Add the parisc version of the "mark rodata section read only" patches.
Based on code from and Signed-off-by Arjan van de Ven
<arjan@infradead.org>, Ingo Molnar <mingo@elte.hu>, Andi Kleen <ak@muc.de>,
Andrew Morton <akpm@osdl.org>, Linus Torvalds <torvalds@osdl.org>.
Signed-off-by: Helge Deller <deller@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Document clobbers and args in entry.S and syscall.S.
entry.S: Add comment to indicate that cr27 may recycle and EDEADLOCK
detection is not 100% correct. Since this is only enabled when using
ENABLE_LWS_DEBUG, the user is warned by the comment.
Signed-off-by: Carlos O'Donell <carlos@parisc-linux.org>
2.6.12-rc4-pa3 s/__LP64__/CONFIG_64BIT/ and fixup config.h usage
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
infrastructure for it.
Let it rip!
