path: root/arch/nios2
2017-04-12nios2: reserve boot memory for device treeTobias Klauser
commit 921d701e6f31e1ffaca3560416af1aa04edb4c4f upstream. Make sure to reserve the boot memory for the flattened device tree. Otherwise it might get overwritten, e.g. when initial_boot_params is copied, leading to a corrupted FDT and a boot hang/crash: bootconsole [early0] enabled Early console on uart16650 initialized at 0xf8001600 OF: fdt: Error -11 processing FDT Kernel panic - not syncing: setup_cpuinfo: No CPU found in devicetree! ---[ end Kernel panic - not syncing: setup_cpuinfo: No CPU found in devicetree! Guenter Roeck says: > I think I found the problem. In unflatten_and_copy_device_tree(), with added > debug information: > > OF: fdt: initial_boot_params=c861e400, dt=c861f000 size=28874 (0x70ca) > > ... and then initial_boot_params is copied to dt, which results in corrupted > fdt since the memory overlaps. Looks like the initial_boot_params memory > is not reserved and (re-)allocated by early_init_dt_alloc_memory_arch(). Reported-by: Guenter Roeck <linux@roeck-us.net> Reference: http://lkml.kernel.org/r/20170226210338.GA19476@roeck-us.net Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Ley Foon Tan <ley.foon.tan@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-11nios2: fix timer initcall return valueArnd Bergmann
When called more than twice, the nios2_time_init() function return an uninitialized value, as detected by gcc -Wmaybe-uninitialized arch/nios2/kernel/time.c: warning: 'ret' may be used uninitialized in this function This makes it return '0' here, matching the comment above the function. Acked-by: Ley Foon Tan <lftan@altera.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge tag 'nios2-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2 Pull nios2 update from Ley Foon Tan: "Use of_property_read_bool() instead of open-coding it" * tag 'nios2-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2: nios2: use of_property_read_bool
2016-10-07nmi_backtrace: generate one-line reports for idle cpusChris Metcalf
When doing an nmi backtrace of many cores, most of which are idle, the output is a little overwhelming and very uninformative. Suppress messages for cpus that are idling when they are interrupted and just emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN". We do this by grouping all the cpuidle code together into a new .cpuidle.text section, and then checking the address of the interrupted PC to see if it lies within that section. This commit suitably tags x86 and tile idle routines, and only adds in the minimal framework for other architectures. Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm] Tested-by: Petr Mladek <pmladek@suse.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-06nios2: use of_property_read_boolLey Foon Tan
Use of_property_read_bool instead of open-coding it as fpcu_has. Convert the members of struct cpuinfo from u32 to bool accordingly as they are only used as boolean anyhow. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Ley Foon Tan <lftan@altera.com>
2016-10-03Merge tag 'tty-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty and serial updates from Greg KH: "Here is the big tty and serial patch set for 4.9-rc1. It also includes some drivers/dma/ changes, as those were needed by some serial drivers, and they were all acked by the DMA maintainer. Also in here is the long-suffering ACPI SPCR patchset, which was passed around from maintainer to maintainer like a hot-potato. Seems I was the sucker^Wlucky one. All of those patches have been acked by the various subsystem maintainers as well. All of this has been in linux-next with no reported issues" * tag 'tty-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (111 commits) Revert "serial: pl011: add console matching function" MAINTAINERS: update entry for atmel_serial driver serial: pl011: add console matching function ARM64: ACPI: enable ACPI_SPCR_TABLE ACPI: parse SPCR and enable matching console of/serial: move earlycon early_param handling to serial Revert "drivers/tty: Explicitly pass current to show_stack" tty: amba-pl011: Don't complain on -EPROBE_DEFER when no irq nios2: dts: 10m50: Add tx-threshold parameter serial: 8250: Set Altera 16550 TX FIFO Threshold serial: 8250: of: Load TX FIFO Threshold from DT Documentation: dt: serial: Add TX FIFO threshold parameter drivers/tty: Explicitly pass current to show_stack serial: imx: Fix DCD reading serial: stm32: mark symbols static where possible serial: xuartps: Add some register initialisation to cdns_early_console_setup() serial: xuartps: Removed unwanted checks while reading the error conditions serial: xuartps: Rewrite the interrupt handling logic serial: stm32: use mapbase instead of membase for DMA tty/serial: atmel: fix fractional baud rate computation ...
2016-09-27nios2: dts: 10m50: Add tx-threshold parameterThor Thayer
The tx-threshold parameter sets the TX FIFO low water threshold trigger for the Altera 16550-FIFO32 soft IP. Signed-off-by: Thor Thayer <tthayer@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-13nios2: fix __get_user()Al Viro
a) should not leave crap on fault b) should _not_ require access_ok() in any cases. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-13nios2: copy_from_user() should zero the tail of destinationAl Viro
2016-08-04dma-mapping: use unsigned long for dma_attrsKrzysztof Kozlowski
The dma-mapping core and the implementations do not change the DMA attributes passed by pointer. Thus the pointer can point to const data. However the attributes do not have to be a bitfield. Instead unsigned long will do fine: 1. This is just simpler. Both in terms of reading the code and setting attributes. Instead of initializing local attributes on the stack and passing pointer to it to dma_set_attr(), just set the bits. 2. It brings safeness and checking for const correctness because the attributes are passed by value. Semantic patches for this change (at least most of them): virtual patch virtual context @r@ identifier f, attrs; @@ f(..., - struct dma_attrs *attrs + unsigned long attrs , ...) { ... } @@ identifier r.f; @@ f(..., - NULL + 0 ) and // Options: --all-includes virtual patch virtual context @r@ identifier f, attrs; type t; @@ t f(..., struct dma_attrs *attrs); @@ identifier r.f; @@ f(..., - NULL + 0 ) Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Robin Murphy <robin.murphy@arm.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Salter <msalter@redhat.com> [c6x] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris] Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm] Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp] Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core] Acked-by: David Vrabel <david.vrabel@citrix.com> [xen] Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb] Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390] Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32] Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02treewide: replace obsolete _refok by __refFabian Frederick
There was only one use of __initdata_refok and __exit_refok __init_refok was used 46 times against 82 for __ref. Those definitions are obsolete since commit 312b1485fb50 ("Introduce new section reference annotations tags: __ref, __refdata, __refconst") This patch removes the following compatibility definitions and replaces them treewide. /* compatibility defines */ #define __init_refok __ref #define __initdata_refok __refdata #define __exit_refok __ref I can also provide separate patches if necessary. (One patch per tree and check in 1 month or 2 to remove old definitions) [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/1466796271-3043-1-git-send-email-fabf@skynet.be Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Ingo Molnar <mingo@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-30Merge tag 'devicetree-for-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: - remove most of_platform_populate() calls in arch code. Now the DT core code calls it in the default case and platforms only need to call it if they have special needs - use pr_fmt on all the DT core print statements - CoreSight binding doc improvements to block name descriptions - add dt_to_config script which can parse dts files and list corresponding kernel config options - fix memory leak hit with a PowerMac DT - correct a bunch of STMicro compatible strings to use the correct vendor prefix - fix DA9052 PMIC binding doc to match what is actually used in dts files * tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits) documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table" xtensa: Fix build error due to missing include file MIPS: ath79: Add missing include file Fix spelling errors in Documentation/devicetree ARM: dts: fix STMicroelectronics compatible strings powerpc/dts: fix STMicroelectronics compatible strings Documentation: dt: i2c: use correct STMicroelectronics vendor prefix scripts/dtc: dt_to_config - kernel config options for a devicetree of: fdt: mark unflattened tree as detached of: overlay: add resolver error prints coresight: document binding acronyms Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties of: use pr_fmt prefix for all console printing of/irq: Mark initialised interrupt controllers as populated of: fix memory leak related to safe_name() Revert "of/platform: export of_default_bus_match_table" of: unittest: use of_platform_default_populate() to populate default bus memory: omap-gpmc: use of_platform_default_populate() to populate default bus bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus ...
2016-07-26mm: do not pass mm_struct into handle_mm_faultKirill A. Shutemov
We always have vma->vm_mm around. Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-07Merge branch 'clockevents/4.8' of ↵Thomas Gleixner
http://git.linaro.org/people/daniel.lezcano/linux into timers/core Pull the clockevents/clocksource tree from Daniel Lezcano: - Convert the clocksource-probe init functions to return a value in order to prepare the consolidation of the drivers using the DT. It is a big patchset but went through 01.org (kbuild bot), linux next and kernel-ci (continuous integration) (Daniel Lezcano) - Fix a bad error handling by returning the right value for cadence_ttc (Christophe Jaillet) - Fix typo in the Kconfig for the Samsung pwm (Alexandre Belloni) - Change functions to static for armada-370-xp and digicolor (Ben Dooks) - Add support for the rk3399 SoC timer by adding bindings and a slight change in the base address. Take the opportunity to add the DYNIRQ flag (Huang Tao) - Fix endian accessors for the Samsung pwm timer (Matthew Leach) - Add Oxford Semiconductor RPS Dual Timer driver (Neil Armstrong) - Add a kernel parameter to swich on/off the event stream feature of the arch arm timer (Will Deacon)
2016-06-28clocksources: Switch back to the clksrc tableDaniel Lezcano
All the clocksource drivers's init function are now converted to return an error code. CLOCKSOURCE_OF_DECLARE is no longer used as well as the clksrc-of table. Let's convert back the names: - CLOCKSOURCE_OF_DECLARE_RET => CLOCKSOURCE_OF_DECLARE - clksrc-of-ret => clksrc-of Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> For exynos_mct and samsung_pwm_timer: Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> For arch/arc: Acked-by: Vineet Gupta <vgupta@synopsys.com> For mediatek driver: Acked-by: Matthias Brugger <matthias.bgg@gmail.com> For the Rockchip-part Acked-by: Heiko Stuebner <heiko@sntech.de> For STi : Acked-by: Patrice Chotard <patrice.chotard@st.com> For the mps2-timer.c and versatile.c changes: Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> For the OXNAS part : Acked-by: Neil Armstrong <narmstrong@baylibre.com> For LPC32xx driver: Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com> For Broadcom Kona timer change: Acked-by: Ray Jui <ray.jui@broadcom.com> For Sun4i and Sun5i: Acked-by: Chen-Yu Tsai <wens@csie.org> For Meson6: Acked-by: Carlo Caione <carlo@caione.org> For Keystone: Acked-by: Santosh Shilimkar <ssantosh@kernel.org> For NPS: Acked-by: Noam Camus <noamca@mellanox.com> For bcm2835: Acked-by: Eric Anholt <eric@anholt.net>
2016-06-28clocksource/drivers/nios2: Convert init function to return errorDaniel Lezcano
The init functions do not return any error. They behave as the following: - panic, thus leading to a kernel crash while another timer may work and make the system boot up correctly or - print an error and let the caller unaware if the state of the system Change that by converting the init functions to return an error conforming to the CLOCKSOURCE_OF_RET prototype. Proper error handling (rollback, errno value) will be changed later case by case, thus this change just return back an error or success in the init function. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2016-06-24nios2: get rid of superfluous __GFP_REPEATMichal Hocko
__GFP_REPEAT has a rather weak semantic but since it has been introduced around 2.6.12 it has been ignored for low order allocations. pte_alloc_one{_kernel} allocate PTE_ORDER which is 0. This means that this flag has never been actually useful here because it has always been used only for PAGE_ALLOC_COSTLY requests. Link: http://lkml.kernel.org/r/1464599699-30131-9-git-send-email-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Cc: Ley Foon Tan <lftan@altera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-23nios2: Remove unnecessary of_platform_populate with default match tableKefeng Wang
After patch "of/platform: Add common method to populate default bus", it is possible for arch code to remove unnecessary callers of of_platform_populate with default match table. Cc: Ley Foon Tan <lftan@altera.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-05-26Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - new option CONFIG_TRIM_UNUSED_KSYMS which does a two-pass build and unexports symbols which are not used in the current config [Nicolas Pitre] - several kbuild rule cleanups [Masahiro Yamada] - warning option adjustments for gcov etc [Arnd Bergmann] - a few more small fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (31 commits) kbuild: move -Wunused-const-variable to W=1 warning level kbuild: fix if_change and friends to consider argument order kbuild: fix adjust_autoksyms.sh for modules that need only one symbol kbuild: fix ksym_dep_filter when multiple EXPORT_SYMBOL() on the same line gcov: disable -Wmaybe-uninitialized warning gcov: disable tree-loop-im to reduce stack usage gcov: disable for COMPILE_TEST Kbuild: disable 'maybe-uninitialized' warning for CONFIG_PROFILE_ALL_BRANCHES Kbuild: change CC_OPTIMIZE_FOR_SIZE definition kbuild: forbid kernel directory to contain spaces and colons kbuild: adjust ksym_dep_filter for some cmd_* renames kbuild: Fix dependencies for final vmlinux link kbuild: better abstract vmlinux sequential prerequisites kbuild: fix call to adjust_autoksyms.sh when output directory specified kbuild: Get rid of KBUILD_STR kbuild: rename cmd_as_s_S to cmd_cpp_s_S kbuild: rename cmd_cc_i_c to cmd_cpp_i_c kbuild: drop redundant "PHONY += FORCE" kbuild: delete unnecessary "@:" kbuild: mark help target as PHONY ...
2016-05-24Merge tag 'asm-generic-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic cleanup from Arnd Bergmann: "I have only one patch for asm-generic in this release, this one is from James Hogan and updates the generic system call table for renameat2 so we don't need to provide both renameat and renameat2 in newly added architectures" * tag 'asm-generic-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: Drop renameat syscall from default list
2016-05-24Merge tag 'nios2-v4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2 Pull nios2 update from Ley Foon Tan: - add order-only DTC dependency to %.dtb target - fix libgcc location detection * tag 'nios2-v4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2: nios2: Add order-only DTC dependency to %.dtb target nios2: Fix libgcc location detection
2016-05-20lib/GCD.c: use binary GCD algorithm instead of EuclideanZhaoxiu Zeng
The binary GCD algorithm is based on the following facts: 1. If a and b are all evens, then gcd(a,b) = 2 * gcd(a/2, b/2) 2. If a is even and b is odd, then gcd(a,b) = gcd(a/2, b) 3. If a and b are all odds, then gcd(a,b) = gcd((a-b)/2, b) = gcd((a+b)/2, b) Even on x86 machines with reasonable division hardware, the binary algorithm runs about 25% faster (80% the execution time) than the division-based Euclidian algorithm. On platforms like Alpha and ARMv6 where division is a function call to emulation code, it's even more significant. There are two variants of the code here, depending on whether a fast __ffs (find least significant set bit) instruction is available. This allows the unpredictable branches in the bit-at-a-time shifting loop to be eliminated. If fast __ffs is not available, the "even/odd" GCD variant is used. I use the following code to benchmark: #include <stdio.h> #include <stdlib.h> #include <stdint.h> #include <string.h> #include <time.h> #include <unistd.h> #define swap(a, b) \ do { \ a ^= b; \ b ^= a; \ a ^= b; \ } while (0) unsigned long gcd0(unsigned long a, unsigned long b) { unsigned long r; if (a < b) { swap(a, b); } if (b == 0) return a; while ((r = a % b) != 0) { a = b; b = r; } return b; } unsigned long gcd1(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; b >>= __builtin_ctzl(b); for (;;) { a >>= __builtin_ctzl(a); if (a == b) return a << __builtin_ctzl(r); if (a < b) swap(a, b); a -= b; } } unsigned long gcd2(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; r &= -r; while (!(b & r)) b >>= 1; for (;;) { while (!(a & r)) a >>= 1; if (a == b) return a; if (a < b) swap(a, b); a -= b; a >>= 1; if (a & r) a += b; a >>= 1; } } unsigned long gcd3(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; b >>= __builtin_ctzl(b); if (b == 1) return r & -r; for (;;) { a >>= __builtin_ctzl(a); if (a == 1) return r & -r; if (a == b) return a << __builtin_ctzl(r); if (a < b) swap(a, b); a -= b; } } unsigned long gcd4(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; r &= -r; while (!(b & r)) b >>= 1; if (b == r) return r; for (;;) { while (!(a & r)) a >>= 1; if (a == r) return r; if (a == b) return a; if (a < b) swap(a, b); a -= b; a >>= 1; if (a & r) a += b; a >>= 1; } } static unsigned long (*gcd_func[])(unsigned long a, unsigned long b) = { gcd0, gcd1, gcd2, gcd3, gcd4, }; #define TEST_ENTRIES (sizeof(gcd_func) / sizeof(gcd_func[0])) #if defined(__x86_64__) #define rdtscll(val) do { \ unsigned long __a,__d; \ __asm__ __volatile__("rdtsc" : "=a" (__a), "=d" (__d)); \ (val) = ((unsigned long long)__a) | (((unsigned long long)__d)<<32); \ } while(0) static unsigned long long benchmark_gcd_func(unsigned long (*gcd)(unsigned long, unsigned long), unsigned long a, unsigned long b, unsigned long *res) { unsigned long long start, end; unsigned long long ret; unsigned long gcd_res; rdtscll(start); gcd_res = gcd(a, b); rdtscll(end); if (end >= start) ret = end - start; else ret = ~0ULL - start + 1 + end; *res = gcd_res; return ret; } #else static inline struct timespec read_time(void) { struct timespec time; clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &time); return time; } static inline unsigned long long diff_time(struct timespec start, struct timespec end) { struct timespec temp; if ((end.tv_nsec - start.tv_nsec) < 0) { temp.tv_sec = end.tv_sec - start.tv_sec - 1; temp.tv_nsec = 1000000000ULL + end.tv_nsec - start.tv_nsec; } else { temp.tv_sec = end.tv_sec - start.tv_sec; temp.tv_nsec = end.tv_nsec - start.tv_nsec; } return temp.tv_sec * 1000000000ULL + temp.tv_nsec; } static unsigned long long benchmark_gcd_func(unsigned long (*gcd)(unsigned long, unsigned long), unsigned long a, unsigned long b, unsigned long *res) { struct timespec start, end; unsigned long gcd_res; start = read_time(); gcd_res = gcd(a, b); end = read_time(); *res = gcd_res; return diff_time(start, end); } #endif static inline unsigned long get_rand() { if (sizeof(long) == 8) return (unsigned long)rand() << 32 | rand(); else return rand(); } int main(int argc, char **argv) { unsigned int seed = time(0); int loops = 100; int repeats = 1000; unsigned long (*res)[TEST_ENTRIES]; unsigned long long elapsed[TEST_ENTRIES]; int i, j, k; for (;;) { int opt = getopt(argc, argv, "n:r:s:"); /* End condition always first */ if (opt == -1) break; switch (opt) { case 'n': loops = atoi(optarg); break; case 'r': repeats = atoi(optarg); break; case 's': seed = strtoul(optarg, NULL, 10); break; default: /* You won't actually get here. */ break; } } res = malloc(sizeof(unsigned long) * TEST_ENTRIES * loops); memset(elapsed, 0, sizeof(elapsed)); srand(seed); for (j = 0; j < loops; j++) { unsigned long a = get_rand(); /* Do we have args? */ unsigned long b = argc > optind ? strtoul(argv[optind], NULL, 10) : get_rand(); unsigned long long min_elapsed[TEST_ENTRIES]; for (k = 0; k < repeats; k++) { for (i = 0; i < TEST_ENTRIES; i++) { unsigned long long tmp = benchmark_gcd_func(gcd_func[i], a, b, &res[j][i]); if (k == 0 || min_elapsed[i] > tmp) min_elapsed[i] = tmp; } } for (i = 0; i < TEST_ENTRIES; i++) elapsed[i] += min_elapsed[i]; } for (i = 0; i < TEST_ENTRIES; i++) printf("gcd%d: elapsed %llu\n", i, elapsed[i]); k = 0; srand(seed); for (j = 0; j < loops; j++) { unsigned long a = get_rand(); unsigned long b = argc > optind ? strtoul(argv[optind], NULL, 10) : get_rand(); for (i = 1; i < TEST_ENTRIES; i++) { if (res[j][i] != res[j][0]) break; } if (i < TEST_ENTRIES) { if (k == 0) { k = 1; fprintf(stderr, "Error:\n"); } fprintf(stderr, "gcd(%lu, %lu): ", a, b); for (i = 0; i < TEST_ENTRIES; i++) fprintf(stderr, "%ld%s", res[j][i], i < TEST_ENTRIES - 1 ? ", " : "\n"); } } if (k == 0) fprintf(stderr, "PASS\n"); free(res); return 0; } Compiled with "-O2", on "VirtualBox 4.4.0-22-generic #38-Ubuntu x86_64" got: zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 10174 gcd1: elapsed 2120 gcd2: elapsed 2902 gcd3: elapsed 2039 gcd4: elapsed 2812 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9309 gcd1: elapsed 2280 gcd2: elapsed 2822 gcd3: elapsed 2217 gcd4: elapsed 2710 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9589 gcd1: elapsed 2098 gcd2: elapsed 2815 gcd3: elapsed 2030 gcd4: elapsed 2718 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9914 gcd1: elapsed 2309 gcd2: elapsed 2779 gcd3: elapsed 2228 gcd4: elapsed 2709 PASS [akpm@linux-foundation.org: avoid #defining a CONFIG_ variable] Signed-off-by: Zhaoxiu Zeng <zhaoxiu.zeng@gmail.com> Signed-off-by: George Spelvin <linux@horizon.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20exit_thread: remove empty bodiesJiri Slaby
Define HAVE_EXIT_THREAD for archs which want to do something in exit_thread. For others, let's define exit_thread as an empty inline. This is a cleanup before we change the prototype of exit_thread to accept a task parameter. [akpm@linux-foundation.org: fix mips] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19nios2: Add order-only DTC dependency to %.dtb targetMarek Vasut
The dtc dependency is missing, thus dtc is not built before it's invoked, resulting in the following problem: linux-2.6$ make 10m50_defconfig && make 10m50_devboard.dtb [...] scripts/kconfig/conf --silentoldconfig Kconfig DTC arch/nios2/boot/10m50_devboard.dtb /bin/sh: 1: ./scripts/dtc/dtc: not found arch/nios2/boot/Makefile:52: recipe for target 'arch/nios2/boot/10m50_devboard.dtb' failed make[1]: *** [arch/nios2/boot/10m50_devboard.dtb] Error 127 arch/nios2/Makefile:57: recipe for target '10m50_devboard.dtb' failed make: *** [10m50_devboard.dtb] Error 2 Signed-off-by: Marek Vasut <marex@denx.de> Cc: Ley Foon Tan <lftan@altera.com> Cc: Romain Perier <romain.perier@free-electrons.com> Acked-by: Ley Foon Tan <lftan@altera.com>
2016-05-17Merge tag 'gpio-v4.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for kernel cycle v4.7: Core infrastructural changes: - Support for natively single-ended GPIO driver stages. This means that if the hardware has registers to configure open drain or open source configuration, we use that rather than (as we did before) try to emulate it by switching the line to an input to get high impedance. This is also documented throughly in Documentation/gpio/driver.txt for those of you who did not understand one word of what I just wrote. - Start to do away with the unnecessarily complex and unitelligible ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB, another evolutional artifact from the time when the GPIO subsystem was unmaintained. Archs can now just select GPIOLIB and be done with it, cleanups to arches will trickle in for the next kernel. Some minor archs ACKed the changes immediately so these are included in this pull request. - Advancing the use of the data pointer inside the GPIO device for storing driver data by switching the PowerPC, Super-H Unicore and a few other subarches or subsystem drivers in ALSA SoC, Input, serial, SSB, staging etc to use it. - The initialization now reads the input/output state of the GPIO lines, so that each GPIO descriptor knows - if this callback is implemented - whether the line is input or output. This also reflects nicely in userspace "lsgpio". - It is now possible to name GPIO producer names, line names, from the device tree. (Platform data has been supported for a while). I bet we will get a similar mechanism for ACPI one of those days. This makes is possible to get sensible producer names for e.g. GPIO rails in "lsgpio" in userspace. New drivers: - New driver for the Loongson1. - The XLP driver now supports Broadcom Vulcan ARM64. - The IT87 driver now supports IT8620 and IT8628. - The PCA953X driver now supports Galileo Gen2. Driver improvements: - MCP23S08 was switched to use the gpiolib irqchip helpers and now also suppors level-triggered interrupts. - 74x164 and RCAR now supports the .set_multiple() callback - AMDPT was converted to use generic GPIO. - TC3589x, TPS65218, SX150X, F7188X, MENZ127, VX855, WM831X, WM8994 support the new single ended callback for open drain and in some cases open source. - Implement the .get_direction() callback for a few more drivers like PL061, Xgene. Cleanups: - Paul Gortmaker combed through the drivers and de-modularized those who are not really modules. - Move the GPIO poweroff DT bindings to the power subdir where they belong. - Rename gpio-generic.c to gpio-mmio.c, which is much more to the point. That's what it is handling, nothing more, nothing less" * tag 'gpio-v4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (126 commits) MIPS: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB gpio: zevio: make it explicitly non-modular gpio: timberdale: make it explicitly non-modular gpio: stmpe: make it explicitly non-modular gpio: sodaville: make it explicitly non-modular pinctrl: sh-pfc: Let gpio_chip.to_irq() return zero on error gpio: dwapb: Add ACPI device ID for DWAPB GPIO controller on X-Gene platforms gpio: dt-bindings: add wd,mbl-gpio bindings gpio: of: make it possible to name GPIO lines gpio: make gpiod_to_irq() return negative for NO_IRQ gpio: xgene: implement .get_direction() gpio: xgene: Enable ACPI support for X-Gene GFC GPIO driver gpio: tegra: Implement gpio_get_direction callback gpio: set up initial state from .get_direction() gpio: rename gpio-generic.c into gpio-mmio.c gpio: generic: fix GPIO_GENERIC_PLATFORM is set to module case gpio: dwapb: add gpio-signaled acpi event support gpio: dwapb: convert device node to fwnode gpio: dwapb: remove name from dwapb_port_property gpio/qoriq: select IRQ_DOMAIN ...
2016-05-17nios2: Fix libgcc location detectionMarek Vasut
The extra CFLAGS required for correct operation of the toolchain are not propagated into the libgcc detection code. In case of the compiler from poky sdk, these extra CFLAGS contain the location of compiler sysroot (the --sysroot= option) and without this option, the location of libgcc is not properly reported. Add the missing CFLAGS to address this issue. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Ley Foon Tan <lftan@altera.com> Cc: Romain Perier <romain.perier@free-electrons.com> Acked-by: Romain Perier <romain.perier@free-electrons.com> Acked-by: Ley Foon Tan <lftan@altera.com>
2016-05-16Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Will Deacon: - virt_to_page/page_address optimisations - support for NUMA systems described using device-tree - support for hibernate/suspend-to-disk - proper support for maxcpus= command line parameter - detection and graceful handling of AArch64-only CPUs - miscellaneous cleanups and non-critical fixes * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (92 commits) arm64: do not enforce strict 16 byte alignment to stack pointer arm64: kernel: Fix incorrect brk randomization arm64: cpuinfo: Missing NULL terminator in compat_hwcap_str arm64: secondary_start_kernel: Remove unnecessary barrier arm64: Ensure pmd_present() returns false after pmd_mknotpresent() arm64: Replace hard-coded values in the pmd/pud_bad() macros arm64: Implement pmdp_set_access_flags() for hardware AF/DBM arm64: Fix typo in the pmdp_huge_get_and_clear() definition arm64: mm: remove unnecessary EXPORT_SYMBOL_GPL arm64: always use STRICT_MM_TYPECHECKS arm64: kvm: Fix kvm teardown for systems using the extended idmap arm64: kaslr: increase randomization granularity arm64: kconfig: drop CONFIG_RTC_LIB dependency arm64: make ARCH_SUPPORTS_DEBUG_PAGEALLOC depend on !HIBERNATION arm64: hibernate: Refuse to hibernate if the boot cpu is offline arm64: kernel: Add support for hibernate/suspend-to-disk PM / Hibernate: Call flush_icache_range() on pages restored in-place arm64: Add new asm macro copy_page arm64: Promote KERNEL_START/KERNEL_END definitions to a header file arm64: kernel: Include _AC definition in page.h ...
2016-05-05asm-generic: Drop renameat syscall from default listJames Hogan
The newer renameat2 syscall provides all the functionality provided by the renameat syscall and adds flags, so future architectures won't need to include renameat. Therefore drop the renameat syscall from the generic syscall list unless __ARCH_WANT_RENAMEAT is defined by the architecture's unistd.h prior to including asm-generic/unistd.h, and adjust all architectures using the generic syscall list to define it so that no in-tree architectures are affected. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: linux-arch@vger.kernel.org Cc: linux-snps-arc@lists.infradead.org Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: linux-metag@vger.kernel.org Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ley Foon Tan <lftan@altera.com> Cc: nios2-dev@lists.rocketboards.org Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-04-27nios2: memset: use the right constraint modifier for the %4 output operandRomain Perier
Depending on the size of the area to be memset'ed, the nios2 memset implementation either uses a naive loop (for buffers smaller or equal than 8 bytes) or a more optimized implementation (for buffers larger than 8 bytes). This implementation does 4-byte stores rather than 1-byte stores to speed up memset. However, we discovered that on our nios2 platform, memset() was not properly setting the buffer to the expected value. A memset of 0xff would not set the entire buffer to 0xff, but to: 0xff 0x00 0xff 0x00 0xff 0x00 0xff 0x00 ... Which is obviously incorrect. Our investigation has revealed that the problem lies in the incorrect constraints used in the inline assembly. The following piece of assembly, from the nios2 memset implementation, is supposed to create a 4-byte value that repeats 4 times the 1-byte pattern passed as memset argument: /* fill8 %3, %5 (c & 0xff) */ " slli %4, %5, 8\n" " or %4, %4, %5\n" " slli %3, %4, 16\n" " or %3, %3, %4\n" However, depending on the compiler and optimization level, this code might be compiled as: 34: 280a923a slli r5,r5,8 38: 294ab03a or r5,r5,r5 3c: 2808943a slli r4,r5,16 40: 2148b03a or r4,r4,r5 This is wrong because r5 gets used both for %5 and %4, which leads to the final pattern stored in r4 to be 0xff00ff00 rather than the expected 0xffffffff. %4 is defined with the "=r" constraint, i.e as an output operand. However, as explained in http://www.ethernut.de/en/documents/arm-inline-asm.html, this does not prevent gcc from using the same register for an output operand (%4) and input operand (%5). By using the constraint modifier '&', we indicate that the register should be used for output only. With this change, we get the following assembly output: 34: 2810923a slli r8,r5,8 38: 4150b03a or r8,r8,r5 3c: 400e943a slli r7,r8,16 40: 3a0eb03a or r7,r7,r8 Which correctly produces the 0xffffffff pattern when 0xff is passed as the memset() pattern. It is worth mentioning the observed consequence of this bug: we were hitting the kernel BUG() in mm/bootmem.c:__free() that verifies when marking a page as free that it was previously marked as occupied (i.e that the bit was set to 1). The entire bootmem bitmap is set to 0xff bit via a memset() during the bootmem initialization. The bootmem_free() call right after the initialization was finding some bits to be set to 0, which didn't make sense since the bitmap has just been memset'ed to 0xff. Except that due to the bug explained above, the bitmap was in fact initialized to 0xff00ff00. Thanks to Marek Vasut for his help and feedback. Signed-off-by: Romain Perier <romain.perier@free-electrons.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Ley Foon Tan <lftan@altera.com>
2016-04-26nios2: remove ARCH_WANT_OPTIONAL_GPIOLIBLinus Walleij
This symbols is not needed to get access to selecting the GPIOLIB anymore: any arch can select GPIOLIB. Cc: Michael Büsch <m@bues.ch> Cc: nios2-dev@lists.rocketboards.org Acked-by: Ley Foon Tan <lftan@altera.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-22nios2: use correct void* return type for page_to_virt()Ard Biesheuvel
To align with other architectures, the expression produced by expanding the macro page_to_virt() should be of type void*, since it returns a virtual address. Fix that, and also fix up an instance where page_to_virt was expected to return 'unsigned long', and drop another instance that was entirely unused (page_to_bus) Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2016-04-20kbuild: delete unnecessary "@:"Masahiro Yamada
Since commit 2aedcd098a94 ('kbuild: suppress annoying "... is up to date." message'), $(call if_changed,...) is evaluated to "@:" when there is nothing to do. We no longer need to add "@:" after $(call if_changed,...) to suppress "... is up to date." message. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-03-31nios2: Replace fdt_translate_address with of_flat_dt_translate_addressGuenter Roeck
nios2 builds fail with the following build error. arch/nios2/kernel/prom.c: In function 'early_init_dt_scan_serial': arch/nios2/kernel/prom.c:100:2: error: implicit declaration of function 'fdt_translate_address' Commit c90fe9c0394b ("of: earlycon: Move address translation to of_setup_earlycon()") replaced fdt_translate_address() with of_flat_dt_translate_address() but missed updating the nios2 code. Fixes: c90fe9c0394b ("of: earlycon: Move address translation to of_setup_earlycon()") Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Rob Herring <robh@kernel.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Ley Foon Tan <lftan@altera.com>
2016-03-25arch, ftrace: for KASAN put hard/soft IRQ entries into separate sectionsAlexander Potapenko
KASAN needs to know whether the allocation happens in an IRQ handler. This lets us strip everything below the IRQ entry point to reduce the number of unique stack traces needed to be stored. Move the definition of __irq_entry to <linux/interrupt.h> so that the users don't need to pull in <linux/ftrace.h>. Also introduce the __softirq_entry macro which is similar to __irq_entry, but puts the corresponding functions to the .softirqentry.text section. Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-13ipv4: Update parameters for csum_tcpudp_magic to their original typesAlexander Duyck
This patch updates all instances of csum_tcpudp_magic and csum_tcpudp_nofold to reflect the types that are usually used as the source inputs. For example the protocol field is populated based on nexthdr which is actually an unsigned 8 bit value. The length is usually populated based on skb->len which is an unsigned integer. This addresses an issue in which the IPv6 function csum_ipv6_magic was generating a checksum using the full 32b of skb->len while csum_tcpudp_magic was only using the lower 16 bits. As a result we could run into issues when attempting to adjust the checksum as there was no protocol agnostic way to update it. With this change the value is still truncated as many architectures use "(len + proto) << 8", however this truncation only occurs for values greater than 16776960 in length and as such is unlikely to occur as we stop the inner headers at ~64K in size. I did have to make a few minor changes in the arm, mn10300, nios2, and score versions of the function in order to support these changes as they were either using things such as an OR to combine the protocol and length, or were using ntohs to convert the length which would have truncated the value. I also updated a few spots in terms of whitespace and type differences for the addresses. Most of this was just to make sure all of the definitions were in sync going forward. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-20dma-mapping: always provide the dma_map_ops based implementationChristoph Hellwig
Move the generic implementation to <linux/dma-mapping.h> now that all architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now that everyone supports them. [valentinrothberg@gmail.com: remove leftovers in Kconfig] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Helge Deller <deller@gmx.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Steven Miao <realmz6@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20nios2: convert to dma_map_opsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ley Foon Tan <lftan@altera.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-26nios2: fix cache coherencyLey Foon Tan
There is intermittent cache coherency issue caught in toolchian tests. Revert to use flushd. Signed-off-by: Ley Foon Tan <lftan@altera.com>
2015-11-09Merge tag 'nios2-v4.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2 Pull nios2 updates from Ley Foon Tan: - nios2: Remove unnecessary #ifdef guards - nios2: Switch to generic __xchg() - nios2: Fix unused variable warning * tag 'nios2-v4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/lftan/nios2: nios2: Remove unnecessary #ifdef guards nios2: Switch to generic __xchg() nios2: Fix unused variable warning
2015-11-09nios2: Remove unnecessary #ifdef guardsTobias Klauser
__HAVE_ARCH_MEMMOVE and __HAVE_ARCH_MEMSET are unconditionally defined for nios2, so there is no need to protect the function definitions of memmove() and memset(). Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Ley Foon Tan <lftan@altera.com>
2015-11-09nios2: Switch to generic __xchg()Marek Vasut
The generic __xchg() implementation present in asm-generic/cmpxchg.h is correct on nios2 and even generates the same code. Switch to this generic implementation to trim down the amount of ad-hoc copies of the code. Signed-off-by: Marek Vasut <marex@denx.de> Acked-by: Ley Foon Tan <lftan@altera.com>
2015-11-09nios2: Fix unused variable warningMarek Vasut
Fix the following compiler splat by adding __maybe_unused annotation to the variable. Using this particular annotation has the least ugly impact on the code compared to using ifdeffery. arch/nios2/kernel/setup.c: In function 'nios2_boot_init': arch/nios2/kernel/setup.c:107:7: warning: unused variable 'cmdline_passed' [-Wunused-variable] char cmdline_passed[COMMAND_LINE_SIZE] = { 0, }; ^ Signed-off-by: Marek Vasut <marex@denx.de> Acked-by: Ley Foon Tan <lftan@altera.com>
2015-10-25Merge branch 'acpi-init'Rafael J. Wysocki
* acpi-init: clocksource: cosmetic: Drop OF 'dependency' from symbols clocksource / arm_arch_timer: Convert to ACPI probing clocksource: Add new CLKSRC_{PROBE,ACPI} config symbols clocksource / ACPI: Add probing infrastructure for ACPI-based clocksources irqchip / GIC: Convert the GIC driver to ACPI probing irqchip / ACPI: Add probing infrastructure for ACPI-based irqchips ACPI: Add early device probing infrastructure
2015-10-04Merge branch 'strscpy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull strscpy string copy function implementation from Chris Metcalf. Chris sent this during the merge window, but I waffled back and forth on the pull request, which is why it's going in only now. The new "strscpy()" function is definitely easier to use and more secure than either strncpy() or strlcpy(), both of which are horrible nasty interfaces that have serious and irredeemable problems. strncpy() has a useless return value, and doesn't NUL-terminate an overlong result. To make matters worse, it pads a short result with zeroes, which is a performance disaster if you have big buffers. strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking the insane NUL padding, but having a differently broken return value which returns the original length of the source string. Which means that it will read characters past the count from the source buffer, and you have to trust the source to be properly terminated. It also makes error handling fragile, since the test for overflow is unnecessarily subtle. strscpy() avoids both these problems, guaranteeing the NUL termination (but not excessive padding) if the destination size wasn't zero, and making the overflow condition very obvious by returning -E2BIG. It also doesn't read past the size of the source, and can thus be used for untrusted source data too. So why did I waffle about this for so long? Every time we introduce a new-and-improved interface, people start doing these interminable series of trivial conversion patches. And every time that happens, somebody does some silly mistake, and the conversion patch to the improved interface actually makes things worse. Because the patch is mindnumbing and trivial, nobody has the attention span to look at it carefully, and it's usually done over large swatches of source code which means that not every conversion gets tested. So I'm pulling the strscpy() support because it *is* a better interface. But I will refuse to pull mindless conversion patches. Use this in places where it makes sense, but don't do trivial patches to fix things that aren't actually known to be broken. * 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: use global strscpy() rather than private copy string: provide strscpy() Make asm/word-at-a-time.h available on all architectures
2015-10-01clocksource: cosmetic: Drop OF 'dependency' from symbolsMarc Zyngier
Seeing the 'of' characters in a symbol that is being called from ACPI seems to freak out people. So let's do a bit of pointless renaming so that these folks do feel at home. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-09-08nios2: add Max10 defconfigChee Nouk Phoon
Max10 is a FPGA device. This patch adds defconfig based on Max10 hardware reference design. Design is intended to run on Max10 development kit. Signed-off-by: Chee Nouk Phoon <cnphoon@altera.com> Signed-off-by: Ley Foon Tan <lftan@altera.com>
2015-09-08nios2: Add Max10 device treeChee Nouk Phoon
Max10 is a FPGA device. This patch adds Nios2 support for Max10. This device tree is based on Max10 hardware reference design. Signed-off-by: Chee Nouk Phoon <cnphoon@altera.com> Signed-off-by: Ley Foon Tan <lftan@altera.com>
2015-09-08nios2: remove unused statistic countersBernd Weiberg
Removed some statistic counters to improve the performance of the handler. Signed-off-by: Bernd Weiberg <bernd.weiberg@siemens.com> Signed-off-by: Ley Foon Tan <lftan@altera.com>
2015-09-08nios2: fixed variable imm16 to s16Bernd Weiberg
Fxid variable imm16 to s16 instead of u16, offset might be negative. Signed-off-by: Bernd Weiberg <bernd.weiberg@siemens.com> Signed-off-by: Ley Foon Tan <lftan@altera.com>
2015-09-08nios2/time: Migrate to new 'set-state' interfaceViresh Kumar
Migrate nios2 driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Cc: Ley Foon Tan <lftan@altera.com> Cc: Tobias Klauser <tklauser@distanz.ch> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Dmitry Torokhov <dtor@chromium.org> Cc: nios2-dev@lists.rocketboards.org Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Ley Foon Tan <lftan@altera.com>
