path: root/arch/parisc/kernel/hpmc.S
2009-01-05parisc: export length of os_hpmc vectorKyle McMartin
and use this instead of dealing with exporting start/end and toying with function descriptors. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13Revert "parisc: fix trivial section name warnings"Kyle McMartin
This reverts commit bd3bb8c15b9a80dbddfb7905b237a4a11a4725b4. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: fix trivial section name warningsHelge Deller
This trivial patch fixes the following section warnings on PARISC: > WARNING: vmlinux.o (.text.1): unexpected section name. >The (.[number]+) following section name are ld generated and not expected. > Did you forget to use "ax"/"aw" in a .S file? > Note that for example <linux/init.h> contains > section definitions for use in .S files. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Remove hardcoded uses of PAGE_SIZEKyle McMartin
2007-06-04[PARISC] Fix kernel panic in check_ivtKyle McMartin
check_ivt had some seriously broken code wrt function pointers on parisc64. Instead of referencing the hpmc code via a function pointer, export symbols and reference it as a const array. Thanks to jda for pointing out the broken 64-bit func ptr handling. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] more ENTRY(), ENDPROC(), END() conversionsHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
