path: root/arch/mn10300/unit-asb2364
2011-03-29mn10300: Convert genirq namespaceThomas Gleixner
Convert to new function names. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-18MN10300: Clear ASB2364 peripheral interrupt masks before enabling interruptsDavid Howells
Clear the interrupt mask registers of ASB2364 peripherals before enabling interrupts so that any peripherals that weren't dealt with by the bootloader after a reboot (if there was one) won't cause an interrupt storm when interrupts are first enabled before the drivers are initialised. Also, attempt to reset the peripherals attached to the FPGA. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Fix the ASB2364 gdbport UART register defsDavid Howells
Fix the ASB2364 gdbport UART register definitions. These registers are actually 2 bytes apart, not 4 (which the ASB2303 and ASB2305 are). Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Fix ASB2364 FPGA register defsDavid Howells
Fix the definition of the ASB2364 FPGA IRQ detect registers. They accidentally got defined to be the same as the mask registers when the patches were being ported to the upstream kernel. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Convert ASB2364 FPGA irq_chip to new functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: ASB2364: Add support for SMSC911X and SMC911XAkira Takeuchi
Add support for SMSC911X and SMC911X for the ASB2364 unit. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: steve.glendinning@smsc.com cc: netdev@vger.kernel.org
2010-10-27MN10300: ASB2364: Handle the IRQ multiplexer in the FPGADavid Howells
Handle the IRQ multiplexer in the FPGA by implementing a cascade interrupt driver for it. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Generic time supportMark Salter
Implement generic time support for MN10300. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: And Panasonic AM34 subarch and implement SMPAkira Takeuchi
Implement the Panasonic MN10300 AM34 CPU subarch and implement SMP support for MN10300. Also implement support for the MN2WS0060 processor and the ASB2364 evaluation board which are AM34 based. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
