path: root/arch/parisc/kernel/inventory.c
2008-05-15parisc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-02-17[PARISC] use CONFIG_64BIT instead of __LP64__Helge Deller
- additionally update my copyright timestamps Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Add __read_mostly section for pariscHelge Deller
Flag a whole bunch of things as __read_mostly on parisc. Also flag a few branches as unlikely() and cleanup a bit of code. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Return PDC_OK when alloc_pa_dev fails to enumerate all devicesMatthew Wilcox
Return PDC_OK when device registration fails so that we enumerate all subsequent devices, even when we get two devices with the same hardware path (which should never happen, but does with at least one revision of rp8400 firmware). Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
