path: root/arch/openrisc/include
2011-09-11Add missing DMA opsJonas Bonn
For the initial architecture submission, not all of the DMA ops were implemented. This patch adds the *map_page and *map_sg variants of the DMA mapping ops. This patch is currently of interest mainly to some drivers that haven't been submitted upstream yet. Signed-off-by: Jonas Bonn <jonas@southpole.se>
2011-09-05openrisc: don't use pt_regs in struct sigcontextJonas Bonn
As it was decided not to export struct pt_regs to userspace, struct sigcontext shouldn't be using it either. The pt_regs struct for OpenRISC is kernel internal and the layout of the registers may change in the future. The struct user_regs_struct is what is guaranteed to remain stable, so struct sigcontext may use that instead. This patch removes the usage of struct pt_regs in struct sigcontext and makes according changes in signal.c to get the register layout right. The usp field is removed from the sigcontext structure as this information is already contained in the user_regs_struct. Signed-off-by: Jonas Bonn <jonas@southpole.se> Reviewed-by: Emilio Cota <cota@braap.org>
2011-07-22OpenRISC: HeadersJonas Bonn
Signed-off-by: Jonas Bonn <jonas@southpole.se> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22OpenRISC: GPIOJonas Bonn
2011-07-22OpenRISC: Scheduling/Process managementJonas Bonn
2011-07-22OpenRISC: System callsJonas Bonn
The OpenRISC Linux kernel conforms to the "generic" syscall interface which contains only the reduced set of syscalls deemed necessary for new architectures. Unfortunately, the uClibc port for OpenRISC does not fully support this reduced set; as such, an additional patch available out-of-tree needs to be applied to the kernel in order to use the current uClibc. This is just a temporary measure until the libc port can be straightened out; it is likely that OpenRISC will make the transition to glibc shortly where the generic syscall interface is better supported. Signed-off-by: Jonas Bonn <jonas@southpole.se> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22OpenRISC: IRQJonas Bonn
This patch adds support for the OpenRISC PIC. Signed-off-by: Jonas Bonn <jonas@southpole.se> Cc: tglx@linutronix.de Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22OpenRISC: TimekeepingJonas Bonn
Implements support for the OpenRISC timer which is a 28 bit cycle counter that can be read out of a special purpose register. This counter is used as a both a clock event and clocksource device. Signed-off-by: Jonas Bonn <jonas@southpole.se> Cc: tglx@linutronix.de Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22OpenRISC: DMAJonas Bonn
Simple DMA implementation. Allows for allocation of coherent memory (simply uncached) for DMA operations. Signed-off-by: Jonas Bonn <jonas@southpole.se> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22OpenRISC: PTraceJonas Bonn
This patch implements minimal PTrace support. The pt_regs structure is not exported to userspace for OpenRISC; rather, the GETREGSET mechanism is intended to be used and the registers, as such, exported in the core dump format which is ABI stable. This is in line with what is intended for new architectures as of 2.6.34 and has the advantage of permitting the layout of the registers on the kernel stack (as per pt_regs) to be freely modified. Signed-off-by: Jonas Bonn <jonas@southpole.se> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22OpenRISC: Build infrastructureJonas Bonn
2011-07-22OpenRISC: Signal handlingJonas Bonn
2011-07-22OpenRISC: Memory managementJonas Bonn
2011-07-22OpenRISC: Device treeJonas Bonn
The OpenRISC architecture uses the device tree infrastructure for the platform description. This is currently limited to having a device tree built into the kernel, but work is underway within the OpenRISC project to define how this device tree blob should be passed into the kernel from an external resource. Patch contains a single example DTS file to go with the defconfig for or1ksim. Signed-off-by: Jonas Bonn <jonas@southpole.se> Cc: devicetree-discuss@lists.ozlabs.org Reviewed-by: Arnd Bergmann <arnd@arndb.de>
