path: root/arch/parisc/kernel/pacache.S
2008-06-13Revert "parisc: fix trivial section name warnings"Kyle McMartin
This reverts commit bd3bb8c15b9a80dbddfb7905b237a4a11a4725b4. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: use conditional macro for 64-bit wide opsKyle McMartin
This work enables us to remove -traditional from $AFLAGS on parisc. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: fix trivial section name warningsHelge Deller
This trivial patch fixes the following section warnings on PARISC: > WARNING: vmlinux.o (.text.1): unexpected section name. >The (.[number]+) following section name are ld generated and not expected. > Did you forget to use "ax"/"aw" in a .S file? > Note that for example <linux/init.h> contains > section definitions for use in .S files. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Clean up pointless ASM_PAGE_SIZE_DIV useKyle McMartin
2007-02-17[PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macroHelge Deller
- this macro unifies the code to add exception table entries - additionally use ENTRY()/ENDPROC() at more places Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] more ENTRY(), ENDPROC(), END() conversionsHelge Deller
2006-04-21[PARISC] Further work for multiple page sizesHelge Deller
More work towards supporing multiple page sizes on 64-bit. Convert some assumptions that 64bit uses 3 level page tables into testing PT_NLEVELS. Also some BUG() to BUG_ON() conversions and some cleanups to assembler. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] Add parisc implementation of flush_kernel_dcache_page()James Bottomley
We need to do a little renaming of our original syntax because of the difference in arguments. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Explicitly specify sr4 when flushing kernel spaceMatthew Wilcox
Specify sr4 when flushing kernel space (we could equally well use sr5-7, but must not use sr0). Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Properly specify index field to I/D cache flush opsGrant Grundler
replace use of "0" with "%r0" since PA 1.1 I/D flush ops only take a general register and not an immediate value for the index field. This just forces the code to always be PA 1.1 "clean". From: Joel Soete <soete.joel@tiscali.be> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Fix copy_user_page_asm to NOT access past end of pageGrant Grundler
2.6.12-rc2-pa3 fix copy_user_page_asm to NOT access past end of page. My bad. /o\ Lamont confirmed that instructions following a conditional branch are *alway* executed regardless if the branch is taken or not. Unless they are nullified (which was missing in this case). He also noted: Conditional branches nullify on forward taken branch, and on non-taken backward branch. Note that .+4 is a backwards branch. This makes alot more sense than the giberish in the PA20 arch book. Compiles and boots on both 64-bit (a500) and 32-bit (j6k). Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Replace uses of __LP64__ with CONFIG_64BITGrant Grundler
2.6.12-rc4-pa3 s/__LP64__/CONFIG_64BIT/ and fixup config.h usage Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Make sure use of RFI conforms to PA 2.0 and 1.1 arch docsGrant Grundler
2.6.12-rc4-pa3 : first pass at making sure use of RFI conforms to PA 2.0 arch pages F-4 and F-5, PA 1.1 Arch page 3-19 and 3-20. The discussion revolves around all the rules for clearing PSW Q-bit. The hard part is meeting all the rules for "relied upon translation". .align directive is used to guarantee the critical sequence ends more than 8 instructions (32 bytes) from the end of page. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
