path: root/arch/openrisc
2015-08-03openrisc: fix CONFIG_UID16 settingAndrew Morton
commit 04ea1e91f85615318ea91ce8ab50cb6a01ee4005 upstream. openrisc-allnoconfig: kernel/uid16.c: In function 'SYSC_setgroups16': kernel/uid16.c:184:2: error: implicit declaration of function 'groups_alloc' kernel/uid16.c:184:13: warning: assignment makes pointer from integer without a cast openrisc shouldn't be setting CONFIG_UID16 when CONFIG_MULTIUSER=n. Fixes: 2813893f8b197a1 ("kernel: conditionally support non-root users, groups and capabilities") Reported-by: Fengguang Wu <fengguang.wu@gmail.com> Cc: Iulia Manda <iulia.manda21@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-15Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - the rest of MM - various misc bits - add ability to run /sbin/reboot at reboot time - printk/vsprintf changes - fiddle with seq_printf() return value * akpm: (114 commits) parisc: remove use of seq_printf return value lru_cache: remove use of seq_printf return value tracing: remove use of seq_printf return value cgroup: remove use of seq_printf return value proc: remove use of seq_printf return value s390: remove use of seq_printf return value cris fasttimer: remove use of seq_printf return value cris: remove use of seq_printf return value openrisc: remove use of seq_printf return value ARM: plat-pxa: remove use of seq_printf return value nios2: cpuinfo: remove use of seq_printf return value microblaze: mb: remove use of seq_printf return value ipc: remove use of seq_printf return value rtc: remove use of seq_printf return value power: wakeup: remove use of seq_printf return value x86: mtrr: if: remove use of seq_printf return value linux/bitmap.h: improve BITMAP_{LAST,FIRST}_WORD_MASK MAINTAINERS: CREDITS: remove Stefano Brivio from B43 .mailmap: add Ricardo Ribalda CREDITS: add Ricardo Ribalda Delgado ...
2015-04-15openrisc: remove use of seq_printf return valueJoe Perches
The seq_printf return value, because it's frequently misused, will eventually be converted to void. See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to seq_has_overflowed() and make public") Signed-off-by: Joe Perches <joe@perches.com> Cc: Jonas Bonn <jonas@southpole.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15Merge branch 'exec_domain_rip_v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc Pull exec domain removal from Richard Weinberger: "This series removes execution domain support from Linux. The idea behind exec domains was to support different ABIs. The feature was never complete nor stable. Let's rip it out and make the kernel signal handling code less complicated" * 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits) arm64: Removed unused variable sparc: Fix execution domain removal Remove rest of exec domains. arch: Remove exec_domain from remaining archs arc: Remove signal translation and exec_domain xtensa: Remove signal translation and exec_domain xtensa: Autogenerate offsets in struct thread_info x86: Remove signal translation and exec_domain unicore32: Remove signal translation and exec_domain um: Remove signal translation and exec_domain tile: Remove signal translation and exec_domain sparc: Remove signal translation and exec_domain sh: Remove signal translation and exec_domain s390: Remove signal translation and exec_domain mn10300: Remove signal translation and exec_domain microblaze: Remove signal translation and exec_domain m68k: Remove signal translation and exec_domain m32r: Remove signal translation and exec_domain m32r: Autogenerate offsets in struct thread_info frv: Remove signal translation and exec_domain ...
2015-04-12arch: Remove exec_domain from remaining archsRichard Weinberger
Signed-off-by: Richard Weinberger <richard@nod.at>
2015-04-11whack-a-mole: no need to set_fs(USER_DS) in {start,flush}_thread()Al Viro
flush_old_exec() has already done that. Back on 2011 a bunch of instances like that had been kicked out, but that hadn't taken care of then-out-of-tree architectures, obviously, and they served as reinfection vector... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-18Merge tag 'asm-generic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic uaccess.h cleanup from Arnd Bergmann: "Like in 3.19, I once more have a multi-stage cleanup for one asm-generic header file, this time the work was done by Michael Tsirkin and cleans up the uaccess.h file in asm-generic, as well as all architectures for which the respective maintainers did not pick up his patches directly" * tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (37 commits) sparc32: nocheck uaccess coding style tweaks sparc64: nocheck uaccess coding style tweaks xtensa: macro whitespace fixes sh: macro whitespace fixes parisc: macro whitespace fixes m68k: macro whitespace fixes m32r: macro whitespace fixes frv: macro whitespace fixes cris: macro whitespace fixes avr32: macro whitespace fixes arm64: macro whitespace fixes arm: macro whitespace fixes alpha: macro whitespace fixes blackfin: macro whitespace fixes sparc64: uaccess_64 macro whitespace fixes sparc32: uaccess_32 macro whitespace fixes avr32: whitespace fix sh: fix put_user sparse errors metag: fix put_user sparse errors ia64: fix put_user sparse errors ...
2015-02-12all arches, signal: move restart_block to struct task_structAndy Lutomirski
If an attacker can cause a controlled kernel stack overflow, overwriting the restart block is a very juicy exploit target. This is because the restart_block is held in the same memory allocation as the kernel stack. Moving the restart block to struct task_struct prevents this exploit by making the restart_block harder to locate. Note that there are other fields in thread_info that are also easy targets, at least on some architectures. It's also a decent simplification, since the restart code is more or less identical on all architectures. [james.hogan@imgtec.com: metag: align thread_info::supervisor_stack] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Steven Miao <realmz6@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: make FIRST_USER_ADDRESS unsigned long on all archsKirill A. Shutemov
LKP has triggered a compiler warning after my recent patch "mm: account pmd page tables to the process": mm/mmap.c: In function 'exit_mmap': >> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default] The code: > 2857 WARN_ON(mm_nr_pmds(mm) > 2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT); In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has the same type -- int. PUD_SHIFT. I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned long. On every arch for consistency. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10openrisc: drop _PAGE_FILE and pte_file()-related helpersKirill A. Shutemov
We've replaced remap_file_pages(2) implementation with emulation. Nobody creates non-linear mapping anymore. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jonas Bonn <jonas@southpole.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-29vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-13openrisc/uaccess: fix sparse errorsMichael S. Tsirkin
virtio wants to read bitwise types from userspace using get_user. At the moment this triggers sparse errors, since the value is passed through an integer. Fix that up using __force. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2014-12-10net, lib: kill arch_fast_hash library bitsDaniel Borkmann
As there are now no remaining users of arch_fast_hash(), lets kill it entirely. This basically reverts commit 71ae8aac3e19 ("lib: introduce arch optimized hash library") and follow-up work, that is f.e., commit 237217546d44 ("lib: hash: follow-up fixups for arch hash"), commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for asm-generic/hash.h") and last but not least commit 6a02652df511 ("perf tools: Fix include for non x86 architectures"). Cc: Francesco Fusco <fusco@ntop.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-19Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris: "So this change across a whole bunch of arches really solves one basic problem. We want to audit when seccomp is killing a process. seccomp hooks in before the audit syscall entry code. audit_syscall_entry took as an argument the arch of the given syscall. Since the arch is part of what makes a syscall number meaningful it's an important part of the record, but it isn't available when seccomp shoots the syscall... For most arch's we have a better way to get the arch (syscall_get_arch) So the solution was two fold: Implement syscall_get_arch() everywhere there is audit which didn't have it. Use syscall_get_arch() in the seccomp audit code. Having syscall_get_arch() everywhere meant it was a useless flag on the stack and we could get rid of it for the typical syscall entry. The other changes inside the audit system aren't grand, fixed some records that had invalid spaces. Better locking around the task comm field. Removing some dead functions and structs. Make some things static. Really minor stuff" * git://git.infradead.org/users/eparis/audit: (31 commits) audit: rename audit_log_remove_rule to disambiguate for trees audit: cull redundancy in audit_rule_change audit: WARN if audit_rule_change called illegally audit: put rule existence check in canonical order next: openrisc: Fix build audit: get comm using lock to avoid race in string printing audit: remove open_arg() function that is never used audit: correct AUDIT_GET_FEATURE return message type audit: set nlmsg_len for multicast messages. audit: use union for audit_field values since they are mutually exclusive audit: invalid op= values for rules audit: use atomic_t to simplify audit_serial() kernel/audit.c: use ARRAY_SIZE instead of sizeof/sizeof[0] audit: reduce scope of audit_log_fcaps audit: reduce scope of audit_net_id audit: arm64: Remove the audit arch argument to audit_syscall_entry arm64: audit: Add audit hook in syscall_trace_enter/exit() audit: x86: drop arch from __audit_syscall_entry() interface sparc: implement is_32bit_task sparc: properly conditionalize use of TIF_32BIT ...
2014-10-09Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "The irq departement delivers: - a cleanup series to get rid of mindlessly copied code. - another bunch of new pointlessly different interrupt chip drivers. Adding homebrewn irq chips (and timers) to SoCs must provide a value add which is beyond the imagination of mere mortals. - the usual SoC irq controller updates, IOW my second cat herding project" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) irqchip: gic-v3: Implement CPU PM notifier irqchip: gic-v3: Refactor gic_enable_redist to support both enabling and disabling irqchip: renesas-intc-irqpin: Add minimal runtime PM support irqchip: renesas-intc-irqpin: Add helper variable dev = &pdev->dev irqchip: atmel-aic5: Add sama5d4 support irqchip: atmel-aic5: The sama5d3 has 48 IRQs Documentation: bcm7120-l2: Add Broadcom BCM7120-style L2 binding irqchip: bcm7120-l2: Add Broadcom BCM7120-style Level 2 interrupt controller irqchip: renesas-irqc: Add binding docs for new R-Car Gen2 SoCs irqchip: renesas-irqc: Add DT binding documentation irqchip: renesas-intc-irqpin: Document SoC-specific bindings openrisc: Get rid of handle_IRQ arm64: Get rid of handle_IRQ ARM: omap2: irq: Convert to handle_domain_irq ARM: imx: tzic: Convert to handle_domain_irq ARM: imx: avic: Convert to handle_domain_irq irqchip: or1k-pic: Convert to handle_domain_irq irqchip: atmel-aic5: Convert to handle_domain_irq irqchip: atmel-aic: Convert to handle_domain_irq irqchip: gic-v3: Convert to handle_domain_irq ...
2014-09-26next: openrisc: Fix buildGuenter Roeck
openrisc:defconfig fails to build in next-20140926 with the following error. In file included from arch/openrisc/kernel/signal.c:31:0: ./arch/openrisc/include/asm/syscall.h: In function 'syscall_get_arch': ./arch/openrisc/include/asm/syscall.h:77:9: error: 'EM_OPENRISC' undeclared Fix by moving EM_OPENRISC to include/uapi/linux/elf-em.h. Fixes: ce5d112827e5 ("ARCH: AUDIT: implement syscall_get_arch for all arches") Cc: Eric Paris <eparis@redhat.com> Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-09-23ARCH: AUDIT: audit_syscall_entry() should not require the archEric Paris
We have a function where the arch can be queried, syscall_get_arch(). So rather than have every single piece of arch specific code use and/or duplicate syscall_get_arch(), just have the audit code use the syscall_get_arch() code. Based-on-patch-by: Richard Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-ia64@vger.kernel.org Cc: microblaze-uclinux@itee.uq.edu.au Cc: linux-mips@linux-mips.org Cc: linux@lists.openrisc.net Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: user-mode-linux-devel@lists.sourceforge.net Cc: linux-xtensa@linux-xtensa.org Cc: x86@kernel.org
2014-09-23ARCH: AUDIT: implement syscall_get_arch for all archesEric Paris
For all arches which support audit implement syscall_get_arch() They are all pretty easy and straight forward, stolen from how the call to audit_syscall_entry() determines the arch. Based-on-patch-by: Richard Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Cc: linux-ia64@vger.kernel.org Cc: microblaze-uclinux@itee.uq.edu.au Cc: linux-mips@linux-mips.org Cc: linux@lists.openrisc.net Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: sparclinux@vger.kernel.org
2014-09-13irq_work: Introduce arch_irq_work_has_interrupt()Peter Zijlstra
The nohz full code needs irq work to trigger its own interrupt so that the subsystem can work even when the tick is stopped. Lets introduce arch_irq_work_has_interrupt() that archs can override to tell about their support for this ability. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2014-09-03openrisc: Get rid of handle_IRQMarc Zyngier
The openrisc irqchip driver has been converted to handle_domain_irq, making it possible to remove the handle_IRQ stub entierely. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Link: https://lkml.kernel.org/r/1409047421-27649-27-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-09-03openrisc: Convert handle_IRQ to use __handle_domain_irqMarc Zyngier
In order to limit code duplication, convert the architecture specific handle_IRQ to use the generic __handle_domain_irq function. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Link: https://lkml.kernel.org/r/1409047421-27649-5-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-08-09Merge branch 'signal-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc Pull arch signal handling cleanup from Richard Weinberger: "This patch series moves all remaining archs to the get_signal(), signal_setup_done() and sigsp() functions. Currently these archs use open coded variants of the said functions. Further, unused parameters get removed from get_signal_to_deliver(), tracehook_signal_handler() and signal_delivered(). At the end of the day we save around 500 lines of code." * 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits) powerpc: Use sigsp() openrisc: Use sigsp() mn10300: Use sigsp() mips: Use sigsp() microblaze: Use sigsp() metag: Use sigsp() m68k: Use sigsp() m32r: Use sigsp() hexagon: Use sigsp() frv: Use sigsp() cris: Use sigsp() c6x: Use sigsp() blackfin: Use sigsp() avr32: Use sigsp() arm64: Use sigsp() arc: Use sigsp() sas_ss_flags: Remove nested ternary if Rip out get_signal_to_deliver() Clean up signal_delivered() tracehook_signal_handler: Remove sig, info, ka and regs ...
2014-08-06openrisc: Use sigsp()Richard Weinberger
Use sigsp() instead of the open coded variant. Signed-off-by: Richard Weinberger <richard@nod.at>
2014-08-05Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "Nothing spectacular from the irq department this time: - overhaul of the crossbar chip driver - overhaul of the spear shirq chip driver - support for the atmel-aic chip - code move from arch to drivers - the usual tiny fixlets - two reverts worth to mention which undo the too simple attempt of supporting wakeup interrupts on shared interrupt lines" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits) Revert "irq: Warn when shared interrupts do not match on NO_SUSPEND" Revert "PM / sleep / irq: Do not suspend wakeup interrupts" irq: Warn when shared interrupts do not match on NO_SUSPEND irqchip: atmel-aic: Define irq fixups for atmel SoCs irqchip: atmel-aic: Implement RTC irq fixup irqchip: atmel-aic: Add irq fixup infrastructure irqchip: atmel-aic: Add atmel AIC/AIC5 drivers irqchip: atmel-aic: Move binding doc to interrupt-controller directory genirq: generic chip: Export irq_map_generic_chip function PM / sleep / irq: Do not suspend wakeup interrupts irqchip: or1k-pic: Migrate from arch/openrisc/ irqchip: crossbar: Allow for quirky hardware with direct hardwiring of GIC documentation: dt: omap: crossbar: Add description for interrupt consumer irqchip: crossbar: Introduce centralized check for crossbar write irqchip: crossbar: Introduce ti, max-crossbar-sources to identify valid crossbar mapping irqchip: crossbar: Add kerneldoc for crossbar_domain_unmap callback irqchip: crossbar: Set cb pointer to null in case of error irqchip: crossbar: Change the goto naming irqchip: crossbar: Return proper error value irqchip: crossbar: Fix kerneldoc warning ...
2014-07-17arch, locking: Ciao arch_mutex_cpu_relax()Davidlohr Bueso
The arch_mutex_cpu_relax() function, introduced by 34b133f, is hacky and ugly. It was added a few years ago to address the fact that common cpu_relax() calls include yielding on s390, and thus impact the optimistic spinning functionality of mutexes. Nowadays we use this function well beyond mutexes: rwsem, qrwlock, mcs and lockref. Since the macro that defines the call is in the mutex header, any users must include mutex.h and the naming is misleading as well. This patch (i) renames the call to cpu_relax_lowlatency ("relax, but only if you can do it with very low latency") and (ii) defines it in each arch's asm/processor.h local header, just like for regular cpu_relax functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax, and thus we can take it out of mutex.h. While this can seem redundant, I believe it is a good choice as it allows us to move out arch specific logic from generic locking primitives and enables future(?) archs to transparently define it, similarly to System Z. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Blanchard <anton@samba.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Bharat Bhushan <r65777@freescale.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> Cc: Dominik Dingel <dingel@linux.vnet.ibm.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jason Wang <jasowang@redhat.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Joe Perches <joe@perches.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Joseph Myers <joseph@codesourcery.com> Cc: Kees Cook <keescook@chromium.org> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Neuling <mikey@neuling.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Nicolas Pitre <nico@linaro.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Qais Yousef <qais.yousef@imgtec.com> Cc: Qiaowei Ren <qiaowei.ren@intel.com> Cc: Rafael Wysocki <rafael.j.wysocki@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Stratos Karafotis <stratosk@semaphore.gr> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Vasily Kulikov <segoon@openwall.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Wolfram Sang <wsa@the-dreams.de> Cc: adi-buildroot-devel@lists.sourceforge.net Cc: linux390@de.ibm.com Cc: linux-alpha@vger.kernel.org Cc: linux-am33-list@redhat.com Cc: linux-arm-kernel@lists.infradead.org Cc: linux-c6x-dev@linux-c6x.org Cc: linux-cris-kernel@axis.com Cc: linux-hexagon@vger.kernel.org Cc: linux-ia64@vger.kernel.org Cc: linux@lists.openrisc.net Cc: linux-m32r-ja@ml.linux-m32r.org Cc: linux-m32r@ml.linux-m32r.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-metag@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-xtensa@linux-xtensa.org Cc: sparclinux@vger.kernel.org Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-01irqchip: or1k-pic: Migrate from arch/openrisc/Stefan Kristiansson
In addition to consolidating the or1k-pic with other interrupt controllers, this makes OpenRISC less tied to its on-cpu interrupt controller. All or1k-pic specific parts are moved out of irq.c and into drivers/irqchip/irq-or1k-pic.c In that transition, the functionality have been divided into three chip variants. One that handles level triggered interrupts, one that handles edge triggered interrupts and one that handles the interrupt controller that is present in the or1200 OpenRISC cpu implementation. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Link: https://lkml.kernel.org/r/1401136302-27654-1-git-send-email-stefan.kristiansson@saunalahti.fi Acked-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-04Merge tag 'devicetree-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux into next Pull DeviceTree updates from Rob Herring: - Another round of clean-up of FDT related code in architecture code. This removes knowledge of internal FDT details from most architectures except powerpc. - Conversion of kernel's custom FDT parsing code to use libfdt. - DT based initialization for generic serial earlycon. The introduction of generic serial earlycon support went in through the tty tree. - Improve the platform device naming for DT probed devices to ensure unique naming and use parent names instead of a global index. - Fix a race condition in of_update_property. - Unify the various linker section OF match tables and fix several function prototype errors. - Update platform_get_irq_byname to work in deferred probe cases. - 2 binding doc updates * tag 'devicetree-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (58 commits) of: handle NULL node in next_child iterators of/irq: provide more wrappers for !CONFIG_OF devicetree: bindings: Document micrel vendor prefix dt: bindings: dwc2: fix required value for the phy-names property of_pci_irq: kill useless variable in of_irq_parse_pci() of/irq: do irq resolution in platform_get_irq_byname() of: Add a testcase for of_find_node_by_path() of: Make of_find_node_by_path() handle /aliases of: Create unlocked version of for_each_child_of_node() lib: add glibc style strchrnul() variant of: Handle memory@0 node on PPC32 only pci/of: Remove dead code of: fix race between search and remove in of_update_property() of: Use NULL for pointers of: Stop naming platform_device using dcr address of: Ensure unique names without sacrificing determinism tty/serial: pl011: add DT based earlycon support of/fdt: add FDT serial scanning for earlycon of/fdt: add FDT address translation support serial: earlycon: add DT support ...
2014-04-30of/fdt: consolidate built-in dtb section variablesRob Herring
Unify the various architectures __dtb_start and __dtb_end definitions moving them into of_fdt.h. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: James Hogan <james.hogan@imgtec.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: linux-metag@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux@lists.openrisc.net Cc: linux-xtensa@linux-xtensa.org Tested-by: Grant Likely <grant.likely@linaro.org> Tested-by: Stephen Chivers <schivers@csc.com>
2014-04-18arch,openrisc: Convert smp_mb__*()Peter Zijlstra
Openrisc fully relies on asm-generic/barrier.h and therefore its smp_mb() is barrier(). Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-sxgxgqag9tond4kji07d22oh@git.kernel.org Cc: Jonas Bonn <jonas@southpole.se> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Cc: linux@lists.openrisc.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-07Kconfig: rename HAS_IOPORT to HAS_IOPORT_MAPUwe Kleine-König
If the renamed symbol is defined lib/iomap.c implements ioport_map and ioport_unmap and currently (nearly) all platforms define the port accessor functions outb/inb and friend unconditionally. So HAS_IOPORT_MAP is the better name for this. Consequently NO_IOPORT is renamed to NO_IOPORT_MAP. The motivation for this change is to reintroduce a symbol HAS_IOPORT that signals if outb/int et al are available. I will address that at least one merge window later though to keep surprises to a minimum and catch new introductions of (HAS|NO)_IOPORT. The changes in this commit were done using: $ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/' Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-09locking/mcs: Allow architecture specific asm files to be used for contended caseTim Chen
This patch allows each architecture to add its specific assembly optimized arch_mcs_spin_lock_contended and arch_mcs_spinlock_uncontended for MCS lock and unlock functions. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Scott J Norton <scott.norton@hp.com> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: AswinChandramouleeswaran <aswin@hp.com> Cc: George Spelvin <linux@horizon.com> Cc: Rik vanRiel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: MichelLespinasse <walken@google.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alex Shi <alex.shi@linaro.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Figo.zhang" <figo1802@gmail.com> Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Will Deacon <will.deacon@arm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matthew R Wilcox <matthew.r.wilcox@intel.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1390347382.3138.67.camel@schen9-DESK Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-09locking/mcs: Order the header files in Kbuild of each architecture in ↵Tim Chen
alphabetical order We perform a clean up of the Kbuid files in each architecture. We order the files in each Kbuild in alphabetical order by running the below script. for i in arch/*/include/asm/Kbuild do cat $i | gawk '/^generic-y/ { i = 3; do { for (; i <= NF; i++) { if ($i == "\\") { getline; i = 1; continue; } if ($i != "") hdr[$i] = $i; } break; } while (1); next; } // { print $0; } END { n = asort(hdr); for (i = 1; i <= n; i++) print "generic-y += " hdr[i]; }' > ${i}.sorted; mv ${i}.sorted $i; done Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Matthew R Wilcox <matthew.r.wilcox@intel.com> Cc: AswinChandramouleeswaran <aswin@hp.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com> Cc: Scott J Norton <scott.norton@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: "Figo.zhang" <figo1802@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rik van Riel <riel@redhat.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Alex Shi <alex.shi@linaro.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: George Spelvin <linux@horizon.com> Cc: MichelLespinasse <walken@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> [ Fixed build bug. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-30Merge tag 'for-3.14' of git://openrisc.net/~jonas/linuxLinus Torvalds
Pull OpenRISC updates from Jonas Bonn: "The interesting change here is a rework of the OpenRISC signal handling to make it more like other architectures in the hopes that this makes it easier for others to comment on and understand. This rework fixes some real bugs, like the fact that syscall restart did not work reliably" * tag 'for-3.14' of git://openrisc.net/~jonas/linux: openrisc: Use get_signal() signal_setup_done() openrisc: Rework signal handling
2014-01-09openrisc: Use get_signal() signal_setup_done()Richard Weinberger
Use the more generic functions get_signal() signal_setup_done() for signal delivery. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2014-01-09openrisc: Rework signal handlingJonas Bonn
The mainline signal handling code for OpenRISC has been buggy since day one with respect to syscall restart. This patch significantly reworks the signal handling code: i) Move the "work pending" loop to C code (borrowed from ARM arch) ii) Allow a tracer to muck about with the IP and skip syscall restart in that case (again, borrowed from ARM) iii) Make signal handling WRT syscall restart actually work v) Make the signal handling code look more like that of other architectures so that it's easier for others to follow Reported-by: Anders Nystrom <anders@southpole.se> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-12-17lib: Add missing arch generic-y entries for asm-generic/hash.hDavid S. Miller
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-15Merge tag 'for-3.13' of git://git.openrisc.net/~jonas/linuxLinus Torvalds
Pull OpenRISC updates from Jonas Bonn: - small cleanups to make allmodconfig pass - defconfig refresh - a handful of code sanitization patches * tag 'for-3.13' of git://git.openrisc.net/~jonas/linux: openrisc: Refactor or32_early_setup() openrisc: Remove unused declaration of __initramfs_start openrisc: Use the declarations provided by <asm/sections.h> openrisc: Refresh or1ksim_defconfig for v3.12 openrisc: Refactor 16-bit constant relocation openrisc: include: asm: Kbuild: add default "vga.h" openrisc: Makefile: append "-D__linux__" to KBUILD_CFLAGS
2013-11-15openrisc: Refactor or32_early_setup()Geert Uytterhoeven
- Change fdt pointer (passed from head.S) from unsigned int to void *, which allows to kill a cast, and makes it compatible with __dtb_start. - Use pr_info(), - Extract common part. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux@lists.openrisc.net Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-15openrisc: Remove unused declaration of __initramfs_startGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-15openrisc: Use the declarations provided by <asm/sections.h>Geert Uytterhoeven
Openrisc's private vmlinux.h duplicates a few definitions that are already provided by asm-generic/sections.h. The former is used by setup.c only, while the latter is already used everywhere else. Convert setup.c to use the generic version: - Include <asm/sections.h>, - Remove the (slightly different) extern declarations, - Remove the no longer needed address-of ('&') operators. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-15openrisc: Refresh or1ksim_defconfig for v3.12Geert Uytterhoeven
2013-11-15openrisc: add missing pgtable_page_ctor/dtor callsKirill A. Shutemov
It will fix NR_PAGETABLE accounting. It's also required if the arch is going ever support split ptl. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jonas Bonn <jonas@southpole.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-11-05openrisc: Refactor 16-bit constant relocationGeert Uytterhoeven
arch/openrisc/kernel/module.c: In function 'apply_relocate_add': arch/openrisc/kernel/module.c:50:13: warning: assignment from incompatible pointer type arch/openrisc/kernel/module.c:54:13: warning: assignment from incompatible pointer type Move the pointer increments to the dereference statements to avoid incompatible pointer assignments, and remove superfluous casts. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-05openrisc: include: asm: Kbuild: add default "vga.h"Chen Gang
Add default "vga.h", or compiling fails with 'allmodconfig'. The related error: CC [M] drivers/gpu/drm/drm_irq.o In file included from include/linux/vgaarb.h:34:0, from drivers/gpu/drm/drm_irq.c:42: include/video/vga.h:22:21: fatal error: asm/vga.h: No such file or directory compilation terminated. make[3]: *** [drivers/gpu/drm/drm_irq.o] Error 1 make[2]: *** [drivers/gpu/drm] Error 2 make[1]: *** [drivers/gpu] Error 2 make: *** [drivers] Error 2 Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-11-05openrisc: Makefile: append "-D__linux__" to KBUILD_CFLAGSChen Gang
Need append "_D__linux__" to KBUILD_CFLAGS, just like some of another architectures have done, or 'allmodconfig' can not pass compiling. The related error: CC [M] fs/coda/psdev.o In file included from include/linux/coda.h:65:0, from fs/coda/psdev.c:45: include/uapi/linux/coda.h:221:2: error: expected specifier-qualifier-list before 'u_quad_t' The related compiler information: [root@dhcp122 ~]# /usr/local/bin/or32-linux-gcc -v Using built-in specs. COLLECT_GCC=/usr/local/bin/or32-linux-gcc COLLECT_LTO_WRAPPER=/usr/local/libexec/gcc/or32-linux/4.5.1-or32-1.0rc1/lto-wrapper Target: or32-linux Configured with: ../gcc-openrisc/configure --target=or32-linux --disable-nls --enable-languages=c --without-headers --disable-shared --disable-threads --enable-werror=no Thread model: single gcc version 4.5.1-or32-1.0rc1 (GCC) Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2013-10-09of: remove empty arch prom.h headersRob Herring
Now that prom.h is optional, all the empty prom.h headers can be removed. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com>
2013-10-09of: remove HAVE_ARCH_DEVTREE_FIXUPSRob Herring
HAVE_ARCH_DEVTREE_FIXUPS appears to always be needed except for sparc, but it is only used for /proc/device-teee and sparc does not enable /proc/device-tree. So this option is redundant. Remove the option and always enable it. This has the side effect of fixing /proc/device-tree on arches such as arm64 which failed to define this option. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com>
2013-10-09openrisc: remove unnecessary prom.c includesRob Herring
It appears openrisc prom.c was just copied from another arch with a bunch of unnecessary includes. Remove all the unecessary ones. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net
2013-10-09of: remove early_init_dt_setup_initrd_archRob Herring
All arches do essentially the same thing now for early_init_dt_setup_initrd_arch, so it can now be removed. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Grant Likely <grant.likely@linaro.org>
