that identifies faults originating in user space from the architecture-specific fault handlers to generic code so that memcg OOM handling can be improved. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm: invoke oom-killer from remaining unconverted page fault handlersJohannes Weiner
A few remaining architectures directly kill the page faulting task in an out of memory situation. This is usually not a good idea since that task might not even use a significant amount of memory and so may not be the optimal victim to resolve the situation. Since 2.6.29's 1c0fe6e ("mm: invoke oom-killer from page fault") there is a hook that architecture page fault handlers are supposed to call to invoke the OOM killer and let it pick the right task to kill. Convert the remaining architectures over to this hook. To have the previous behavior of simply taking out the faulting task the vm.oom_kill_allocating_task sysctl can be set to 1. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits] Cc: James Hogan <james.hogan@imgtec.com> Cc: David Howells <dhowells@redhat.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm/mn10300: prepare for removing num_physpages and simplify mem_init()Jiang Liu
Prepare for removing num_physpages and simplify mem_init(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: concentrate modification of totalram_pages into the mm coreJiang Liu
Concentrate code to modify totalram_pages into the mm core, so the arch memory initialized code doesn't need to take care of it. With these changes applied, only following functions from mm core modify global variable totalram_pages: free_bootmem_late(), free_all_bootmem(), free_all_bootmem_node(), adjust_managed_page_count(). With this patch applied, it will be much more easier for us to keep totalram_pages and zone->managed_pages in consistence. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: change signature of free_reserved_area() to fix building warningsJiang Liu
Change signature of free_reserved_area() according to Russell King's suggestion to fix following build warnings: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default] free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL); ^ In file included from include/linux/mman.h:4:0, from arch/arm/mm/init.c:15: include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *' extern unsigned long free_reserved_area(unsigned long start, unsigned long end, mm/page_alloc.c: In function 'free_reserved_area': >> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] In file included from arch/mips/include/asm/page.h:49:0, from include/linux/mmzone.h:20, from include/linux/gfp.h:4, from include/linux/mm.h:8, from mm/page_alloc.c:18: arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int' mm/page_alloc.c: In function 'free_area_init_nodes': mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds] Also address some minor code review comments. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm/mn10300: use common help functions to free reserved pagesJiang Liu
Use common help functions to free reserved pages. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-12mn10300/mm/fault.c: Port OOM changes to do_page_faultKautuk Consul
Commit d065bd810b6deb67d4897a14bfe21f8eb526ba99 (mm: retry page fault when blocking on disk transfer) and commit 37b23e0525d393d48a7d59f870b3bc061a30ccdb (x86,mm: make pagefault killable) The above commits introduced changes into the x86 pagefault handler for making the page fault handler retryable as well as killable. These changes reduce the mmap_sem hold time, which is crucial during OOM killer invocation. Port these changes to mn10300. Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-06propagate name change to comments in kernel sourceNadia Yvette Chambers
I've legally changed my name with New York State, the US Social Security Administration, et al. This patch propagates the name change and change in initials and login to comments in the kernel source as well. Signed-off-by: Nadia Yvette Chambers <nyc@holomorphy.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-11mn10300: mm/dma-alloc.c needs <linux/export.h>Geert Uytterhoeven
Fix the warnings: arch/mn10300/mm/dma-alloc.c: At top level: arch/mn10300/mm/dma-alloc.c:63:1: warning: data definition has no type or storage class [enabled by default] arch/mn10300/mm/dma-alloc.c:63:1: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Wimplicit-int] arch/mn10300/mm/dma-alloc.c:63:1: warning: parameter names (without types) in function declaration [enabled by default] arch/mn10300/mm/dma-alloc.c:75:1: warning: data definition has no type or storage class [enabled by default] arch/mn10300/mm/dma-alloc.c:75:1: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Wimplicit-int] arch/mn10300/mm/dma-alloc.c:75:1: warning: parameter names (without types) in function declaration [enabled by default] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Disintegrate asm/system.h for MN10300David Howells
Disintegrate asm/system.h for MN10300. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-am33-list@redhat.com
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-07MN10300: Fix one of the kernel debugger cacheflush variantsDavid Howells
One of the kernel debugger cacheflush variants escaped proper testing. Two of the labels are wrong, being derived from the code that was copied to construct the variant. The first label results in the following assembler message: AS arch/mn10300/mm/cache-dbg-flush-by-reg.o arch/mn10300/mm/cache-dbg-flush-by-reg.S: Assembler messages: arch/mn10300/mm/cache-dbg-flush-by-reg.S:123: Error: symbol `debugger_local_cache_flushinv_no_dcache' is already defined And the second label results in the following linker message: arch/mn10300/mm/built-in.o:(.text+0x1d39): undefined reference to `mn10300_local_icache_inv_range_reg_end' arch/mn10300/mm/built-in.o:(.text+0x1d39): relocation truncated to fit: R_MN10300_PCREL16 against undefined symbol `mn10300_local_icache_inv_range_reg_end' To test this file the following configuration pieces must be set: CONFIG_AM34=y CONFIG_MN10300_CACHE_WBACK=y CONFIG_MN10300_DEBUGGER_CACHE_FLUSH_BY_REG=y CONFIG_MN10300_CACHE_MANAGE_BY_REG=y CONFIG_AM34_HAS_CACHE_SNOOP=n Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mn10300: convert old cpumask API into new oneKOSAKI Motohiro
Adapt to the new API. We plan to remove old cpumask APIs later. Thus this patch converts them into the new one. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Hugh Dickins <hughd@google.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18MN10300: Create generic kernel debugger hooksDavid Howells
Create generic kernel debugger hooks in the MN10300 arch and make gdbstub use them. This is a preparation for KGDB support. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Create general kernel debugger cache flushingDavid Howells
Create general kernel debugger cache flushing for MN10300 and get rid of the old stuff that gdbstub was using. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: The icache invalidate functions should disable the icache firstDavid Howells
The icache invalidate functions should disable the icache on AM33 and wait for it to quiesce before attempting to invalidate it, and should then wait for it to quiesce again before reenabling it, but on AM34 they should invalidate directly. The same goes for the dcache invalidation, but this isn't used much. Whilst we're at it, this can be wrapped in assembler macros to remove duplicate code. The AM33 manual states that: An operation that invalidates the cache, switches the writing mode, or changes the way mode must be performed after disabling the cache, checking the busy bit, and confirming that the cache is not in operation. for the dcache [sec 2.8.3.2.1]. This is not stated so for the icache [sec 2.8.3.1.1] but the example code there suggests that it is. Whilst the AM34 manual states that the cache must be disabled for both the icache [sec 1.8.3.2.1] and the dcache [sec 1.8.3.2.1], the Panasonic hardware engineers say the manual is wrong and that disabling the caches for invalidation is wrong. Furthermore, they say that disabling the caches on the AM34 whilst running an SMP kernel can lead to incoherency between the various CPU caches and should thus be avoided. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-14MN10300: The SMP_ICACHE_INV_FLUSH_RANGE IPI command does not existDavid Howells
The invalidate-only versions of flush_icache_*range() are trying sending the SMP_ICACHE_INV_FLUSH_RANGE IPI command in SMP kernels when they should be sending SMP_ICACHE_INV_RANGE as the former does not exist. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Map userspace atomic op regs as a vmalloc pageMark Salter
The AM34 processor has an atomic operation that's the equivalent of LL/SC on other architectures. However, rather than being done through a pair of instructions, it's driven by writing to a pair of memory-mapped CPU control registers. One set of these registers (AARU/ADRU/ASRU) is available for use by userspace, but for userspace to access them a PTE must be set up to cover the region. This is done by dedicating the first vmalloc region page to this purpose, setting the permissions on its PTE such that userspace can access the page. glibc is hardcoded to expect the registers to be there. The way atomic ops are done through these registers is straightforward: (1) Write the address of the word you wish to access into AARU. This causes the CPU to go and fetch that word and load it into ADRU. The status bits are also cleared in ASRU. (2) The current data value is read from the ADRU register and modified. (3) To alter the data in RAM, the revised data is written back to the ADRU register, which causes the CPU to attempt to write it back. (4) The ASRU.RW flag (ASRU read watch), ASRU.LW flag (bus lock watch), ASRU.IW (interrupt watch) and the ASRU.BW (bus error watch) flags then must be checked to confirm that the operation wasn't aborted. If any of the watches have been set to true, the operation was aborted. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: And Panasonic AM34 subarch and implement SMPAkira Takeuchi
Implement the Panasonic MN10300 AM34 CPU subarch and implement SMP support for MN10300. Also implement support for the MN2WS0060 processor and the ASB2364 evaluation board which are AM34 based. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: SMP TLB flushingAkira Takeuchi
Implement global TLB flushing for MN10300. This will be used by the AM34 which is SMP capable. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Use the [ID]PTEL2 registers rather than [ID]PTEL for TLB controlAkira Takeuchi
Use the [ID]PTEL2 registers rather than [ID]PTEL for TLB control as the bits are a more suitable layout. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Make the use of PIDR to mark TLB entries controllableAkira Takeuchi
Make controllable the use of the PIDR register to mark TLB entries as belonging to particular processes. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Rename __flush_tlb*() to local_flush_tlb*()David Howells
Rename __flush_tlb*() to local_flush_tlb*() as it's more appropriate, and ready to differentiate local from global TLB flushes when SMP is introduced. Whilst we're at it, get rid of __flush_tlb_global() and make local_flush_tlb_page() take an mm_struct pointer rather than VMA pointer. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: AM34 erratum requires MMUCTR read and write on exception entryAkira Takeuchi
An AM34 erratum requires MMUCTR read and write on entry to certain exceptions, prior to EPSW.NMID being cleared to allow NMIs to happen. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Cache: Implement SMP global cache flushingAkira Takeuchi
Implement SMP global cache flushing for MN10300. This will be used by the AM34 which is SMP capable. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Allow some cacheflushes to be avoided if cache snooping is availableDavid Howells
The AM34 core is able to do cache snooping, and so can skip some of the cache flushing. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: AM34: Add cacheflushing by using the AM34 purge registersAkira Takeuchi
The AM34 CPU core provides an automated way of purging the cache rather than manually iterating over all the tags in the cache. Make it possible to use these. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: SMP: Differentiate local cache flushingAkira Takeuchi
Differentiate local cache flushing from global cache flushing so that they can be done differently on SMP systems. Rename the cache functions from: mn10300_[id]cache_*() to: mn10300_[id]_localcache_*() and on a UP system, assign the global labels to the local labels. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Cacheflush functions should take unsigned long addressesAkira Takeuchi
The functions that perform cache flushing should take addresses of unsigned long type, not unsigned int. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: AM34: The current cacheflush routines operate by controlling tag regsDavid Howells
The current cache flush and invalidate routines operate by controlling the cache tag registers. Rename the files and add config items to select them. This makes it easier to support the use of other cache flush methods instead, such as the use of AM34's area purge registers, if available. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Provide a MN10300_CACHE_ENABLED config optionDavid Howells
Provide a MN10300_CACHE_ENABLED config option as inverted logic of MN10300_CACHE_DISABLED to make things simpler. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Cache: Split cache bits out of arch KconfigDavid Howells
Split the cache bits out of arch/mn10300/Kconfig as they're quite complex. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Remove monitor/JTAG functionsAkira Takeuchi
Remove the monitor trap function and the set_jtag_stub function as they're not really necessary. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: BUG to BUG_ON changesStoyan Gaydarov
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-01MN10300: Fix flush_icache_range()David Howells
flush_icache_range() is given virtual addresses to describe the region. It deals with these by attempting to translate them through the current set of page tables. This is fine for userspace memory and vmalloc()'d areas as they are governed by page tables. However, since the regions above 0x80000000 aren't translated through the page tables by the MMU, the kernel doesn't bother to set up page tables for them (see paging_init()). This means flush_icache_range() as it stands cannot be used to flush regions of the VM area between 0x80000000 and 0x9fffffff where the kernel resides if the data cache is operating in WriteBack mode. To fix this, make flush_icache_range() first check for addresses in the upper half of VM space and deal with them appropriately, before dealing with any range in the page table mapped area. Ordinarily, this is not a problem, but it has the capacity to make kprobes and kgdb malfunction. It should not affect gdbstub, signal frame setup or module loading as gdb has its own flush functions, and the others take place in the page table mapped area only. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-28MN10300: Handle missing sys_cacheflush() when caching disabledDavid Howells
When caching is disabled on the MN10300 arch, the sys_cacheflush() function is removed by conditional stuff in the makefiles, but is still referred to by the syscall table. Provide a null version that just returns 0 when caching is disabled (or -EINVAL if the arguments are silly). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-23arch/mn10300/mm: eliminate NULL dereferenceJulia Lawall
dev_name always dereferences its argument, so it should not be called if the argument is NULL. The function indeed later tests the argument for being NULL. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression dev,E; @@ *dev_name(dev) ... when != dev = E ( *dev == NULL | *dev != NULL ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04mn10300: invoke oom-killer from page faultNick Piggin
As explained in commit 1c0fe6e3bd ("mm: invoke oom-killer from page fault") , we want to call the architecture independent oom killer when getting an unexplained OOM from handle_mm_fault, rather than simply killing current. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: David Rientjes <rientjes@google.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-20MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itselfRussell King
On VIVT ARM, when we have multiple shared mappings of the same file in the same MM, we need to ensure that we have coherency across all copies. We do this via make_coherent() by making the pages uncacheable. This used to work fine, until we allowed highmem with highpte - we now have a page table which is mapped as required, and is not available for modification via update_mmu_cache(). Ralf Beache suggested getting rid of the PTE value passed to update_mmu_cache(): On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables to construct a pointer to the pte again. Passing a pte_t * is much more elegant. Maybe we might even replace the pte argument with the pte_t? Ben Herrenschmidt would also like the pte pointer for PowerPC: Passing the ptep in there is exactly what I want. I want that -instead- of the PTE value, because I have issue on some ppc cases, for I$/D$ coherency, where set_pte_at() may decide to mask out the _PAGE_EXEC. So, pass in the mapped page table pointer into update_mmu_cache(), and remove the PTE value, updating all implementations and call sites to suit. Includes a fix from Stephen Rothwell: sparc: fix fallout from update_mmu_cache API change Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-11mn10300: make the ASB2305's PCnet32 NIC work by using the PCI bridge's SRAMDavid Howells
Access to the ASB2305's PCnet32 NIC doesn't work correctly because when the NIC attempts to update the ring buffer flags by DMA, the change to RAM crops up about 17uS after the interrupt line is asserted. This is almost certainly due to a bug in the PCI bridge FPGA on that board. We can get around this by making dma_alloc_coherent() put the ring buffer in the SRAM attached to the PCI bridge rather than in the SDRAM. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: add cc clobbers to asm statementsMark Salter
gcc 4.2.1 for MN10300 is more agressive than the older gcc in reordering/moving other insns between an insn that sets flags and an insn that uses those flags. This leads to trouble with asm statements which are missing an explicit "cc" clobber. This patch adds the explicit "cc" clobber to asm statements which do indeed clobber the condition flags. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mm: make totalhigh_pages unsigned longAndreas Fenkart
Makes it consistent with the extern declaration, used when CONFIG_HIGHMEM is set Removes redundant casts in printout messages Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11MN10300: Don't set the dirty bit in the DTLB entries in the TLB-miss handlerDavid Howells
Remove the special handling for the Data TLB entry dirty bit in the TLB-miss handler. As the code stands, all that it does is to cause us to take a second data address exception to set the dirty bit. Instead, we can just let pte_mkdirty() set the bit. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
