Noticed this when building with allyesconfig. Got build failures due
to iounmap and __ioremap symbols missing. This patch exports them so
modules can use them. This is inline with other architectures.
Signed-off-by: Stafford Horne <shorne@gmail.com>
The Kconfig option for OR12000 is OR1K_1200.
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
These string definitions are no longer used removed them. Noticed this
while working on a CONFIG_DEBUG_INFO build issue.
The strings used during the head/init phase of openrisc bootup were
stored in the executable section of the binary.
This causes compilation to fail when using CONFIG_DEBUG_INFO with
error:
Error: unaligned opcodes detected in executable segment
Use execption SR stored in pt_regs for detection, the current SR is not
correct as the handler is running after return from exception.
Also, The code that checks for a delay slot uses a flag bitmask and then
wants to check if the result is not zero. The test it implemented was
wrong.
Correct it by changing the test to check result against non zero.
Cleanups to whitespace and add some comments. Reading through the delay
slot logic I noticed some things:
- Delay slot instructions were not indented
- Some comments are not lined up
- Use tabs and spaces consistent with other code
No functional change
This helps to suppress the vmlinux.lds file.
The generic memcpy routine provided in kernel does only byte copies.
Using word copies we can lower boot time and cycles spend in memcpy
quite significantly.
Booting on my de0 nano I see boot times go from 7.2 to 5.6 seconds.
The avg cycles in memcpy during boot go from 6467 to 1887.
I tested several algorithms (see code in previous patch mails)
The implementations I tested and avg cycles:
- Word Copies + Loop Unrolls + Non Aligned 1882
- Word Copies + Loop Unrolls 1887
- Word Copies 2441
- Byte Copies + Loop Unrolls 6467
- Byte Copies 7600
In the end I ended up going with Word Copies + Loop Unrolls as it
provides best tradeoff between simplicity and boot speedups.
This adds a hand-optimized assembler version of memset and sets
__HAVE_ARCH_MEMSET to use this version instead of the generic C
routine
Signed-off-by: Olof Kindgren <olof.kindgren@gmail.com>
This patch adds basic support for the idle state of the cpu.
The patch overrides the regular idle function, enables the interupts,
checks for the power management unit and enables the cpu doze mode
if available.
Signed-off-by: Sebastian Macke <sebastian@macke.de>
[shorne@gmail.com: Fixed checkpatch, blankline after declarations]
The bits were swapped, as per spec and processor implementation the
power management present bit is 9 and PIC bit is 8. This patch brings
the definitions into spec.
[shorne@gmail.com: Added commit body]
This causes the build to fail when building with the or1k-musl-linux-
toolchain and it is not needed.
Support for the futex_atomic_* operations by using the
load-link/store-conditional l.lwa/l.swa instructions.
Most openrisc cores provide these instructions now if not available,
emulation is provided.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
[shorne@gmail.com: remove OPENRISC_HAVE_INST_LWA_SWA config suggesed by
Alan Cox https://lkml.org/lkml/2014/7/23/666]
Using the l.lwa and l.swa atomic instruction pair.
Most openrisc processor cores provide these instructions now. If the
instructions are not available emulation is provided.
[shorne@gmail.com: expand to implement all ops suggested by Peter
Zijlstra https://lkml.org/lkml/2017/2/20/317]
Optimized version that make use of the l.lwa and l.swa atomic instruction
pair.
Most openrisc cores provide these instructions now, if not available
[shorne@gmail.com: fixed unused calculated value compiler warning in
define cmpxchg]
This utilize the load-link/store-conditional l.lwa and l.swa
instructions to implement the atomic bitops.
When those instructions are not available emulation is provided.
Alan Cox https://lkml.org/lkml/2014/7/23/666, implement
test_and_change_bit]
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull exception table module split from Paul Gortmaker:
"Final extable.h related changes.
This completes the separation of exception table content from the
module.h header file. This is achieved with the final commit that
removes the one line back compatible change that sourced extable.h
into the module.h file.
The commits are unchanged since January, with the exception of a
couple Acks that came in for the last two commits a bit later. The
changes have been in linux-next for quite some time[1] and have got
widespread arch coverage via toolchains I have and also from
additional ones the kbuild bot has.
Maintaners of the various arch were Cc'd during the postings to
lkml[2] and informed that the intention was to take the remaining arch
specific changes and lump them together with the final two non-arch
specific changes and submit for this merge window.
The ia64 diffstat stands out and probably warrants a mention. In an
earlier review, Al Viro made a valid comment that the original header
separation of content left something to be desired, and that it get
fixed as a part of this change, hence the larger diffstat"
* tag 'extable-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (21 commits)
module.h: remove extable.h include now users have migrated
core: migrate exception table users off module.h and onto extable.h
cris: migrate exception table users off module.h and onto extable.h
hexagon: migrate exception table users off module.h and onto extable.h
microblaze: migrate exception table users off module.h and onto extable.h
unicore32: migrate exception table users off module.h and onto extable.h
score: migrate exception table users off module.h and onto extable.h
metag: migrate exception table users off module.h and onto extable.h
arc: migrate exception table users off module.h and onto extable.h
nios2: migrate exception table users off module.h and onto extable.h
sparc: migrate exception table users onto extable.h
openrisc: migrate exception table users off module.h and onto extable.h
frv: migrate exception table users off module.h and onto extable.h
sh: migrate exception table users off module.h and onto extable.h
xtensa: migrate exception table users off module.h and onto extable.h
mn10300: migrate exception table users off module.h and onto extable.h
alpha: migrate exception table users off module.h and onto extable.h
arm: migrate exception table users off module.h and onto extable.h
m32r: migrate exception table users off module.h and onto extable.h
ia64: ensure exception table search users include extable.h
This adds an emulation layer for implementations
that lack the l.lwa and l.swa instructions.
It handles these instructions both in kernel space and
user space.
[shorne@gmail.com: Added delay slot pc adjust logic]
This brings it inline with the other setup oprations done like the cache
enables _ic_enable and _dc_enable. Also, this is going to make it
easier to initialize additional cpu's when smp is introduced.
The stack size was hard coded to 0x2000, use the standard THREAD_SIZE
definition loaded from thread_info.h.
[shorne@gmail.com: Added body to the commit message]
By slightly reorganizing the code, the number of registers
used in the tlb miss handlers can be reduced by two,
thus removing the need to save them to memory.
Also, some dead and commented out code is removed.
No functional change.
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Motivation for this is to be able to print the way information
properly in print_cpuinfo(), instead of hardcoding it to one.
[shorne@gmail.com fixed conflict with show_cpuinfo change]
The sparse IRQ framework is preferred nowadays so switch over to it.
cputime_t is now only used by two architectures:
* powerpc (when CONFIG_VIRT_CPU_ACCOUNTING_NATIVE=y)
* s390
And since the core doesn't use it anymore, we don't need any arch support
from the others. So we can remove their stub implementations.
A final cleanup would be to provide an efficient pure arch
implementation of cputime_to_nsec() for s390 and powerpc and finally
remove include/linux/cputime.h .
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Link: http://lkml.kernel.org/r/1485832191-26889-36-git-send-email-fweisbec@gmail.com
These files were only including module.h for exception table related
functions. We've now separated that content out into its own file
"extable.h" so now move over to that and avoid all the extra header
content in module.h that we don't really need to compile these files.
Reported-by: kbuild test robot <lkp@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Stafford Horne <shorne@gmail.com>
Cc: openrisc@lists.librecores.org
Introduce a new architecture-specific get_arch_dma_ops() function
that takes a struct bus_type * argument. Add get_dma_ops() in
<linux/dma-mapping.h>.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: x86@kernel.org
Signed-off-by: Doug Ledford <dledford@redhat.com>
Most dma_map_ops structures are never modified. Constify these
structures such that these can be write-protected. This patch
has been generated as follows:
git grep -l 'struct dma_map_ops' |
xargs -d\\n sed -i \
-e 's/struct dma_map_ops/const struct dma_map_ops/g' \
-e 's/const struct dma_map_ops {/struct dma_map_ops {/g' \
-e 's/^const struct dma_map_ops;$/struct dma_map_ops;/' \
-e 's/const const struct dma_map_ops /const struct dma_map_ops /g';
sed -i -e 's/const \(struct dma_map_ops intel_dma_ops\)/\1/' \
$(git grep -l 'struct dma_map_ops intel_dma_ops');
sed -i -e 's/const \(struct dma_map_ops dma_iommu_ops\)/\1/' \
$(git grep -l 'struct dma_map_ops' | grep ^arch/powerpc);
sed -i -e '/^struct vmd_dev {$/,/^};$/ s/const \(struct dma_map_ops[[:blank:]]dma_ops;\)/\1/' \
-e '/^static void vmd_setup_dma_ops/,/^}$/ s/const \(struct dma_map_ops \*dest\)/\1/' \
-e 's/const \(struct dma_map_ops \*dest = \&vmd->dma_ops\)/\1/' \
drivers/pci/host/*.c
sed -i -e '/^void __init pci_iommu_alloc(void)$/,/^}$/ s/dma_ops->/intel_dma_ops./' arch/ia64/kernel/pci-dma.c
sed -i -e 's/static const struct dma_map_ops sn_dma_ops/static struct dma_map_ops sn_dma_ops/' arch/ia64/sn/pci/pci_dma.c
sed -i -e 's/(const struct dma_map_ops \*)//' drivers/misc/mic/bus/vop_bus.c
Cc: x86@kernel.org
The build robot reports:
.tmp_kallsyms1.o: In function `kallsyms_relative_base':
>> (.rodata+0x8a18): undefined reference to `_text'
This is when using 'make alldefconfig'. Adding this _text symbol to mark
the start of the kernel as in other architecture fixes this.
Acked-by: Jonas Bonn <jonas@southpole.se>
There is no point in having an extra type for extra confusion. u64 is
unambiguous.
Conversion was done with the following coccinelle script:
@rem@
-typedef u64 cycle_t;
@fix@
typedef cycle_t;
-cycle_t
+u64
Cc: John Stultz <john.stultz@linaro.org>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
This change allows us to pass DMA_ATTR_SKIP_CPU_SYNC which allows us to
avoid invoking cache line invalidation if the driver will just handle it
via a sync_for_cpu or sync_for_device call.
Link: http://lkml.kernel.org/r/20161110113524.76501.87966.stgit@ahduyck-blue-test.jf.intel.com
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Pull locking updates from Ingo Molnar:
"The tree got pretty big in this development cycle, but the net effect
is pretty good:
115 files changed, 673 insertions(+), 1522 deletions(-)
The main changes were:
- Rework and generalize the mutex code to remove per arch mutex
primitives. (Peter Zijlstra)
- Add vCPU preemption support: add an interface to query the
preemption status of vCPUs and use it in locking primitives - this
optimizes paravirt performance. (Pan Xinhui, Juergen Gross,
Christian Borntraeger)
- Introduce cpu_relax_yield() and remov cpu_relax_lowlatency() to
clean up and improve the s390 lock yielding machinery and its core
kernel impact. (Christian Borntraeger)
- Micro-optimize mutexes some more. (Waiman Long)
- Reluctantly add the to-be-deprecated mutex_trylock_recursive()
interface on a temporary basis, to give the DRM code more time to
get rid of its locking hacks. Any other users will be NAK-ed on
sight. (We turned off the deprecation warning for the time being to
not pollute the build log.) (Peter Zijlstra)
- Improve the rtmutex code a bit, in light of recent long lived
bugs/races. (Thomas Gleixner)
- Misc fixes, cleanups"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (36 commits)
x86/paravirt: Fix bool return type for PVOP_CALL()
x86/paravirt: Fix native_patch()
locking/ww_mutex: Use relaxed atomics
locking/rtmutex: Explain locking rules for rt_mutex_proxy_unlock()/init_proxy_locked()
locking/rtmutex: Get rid of RT_MUTEX_OWNER_MASKALL
x86/paravirt: Optimize native pv_lock_ops.vcpu_is_preempted()
locking/mutex: Break out of expensive busy-loop on {mutex,rwsem}_spin_on_owner() when owner vCPU is preempted
locking/osq: Break out of spin-wait busy waiting loop for a preempted vCPU in osq_lock()
Documentation/virtual/kvm: Support the vCPU preemption check
x86/xen: Support the vCPU preemption check
x86/kvm: Support the vCPU preemption check
kvm: Introduce kvm_write_guest_offset_cached()
locking/core, x86/paravirt: Implement vcpu_is_preempted(cpu) for KVM and Xen guests
locking/spinlocks, s390: Implement vcpu_is_preempted(cpu)
locking/core, powerpc: Implement vcpu_is_preempted(cpu)
sched/core: Introduce the vcpu_is_preempted(cpu) interface
sched/wake_q: Rename WAKE_Q to DEFINE_WAKE_Q
locking/core: Provide common cpu_relax_yield() definition
locking/mutex: Don't mark mutex_trylock_recursive() as deprecated, temporarily
During page fault handling we check the last instruction to understand
if the fault was for a read or for a write. By default we fall back to
read. New instructions were added to the openrisc 1.1 spec for an
atomic load/store pair (l.lwa/l.swa).
This patch adds the opcode for l.swa (0x33) allowing it to be treated as
a write operation.
[shorne@gmail.com: expanded a bit on the comment]
The openrisc.net domain expired and was taken over by squatters.
These updates point documentation to the new domain, mailing lists
and git repos.
Also, Jonas is not the main maintainer anylonger, he reviews changes
but does not maintain a repo or sent pull requests. Updating this to
add Stafford and Stefan who are the active maintainers.
Acked-by: Olof Kindgren <olof.kindgren@gmail.com>
Clearing out one todo item. Use the memblock boot time memory
which is the current standard.
Tested-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Jonas <jonas@southpole.se>
The of_platform_populate call in the openrisc arch code is now redundant
as the DT core provides a default call. Openrisc has a NULL match table
which means only top level nodes with compatible strings will have
devices creates. The default version will also descend nodes in the
match table such as "simple-bus" which should be fine as openrisc
doesn't have any of these (though it is preferred that memory-mapped
peripherals be grouped under a bus node(s)).
Signed-off-by: Rob Herring <robh@kernel.org>
The build system now expects that NR_CPUS is defined.
Follow 4cbbbb4 ("microblaze: Fix missing NR_CPUS in menuconfig")
The output file format for or1k has changed from "elf32-or32"
to "elf32-or1k". Select the correct output format automatically
to be able to compile the kernel with both toolchain variants.
Historically OpenRISC GCC has reserved r10 which we now use to hold
the thread pointer for thread-local storage (TLS).
Signed-off-by: Christian Svensson <blue@cmd.nu>
Fix signal handling for when signals are handled as the result of timers
or exceptions, previous code assumed syscalls. This was noticeable with X
crashing where it uses SIGALRM.
This patch restores all regs before returning to userspace via
_resume_userspace instead of via syscall return path.
The rt_sigreturn syscall is more like a context switch than a function
call; it entails a return from one context (the signal handler) to another
(the process in question). For a context switch like this there are
effectively no call-saved regs that remain constant across the transition.
Reported-by: Sebastian Macke <sebastian@macke.de>
[shorne@gmail.com: Updated comment better reflect change and issue]
On OpenRISC, with its 8k pages, PAGE_SHIFT is defined to be 13.
That makes the expression (1UL << (PAGE_SHIFT-2)) evaluate
to 2048.
The correct value for PTRS_PER_PGD should be 256.
Correcting the PTRS_PER_PGD define unveiled a bug in map_ram(),
where PTRS_PER_PGD was used when the intent was to iterate
over a set of page table entries.
This patch corrects that issue as well.
No need to duplicate the same define everywhere. Since
the only user is stop-machine and the only provider is
s390, we can use a default implementation of cpu_relax_yield()
in sched.h.
Suggested-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Noam Camus <noamc@ezchip.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: kvm@vger.kernel.org
Cc: linux-s390 <linux-s390@vger.kernel.org>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Cc: virtualization@lists.linux-foundation.org
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/1479298985-191589-1-git-send-email-borntraeger@de.ibm.com
As there are no users left, we can remove cpu_relax_lowlatency()
implementations from every architecture.
Cc: <linux-arch@vger.kernel.org>
Link: http://lkml.kernel.org/r/1477386195-32736-6-git-send-email-borntraeger@de.ibm.com
For spinning loops people do often use barrier() or cpu_relax().
For most architectures cpu_relax and barrier are the same, but on
some architectures cpu_relax can add some latency.
For example on power,sparc64 and arc, cpu_relax can shift the CPU
towards other hardware threads in an SMT environment.
On s390 cpu_relax does even more, it uses an hypercall to the
hypervisor to give up the timeslice.
In contrast to the SMT yielding this can result in larger latencies.
In some places this latency is unwanted, so another variant
"cpu_relax_lowlatency" was introduced. Before this is used in more
and more places, lets revert the logic and provide a cpu_relax_yield
that can be called in places where yielding is more important than
latency. By default this is the same as cpu_relax on all architectures.
Link: http://lkml.kernel.org/r/1477386195-32736-2-git-send-email-borntraeger@de.ibm.com
openrisc qemu tests fail with the following crash.
Unable to handle kernel access at virtual address 0xc0300c34
Oops#: 0001
CPU #: 0
PC: c016c710 SR: 0000ae67 SP: c1017e04
GPR00: 00000000 GPR01: c1017e04 GPR02: c0300c34 GPR03: c0300c34
GPR04: 00000000 GPR05: c0300cb0 GPR06: c0300c34 GPR07: 000000ff
GPR08: c107f074 GPR09: c0199ef4 GPR10: c1016000 GPR11: 00000000
GPR12: 00000000 GPR13: c107f044 GPR14: c0473774 GPR15: 07ce0000
GPR16: 00000000 GPR17: c107ed8a GPR18: 00009600 GPR19: c107f044
GPR20: c107ee74 GPR21: 00000003 GPR22: c0473770 GPR23: 00000033
GPR24: 000000bf GPR25: 00000019 GPR26: c046400c GPR27: 00000001
GPR28: c0464028 GPR29: c1018000 GPR30: 00000006 GPR31: ccf37483
RES: 00000000 oGPR11: ffffffff
Process swapper (pid: 1, stackpage=c1001960)
Stack: Stack dump [0xc1017cf8]:
sp + 00: 0xc1017e04
sp + 04: 0xc0300c34
sp + 08: 0xc0300c34
sp + 12: 0x00000000
Bisect points to commit d2ec3f77de8e ("pty: make ptmx file ops read-only
after init"). Fix by defining __ro_after_init for the openrisc
architecture, similar to parisc.
Fixes: d2ec3f77de8e ("pty: make ptmx file ops read-only after init")
Acked-by: Stafford Horne <shorne@gmail.com>
Its all generic atomic_long_t stuff now.
Tested-by: Jason Low <jason.low2@hpe.com>
Pull uaccess.h prepwork from Al Viro:
"Preparations to tree-wide switch to use of linux/uaccess.h (which,
obviously, will allow to start unifying stuff for real). The last step
there, ie
`git grep -l "$PATT"|grep -v ^include/linux/uaccess.h`
is not taken here - I would prefer to do it once just before or just
after -rc1. However, everything should be ready for it"
* 'work.uaccess2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
remove a stray reference to asm/uaccess.h in docs
sparc64: separate extable_64.h, switch elf_64.h to it
score: separate extable.h, switch module.h to it
mips: separate extable.h, switch module.h to it
x86: separate extable.h, switch sections.h to it
remove stray include of asm/uaccess.h from cacheflush.h
mn10300: remove a bogus processor.h->uaccess.h include
xtensa: split uaccess.h into C and asm sides
bonding: quit messing with IOCTL
kill __kernel_ds_p off
mn10300: finish verify_area() off
frv: move HAVE_ARCH_UNMAPPED_AREA to pgtable.h
exceptions: detritus removal
When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
externs and defines for stuff that is never used
