path: root/arch/openrisc
2014-01-30Merge tag 'for-3.14' of git://openrisc.net/~jonas/linuxLinus Torvalds
Pull OpenRISC updates from Jonas Bonn: "The interesting change here is a rework of the OpenRISC signal handling to make it more like other architectures in the hopes that this makes it easier for others to comment on and understand. This rework fixes some real bugs, like the fact that syscall restart did not work reliably" * tag 'for-3.14' of git://openrisc.net/~jonas/linux: openrisc: Use get_signal() signal_setup_done() openrisc: Rework signal handling
2014-01-09openrisc: Use get_signal() signal_setup_done()Richard Weinberger
Use the more generic functions get_signal() signal_setup_done() for signal delivery. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2014-01-09openrisc: Rework signal handlingJonas Bonn
The mainline signal handling code for OpenRISC has been buggy since day one with respect to syscall restart. This patch significantly reworks the signal handling code: i) Move the "work pending" loop to C code (borrowed from ARM arch) ii) Allow a tracer to muck about with the IP and skip syscall restart in that case (again, borrowed from ARM) iii) Make signal handling WRT syscall restart actually work v) Make the signal handling code look more like that of other architectures so that it's easier for others to follow Reported-by: Anders Nystrom <anders@southpole.se> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-12-17lib: Add missing arch generic-y entries for asm-generic/hash.hDavid S. Miller
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-15Merge tag 'for-3.13' of git://git.openrisc.net/~jonas/linuxLinus Torvalds
Pull OpenRISC updates from Jonas Bonn: - small cleanups to make allmodconfig pass - defconfig refresh - a handful of code sanitization patches * tag 'for-3.13' of git://git.openrisc.net/~jonas/linux: openrisc: Refactor or32_early_setup() openrisc: Remove unused declaration of __initramfs_start openrisc: Use the declarations provided by <asm/sections.h> openrisc: Refresh or1ksim_defconfig for v3.12 openrisc: Refactor 16-bit constant relocation openrisc: include: asm: Kbuild: add default "vga.h" openrisc: Makefile: append "-D__linux__" to KBUILD_CFLAGS
2013-11-15openrisc: Refactor or32_early_setup()Geert Uytterhoeven
- Change fdt pointer (passed from head.S) from unsigned int to void *, which allows to kill a cast, and makes it compatible with __dtb_start. - Use pr_info(), - Extract common part. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux@lists.openrisc.net Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-15openrisc: Remove unused declaration of __initramfs_startGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-15openrisc: Use the declarations provided by <asm/sections.h>Geert Uytterhoeven
Openrisc's private vmlinux.h duplicates a few definitions that are already provided by asm-generic/sections.h. The former is used by setup.c only, while the latter is already used everywhere else. Convert setup.c to use the generic version: - Include <asm/sections.h>, - Remove the (slightly different) extern declarations, - Remove the no longer needed address-of ('&') operators. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-15openrisc: Refresh or1ksim_defconfig for v3.12Geert Uytterhoeven
2013-11-15openrisc: add missing pgtable_page_ctor/dtor callsKirill A. Shutemov
It will fix NR_PAGETABLE accounting. It's also required if the arch is going ever support split ptl. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jonas Bonn <jonas@southpole.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-11-05openrisc: Refactor 16-bit constant relocationGeert Uytterhoeven
arch/openrisc/kernel/module.c: In function 'apply_relocate_add': arch/openrisc/kernel/module.c:50:13: warning: assignment from incompatible pointer type arch/openrisc/kernel/module.c:54:13: warning: assignment from incompatible pointer type Move the pointer increments to the dereference statements to avoid incompatible pointer assignments, and remove superfluous casts. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-05openrisc: include: asm: Kbuild: add default "vga.h"Chen Gang
Add default "vga.h", or compiling fails with 'allmodconfig'. The related error: CC [M] drivers/gpu/drm/drm_irq.o In file included from include/linux/vgaarb.h:34:0, from drivers/gpu/drm/drm_irq.c:42: include/video/vga.h:22:21: fatal error: asm/vga.h: No such file or directory compilation terminated. make[3]: *** [drivers/gpu/drm/drm_irq.o] Error 1 make[2]: *** [drivers/gpu/drm] Error 2 make[1]: *** [drivers/gpu] Error 2 make: *** [drivers] Error 2 Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-05openrisc: Makefile: append "-D__linux__" to KBUILD_CFLAGSChen Gang
Need append "_D__linux__" to KBUILD_CFLAGS, just like some of another architectures have done, or 'allmodconfig' can not pass compiling. The related error: CC [M] fs/coda/psdev.o In file included from include/linux/coda.h:65:0, from fs/coda/psdev.c:45: include/uapi/linux/coda.h:221:2: error: expected specifier-qualifier-list before 'u_quad_t' The related compiler information: [root@dhcp122 ~]# /usr/local/bin/or32-linux-gcc -v Using built-in specs. COLLECT_GCC=/usr/local/bin/or32-linux-gcc COLLECT_LTO_WRAPPER=/usr/local/libexec/gcc/or32-linux/4.5.1-or32-1.0rc1/lto-wrapper Target: or32-linux Configured with: ../gcc-openrisc/configure --target=or32-linux --disable-nls --enable-languages=c --without-headers --disable-shared --disable-threads --enable-werror=no Thread model: single gcc version 4.5.1-or32-1.0rc1 (GCC) Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-10-09of: remove empty arch prom.h headersRob Herring
Now that prom.h is optional, all the empty prom.h headers can be removed. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com>
2013-10-09of: remove HAVE_ARCH_DEVTREE_FIXUPSRob Herring
HAVE_ARCH_DEVTREE_FIXUPS appears to always be needed except for sparc, but it is only used for /proc/device-teee and sparc does not enable /proc/device-tree. So this option is redundant. Remove the option and always enable it. This has the side effect of fixing /proc/device-tree on arches such as arm64 which failed to define this option. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com>
2013-10-09openrisc: remove unnecessary prom.c includesRob Herring
It appears openrisc prom.c was just copied from another arch with a bunch of unnecessary includes. Remove all the unecessary ones. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net
2013-10-09of: remove early_init_dt_setup_initrd_archRob Herring
All arches do essentially the same thing now for early_init_dt_setup_initrd_arch, so it can now be removed. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-10-09of: create default early_init_dt_add_memory_archRob Herring
Create a weak version of early_init_dt_add_memory_arch which uses memblock. This will unify all architectures except ones with custom memory bank structs. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: linux-arm-kernel@lists.infradead.org Cc: microblaze-uclinux@itee.uq.edu.au Cc: linux@lists.openrisc.net Cc: devicetree@vger.kernel.org
2013-10-09openrisc: use early_init_dt_scanRob Herring
Convert openrisc to use new early_init_dt_scan function. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net
2013-10-09openrisc: use unflatten_and_copy_device_treeRob Herring
Use the common unflatten_and_copy_device_tree to copy the built-in FDT out of init section. This moves the copy later in the boot, but there do not appear to be any references to strings in the FDT before the copy. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net
2013-10-09openrisc: use boot_command_line instead of private cmd_lineRob Herring
Save some pointless copying of the kernel command line and just use boot_command_line instead. The DT code already handles CONFIG_CMDLINE, so a separate copy is not needed. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net Reviewed-by: Grant Likely <grant.likely@linaro.org>
2013-10-09Merge tag 'v3.12-rc4' into sched/coreIngo Molnar
Merge Linux v3.12-rc4 to fix a conflict and also to refresh the tree before applying more scheduler patches. Conflicts: arch/avr32/include/asm/Kbuild Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched, arch: Create asm/preempt.hPeter Zijlstra
In order to prepare to per-arch implementations of preempt_count move the required bits into an asm-generic header and use this for all archs. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-24openrisc: clean-up prom.hRob Herring
Clean-up some copy/paste declarations that are not necessary. All the functions either don't exist or are already declared in other headers. This is needed in preparation of of_irq.h clean-up. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-12arch: mm: pass userspace fault flag to generic fault handlerJohannes Weiner
Unlike global OOM handling, memory cgroup code will invoke the OOM killer in any OOM situation because it has no way of telling faults occuring in kernel context - which could be handled more gracefully - from user-triggered faults. Pass a flag that identifies faults originating in user space from the architecture-specific fault handlers to generic code so that memcg OOM handling can be improved. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-10Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree core updates from Grant Likely: "Generally minor changes. A bunch of bug fixes, particularly for initialization and some refactoring. Most notable change if feeding the entire flattened tree into the random pool at boot. May not be significant, but shouldn't hurt either" Tim Bird questions whether the boot time cost of the random feeding may be noticeable. And "add_device_randomness()" is definitely not some speed deamon of a function. * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: of/platform: add error reporting to of_amba_device_create() irq/of: Fix comment typo for irq_of_parse_and_map of: Feed entire flattened device tree into the random pool of/fdt: Clean up casting in unflattening path of/fdt: Remove duplicate memory clearing on FDT unflattening gpio: implement gpio-ranges binding document fix of: call __of_parse_phandle_with_args from of_parse_phandle of: introduce of_parse_phandle_with_fixed_args of: move of_parse_phandle() of: move documentation of of_parse_phandle_with_args of: Fix missing memory initialization on FDT unflattening of: consolidate definition of early_init_dt_alloc_memory_arch() of: Make of_get_phy_mode() return int i.s.o. const int include: dt-binding: input: create a DT header defining key codes. of/platform: Staticize of_platform_device_create_pdata() of: Specify initrd location using 64-bit dt: Typo fix OF: make of_property_for_each_{u32|string}() use parameters if OF is not enabled
2013-08-28of: consolidate definition of early_init_dt_alloc_memory_arch()Grant Likely
Most architectures use the same implementation. Collapse the common ones into a single weak function that can be overridden. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-08-28Merge tag 'v3.11-rc7' into devicetree/nextGrant Likely
Linux 3.11-rc7
2013-08-21openrisc: remove undefined of_get_cpu_node declarationSudeep KarkadaNagesha
This patch removes the declaration of the function 'of_get_cpu_node' which is not defined for openrisc. This is in preparation to move it's definition from PPC to DT common code. Again it could be there as it was originally copied from powerpc. Acked-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com>
2013-08-13arch: *: Kconfig: add "kernel/Kconfig.freezer" to "arch/*/Kconfig"Chen Gang
All architectures include "kernel/Kconfig.freezer" except three left, so let them include it too, or 'allmodconfig' will report error. The related errors: (with allmodconfig for openrisc): CC kernel/cgroup_freezer.o kernel/cgroup_freezer.c: In function 'freezer_css_online': kernel/cgroup_freezer.c:133:15: error: 'system_freezing_cnt' undeclared (first use in this function) kernel/cgroup_freezer.c:133:15: note: each undeclared identifier is reported only once for each function it appears in kernel/cgroup_freezer.c: In function 'freezer_css_offline': kernel/cgroup_freezer.c:157:15: error: 'system_freezing_cnt' undeclared (first use in this function) kernel/cgroup_freezer.c: In function 'freezer_attach': kernel/cgroup_freezer.c:200:4: error: implicit declaration of function 'freeze_task' kernel/cgroup_freezer.c: In function 'freezer_apply_state': kernel/cgroup_freezer.c:371:16: error: 'system_freezing_cnt' undeclared (first use in this function) Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-24of: Specify initrd location using 64-bitSantosh Shilimkar
On some PAE architectures, the entire range of physical memory could reside outside the 32-bit limit. These systems need the ability to specify the initrd location using 64-bit numbers. This patch globally modifies the early_init_dt_setup_initrd_arch() function to use 64-bit numbers instead of the current unsigned long. There has been quite a bit of debate about whether to use u64 or phys_addr_t. It was concluded to stick to u64 to be consistent with rest of the device tree code. As summarized by Geert, "The address to load the initrd is decided by the bootloader/user and set at that point later in time. The dtb should not be tied to the kernel you are booting" More details on the discussion can be found here: https://lkml.org/lkml/2013/6/20/690 https://lkml.org/lkml/2012/9/13/544 Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-07-14openrisc: delete __cpuinit usage from all openrisc filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) are flagged as __cpuinit -- so if we remove the __cpuinit from arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the arch/openrisc uses of the __cpuinit macros from all C files. Currently openrisc does not have any __CPUINIT used in assembly files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-09mm: invoke oom-killer from remaining unconverted page fault handlersJohannes Weiner
A few remaining architectures directly kill the page faulting task in an out of memory situation. This is usually not a good idea since that task might not even use a significant amount of memory and so may not be the optimal victim to resolve the situation. Since 2.6.29's 1c0fe6e ("mm: invoke oom-killer from page fault") there is a hook that architecture page fault handlers are supposed to call to invoke the OOM killer and let it pick the right task to kill. Convert the remaining architectures over to this hook. To have the previous behavior of simply taking out the faulting task the vm.oom_kill_allocating_task sysctl can be set to 1. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits] Cc: James Hogan <james.hogan@imgtec.com> Cc: David Howells <dhowells@redhat.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04Merge branch 'kconfig-diet' from Dave HansenLinus Torvalds
Merge Kconfig menu diet patches from Dave Hansen: "I think the "Kernel Hacking" menu has gotten a bit out of hand. It is over 120 lines long on my system with everything enabled and options are scattered around it haphazardly. http://sr71.net/~dave/linux/kconfig-horror.png Let's try to introduce some sanity. This set takes that 120 lines down to 55 and makes it vastly easier to find some things. It's a start. This set stands on its own, but there is plenty of room for follow-up patches. The arch-specific debug options still end up getting stuck in the top-level "kernel hacking" menu. OPTIMIZE_INLINING, for instance, could obviously go in to the "compiler options" menu, but the fact that it is defined in arch/ in a separate Kconfig file keeps it on its own for the moment. The Signed-off-by's in here look funky. I changed employers while working on this set, so I have signoffs from both email addresses" * emailed patches from Dave Hansen <dave@sr71.net>: hang and lockup detection menu kconfig: consolidate printk options group locking debugging options consolidate compilation option configs consolidate runtime testing configs order memory debugging Kconfig options consolidate per-arch stack overflow debugging options
2013-07-04consolidate per-arch stack overflow debugging optionsDave Hansen
Original posting: http://lkml.kernel.org/r/20121214184202.F54094D9@kernel.stglabs.ibm.com Several architectures have similar stack debugging config options. They all pretty much do the same thing, some with slightly differing help text. This patch changes the architectures to instead enable a Kconfig boolean, and then use that boolean in the generic Kconfig.debug to present the actual menu option. This removes a bunch of duplication and adds consistency across arches. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [for tile] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03mm/openrisc: prepare for removing num_physpages and simplify mem_init()Jiang Liu
Prepare for removing num_physpages and simplify mem_init(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Jonas Bonn <jonas@southpole.se> Cc: David Howells <dhowells@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: concentrate modification of totalram_pages into the mm coreJiang Liu
Concentrate code to modify totalram_pages into the mm core, so the arch memory initialized code doesn't need to take care of it. With these changes applied, only following functions from mm core modify global variable totalram_pages: free_bootmem_late(), free_all_bootmem(), free_all_bootmem_node(), adjust_managed_page_count(). With this patch applied, it will be much more easier for us to keep totalram_pages and zone->managed_pages in consistence. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: enhance free_reserved_area() to support poisoning memory with zeroJiang Liu
Address more review comments from last round of code review. 1) Enhance free_reserved_area() to support poisoning freed memory with pattern '0'. This could be used to get rid of poison_init_mem() on ARM64. 2) A previous patch has disabled memory poison for initmem on s390 by mistake, so restore to the original behavior. 3) Remove redundant PAGE_ALIGN() when calling free_reserved_area(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: change signature of free_reserved_area() to fix building warningsJiang Liu
Change signature of free_reserved_area() according to Russell King's suggestion to fix following build warnings: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default] free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL); ^ In file included from include/linux/mman.h:4:0, from arch/arm/mm/init.c:15: include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *' extern unsigned long free_reserved_area(unsigned long start, unsigned long end, mm/page_alloc.c: In function 'free_reserved_area': >> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] In file included from arch/mips/include/asm/page.h:49:0, from include/linux/mmzone.h:20, from include/linux/gfp.h:4, from include/linux/mm.h:8, from mm/page_alloc.c:18: arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int' mm/page_alloc.c: In function 'free_area_init_nodes': mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds] Also address some minor code review comments. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Merge branch 'exotic-arch-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull "exotic" arch fixes from Geert Uytterhoeven: "This is a collection of several exotic architecture fixes, and a few other fixes for issues that were detected while doing the former" * 'exotic-arch-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (35 commits) lib: Move fonts from drivers/video/console/ to lib/fonts/ console/font: Refactor font support code selection logic Revert "staging/solo6x10: depend on CONFIG_FONTS" input: cros_ec_keyb_clear_keyboard() depends on CONFIG_PM_SLEEP score: Wire up asm-generic/xor.h score: Remove unneeded <asm/dma-mapping.h> openrisc: Wire up asm-generic/xor.h h8300/boot: Use POSIX "$((..))" instead of bashism "$[...]" h8300: Mark H83002 and H83048 CPU support broken h8300: Switch h8300 to drivers/Kconfig h8300: Limit timer channel ranges in Kconfig h8300: Wire up asm-generic/xor.h h8300: Fill the system call table using a CALL() macro h8300: Fix <asm/tlb.h> h8300: Hardcode symbol prefixes in asm sources h8300: add missing definition for read_barries_depends() frv: head.S - Remove commented-out initialization code cris: Wire up asm-generic/vga.h parport: disable PC-style parallel port support on cris console: Disable VGA text console support on cris ...
2013-06-29consolidate io_remap_pfn_range definitionsAl Viro
2013-06-23openrisc: Wire up asm-generic/xor.hGeert Uytterhoeven
crypto/xor.c:25:21: error: asm/xor.h: No such file or directory Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Jonas Bonn <jonas@southpole.se>
2013-05-09Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull removal of GENERIC_GPIO from Grant Likely: "GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it is possible to do so which has been causing confusion and breakage. This branch does the work to completely eliminate GENERIC_GPIO." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: gpio: update gpio Chinese documentation Remove GENERIC_GPIO config option Convert selectors of GENERIC_GPIO to GPIOLIB blackfin: force use of gpiolib m68k: coldfire: use gpiolib mips: pnx833x: remove requirement for GENERIC_GPIO openrisc: default GENERIC_GPIO to false avr32: default GENERIC_GPIO to false xtensa: remove explicit selection of GENERIC_GPIO sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB powerpc: remove redundant GENERIC_GPIO selection unicore32: default GENERIC_GPIO to false unicore32: remove unneeded select GENERIC_GPIO arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB arm: remove redundant GENERIC_GPIO selection mips: alchemy: require gpiolib mips: txx9: change GENERIC_GPIO to GPIOLIB mips: loongson: use GPIO driver on CONFIG_GPIOLIB mips: remove redundant GENERIC_GPIO select
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel Pull Hexagon fixes from Richard Kuo: "Changes for the Hexagon architecture (and one touching OpenRISC). They include various fixes to make use of additional arch features and cleanups. The largest functional change is a cleanup of the signal and event return paths" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel: (32 commits) Hexagon: add v4 CS regs to core copyout macro Hexagon: use correct translation for VMALLOC_START Hexagon: use correct translations for DMA mappings Hexagon: fix return value for notify_resume case in do_work_pending Hexagon: fix signal number for user mem faults Hexagon: remove two Kconfig entries arch: remove CONFIG_GENERIC_FIND_NEXT_BIT again Hexagon: update copyright dates Hexagon: add translation types for __vmnewmap Hexagon: fix signal.c compile error Hexagon: break up user fn/arg register setting Hexagon: use generic sys_fork, sys_vfork, and sys_clone Hexagon: fix psp/sp macro Hexagon: fix up int enable/disable at ret_from_fork Hexagon: add IOMEM and _relaxed IO macros Hexagon: switch to using the device type for IO mappings Hexagon: don't print info for offline CPU's Hexagon: add support for single-stepping (v4+) Hexagon: use correct work mask when checking for more work Hexagon: add support for additional exceptions ...
2013-04-30arch: remove CONFIG_GENERIC_FIND_NEXT_BIT againPaul Bolle
CONFIG_GENERIC_FIND_NEXT_BIT was removed in v3.0, but reappeared in two architectures. Remove it again. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
