path: root/arch/parisc/kernel/parisc_ksyms.c
2007-12-06Revert "[PARISC] import necessary bits of libgcc.a"Kyle McMartin
This reverts commit efb80e7e097d0888e59fbbe4ded2ac5a256f556d, it turned out to cause sporadic problems with the timer interrupt on 32-bit kernels. Needs more investigation. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] import necessary bits of libgcc.aKyle McMartin
Currently we're hacking libs-y to include libgcc.a, but this has unforeseen consequences since the userspace libgcc is linked with fpregs enabled. We need the kernel to stop using fpregs in an uncontrolled manner to implement lazy fpu state saves. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-02-17[PARISC] use CONFIG_64BIT instead of __LP64__Helge Deller
- additionally update my copyright timestamps Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-11[PATCH] remove bogus arch-specific syscall exportsAl Viro
2006-04-11[PATCH] No arch-specific strpbrk implementationsKyle McMartin
While cleaning up parisc_ksyms.c earlier, I noticed that strpbrk wasn't being exported from lib/string.c. Investigating further, I noticed a changeset that removed its export and added it to _ksyms.c on a few more architectures. The justification was that "other arches do it." I think this is wrong, since no architecture currently defines __HAVE_ARCH_STRPBRK, there's no reason for any of them to be exporting it themselves. Therefore, consolidate the export to lib/string.c. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PARISC] Kill duplicated EXPORT_SYMBOL warningsKyle McMartin
Some symbols are exported both in parisc_ksyms.c, and at their definition site. Nuke the redundant EXPORT_SYMBOL in ksyms to quiet warnings when vmlinux is linked. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] Move ioremap EXPORT_SYMBOL from parisc_ksyms.cKyle McMartin
Move ioremap/iounmap EXPORT_SYMBOL to ioremap.c where they belong. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Move pm_power_off export to process.cKyle McMartin
Move the EXPORT_SYMBOL() of pm_power_off from parisc_ksyms.c to the location of its definition in process.c Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
