commit 88776c0e70be0290f8357019d844aae15edaa967 upstream.
Qemu for PARISC reported on a 32bit SMP parisc kernel strange failures
about "Not-handled unaligned insn 0x0e8011d6 and 0x0c2011c9."
Those opcodes evaluate to the ldcw() assembly instruction which requires
(on 32bit) an alignment of 16 bytes to ensure atomicity.
As it turns out, qemu is correct and in our assembly code in entry.S and
pacache.S we don't pay attention to the required alignment.
This patch fixes the problem by aligning the lock offset in assembly
code in the same manner as we do in our C-code.
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
The __ldcw macro has a problem when its argument needs to be reloaded from
memory. The output memory operand and the input register operand both need to
be reloaded using a register in class R1_REGS when generating 64-bit code.
This fails because there's only a single register in the class. Instead, use a
memory clobber. This also makes the __ldcw macro a compiler memory barrier.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: <stable@vger.kernel.org> [3.13+]
Disintegrate asm/system.h for PA-RISC.
cc: linux-parisc@vger.kernel.org
