path: root/arch/parisc/hpux/gate.S
2015-02-16parisc: hpux - Delete files in hpux subdirectoryHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de>
2012-10-01parisc: fix double restartsAl Viro
Don't bother restoring r28 on syscall restarts; it's clobbered by syscall anyway. Reuse (now unused) ->orig_r28 as "no restarts allowed" flag. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-06-13Revert "parisc: fix trivial section name warnings"Kyle McMartin
This reverts commit bd3bb8c15b9a80dbddfb7905b237a4a11a4725b4. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: fix trivial section name warningsHelge Deller
This trivial patch fixes the following section warnings on PARISC: > WARNING: vmlinux.o (.text.1): unexpected section name. >The (.[number]+) following section name are ld generated and not expected. > Did you forget to use "ax"/"aw" in a .S file? > Note that for example <linux/init.h> contains > section definitions for use in .S files. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Remove hardcoded uses of PAGE_SIZEKyle McMartin
2007-02-17[PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation codeHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
