path: root/arch/mn10300
2013-04-05signal: Define __ARCH_HAS_SA_RESTORER so we know whether to clear sa_restorerBen Hutchings
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side struct sigaction declarations'. flush_signal_handlers() needs to know whether sigaction::sa_restorer is defined, not whether SA_RESTORER is defined. Define the __ARCH_HAS_SA_RESTORER macro to indicate this. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mn10300: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit 5b0753a90b7a98bc613c3767e9263a1a76d4f900 upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the mn10300's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mn10300: only add -mmem-funcs to KBUILD_CFLAGS if gcc supports itGeert Uytterhoeven
commit 9957423f035c2071f6d1c5d2f095cdafbeb25ad7 upstream. It seems the current (gcc 4.6.3) no longer provides this so make it conditional. As reported by Tony before, the mn10300 architecture cross-compiles with gcc-4.6.3 if -mmem-funcs is not added to KBUILD_CFLAGS. Reported-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-15mn10300/CPU hotplug: Add missing call to notify_cpu_starting()Srivatsa S. Bhat
The scheduler depends on receiving the CPU_STARTING notification, without which we end up into a lot of trouble. So add the missing call to notify_cpu_starting() in the bringup code. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Delete all instances of asm/system.hDavid Howells
Delete all instances of asm/system.h as they should be redundant by this point. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Disintegrate asm/system.h for MN10300David Howells
Disintegrate asm/system.h for MN10300. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-am33-list@redhat.com
2012-03-23Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge second batch of patches from Andrew Morton: - various misc things - core kernel changes to prctl, exit, exec, init, etc. - kernel/watchdog.c updates - get_maintainer - MAINTAINERS - the backlight driver queue - core bitops code cleanups - the led driver queue - some core prio_tree work - checkpatch udpates - largeish crc32 update - a new poll() feature for the v4l guys - the rtc driver queue - fatfs - ptrace - signals - kmod/usermodehelper updates - coredump - procfs updates * emailed from Andrew Morton <akpm@linux-foundation.org>: (141 commits) seq_file: add seq_set_overflow(), seq_overflow() proc-ns: use d_set_d_op() API to set dentry ops in proc_ns_instantiate(). procfs: speed up /proc/pid/stat, statm procfs: add num_to_str() to speed up /proc/stat proc: speed up /proc/stat handling fs/proc/kcore.c: make get_sparsemem_vmemmap_info() static coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMP coredump: remove VM_ALWAYSDUMP flag kmod: make __request_module() killable kmod: introduce call_modprobe() helper usermodehelper: ____call_usermodehelper() doesn't need do_exit() usermodehelper: kill umh_wait, renumber UMH_* constants usermodehelper: implement UMH_KILLABLE usermodehelper: introduce umh_complete(sub_info) usermodehelper: use UMH_WAIT_PROC consistently signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/ signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig() signal: cosmetic, s/from_ancestor_ns/force/ in prepare_signal() paths signal: give SEND_SIG_FORCED more power to beat SIGNAL_UNKILLABLE Hexagon: use set_current_blocked() and block_sigmask() ...
2012-03-23nmi watchdog: do not use cpp symbol in KconfigCong Wang
ARCH_HAS_NMI_WATCHDOG is a macro defined by arch, but config HARDLOCKUP_DETECTOR depends on it. This is wrong, ARCH_HAS_NMI_WATCHDOG has to be a Kconfig config, and arch's need it should select it explicitly. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Don Zickus <dzickus@redhat.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-21Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull kmap_atomic cleanup from Cong Wang. It's been in -next for a long time, and it gets rid of the (no longer used) second argument to k[un]map_atomic(). Fix up a few trivial conflicts in various drivers, and do an "evil merge" to catch some new uses that have come in since Cong's tree. * 'kmap_atomic' of git://github.com/congwang/linux: (59 commits) feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] drbd: remove the second argument of k[un]map_atomic() zcache: remove the second argument of k[un]map_atomic() gma500: remove the second argument of k[un]map_atomic() dm: remove the second argument of k[un]map_atomic() tomoyo: remove the second argument of k[un]map_atomic() sunrpc: remove the second argument of k[un]map_atomic() rds: remove the second argument of k[un]map_atomic() net: remove the second argument of k[un]map_atomic() mm: remove the second argument of k[un]map_atomic() lib: remove the second argument of k[un]map_atomic() power: remove the second argument of k[un]map_atomic() kdb: remove the second argument of k[un]map_atomic() udf: remove the second argument of k[un]map_atomic() ubifs: remove the second argument of k[un]map_atomic() squashfs: remove the second argument of k[un]map_atomic() reiserfs: remove the second argument of k[un]map_atomic() ocfs2: remove the second argument of k[un]map_atomic() ntfs: remove the second argument of k[un]map_atomic() ...
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-20highmem: kill all __kmap_atomic()Cong Wang
[swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-24net: Add framework to allow sending packets with customized CRC.Ben Greear
This is useful for testing RX handling of frames with bad CRCs. Requires driver support to actually put the packet on the wire properly. Signed-off-by: Ben Greear <greearb@candelatech.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2012-02-23PCI: collapse pcibios_resource_to_busBjorn Helgaas
Everybody uses the generic pcibios_resource_to_bus() supplied by the core now, so remove the ARCH_HAS_GENERIC_PCI_OFFSETS used during conversion. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-23mn10300/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: David Howells <dhowells@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-21sock: Introduce the SO_PEEK_OFF sock optionPavel Emelyanov
This one specifies where to start MSG_PEEK-ing queue data from. When set to negative value means that MSG_PEEK works as ususally -- peeks from the head of the queue always. When some bytes are peeked from queue and the peeking offset is non negative it is moved forward so that the next peek will return next portion of data. When non-peeking recvmsg occurs and the peeking offset is non negative is is moved backward so that the next peek will still peek the proper data (i.e. the one that would have been picked if there were no non peeking recv in between). The offset is set using per-proto opteration to let the protocol handle the locking issues and to check whether the peeking offset feature is supported by the protocol the socket belongs to. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-14mn10300: Use generic posix_types.hH. Peter Anvin
Change the mn10300 architecture to use <asm-generic/posix_types.h>. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/1328677745-20121-14-git-send-email-hpa@zytor.com Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
2012-01-14Merge branch 'for-next' of git://git.infradead.org/users/dhowells/linux-headersLinus Torvalds
* 'for-next' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: Split trivial #if defined(__KERNEL__) && X conditionals UAPI: Don't have a #elif clause in a __KERNEL__ guard in linux/soundcard.h UAPI: Fix AHZ multiple inclusion when __KERNEL__ is removed UAPI: Make linux/patchkey.h easier to parse UAPI: Fix nested __KERNEL__ guards in video/edid.h UAPI: Alter the S390 asm include guards to be recognisable by the UAPI splitter UAPI: Guard linux/cuda.h UAPI: Guard linux/pmu.h UAPI: Guard linux/isdn_divertif.h UAPI: Guard linux/sound.h UAPI: Rearrange definition of HZ in asm-generic/param.h UAPI: Make FRV use asm-generic/param.h UAPI: Make M32R use asm-generic/param.h UAPI: Make MN10300 use asm-generic/param.h UAPI: elf_read_implies_exec() is a kernel-only feature - so hide from userspace UAPI: Don't include linux/compat.h in sparc's asm/siginfo.h UAPI: Fix arch/mips/include/asm/Kbuild to have separate header-y lines
2012-01-12treewide: convert uses of ATTRIB_NORETURN to __noreturnJoe Perches
Use the more commonly used __noreturn instead of ATTRIB_NORETURN. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits) x86/PCI: Expand the x86_msi_ops to have a restore MSIs. PCI: Increase resource array mask bit size in pcim_iomap_regions() PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT) PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB x86/PCI: amd: factor out MMCONFIG discovery PCI: Enable ATS at the device state restore PCI: msi: fix imbalanced refcount of msi irq sysfs objects PCI: kconfig: English typo in pci/pcie/Kconfig PCI/PM/Runtime: make PCI traces quieter PCI: remove pci_create_bus() xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus() x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented() x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources sparc/PCI: convert to pci_create_root_bus() sh/PCI: convert to pci_scan_root_bus() for correct root bus resources powerpc/PCI: convert to pci_create_root_bus() powerpc/PCI: split PHB part out of pcibios_map_io_space() ... Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due to the same patches being applied in other branches.
2012-01-10Merge tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
lib: use generic pci_iomap on all architectures Many architectures don't want to pull in iomap.c, so they ended up duplicating pci_iomap from that file. That function isn't trivial, and we are going to modify it https://lkml.org/lkml/2011/11/14/183 so the duplication hurts. This reduces the scope of the problem significantly, by moving pci_iomap to a separate file and referencing that from all architectures. * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: alpha: drop pci_iomap/pci_iounmap from pci-noop.c mn10300: switch to GENERIC_PCI_IOMAP mn10300: add missing __iomap markers frv: switch to GENERIC_PCI_IOMAP tile: switch to GENERIC_PCI_IOMAP tile: don't panic on iomap sparc: switch to GENERIC_PCI_IOMAP sh: switch to GENERIC_PCI_IOMAP powerpc: switch to GENERIC_PCI_IOMAP parisc: switch to GENERIC_PCI_IOMAP mips: switch to GENERIC_PCI_IOMAP microblaze: switch to GENERIC_PCI_IOMAP arm: switch to GENERIC_PCI_IOMAP alpha: switch to GENERIC_PCI_IOMAP lib: add GENERIC_PCI_IOMAP lib: move GENERIC_IOMAP to lib/Kconfig Fix up trivial conflicts due to changes nearby in arch/{m68k,score}/Kconfig
2012-01-08Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (76 commits) PM / Hibernate: Implement compat_ioctl for /dev/snapshot PM / Freezer: fix return value of freezable_schedule_timeout_killable() PM / shmobile: Allow the A4R domain to be turned off at run time PM / input / touchscreen: Make st1232 use device PM QoS constraints PM / QoS: Introduce dev_pm_qos_add_ancestor_request() PM / shmobile: Remove the stay_on flag from SH7372's PM domains PM / shmobile: Don't include SH7372's INTCS in syscore suspend/resume PM / shmobile: Add support for the sh7372 A4S power domain / sleep mode PM: Drop generic_subsys_pm_ops PM / Sleep: Remove forward-only callbacks from AMBA bus type PM / Sleep: Remove forward-only callbacks from platform bus type PM: Run the driver callback directly if the subsystem one is not there PM / Sleep: Make pm_op() and pm_noirq_op() return callback pointers PM/Devfreq: Add Exynos4-bus device DVFS driver for Exynos4210/4212/4412. PM / Sleep: Merge internal functions in generic_ops.c PM / Sleep: Simplify generic system suspend callbacks PM / Hibernate: Remove deprecated hibernation snapshot ioctls PM / Sleep: Fix freezer failures due to racy usermodehelper_is_disabled() ARM: S3C64XX: Implement basic power domain support PM / shmobile: Use common always on power domain governor ... Fix up trivial conflict in fs/xfs/xfs_buf.c due to removal of unused XBT_FORCE_SLEEP bit
2012-01-08Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (165 commits) reiserfs: Properly display mount options in /proc/mounts vfs: prevent remount read-only if pending removes vfs: count unlinked inodes vfs: protect remounting superblock read-only vfs: keep list of mounts for each superblock vfs: switch ->show_options() to struct dentry * vfs: switch ->show_path() to struct dentry * vfs: switch ->show_devname() to struct dentry * vfs: switch ->show_stats to struct dentry * switch security_path_chmod() to struct path * vfs: prefer ->dentry->d_sb to ->mnt->mnt_sb vfs: trim includes a bit switch mnt_namespace ->root to struct mount vfs: take /proc/*/mounts and friends to fs/proc_namespace.c vfs: opencode mntget() mnt_set_mountpoint() vfs: spread struct mount - remaining argument of next_mnt() vfs: move fsnotify junk to struct mount vfs: move mnt_devname vfs: move mnt_list to struct mount vfs: switch pnode.h macros to struct mount * ...
2012-01-06mn10300/PCI: convert to pci_scan_root_bus() for correct root bus resourcesBjorn Helgaas
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus resource fixups. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. CC: David Howells <dhowells@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06PCI: mn10300: use generic pcibios_set_master()Myron Stowe
This patch removes mn10300's architecture-specific 'pcibios_set_master()' routine for ASB2305 and lets the default PCI core based implementation handle PCI device 'latency timer' setup. No functional change. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06PCI: Pull PCI 'latency timer' setup up into the coreMyron Stowe
The 'latency timer' of PCI devices, both Type 0 and Type 1, is setup in architecture-specific code [see: 'pcibios_set_master()']. There are two approaches being taken by all the architectures - check if the 'latency timer' is currently set between 16 and 255 and if not bring it within bounds, or, do nothing (and then there is the gratuitously different PA-RISC implementation). There is nothing architecture-specific about PCI's 'latency timer' so this patch pulls its setup functionality up into the PCI core by creating a generic 'pcibios_set_master()' function using the '__weak' attribute which can be used by all architectures as a default which, if necessary, can then be over-ridden by architecture-specific code. No functional change. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-03consolidate a bunch of ipcbuf.h instancesAl Viro
... some still remain weird :-/ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03consolidate umode_t declarationsAl Viro
2011-12-12UAPI: Make MN10300 use asm-generic/param.hDavid Howells
Make MN10300 use the generic settings to be found in asm-generic/param.h rather than defining its own as they're exactly the same. This sorts out a problem with HZ being redefined after the UAPI split. Signed-off-by: David Howells <dhowells@redhat.com>
2011-12-04mn10300: switch to GENERIC_PCI_IOMAPMichael S. Tsirkin
The pci_iomap variant that arch/mn10300/unit-asb2305/pci-iomap.c uses differs from the generic one in that it does not use ioremap_nocache for PCI addresses. However, it turns out that PCI addresses are automatically noncached, so switching to ioremap_nocache and to the generic implementation is safe. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-12-04mn10300: add missing __iomap markersMichael S. Tsirkin
MN10300's *ioremap*() collection lacks __iomem markers. Fix that. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-11-21freezer: remove now unused TIF_FREEZETejun Heo
Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: linux-arch@vger.kernel.org
2011-11-17Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: include/net/bluetooth/bluetooth.h
2011-11-09net: add wireless TX status socket optionJohannes Berg
The 802.1X EAPOL handshake hostapd does requires knowing whether the frame was ack'ed by the peer. Currently, we fudge this pretty badly by not even transmitting the frame as a normal data frame but injecting it with radiotap and getting the status out of radiotap monitor as well. This is rather complex, confuses users (mon.wlan0 presence) and doesn't work with all hardware. To get rid of that hack, introduce a real wifi TX status option for data frame transmissions. This works similar to the existing TX timestamping in that it reflects the SKB back to the socket's error queue with a SCM_WIFI_STATUS cmsg that has an int indicating ACK status (0/1). Since it is possible that at some point we will want to have TX timestamping and wifi status in a single errqueue SKB (there's little point in not doing that), redefine SO_EE_ORIGIN_TIMESTAMPING to SO_EE_ORIGIN_TXSTATUS which can collect more than just the timestamp; keep the old constant as an alias of course. Currently the internal APIs don't make that possible, but it wouldn't be hard to split them up in a way that makes it possible. Thanks to Neil Horman for helping me figure out the functions that add the control messages. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31kgdb: follow rename pack_hex_byte() to hex_byte_pack()Andy Shevchenko
There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-26Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) time, s390: Get rid of compile warning dw_apb_timer: constify clocksource name time: Cleanup old CONFIG_GENERIC_TIME references that snuck in time: Change jiffies_to_clock_t() argument type to unsigned long alarmtimers: Fix error handling clocksource: Make watchdog reset lockless posix-cpu-timers: Cure SMP accounting oddities s390: Use direct ktime path for s390 clockevent device clockevents: Add direct ktime programming function clockevents: Make minimum delay adjustments configurable nohz: Remove "Switched to NOHz mode" debugging messages proc: Consider NO_HZ when printing idle and iowait times nohz: Make idle/iowait counter update conditional nohz: Fix update_ts_time_stat idle accounting cputime: Clean up cputime_to_usecs and usecs_to_cputime macros alarmtimers: Rework RTC device selection using class interface alarmtimers: Add try_to_cancel functionality alarmtimers: Add more refined alarm state tracking alarmtimers: Remove period from alarm structure alarmtimers: Remove interval cap limit hack ...
2011-10-04time: Cleanup old CONFIG_GENERIC_TIME references that snuck inJohn Stultz
Awhile back I removed all the CONFIG_GENERIC_TIME referecnes as the last of the non-GENERIC_TIME arches were converted. However, due to the functionality being important and around for awhile, there apparently were some out of tree hardware enablement patches that used it and have since been merged. This patch removes the remaining instances of GENERIC_TIME. Singed-off-by: John Stultz <john.stultz@linaro.org>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26mn10300, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-06-21MN10300: asm/uaccess.h needs to #include linux/kernel.h for might_sleep()David Howells
MN10300's asm/uaccess.h needs to #include linux/kernel.h to get might_sleep() otherwise it fails to build on MN10300 allyesconfig. This fails in a few places with messages like the following: In file included from security/keys/trusted.c:14: include/linux/uaccess.h: In function '__copy_from_user_nocache': include/linux/uaccess.h:52: error: implicit declaration of function 'might_sleep' Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
