path: root/arch/nios2
2019-09-27Merge tag 'nios2-v5.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2 Pull nios2 fix from Ley Foon Tan: "Make sure the command line buffer is NUL-terminated" * tag 'nios2-v5.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2: nios2: force the string buffer NULL-terminated
2019-09-26mm: treewide: clarify pgtable_page_{ctor,dtor}() namingMark Rutland
The naming of pgtable_page_{ctor,dtor}() seems to have confused a few people, and until recently arm64 used these erroneously/pointlessly for other levels of page table. To make it incredibly clear that these only apply to the PTE level, and to align with the naming of pgtable_pmd_page_{ctor,dtor}(), let's rename them to pgtable_pte_page_{ctor,dtor}(). These changes were generated with the following shell script: ---- git grep -lw 'pgtable_page_.tor' | while read FILE; do sed -i '{s/pgtable_page_ctor/pgtable_pte_page_ctor/}' $FILE; sed -i '{s/pgtable_page_dtor/pgtable_pte_page_dtor/}' $FILE; done ---- ... with the documentation re-flowed to remain under 80 columns, and whitespace fixed up in macros to keep backslashes aligned. There should be no functional change as a result of this patch. Link: http://lkml.kernel.org/r/20190722141133.3116-1-mark.rutland@arm.com Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Mike Rapoport <rppt@linux.ibm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Cc: Anshuman Khandual <anshuman.khandual@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Yu Zhao <yuzhao@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-09-24mm: consolidate pgtable_cache_init() and pgd_cache_init()Mike Rapoport
Both pgtable_cache_init() and pgd_cache_init() are used to initialize kmem cache for page table allocations on several architectures that do not use PAGE_SIZE tables for one or more levels of the page table hierarchy. Most architectures do not implement these functions and use __weak default NOP implementation of pgd_cache_init(). Since there is no such default for pgtable_cache_init(), its empty stub is duplicated among most architectures. Rename the definitions of pgd_cache_init() to pgtable_cache_init() and drop empty stubs of pgtable_cache_init(). Link: http://lkml.kernel.org/r/1566457046-22637-1-git-send-email-rppt@linux.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Acked-by: Will Deacon <will@kernel.org> [arm64] Acked-by: Thomas Gleixner <tglx@linutronix.de> [x86] Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Matthew Wilcox <willy@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-09-24mm: remove quicklist page table cachesNicholas Piggin
Patch series "mm: remove quicklist page table caches". A while ago Nicholas proposed to remove quicklist page table caches [1]. I've rebased his patch on the curren upstream and switched ia64 and sh to use generic versions of PTE allocation. [1] https://lore.kernel.org/linux-mm/20190711030339.20892-1-npiggin@gmail.com This patch (of 3): Remove page table allocator "quicklists". These have been around for a long time, but have not got much traction in the last decade and are only used on ia64 and sh architectures. The numbers in the initial commit look interesting but probably don't apply anymore. If anybody wants to resurrect this it's in the git history, but it's unhelpful to have this code and divergent allocator behaviour for minor archs. Also it might be better to instead make more general improvements to page allocator if this is still so slow. Link: http://lkml.kernel.org/r/1565250728-21721-2-git-send-email-rppt@linux.ibm.com Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-09-20nios2: force the string buffer NULL-terminatedWang Xiayang
strncpy() does not ensure NULL-termination when the input string size equals to the destination buffer size COMMAND_LINE_SIZE. Besides, grep under arch/ with 'boot_command_line' shows no other arch-specific code uses strncpy() when copying boot_command_line. Use strlcpy() instead. This issue is identified by a Coccinelle script. Signed-off-by: Wang Xiayang <xywang.sjtu@sjtu.edu.cn> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-07-12Merge tag 'nios2-v5.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2 Pull arch/nios2 updates from Ley Foon Tan. * tag 'nios2-v5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2: nios2: configs: Remove useless UEVENT_HELPER_PATH nios2: remove pointless second entry for CONFIG_TRACE_IRQFLAGS_SUPPORT
2019-07-12Merge tag 'dma-mapping-5.3' of git://git.infradead.org/users/hch/dma-mappingLinus Torvalds
Pull dma-mapping updates from Christoph Hellwig: - move the USB special case that bounced DMA through a device bar into the USB code instead of handling it in the common DMA code (Laurentiu Tudor and Fredrik Noring) - don't dip into the global CMA pool for single page allocations (Nicolin Chen) - fix a crash when allocating memory for the atomic pool failed during boot (Florian Fainelli) - move support for MIPS-style uncached segments to the common code and use that for MIPS and nios2 (me) - make support for DMA_ATTR_NON_CONSISTENT and DMA_ATTR_NO_KERNEL_MAPPING generic (me) - convert nds32 to the generic remapping allocator (me) * tag 'dma-mapping-5.3' of git://git.infradead.org/users/hch/dma-mapping: (29 commits) dma-mapping: mark dma_alloc_need_uncached as __always_inline MIPS: only select ARCH_HAS_UNCACHED_SEGMENT for non-coherent platforms usb: host: Fix excessive alignment restriction for local memory allocations lib/genalloc.c: Add algorithm, align and zeroed family of DMA allocators nios2: use the generic uncached segment support in dma-direct nds32: use the generic remapping allocator for coherent DMA allocations arc: use the generic remapping allocator for coherent DMA allocations dma-direct: handle DMA_ATTR_NO_KERNEL_MAPPING in common code dma-direct: handle DMA_ATTR_NON_CONSISTENT in common code dma-mapping: add a dma_alloc_need_uncached helper openrisc: remove the partial DMA_ATTR_NON_CONSISTENT support arc: remove the partial DMA_ATTR_NON_CONSISTENT support arm-nommu: remove the partial DMA_ATTR_NON_CONSISTENT support ARM: dma-mapping: allow larger DMA mask than supported dma-mapping: truncate dma masks to what dma_addr_t can hold iommu/dma: Apply dma_{alloc,free}_contiguous functions dma-remap: Avoid de-referencing NULL atomic_pool MIPS: use the generic uncached segment support in dma-direct dma-direct: provide generic support for uncached kernel segments au1100fb: fix DMA API abuse ...
2019-07-12nios2: switch to generic version of pte allocationMike Rapoport
nios2 allocates kernel PTE pages with __get_free_pages(GFP_KERNEL | __GFP_ZERO, PTE_ORDER); and user page tables with pte = alloc_pages(GFP_KERNEL, PTE_ORDER); if (pte) clear_highpage(); The PTE_ORDER is hardwired to zero, which makes nios2 implementation almost identical to the generic one. Switch nios2 to the generic version that does exactly the same thing for the kernel page tables and adds __GFP_ACCOUNT for the user PTEs. The pte_free_kernel() and pte_free() versions on nios2 are identical to the generic ones and can be simply dropped. Link: http://lkml.kernel.org/r/1557296232-15361-11-git-send-email-rppt@linux.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Cc: Albert Ou <aou@eecs.berkeley.edu> Cc: Anshuman Khandual <anshuman.khandual@arm.com> Cc: Anton Ivanov <anton.ivanov@cambridgegreys.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Guo Ren <guoren@kernel.org> Cc: Guo Ren <ren_guo@c-sky.com> Cc: Helge Deller <deller@gmx.de> Cc: Ley Foon Tan <lftan@altera.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Hocko <mhocko@suse.com> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@armlinux.org.uk> Cc: Sam Creasey <sammy@sammy.net> Cc: Vincent Chen <deanbo422@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-08Merge branch 'siginfo-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull force_sig() argument change from Eric Biederman: "A source of error over the years has been that force_sig has taken a task parameter when it is only safe to use force_sig with the current task. The force_sig function is built for delivering synchronous signals such as SIGSEGV where the userspace application caused a synchronous fault (such as a page fault) and the kernel responded with a signal. Because the name force_sig does not make this clear, and because the force_sig takes a task parameter the function force_sig has been abused for sending other kinds of signals over the years. Slowly those have been fixed when the oopses have been tracked down. This set of changes fixes the remaining abusers of force_sig and carefully rips out the task parameter from force_sig and friends making this kind of error almost impossible in the future" * 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (27 commits) signal/x86: Move tsk inside of CONFIG_MEMORY_FAILURE in do_sigbus signal: Remove the signal number and task parameters from force_sig_info signal: Factor force_sig_info_to_task out of force_sig_info signal: Generate the siginfo in force_sig signal: Move the computation of force into send_signal and correct it. signal: Properly set TRACE_SIGNAL_LOSE_INFO in __send_signal signal: Remove the task parameter from force_sig_fault signal: Use force_sig_fault_to_task for the two calls that don't deliver to current signal: Explicitly call force_sig_fault on current signal/unicore32: Remove tsk parameter from __do_user_fault signal/arm: Remove tsk parameter from __do_user_fault signal/arm: Remove tsk parameter from ptrace_break signal/nds32: Remove tsk parameter from send_sigtrap signal/riscv: Remove tsk parameter from do_trap signal/sh: Remove tsk parameter from force_sig_info_fault signal/um: Remove task parameter from send_sigtrap signal/x86: Remove task parameter from send_sigtrap signal: Remove task parameter from force_sig_mceerr signal: Remove task parameter from force_sig signal: Remove task parameter from force_sigsegv ...
2019-07-04nios2: configs: Remove useless UEVENT_HELPER_PATHKrzysztof Kozlowski
Remove the CONFIG_UEVENT_HELPER_PATH because: 1. It is disabled since commit 1be01d4a5714 ("driver: base: Disable CONFIG_UEVENT_HELPER by default") as its dependency (UEVENT_HELPER) was made default to 'n', 2. It is not recommended (help message: "This should not be used today [...] creates a high system load") and was kept only for ancient userland, 3. Certain userland specifically requests it to be disabled (systemd README: "Legacy hotplug slows down the system and confuses udev"). Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-07-04nios2: remove pointless second entry for CONFIG_TRACE_IRQFLAGS_SUPPORTMasahiro Yamada
Strangely enough, NIOS2 defines TRACE_IRQFLAGS_SUPPORT twice with different values, which is pointless and confusing. [1] arch/nios2/Kconfig config TRACE_IRQFLAGS_SUPPORT def_bool n [2] arch/nios2/Kconfig.debug config TRACE_IRQFLAGS_SUPPORT def_bool y [1] is included before [2]. In the Kconfig syntax, the first one is effective. So, TRACE_IRQFLAGS_SUPPORT is always 'n'. The second define in arch/nios2/Kconfig.debug is dead code. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-06-25nios2: use the generic uncached segment support in dma-directChristoph Hellwig
Stop providing our own arch alloc/free hooks and just expose the segment offset and use the generic dma-direct allocator. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 234Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not see http www gnu org licenses extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 503 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Alexios Zavras <alexios.zavras@intel.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Enrico Weigelt <info@metux.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190602204653.811534538@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-30treewide: Add SPDX license identifier - KbuildGreg Kroah-Hartman
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0 Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 201Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms and conditions of the gnu general public license version 2 as published by the free software foundation this program is distributed in the hope it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not see http www gnu org licenses extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 228 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Steve Winslow <swinslow@gmail.com> Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Alexios Zavras <alexios.zavras@intel.com> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190528171438.107155473@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-29signal: Remove the task parameter from force_sig_faultEric W. Biederman
As synchronous exceptions really only make sense against the current task (otherwise how are you synchronous) remove the task parameter from from force_sig_fault to make it explicit that is what is going on. The two known exceptions that deliver a synchronous exception to a stopped ptraced task have already been changed to force_sig_fault_to_task. The callers have been changed with the following emacs regular expression (with obvious variations on the architectures that take more arguments) to avoid typos: force_sig_fault[(]\([^,]+\)[,]\([^,]+\)[,]\([^,]+\)[,]\W+current[)] -> force_sig_fault(\1,\2,\3) Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2019-05-27signal: Remove task parameter from force_sigEric W. Biederman
All of the remaining callers pass current into force_sig so remove the task parameter to make this obvious and to make misuse more difficult in the future. This also makes it clear force_sig passes current into force_sig_info. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2019-05-27signal: Remove task parameter from force_sigsegvEric W. Biederman
The function force_sigsegv is always called on the current task so passing in current is redundant and not passing in current makes this fact obvious. This also makes it clear force_sigsegv always calls force_sig on the current task. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2019-05-21treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 13Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not see http www gnu org licenses this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details [based] [from] [clk] [highbank] [c] you should have received a copy of the gnu general public license along with this program if not see http www gnu org licenses extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 355 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com> Reviewed-by: Steve Winslow <swinslow@gmail.com> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190519154041.837383322@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 12Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose good title or non infringement see the gnu general public license for more details extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 7 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Steve Winslow <swinslow@gmail.com> Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190519154041.727898173@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16Merge tag 'asm-generic-nommu' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull nommu generic uaccess updates from Arnd Bergmann: "asm-generic: kill <asm/segment.h> and improve nommu generic uaccess helpers Christoph Hellwig writes: This is a series doing two somewhat interwinded things. It improves the asm-generic nommu uaccess helper to optionally be entirely generic and not require any arch helpers for the actual uaccess. For the generic uaccess.h to actually be generically useful I also had to kill off the mess we made of <asm/segment.h>, which really shouldn't exist on most architectures" * tag 'asm-generic-nommu' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: optimize generic uaccess for 8-byte loads and stores asm-generic: provide entirely generic nommu uaccess arch: mostly remove <asm/segment.h> asm-generic: don't include <asm/segment.h> from <asm/uaccess.h>
2019-05-14mm: memblock: make keeping memblock memory opt-in rather than opt-outMike Rapoport
Most architectures do not need the memblock memory after the page allocator is initialized, but only few enable ARCH_DISCARD_MEMBLOCK in the arch Kconfig. Replacing ARCH_DISCARD_MEMBLOCK with ARCH_KEEP_MEMBLOCK and inverting the logic makes it clear which architectures actually use memblock after system initialization and skips the necessity to add ARCH_DISCARD_MEMBLOCK to the architectures that are still missing that option. Link: http://lkml.kernel.org/r/1556102150-32517-1-git-send-email-rppt@linux.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Russell King <linux@armlinux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Burton <paul.burton@mips.com> Cc: James Hogan <jhogan@kernel.org> Cc: Ley Foon Tan <lftan@altera.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-14init: provide a generic free_initmem implementationMike Rapoport
Patch series "provide a generic free_initmem implementation", v2. Many architectures implement free_initmem() in exactly the same or very similar way: they wrap the call to free_initmem_default() with sometimes different 'poison' parameter. These patches switch those architectures to use a generic implementation that does free_initmem_default(POISON_FREE_INITMEM). This was inspired by Christoph's patches for free_initrd_mem [1] and I shamelessly copied changelog entries from his patches :) [1] https://lore.kernel.org/lkml/20190213174621.29297-1-hch@lst.de/ This patch (of 2): For most architectures free_initmem just a wrapper for the same free_initmem_default(-1) call. Provide that as a generic implementation marked __weak. Link: http://lkml.kernel.org/r/1550515285-17446-2-git-send-email-rppt@linux.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Richard Kuo <rkuo@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-14initramfs: provide a generic free_initrd_mem implementationChristoph Hellwig
For most architectures free_initrd_mem just expands to the same free_reserved_area call. Provide that as a generic implementation marked __weak. Link: http://lkml.kernel.org/r/20190213174621.29297-8-hch@lst.de Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Mike Rapoport <rppt@linux.ibm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> [arm64] Cc: Steven Price <steven.price@arm.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Russell King <linux@armlinux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-07Merge tag 'audit-pr-20190507' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit Pull audit updates from Paul Moore: "We've got a reasonably broad set of audit patches for the v5.2 merge window, the highlights are below: - The biggest change, and the source of all the arch/* changes, is the patchset from Dmitry to help enable some of the work he is doing around PTRACE_GET_SYSCALL_INFO. To be honest, including this in the audit tree is a bit of a stretch, but it does help move audit a little further along towards proper syscall auditing for all arches, and everyone else seemed to agree that audit was a "good" spot for this to land (or maybe they just didn't want to merge it? dunno.). - We can now audit time/NTP adjustments. - We continue the work to connect associated audit records into a single event" * tag 'audit-pr-20190507' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit: (21 commits) audit: fix a memory leak bug ntp: Audit NTP parameters adjustment timekeeping: Audit clock adjustments audit: purge unnecessary list_empty calls audit: link integrity evm_write_xattrs record to syscall event syscall_get_arch: add "struct task_struct *" argument unicore32: define syscall_get_arch() Move EM_UNICORE to uapi/linux/elf-em.h nios2: define syscall_get_arch() nds32: define syscall_get_arch() Move EM_NDS32 to uapi/linux/elf-em.h m68k: define syscall_get_arch() hexagon: define syscall_get_arch() Move EM_HEXAGON to uapi/linux/elf-em.h h8300: define syscall_get_arch() c6x: define syscall_get_arch() arc: define syscall_get_arch() Move EM_ARCOMPACT and EM_ARCV2 to uapi/linux/elf-em.h audit: Make audit_log_cap and audit_copy_inode static audit: connect LOGIN record to its syscall record ...
2019-05-06Merge tag 'arm64-mmiowb' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull mmiowb removal from Will Deacon: "Remove Mysterious Macro Intended to Obscure Weird Behaviours (mmiowb()) Remove mmiowb() from the kernel memory barrier API and instead, for architectures that need it, hide the barrier inside spin_unlock() when MMIO has been performed inside the critical section. The only relatively recent changes have been addressing review comments on the documentation, which is in a much better shape thanks to the efforts of Ben and Ingo. I was initially planning to split this into two pull requests so that you could run the coccinelle script yourself, however it's been plain sailing in linux-next so I've just included the whole lot here to keep things simple" * tag 'arm64-mmiowb' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (23 commits) docs/memory-barriers.txt: Update I/O section to be clearer about CPU vs thread docs/memory-barriers.txt: Fix style, spacing and grammar in I/O section arch: Remove dummy mmiowb() definitions from arch code net/ethernet/silan/sc92031: Remove stale comment about mmiowb() i40iw: Redefine i40iw_mmiowb() to do nothing scsi/qla1280: Remove stale comment about mmiowb() drivers: Remove explicit invocations of mmiowb() drivers: Remove useless trailing comments from mmiowb() invocations Documentation: Kill all references to mmiowb() riscv/mmiowb: Hook up mmwiob() implementation to asm-generic code powerpc/mmiowb: Hook up mmwiob() implementation to asm-generic code ia64/mmiowb: Add unconditional mmiowb() to arch_spin_unlock() mips/mmiowb: Add unconditional mmiowb() to arch_spin_unlock() sh/mmiowb: Add unconditional mmiowb() to arch_spin_unlock() m68k/io: Remove useless definition of mmiowb() nds32/io: Remove useless definition of mmiowb() x86/io: Remove useless definition of mmiowb() arm64/io: Remove useless definition of mmiowb() ARM/io: Remove useless definition of mmiowb() mmiowb: Hook up mmiowb helpers to spinlocks and generic I/O accessors ...
2019-05-06Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "Here are the locking changes in this cycle: - rwsem unification and simpler micro-optimizations to prepare for more intrusive (and more lucrative) scalability improvements in v5.3 (Waiman Long) - Lockdep irq state tracking flag usage cleanups (Frederic Weisbecker) - static key improvements (Jakub Kicinski, Peter Zijlstra) - misc updates, cleanups and smaller fixes" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) locking/lockdep: Remove unnecessary unlikely() locking/static_key: Don't take sleeping locks in __static_key_slow_dec_deferred() locking/static_key: Factor out the fast path of static_key_slow_dec() locking/static_key: Add support for deferred static branches locking/lockdep: Test all incompatible scenarios at once in check_irq_usage() locking/lockdep: Avoid bogus Clang warning locking/lockdep: Generate LOCKF_ bit composites locking/lockdep: Use expanded masks on find_usage_*() functions locking/lockdep: Map remaining magic numbers to lock usage mask names locking/lockdep: Move valid_state() inside CONFIG_TRACE_IRQFLAGS && CONFIG_PROVE_LOCKING locking/rwsem: Prevent unneeded warning during locking selftest locking/rwsem: Optimize rwsem structure for uncontended lock acquisition locking/rwsem: Enable lock event counting locking/lock_events: Don't show pvqspinlock events on bare metal locking/lock_events: Make lock_events available for all archs & other locks locking/qspinlock_stat: Introduce generic lockevent_*() counting APIs locking/rwsem: Enhance DEBUG_RWSEMS_WARN_ON() macro locking/rwsem: Add debug check for __down_read*() locking/rwsem: Micro-optimize rwsem_try_read_lock_unqueued() locking/rwsem: Move rwsem internal function declarations to rwsem-xadd.h ...
2019-05-06Merge branch 'core-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull unified TLB flushing from Ingo Molnar: "This contains the generic mmu_gather feature from Peter Zijlstra, which is an all-arch unification of TLB flushing APIs, via the following (broad) steps: - enhance the <asm-generic/tlb.h> APIs to cover more arch details - convert most TLB flushing arch implementations to the generic <asm-generic/tlb.h> APIs. - remove leftovers of per arch implementations After this series every single architecture makes use of the unified TLB flushing APIs" * 'core-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: mm/resource: Use resource_overlaps() to simplify region_intersects() ia64/tlb: Eradicate tlb_migrate_finish() callback asm-generic/tlb: Remove tlb_table_flush() asm-generic/tlb: Remove tlb_flush_mmu_free() asm-generic/tlb: Remove CONFIG_HAVE_GENERIC_MMU_GATHER asm-generic/tlb: Remove arch_tlb*_mmu() s390/tlb: Convert to generic mmu_gather asm-generic/tlb: Introduce CONFIG_HAVE_MMU_GATHER_NO_GATHER=y arch/tlb: Clean up simple architectures um/tlb: Convert to generic mmu_gather sh/tlb: Convert SH to generic mmu_gather ia64/tlb: Convert to generic mmu_gather arm/tlb: Convert to generic mmu_gather asm-generic/tlb, arch: Invert CONFIG_HAVE_RCU_TABLE_INVALIDATE asm-generic/tlb, ia64: Conditionally provide tlb_migrate_finish() asm-generic/tlb: Provide generic tlb_flush() based on flush_tlb_mm() asm-generic/tlb, arch: Provide generic tlb_flush() based on flush_tlb_range() asm-generic/tlb, arch: Provide generic VIPT cache flush asm-generic/tlb, arch: Provide CONFIG_HAVE_MMU_GATHER_PAGE_SIZE asm-generic/tlb: Provide a comment
2019-04-23arch: mostly remove <asm/segment.h>Christoph Hellwig
A few architectures use <asm/segment.h> internally, but nothing in common code does. Remove all the empty or almost empty versions of it, including the asm-generic one. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2019-04-10Merge branch 'linus' into locking/core, to pick up fixesIngo Molnar
2019-04-08arch: Use asm-generic header for asm/mmiowb.hWill Deacon
Hook up asm-generic/mmiowb.h to Kbuild for all architectures so that we can subsequently include asm/mmiowb.h from core code. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2019-04-05syscalls: Remove start and number from syscall_set_arguments() argsSteven Rostedt (VMware)
After removing the start and count arguments of syscall_get_arguments() it seems reasonable to remove them from syscall_set_arguments(). Note, as of today, there are no users of syscall_set_arguments(). But we are told that there will be soon. But for now, at least make it consistent with syscall_get_arguments(). Link: http://lkml.kernel.org/r/20190327222014.GA32540@altlinux.org Cc: Oleg Nesterov <oleg@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Dave Martin <dave.martin@arm.com> Cc: "Dmitry V. Levin" <ldv@altlinux.org> Cc: x86@kernel.org Cc: linux-snps-arc@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-c6x-dev@linux-c6x.org Cc: uclinux-h8-devel@lists.sourceforge.jp Cc: linux-hexagon@vger.kernel.org Cc: linux-ia64@vger.kernel.org Cc: linux-mips@vger.kernel.org Cc: nios2-dev@lists.rocketboards.org Cc: openrisc@lists.librecores.org Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-riscv@lists.infradead.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: linux-um@lists.infradead.org Cc: linux-xtensa@linux-xtensa.org Cc: linux-arch@vger.kernel.org Acked-by: Max Filippov <jcmvbkbc@gmail.com> # For xtensa changes Acked-by: Will Deacon <will.deacon@arm.com> # For the arm64 bits Reviewed-by: Thomas Gleixner <tglx@linutronix.de> # for x86 Reviewed-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2019-04-05syscalls: Remove start and number from syscall_get_arguments() argsSteven Rostedt (Red Hat)
At Linux Plumbers, Andy Lutomirski approached me and pointed out that the function call syscall_get_arguments() implemented in x86 was horribly written and not optimized for the standard case of passing in 0 and 6 for the starting index and the number of system calls to get. When looking at all the users of this function, I discovered that all instances pass in only 0 and 6 for these arguments. Instead of having this function handle different cases that are never used, simply rewrite it to return the first 6 arguments of a system call. This should help out the performance of tracing system calls by ptrace, ftrace and perf. Link: http://lkml.kernel.org/r/20161107213233.754809394@goodmis.org Cc: Oleg Nesterov <oleg@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Dave Martin <dave.martin@arm.com> Cc: "Dmitry V. Levin" <ldv@altlinux.org> Cc: x86@kernel.org Cc: linux-snps-arc@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-c6x-dev@linux-c6x.org Cc: uclinux-h8-devel@lists.sourceforge.jp Cc: linux-hexagon@vger.kernel.org Cc: linux-ia64@vger.kernel.org Cc: linux-mips@vger.kernel.org Cc: nios2-dev@lists.rocketboards.org Cc: openrisc@lists.librecores.org Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-riscv@lists.infradead.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: linux-um@lists.infradead.org Cc: linux-xtensa@linux-xtensa.org Cc: linux-arch@vger.kernel.org Acked-by: Paul Burton <paul.burton@mips.com> # MIPS parts Acked-by: Max Filippov <jcmvbkbc@gmail.com> # For xtensa changes Acked-by: Will Deacon <will.deacon@arm.com> # For the arm64 bits Reviewed-by: Thomas Gleixner <tglx@linutronix.de> # for x86 Reviewed-by: Dmitry V. Levin <ldv@altlinux.org> Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2019-04-03locking/rwsem: Remove rwsem-spinlock.c & use rwsem-xadd.c for all archsWaiman Long
Currently, we have two different implementation of rwsem: 1) CONFIG_RWSEM_GENERIC_SPINLOCK (rwsem-spinlock.c) 2) CONFIG_RWSEM_XCHGADD_ALGORITHM (rwsem-xadd.c) As we are going to use a single generic implementation for rwsem-xadd.c and no architecture-specific code will be needed, there is no point in keeping two different implementations of rwsem. In most cases, the performance of rwsem-spinlock.c will be worse. It also doesn't get all the performance tuning and optimizations that had been implemented in rwsem-xadd.c over the years. For simplication, we are going to remove rwsem-spinlock.c and make all architectures use a single implementation of rwsem - rwsem-xadd.c. All references to RWSEM_GENERIC_SPINLOCK and RWSEM_XCHGADD_ALGORITHM in the code are removed. Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Waiman Long <longman@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-c6x-dev@linux-c6x.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-riscv@lists.infradead.org Cc: linux-um@lists.infradead.org Cc: linux-xtensa@linux-xtensa.org Cc: linuxppc-dev@lists.ozlabs.org Cc: nios2-dev@lists.rocketboards.org Cc: openrisc@lists.librecores.org Cc: uclinux-h8-devel@lists.sourceforge.jp Link: https://lkml.kernel.org/r/20190322143008.21313-3-longman@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-04-03arch/tlb: Clean up simple architecturesPeter Zijlstra
For the architectures that do not implement their own tlb_flush() but do already use the generic mmu_gather, there are two options: 1) the platform has an efficient flush_tlb_range() and asm-generic/tlb.h doesn't need any overrides at all. 2) the platform lacks an efficient flush_tlb_range() and we select MMU_GATHER_NO_RANGE to minimize full invalidates. Convert all 'simple' architectures to one of these two forms. alpha: has no range invalidate -> 2 arc: already used flush_tlb_range() -> 1 c6x: has no range invalidate -> 2 hexagon: has an efficient flush_tlb_range() -> 1 (flush_tlb_mm() is in fact a full range invalidate, so no need to shoot down everything) m68k: has inefficient flush_tlb_range() -> 2 microblaze: has no flush_tlb_range() -> 2 mips: has efficient flush_tlb_range() -> 1 (even though it currently seems to use flush_tlb_mm()) nds32: already uses flush_tlb_range() -> 1 nios2: has inefficient flush_tlb_range() -> 2 (no limit on range iteration) openrisc: has inefficient flush_tlb_range() -> 2 (no limit on range iteration) parisc: already uses flush_tlb_range() -> 1 sparc32: already uses flush_tlb_range() -> 1 unicore32: has inefficient flush_tlb_range() -> 2 (no limit on range iteration) xtensa: has efficient flush_tlb_range() -> 1 Note this also fixes a bug in the existing code for a number platforms. Those platforms that did: tlb_end_vma() -> if (!full_mm) flush_tlb_*() tlb_flush -> if (full_mm) flush_tlb_mm() missed the case of shift_arg_pages(), which doesn't have @fullmm set, nor calls into tlb_*vma(), but still frees page-tables and thus needs an invalidate. The new code handles this by detecting a non-empty range, and either issuing the matching range invalidate or a full invalidate, depending on the capabilities. No change in behavior intended. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Greentime Hu <green.hu@gmail.com> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Helge Deller <deller@gmx.de> Cc: Jonas Bonn <jonas@southpole.se> Cc: Ley Foon Tan <lftan@altera.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salter <msalter@redhat.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Nick Piggin <npiggin@gmail.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Rik van Riel <riel@surriel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-04-03asm-generic/tlb, arch: Provide generic VIPT cache flushPeter Zijlstra
The one obvious thing SH and ARM want is a sensible default for tlb_start_vma(). (also: https://lkml.org/lkml/2004/1/15/6 ) Avoid all VIPT architectures providing their own tlb_start_vma() implementation and rely on architectures to provide a no-op flush_cache_range() when it is not relevant. This patch makes tlb_start_vma() default to flush_cache_range(), which should be right and sufficient. The only exceptions that I found where (oddly): - m68k-mmu - sparc64 - unicore Those architectures appear to have flush_cache_range(), but their current tlb_start_vma() does not call it. No change in behavior intended. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Miller <davem@davemloft.net> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nick Piggin <npiggin@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@surriel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-03-28KVM: export <linux/kvm_para.h> and <asm/kvm_para.h> iif KVM is supportedMasahiro Yamada
I do not see any consistency about headers_install of <linux/kvm_para.h> and <asm/kvm_para.h>. According to my analysis of Linux 5.1-rc1, there are 3 groups: [1] Both <linux/kvm_para.h> and <asm/kvm_para.h> are exported alpha, arm, hexagon, mips, powerpc, s390, sparc, x86 [2] <asm/kvm_para.h> is exported, but <linux/kvm_para.h> is not arc, arm64, c6x, h8300, ia64, m68k, microblaze, nios2, openrisc, parisc, sh, unicore32, xtensa [3] Neither <linux/kvm_para.h> nor <asm/kvm_para.h> is exported csky, nds32, riscv This does not match to the actual KVM support. At least, [2] is half-baked. Nor do arch maintainers look like they care about this. For example, commit 0add53713b1c ("microblaze: Add missing kvm_para.h to Kbuild") exported <asm/kvm_para.h> to user-space in order to fix an in-kernel build error. We have two ways to make this consistent: [A] export both <linux/kvm_para.h> and <asm/kvm_para.h> for all architectures, irrespective of the KVM support [B] Match the header export of <linux/kvm_para.h> and <asm/kvm_para.h> to the KVM support My first attempt was [A] because the code looks cleaner, but Paolo suggested [B]. So, this commit goes with [B]. For most architectures, <asm/kvm_para.h> was moved to the kernel-space. I changed include/uapi/linux/Kbuild so that it checks generated asm/kvm_para.h as well as check-in ones. After this commit, there will be two groups: [1] Both <linux/kvm_para.h> and <asm/kvm_para.h> are exported arm, arm64, mips, powerpc, s390, x86 [2] Neither <linux/kvm_para.h> nor <asm/kvm_para.h> is exported alpha, arc, c6x, csky, h8300, hexagon, ia64, m68k, microblaze, nds32, nios2, openrisc, parisc, riscv, sh, sparc, unicore32, xtensa Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Cornelia Huck <cohuck@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2019-03-20syscall_get_arch: add "struct task_struct *" argumentDmitry V. Levin
This argument is required to extend the generic ptrace API with PTRACE_GET_SYSCALL_INFO request: syscall_get_arch() is going to be called from ptrace_request() along with syscall_get_nr(), syscall_get_arguments(), syscall_get_error(), and syscall_get_return_value() functions with a tracee as their argument. The primary intent is that the triple (audit_arch, syscall_nr, arg1..arg6) should describe what system call is being called and what its arguments are. Reverts: 5e937a9ae913 ("syscall_get_arch: remove useless function arguments") Reverts: 1002d94d3076 ("syscall.h: fix doc text for syscall_get_arch()") Reviewed-by: Andy Lutomirski <luto@kernel.org> # for x86 Reviewed-by: Palmer Dabbelt <palmer@sifive.com> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Paul Burton <paul.burton@mips.com> # MIPS parts Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Acked-by: Kees Cook <keescook@chromium.org> # seccomp parts Acked-by: Mark Salter <msalter@redhat.com> # for the c6x bit Cc: Elvira Khabirova <lineprinter@altlinux.org> Cc: Eugene Syromyatnikov <esyr@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: x86@kernel.org Cc: linux-alpha@vger.kernel.org Cc: linux-snps-arc@lists.infradead.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-c6x-dev@linux-c6x.org Cc: uclinux-h8-devel@lists.sourceforge.jp Cc: linux-hexagon@vger.kernel.org Cc: linux-ia64@vger.kernel.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-mips@vger.kernel.org Cc: nios2-dev@lists.rocketboards.org Cc: openrisc@lists.librecores.org Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-riscv@lists.infradead.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: linux-um@lists.infradead.org Cc: linux-xtensa@linux-xtensa.org Cc: linux-arch@vger.kernel.org Cc: linux-audit@redhat.com Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: Paul Moore <paul@paul-moore.com>
2019-03-20nios2: define syscall_get_arch()Dmitry V. Levin
syscall_get_arch() is required to be implemented on all architectures in addition to already implemented syscall_get_nr(), syscall_get_arguments(), syscall_get_error(), and syscall_get_return_value() functions in order to extend the generic ptrace API with PTRACE_GET_SYSCALL_INFO request. Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Elvira Khabirova <lineprinter@altlinux.org> Cc: Eugene Syromyatnikov <esyr@redhat.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: nios2-dev@lists.rocketboards.org Cc: linux-audit@redhat.com Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: Paul Moore <paul@paul-moore.com>
2019-03-17kbuild: force all architectures except um to include mandatory-yMasahiro Yamada
Currently, every arch/*/include/uapi/asm/Kbuild explicitly includes the common Kbuild.asm file. Factor out the duplicated include directives to scripts/Makefile.asm-generic so that no architecture would opt out of the mandatory-y mechanism. um is not forced to include mandatory-y since it is a very exceptional case which does not support UAPI. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-03-10Merge tag 'nios2-v5.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2 Pull nios2 updates from Ley Foon Tan: "Most of updates are MMU related" * tag 'nios2-v5.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2: nios2: Fix update_mmu_cache preload the TLB with the new PTE nios2: update_mmu_cache preload the TLB with the new PTE nios2: User address TLB flush break after finding the matching entry nios2: flush_tlb_all use TLBMISC way auto-increment feature nios2: improve readability of tlb functions nios2: flush_tlb_mm flush only the pid nios2: flush_tlb_pid can just restore TLBMISC once nios2: TLBMISC writes do not require PID bits to be set nios2: Use an invalid TLB entry address helper function nios2: pte_clear does not need to flush TLB nios2: flush_tlb_page use PID based flush nios2: update_mmu_cache clear the old entry from the TLB nios2: remove redundant 'default n' from Kconfig-s nios2: ksyms: Add missing symbol exports
2019-03-07arch/nios2/mm/fault.c: remove duplicate includeSabyasachi Gupta
Remove linux/ptrace.h which is included more than once Link: http://lkml.kernel.org/r/5c45d345.1c69fb81.d90ed.8e05@mx.google.com Signed-off-by: Sabyasachi Gupta <sabyasachi.linux@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-07configs: get rid of obsolete CONFIG_ENABLE_WARN_DEPRECATEDAlexey Brodkin
This Kconfig option was removed during v4.19 development in commit 771c035372a0 ("deprecate the '__deprecated' attribute warnings entirely and for good") so there's no point to keep it in defconfigs any longer. FWIW defconfigs were patched with: --------------------------->8---------------------- find . -name *_defconfig -exec sed -i '/CONFIG_ENABLE_WARN_DEPRECATED/d' {} \; --------------------------->8---------------------- Link: http://lkml.kernel.org/r/20190128152434.41969-1-abrodkin@synopsys.com Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-07nios2: Fix update_mmu_cache preload the TLB with the new PTENicholas Piggin
There is a bug in the TLB preload caused by the pid not being shifted to the correct location in tlbmisc register. Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Tested-by: Guenter Roeck <linux@roeck-us.net>
2019-03-07nios2: update_mmu_cache preload the TLB with the new PTENicholas Piggin
Rather than flush the TLB entry when installing a new PTE to allow the fast TLB reload to re-fill the TLB, just refill the TLB entry when removing the old one. Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-03-07nios2: User address TLB flush break after finding the matching entryNicholas Piggin
2019-03-07nios2: flush_tlb_all use TLBMISC way auto-increment featureNicholas Piggin
Writes to TLBACC cause TLBMISC way to be incremented, which can be used to iterate over ways in a set, then wrap back to zero ready for the next set. This reduces register writes significantly. Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-03-07nios2: improve readability of tlb functionsNicholas Piggin
2019-03-07nios2: flush_tlb_mm flush only the pidNicholas Piggin
Currently flush_tlb_mm flushes the entire TLB. Switch it to doing a PID aware flush. This also improves the readibility of flush_tlb_pid. Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
