path: root/arch/mn10300
2009-02-20mn10300: fix typo && -> || in arch/mn10300/unit-asb2305/pci.cWei Yongjun
Fix the typo && -> ||. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20mn10300: fix oprofileDavid Howells
oprofile for MN10300 seems to have been broken by the advent of the new tracing framework. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] Rename old_readdir to sys_old_readdirHeiko Carstens
This way it matches the generic system call name convention. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-12-31take init_fs to saner placeAl Viro
2008-12-10MN10300: Give correct size when reserving interrupt vector tableAkira Takeuchi
Give the correct size when reserving the interrupt vector table. It should be a page not a single byte. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10MN10300: Fix the preemption resume_kernel() routineAkira Takeuchi
Fix the preemption resume_kernel() routine by inverting the test to see whether interrupts are off (IM7 is all enabled, not all disabled). Furthermore, interrupts should be disabled on entry to resume_kernel() so that they're correctly set for jumping to restore_all() and doing the need reschedule test. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10MN10300: Discard low-priority Tx interrupts when closing an on-chip serial portAkira Takeuchi
Discard low-prioriy Tx interrupts when closing an MN10300 on-chip serial port. The MN10300 on-chip serial port uses three interrupts to manage its serial ports: (1) A very high priority interrupt that drives virtual DMA for Rx. (2) A very high priority interrupt that drives virtual DMA for Tx. (3) A normal priority virtual interrupt that does the normal UART interrupt stuff and is shared between Rx and Tx. mn10300_serial_stop_tx() only disables the high priority Tx interrupt. It doesn't also disable the normal priority one because it is shared with Rx. However, the high priority interrupt may interrupt local_irq_disabled() sections, and so may have queued up a low priority virtual interrupt whilst the UART driver is asking for the Tx interrupt to be disabled. The result of this can be an oops when we try to process the interrupt in mn10300_serial_transmit_interrupt() as port->uart.info and port->uart.info->tty may have gone away. To deal with this, if either of those pointers is NULL, we make sure the high-priority Tx interrupt is disabled and discard the interrupt. The low priority interrupt is disabled by the mn10300_serial_pic irq_chip table. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10MN10300: vmlinux.lds.S cleanup - use PAGE_SIZE, PERCPU macrosCyrill Gorcunov
Include the linux/page.h header into the MN10300 kernel linker script thus allowing us to use PAGE_SIZE macro instead of a numeric constant. Also use the PERCPU macro instead of an explicit section definition. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-03MN10300: Introduce barriers to replace removed volatiles in gdbstub 16550 driverDavid Howells
Introduce into the MN10300 gdbstub 16550 driver a couple of barrier() calls to replace the removed volatility of the input/output index variables for the Rx ring buffer. A previous patch added them into the on-chip serial port driver. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-02MN10300: Fix application of kernel module relocationsMark Salter
This fixes the MN10300 kernel module linking to match the toolchain. RELA relocs don't use the value at the location being relocated. This has been working because the tools always leave the value at the target location cleared. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-30MN10300: Tighten up the code using case rangesRobert P. J. Day
Compress a set of consecutive switch cases into a case-range. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Don't do misalignment handling for userspaceDavid Howells
Don't do misalignment handling for userspace misalignment faults: just generate an appropriate SIGBUS instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Don't handle misaligned loading and storing of SPDavid Howells
Don't handle the misaligned loading and storing of the SP register as in C code that's most certainly a compiler bug. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Handle misaligned SP-based operandsDavid Howells
Support misalignment handling for instructions that have kernel SP-based address operands, including fixing those that include IMM8 or IMM16 displacements. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Fix misaligned index-register addressing handlingDavid Howells
Fix misalignment handling for an address calculated from the sum of two registers. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Handle misaligned postinc-with-imm addressing mode correctlyDavid Howells
Correctly handle misalignment in MOV instructions with postinc-with-immediate addressing mode operands. In these, the immediate value is the increment to be applied the address register, not the displacement to the address. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Perform misalignment fixups of MOV_LccDavid Howells
Perform misalignment fixups of the MOV_Lcc instructions (move postinc memory to register and conditionally loop). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Allow misalignment fixup in interrupt handlingDavid Howells
Allow misalignment fixup in interrupt handling in the MN10300 arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Fix register-postinc addressing misalignment handlingDavid Howells
Fix misalignment handling of operands with register postincrement addressing. The flag to indicate that postincrement is required should not be interpreted as an specification of a value to be added to the address. Also add BUGs to catch unimplemented parameter markings in the opcodes table. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Extract the displacement from an insn correctly in misalignment fixupDavid Howells
Extract the displacement from an MN10300 instruction correctly in the misalignment fixup handler. The code should extract the displacement in LSB order, not MSB order. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Add further misalignment fixupsDavid Howells
Add further misalignment fixup support to the MN10300 arch, notably for ABS32 and SP+disp addressing. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Add built-in testing for misalignment handlerDavid Howells
Add configurable built-in testing for the MN10300 misalignment handler. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12MN10300: Clean up the misalignment handler a littleDavid Howells
Clean up the MN10300 misalignment handler a little by: (1) Use ilog2() rather than doing implementing log2() locally. (2) Make format_tbl[] const and static. (3) Making the debugging prints more consistent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mn10300: use bcd2bin/bin2bcdAdrian Bunk
Change mn10300 to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20container freezer: implement freezer cgroup subsystemMatt Helsley
This patch implements a new freezer subsystem in the control groups framework. It provides a way to stop and resume execution of all tasks in a cgroup by writing in the cgroup filesystem. The freezer subsystem in the container filesystem defines a file named freezer.state. Writing "FROZEN" to the state file will freeze all tasks in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in the cgroup. Reading will return the current state. * Examples of usage : # mkdir /containers/freezer # mount -t cgroup -ofreezer freezer /containers # mkdir /containers/0 # echo $some_pid > /containers/0/tasks to get status of the freezer subsystem : # cat /containers/0/freezer.state RUNNING to freeze all tasks in the container : # echo FROZEN > /containers/0/freezer.state # cat /containers/0/freezer.state FREEZING # cat /containers/0/freezer.state FROZEN to unfreeze all tasks in the container : # echo RUNNING > /containers/0/freezer.state # cat /containers/0/freezer.state RUNNING This is the basic mechanism which should do the right thing for user space task in a simple scenario. It's important to note that freezing can be incomplete. In that case we return EBUSY. This means that some tasks in the cgroup are busy doing something that prevents us from completely freezing the cgroup at this time. After EBUSY, the cgroup will remain partially frozen -- reflected by freezer.state reporting "FREEZING" when read. The state will remain "FREEZING" until one of these things happens: 1) Userspace cancels the freezing operation by writing "RUNNING" to the freezer.state file 2) Userspace retries the freezing operation by writing "FROZEN" to the freezer.state file (writing "FREEZING" is not legal and returns EIO) 3) The tasks that blocked the cgroup from entering the "FROZEN" state disappear from the cgroup's set of tasks. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: export thaw_process] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Tested-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-x86/statfs.h
2008-10-01MN10300: Fix IRQ handlingDavid Howells
Fix the IRQ handling on the MN10300 arch. This patch makes a number of significant changes: (1) It separates the irq_chip definition for edge-triggered interrupts from the one for level-triggered interrupts. This is necessary because the MN10300 PIC latches the IRQ channel's interrupt request bit (GxICR_REQUEST), even after the device has ceased to assert its interrupt line and the interrupt channel has been disabled in the PIC. So for level-triggered interrupts we need to clear this bit when we re-enable - which is achieved by setting GxICR_DETECT but not GxICR_REQUEST when writing to the register. Not doing this results in spurious interrupts occurring because calling mask_ack() at the start of handle_level_irq() is insufficient - it fails to clear the REQUEST latch because the device that caused the interrupt is still asserting its interrupt line at this point. (2) IRQ disablement [irq_chip::disable_irq()] shouldn't clear the interrupt request flag for edge-triggered interrupts lest it lose an interrupt. (3) IRQ unmasking [irq_chip::unmask_irq()] also shouldn't clear the interrupt request flag for edge-triggered interrupts lest it lose an interrupt. (4) The end() operation is now left to the default (no-operation) as __do_IRQ() is compiled out. This may affect misrouted_irq(), but according to Thomas Gleixner it's the correct thing to do. (5) handle_level_irq() is used for edge-triggered interrupts rather than handle_edge_irq() as the MN10300 PIC latches interrupt events even on masked IRQ channels, thus rendering IRQ_PENDING unnecessary. It is sufficient to call mask_ack() at the start and unmask() at the end. (6) For level-triggered interrupts, ack() is now NULL as it's not used, and there is no effective ACK function on the PIC. mask_ack() is now the same as mask() as the latch continues to latch, even when the channel is masked. Further, the patch discards the disable() op implementation as its now the same as the mask() op implementation, which is used instead. It also discards the enable() op implementations as they're now the same as the unmask() op implementations, which are used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-24MN10300: Make sched_clock() report time since bootDavid Howells
Make sched_clock() report time since boot rather than time since last timer interrupt. Make sched_clock() expand and scale the 32-bit TSC value running at IOCLK speed (~33MHz) to a 64-bit nanosecond counter, using cnt32_to_63() acquired from the ARM arch and without using slow DIVU instructions every call. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-11MN10300: Change the fault handler to check in_atomic() not in_interrupt()David Howells
Change the MN10300 fault handler to make it check in_atomic() rather than in_interrupt() as commit 6edaf68a87d17570790fd55f0c451a29ec1d6703 did for other architectures: Author: Peter Zijlstra <a.p.zijlstra@chello.nl> Date: Wed Dec 6 20:32:18 2006 -0800 [PATCH] mm: arch do_page_fault() vs in_atomic() In light of the recent pagefault and filemap_copy_from_user work I've gone through all the arch pagefault handlers to make sure the inc_preempt_count() 'feature' works as expected. Several sections of code (including the new filemap_copy_from_user) rely on the fact that faults do not take locks under increased preempt count. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-06Remove redundant CONFIG_ARCH_SUPPORTS_AOUTDavid Woodhouse
We don't need this any more; arguably we never really did. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04mn10300: Fix up __bug_table handling in module loader.Paul Mundt
Platforms that are using GENERIC_BUG must call in to module_bug_finalize()/module_bug_cleanup() in order to scan modules with their own __bug_table sections that are otherwise unaccounted. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-01MN10300: Wire up new system callsDavid Howells
Wire up system calls added in the last merge window for the MN10300 arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mn10300: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() - pages in swapcache, printed by show_swap_cache_info() where show_mem() calls show_free_areas(), which calls show_swap_cache_info(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mn10300: use the common ascii hex helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25inflate: refactor inflate malloc codeThomas Petazzoni
Inflate requires some dynamic memory allocation very early in the boot process and this is provided with a set of four functions: malloc/free/gzip_mark/gzip_release. The old inflate code used a mark/release strategy rather than implement free. This new version instead keeps a count on the number of outstanding allocations and when it hits zero, it resets the malloc arena. This allows removing all the mark and release implementations and unifying all the malloc/free implementations. The architecture-dependent code must define two addresses: - free_mem_ptr, the address of the beginning of the area in which allocations should be made - free_mem_end_ptr, the address of the end of the area in which allocations should be made. If set to 0, then no check is made on the number of allocations, it just grows as much as needed The architecture-dependent code can also provide an arch_decomp_wdog() function call. This function will be called several times during the decompression process, and allow to notify the watchdog that the system is still running. If an architecture provides such a call, then it must define ARCH_HAS_DECOMP_WDOG so that the generic inflate code calls arch_decomp_wdog(). Work initially done by Matt Mackall, updated to a recent version of the kernel and improved by me. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24bootmem: replace node_boot_start in struct bootmem_dataJohannes Weiner
Almost all users of this field need a PFN instead of a physical address, so replace node_boot_start with node_min_pfn. [Lee.Schermerhorn@hp.com: fix spurious BUG_ON() in mark_bootmem()] Signed-off-by: Johannes Weiner <hannes@saeureba.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20MN10300: Fix MN10300's serial port driver to get at its tty_structDavid Howells
Fix MN10300's serial port driver to get at its tty_struct as this moved from struct uart_info into struct tty_port in patch: Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04mn10300: provide __ucmpdi2() for MN10300David Howells
Provide __ucmpdi2() for MN10300 so that allmodconfig can be built. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04mn10300: export certain arch symbols required to build allmodconfigDavid Howells
Export kernel_thread() and empty_zero_page so that allmodconfig can be built for MN10300. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-16MN10300: Kill linux/a.out.h inclusionsDavid Howells
Kill linux/a.out.h inclusions in the MN10300 arch code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-13mn10300: replace deprecated "TOPDIR" with newer "srctree"Robert P. J. Day
This would appear to be the last reference to TOPDIR in the entire tree, after which i'm guessing that variable can be dropped. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: David Howells <dhowells@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-10BKL: revert back to the old spinlock implementationLinus Torvalds
The generic semaphore rewrite had a huge performance regression on AIM7 (and potentially other BKL-heavy benchmarks) because the generic semaphores had been rewritten to be simple to understand and fair. The latter, in particular, turns a semaphore-based BKL implementation into a mess of scheduling. The attempt to fix the performance regression failed miserably (see the previous commit 00b41ec2611dc98f87f30753ee00a53db648d662 'Revert "semaphore: fix"'), and so for now the simple and sane approach is to instead just go back to the old spinlock-based BKL implementation that never had any issues like this. This patch also has the advantage of being reported to fix the regression completely according to Yanmin Zhang, unlike the semaphore hack which still left a couple percentage point regression. As a spinlock, the BKL obviously has the potential to be a latency issue, but it's not really any different from any other spinlock in that respect. We do want to get rid of the BKL asap, but that has been the plan for several years. These days, the biggest users are in the tty layer (open/release in particular) and Alan holds out some hope: "tty release is probably a few months away from getting cured - I'm afraid it will almost certainly be the very last user of the BKL in tty to get fixed as it depends on everything else being sanely locked." so while we're not there yet, we do have a plan of action. Tested-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <andi@firstfloor.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Alexander Viro <viro@ftp.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29mn10300: use kbuild.h instead of defining macros in asm-offsets.cChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-20PCI: remove initial bios sort of PCI devices on x86Greg Kroah-Hartman
We currently keep 2 lists of PCI devices in the system, one in the driver core, and one all on its own. This second list is sorted at boot time, in "BIOS" order, to try to remain compatible with older kernels (2.2 and earlier days). There was also a "nosort" option to turn this sorting off, to remain compatible with even older kernel versions, but that just ends up being what we have been doing from 2.5 days... Unfortunately, the second list of devices is not really ever used to determine the probing order of PCI devices or drivers[1]. That is done using the driver core list instead. This change happened back in the early 2.5 days. Relying on BIOS ording for the binding of drivers to specific device names is problematic for many reasons, and userspace tools like udev exist to properly name devices in a persistant manner if that is needed, no reliance on the BIOS is needed. Matt Domsch and others at Dell noticed this back in 2006, and added a boot option to sort the PCI device lists (both of them) in a breadth-first manner to help remain compatible with the 2.4 order, if needed for any reason. This option is not going away, as some systems rely on them. This patch removes the sorting of the internal PCI device list in "BIOS" mode, as it's not needed at all anymore, and hasn't for many years. I've also removed the PCI flags for this from some other arches that for some reason defined them, but never used them. This should not change the ordering of any drivers or device probing. [1] The old-style pci_get_device and pci_find_device() still used this sorting order, but there are very few drivers that use these functions, as they are deprecated for use in this manner. If for some reason, a driver rely on the order and uses these functions, the breadth-first boot option will resolve any problem. Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-23MN10300: define HZ as a config optionDavid Howells
Define HZ as a config option. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
