commit 2cc7138f4347df939ce03f313e3d87794bab36f8 upstream.
pci_mmap_page_range() is needed for X11-server support on C8000 with ATI
FireGL card.
Signed-off-by Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Signed-off-by: Helge Deller <deller@gmx.de>
commit 9a66d1869d90f13fbaf83dcce5b1aeec86fbc699 upstream.
The C8000 workstation (64 bit kernel only) has a somewhat different
serial port configuration than other models.
Thomas Bogendoerfer sent a patch to fix this in September 2010, which
was now minimally modified by me.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
commit ea99b1adf22abd62bdcf14b1c9a0a4d3664eefd8 upstream.
'boot_args' is an input args, and 'boot_command_line' has a fix length.
So use strlcpy() instead of strcpy() to avoid memory overflow.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
commit 3f108de96ba449a8df3d7e3c053bf890fee2cb95 upstream.
'path.bc[i]' can be asigned by PCI_SLOT() which can '> 10', so sizeof(6
* "%u:" + "%u" + '\0') may be 21.
Since 'name' length is 20, it may be memory overflow.
And 'path.bc[i]' is 'unsigned char' for printing, we can be sure the
max length of 'name' must be less than 28.
So simplify thinking, we can use 28 instead of 20 directly, and do not
think of whether 'patchc.bc[i]' can '> 100'.
commit d96b51ec14650b490ab98e738bcc02309396e5bc upstream.
The logic to detect if the irq stack was already in use with
raw_spin_trylock() is wrong, because it will generate a "trylock failure
on UP" error message with CONFIG_SMP=n and CONFIG_DEBUG_SPINLOCK=y.
arch_spin_trylock() can't be used either since in the CONFIG_SMP=n case
no atomic protection is given and we are reentrant here. A mutex didn't
worked either and brings more overhead by turning off interrupts.
So, let's use the fastest path for parisc which is the ldcw instruction.
Counting how often the irq stack was used is pretty useless, so just
drop this piece of code.
commit b63a2bbc0b9b106a93e11952ab057e2408f2eb02 upstream.
The get_stack_use_cr30 and get_stack_use_r30 macros allocate a stack
frame for external interrupts and interruptions requiring a stack frame.
They are currently not reentrant in that they save register context
before the stack is set or adjusted.
I have observed a number of system crashes where there was clear
evidence of stack corruption during interrupt processing, and as a
result register corruption. Some interruptions can still occur during
interruption processing, however external interrupts are disabled and
data TLB misses don't occur for absolute accesses. So, it's not entirely
clear what triggers this issue. Also, if an interruption occurs when
Q=0, it is generally not possible to recover as the shadowed registers
are not copied.
The attached patch reworks the get_stack_use_cr30 and get_stack_use_r30
macros to allocate stack before doing register saves. The new code is a
couple of instructions shorter than the old implementation. Thus, it's
an improvement even if it doesn't fully resolve the stack corruption
issue. Based on limited testing, it improves SMP system stability.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
/proc/interrupts
commit d0c3be806a3fe7f4abdb0f7e7287addb55e73f35 upstream.
Show number of floating point assistant and unaligned access fixup
handler in /proc/interrupts file.
commit 949451b9b19da5e998778eb78929aafc73b5c227 upstream.
commit 416821d3d68164909b2cbcf398e4ba0797f5f8a2 upstream.
This patch fixes few build issues which were introduced with the last
irq stack patch, e.g. the combination of stack overflow check and irq
stack.
Furthermore we now do proper locking and change the irq bh handler
to use the irq stack as well.
In /proc/interrupts one now can monitor how huge the irq stack has grown
and how often it was preferred over the kernel stack.
IRQ stacks are now enabled by default just to make sure that we not
overflow the kernel stack by accident.
commit 1ab4ce762370b82870834899e49c08129d7ae271 upstream.
kmap_atomic() requires only one argument now.
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Rolf Eike Beer <eike-kernel@sf-tec.de>
commit 0fc537d1d655cdae69b489dbba46ad617cfc1373 upstream.
Fix up build error on UP and show correctly number of function call
(ipi) irqs.
commit cd85d5514d5c4d7e78abac923fc032457d0c5091 upstream.
Add framework and initial values for more fine grained statistics in
/proc/interrupts.
commit 200c880420a2c02a0899120ce52d801fad705b90 upstream.
Default kernel stack size on parisc is 16k. During tests we found that the
kernel stack can easily grow beyond 13k, which leaves 3k left for irq
processing.
This patch adds the possibility to activate an additional stack of 16k per CPU
which is being used during irq processing. This implementation does not yet
uses this irq stack for the irq bh handler.
The assembler code for call_on_stack was heavily cleaned up by John
David Anglin.
CC: John David Anglin <dave.anglin@bell.net>
commit 9372450cc22d185f708e5cc3557cf991be4b7dc5 upstream.
Add the CONFIG_DEBUG_STACKOVERFLOW config option to enable checks to
detect kernel stack overflows.
Stack overflows can not be detected reliable since we do not want to
introduce too much overhead.
Instead, during irq processing in do_cpu_irq_mask() we check kernel
stack usage of the interrupted kernel process. Kernel threads can be
easily detected by checking the value of space register 7 (sr7) which
is zero when running inside the kernel.
Since THREAD_SIZE is 16k and PAGE_SIZE is 4k, reduce the alignment of
the init thread to the lower value (PAGE_SIZE) in the kernel
vmlinux.ld.S linker script.
commit bbbfde782084b4f0d85ddffb88f1cf4650ff40e4 upstream.
The "b" branch instruction used in the fork_like macro only can handle
17-bit pc-relative offsets.
This fails with an out of range offset with some .config files.
Rewrite to use the "be" instruction which
can branch to any address in a space.
commit f0a18819e261afc5fdbd8c5c6f9943123c5461ba upstream.
Currently, race conditions exist in the handling of TLB interruptions in
entry.S. In particular, dirty bit updates can be lost if an accessed
interruption occurs just after the dirty bit interruption on a different
cpu. Lost dirty bit updates result in user pages not being flushed and
general system instability. This change adds lock and unlock macros to
synchronize all PTE and TLB updates done in entry.S. As a result,
userspace stability is significantly improved.
when returning to userspace
commit c207a76bf155cb5cf24cf849c08f6555e9180594 upstream.
Helge and I have found that we have a kernel stack overflow problem
which causes a variety of random failures.
Currently, we re-enable interrupts when returning from an external
interrupt incase we need to schedule or delivery
signals. As a result, a potentially unlimited number of interrupts
can occur while we are running on the kernel
stack. It is very limited in space (currently, 16k). This change
defers enabling interrupts until we have
actually decided to schedule or delivery signals. This only occurs
when we about to return to userspace. This
limits the number of interrupts on the kernel stack to one. In other
cases, interrupts remain disabled until the
final return from interrupt (rfi).
User applications running on SMP kernels have long suffered from instability
and random segmentation faults. This patch improves the situation although
there is more work to be done.
One of the problems is the various routines in pgtable.h that update page table
entries use different locking mechanisms, or no lock at all (set_pte_at). This
change modifies the routines to all use the same lock pa_dbit_lock. This lock
is used for dirty bit updates in the interruption code. The patch also purges
the TLB entries associated with the PTE to ensure that inconsistent values are
not used after the page table entry is updated. The UP and SMP code are now
identical.
The change also includes a minor update to the purge_tlb_entries function in
cache.c to improve its efficiency.
The Debian experimental linux source package (3.8.5-1) build fails
with the following errors:
MODPOST 2016 modules
ERROR: "__ucmpdi2" [fs/btrfs/btrfs.ko] undefined!
ERROR: "__ucmpdi2" [drivers/md/dm-verity.ko] undefined!
The attached patch resolves this problem. It is based on the s390
implementation of ucmpdi2.c.
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull second round of PARISC updates from Helge Deller:
"The most important fix in this branch is the switch of io_setup,
io_getevents and io_submit syscalls to use the available compat
syscalls when running 32bit userspace on 64bit kernel. Other than
that it's mostly removal of compile warnings."
* 'fixes-for-3.9-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: fix redefinition of SET_PERSONALITY
parisc: do not install modules when installing kernel
parisc: fix compile warnings triggered by atomic_sub(sizeof(),v)
parisc: check return value of down_interruptible() in hp_sdc_rtc.c
parisc: avoid unitialized variable warning in pa_memcpy()
parisc: remove unused variable 'compat_val'
parisc: switch to compat_functions of io_setup, io_getevents and io_submit
parisc: select ARCH_WANT_FRAME_POINTERS
commit e72837e3e7bae3f182c4ac63c9424e86f1158dd0 introduced
a default SET_PERSONALITY() in include/linux/elf.h.
This breaks with our own SET_PERSONALITY define for
clean up after commit 6e26aab98ce8a818fb1ec47f8f727a8480a9011b
(switch to generic sigaltstack)
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull signal/compat fixes from Al Viro:
"Fixes for several regressions introduced in the last signal.git pile,
along with fixing bugs in truncate and ftruncate compat (on just about
anything biarch at least one of those two had been done wrong)."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
compat: restore timerfd settime and gettime compat syscalls
[regression] braino in "sparc: convert to ksignal"
fix compat truncate/ftruncate
switch lseek to COMPAT_SYSCALL_DEFINE
lseek() and truncate() on sparc really need sign extension
Update the parisc arch_get_unmapped_area function to make use of
vm_unmapped_area() instead of implementing a brute force search.
[akpm@linux-foundation.org: remove now-unused DCACHE_ALIGN(), per James]
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Helge Deller <deller@gmx.de>
Tested-by: Helge Deller <deller@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"The sweeping change is to make add_taint() explicitly indicate whether
to disable lockdep, but it's a mechanical change."
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
MODSIGN: Add option to not sign modules during modules_install
MODSIGN: Add -s <signature> option to sign-file
MODSIGN: Specify the hash algorithm on sign-file command line
MODSIGN: Simplify Makefile with a Kconfig helper
module: clean up load_module a little more.
modpost: Ignore ARC specific non-alloc sections
module: constify within_module_*
taint: add explicit flag to show whether lock dep is still OK.
module: printk message when module signature fail taints kernel.
Pull signal handling cleanups from Al Viro:
"This is the first pile; another one will come a bit later and will
contain SYSCALL_DEFINE-related patches.
- a bunch of signal-related syscalls (both native and compat)
unified.
- a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE
(fixing several potential problems with missing argument
validation, while we are at it)
- a lot of now-pointless wrappers killed
- a couple of architectures (cris and hexagon) forgot to save
altstack settings into sigframe, even though they used the
(uninitialized) values in sigreturn; fixed.
- microblaze fixes for delivery of multiple signals arriving at once
- saner set of helpers for signal delivery introduced, several
architectures switched to using those."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits)
x86: convert to ksignal
arm: switch to struct ksignal * passing
alpha: pass k_sigaction and siginfo_t using ksignal pointer
burying unused conditionals
make do_sigaltstack() static
arm64: switch to generic old sigaction() (compat-only)
arm64: switch to generic compat rt_sigaction()
arm64: switch compat to generic old sigsuspend
arm64: switch to generic compat rt_sigqueueinfo()
arm64: switch to generic compat rt_sigpending()
arm64: switch to generic compat rt_sigprocmask()
arm64: switch to generic sigaltstack
sparc: switch to generic old sigsuspend
sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE
sparc: kill sign-extending wrappers for native syscalls
kill sparc32_open()
sparc: switch to use of generic old sigaction
sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE
mips: switch to generic sys_fork() and sys_clone()
Pull parisc updates from Helge Deller.
The bulk of this is optimized page coping/clearing and cache flushing
(virtual caches are lovely) by John David Anglin.
* 'parisc-3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: (31 commits)
arch/parisc/include/asm: use ARRAY_SIZE macro in mmzone.h
parisc: remove empty lines and unnecessary #ifdef coding in include/asm/signal.h
parisc: sendfile and sendfile64 syscall cleanups
parisc: switch to available compat_sched_rr_get_interval implementation
parisc: fix fallocate syscall
parisc: fix error return codes for rt_sigaction and rt_sigprocmask
parisc: convert msgrcv and msgsnd syscalls to use compat layer
parisc: correctly wire up mq_* functions for CONFIG_COMPAT case
parisc: fix personality on 32bit kernel
parisc: wire up process_vm_readv, process_vm_writev, kcmp and finit_module syscalls
parisc: led driver requires CONFIG_VM_EVENT_COUNTERS
parisc: remove unused compat_rt_sigframe.h header
parisc/mm/fault.c: Port OOM changes to do_page_fault
parisc: space register variables need to be in native length (unsigned long)
parisc: fix ptrace breakage
parisc: always detect multiple physical ranges
parisc: ensure that mmapped shared pages are aligned at SHMLBA addresses
parisc: disable preemption while flushing D- or I-caches through TMPALIAS region
parisc: remove IRQF_DISABLED
parisc: fixes and cleanups in page cache flushing (4/4)
Utilize the existing compat_sys_sendfile function for 64bit kernel and add
wrappers for sendfile and sendfile64 to correctly handle the 32/64 bit sign
extension.
fallocate(off_t) gets redirected by glibc to fallocate64(loff_t)
where the 64bit loff_t values get splitted into two 32bit (hi/lo)
values. This patch fixes this syscall for the 32- and 64bit kernel.
Switch over to use the existing compat_* implementation for msgrcv() and
msgsnd(). Existing code was even partly buggy since it returned on some paths
different error codes than the standard.
Fix mq_open, mq_timedsend, mq_timedreceive, mq_notify and mq_getsetattr
syscalls when running 32bit applications on 64bit kernel.
syscalls
1) PTRACE_SYSCALL doesn't work for 64bit process on parisc64.
Compat syscall table is used instead of 64bit one. IMO we should either
refuse to allow PTRACE_SYSCALL for 64bit processes or duplicate the
logics choosing the right syscall table into .Ltracesys.
2) if you have let the tracee run with PTRACE_SYSCALL and
it had stopped, you can use PTRACE_POKEUSR to modify syscall number
(r20) and arguments 1--4 (r26--r23). Modifications will have effect.
However, modifying arguments 5 and 6 (r22 and r21 resp.) works only
when process (32bit one) runs on 64bit host - on 32bit one it has no
effect. AFAICS, the diff below should fix that one.
Signed-off-by: Al Viro <viro@ZenIV.linux.org.uk>
Tested-by: John David Anglin <dave.anglin@bell.net>
It is necessary to disable preemption during cache flushes done through the
TMPALIAS region to ensure that the TLB setup is not clobbered by another flush.
People are playing odd games with IRQF_DISABLED, remove it.
Its not reliable, since shared interrupt lines could disable it for you,
and its possible and allowed for archs to disable IRQs to limit IRQ nesting.
Therefore, simply mandate that _ALL_ IRQ handlers are run with IRQs disabled.
[ This _should_ not break anything, since we've mandated that IRQ handlers
_must_ be able to deal with this for a _long_ time ]
IRQ handlers should be fast, no if buts and any other exceptions. We also have
plenty instrumentation to find any offending IRQ latency sources.
CONFIG_PARISC_TMPALIAS enables clear_user_highpage and copy_user_highpage.
These are essentially alternative implementations of clear_user_page and
copy_user_page. They don't have anything to do with x86 high pages, but they
build on the infrastructure to save a few instructions. Read the comment in
clear_user_highpage as it is very important to the implementation. For this
reason, there isn't any gain in using the TMPALIAS/highpage approach.
flush_cache_mm, for the non current case also uses flush_dcache_page_asm
and flush_icache_page_asm which are TMPALIAS flushes.
For the non current case, the algorithm used by get_ptep is derived from the
vmalloc_to_page implementation in vmalloc.c. It is essentially a generic page
table lookup. The other alternative was to duplicate the lookup in entry.S.
The break point for switching to a full cache flush is somewhat arbitrary. The
same approach is used in flush_cache_range for non current case. In a GCC
build and check, many small programs are executed and this change provided a
significant performance enhancement, e.g. GCC build time was cut almost in half
on a rp3440 at j4. Previously, we always flushed the entire cache.
Implement clear_page_asm and copy_page_asm. These are optimized routines to
clear and copy a page. I tested prefetch optimizations in clear_page_asm and
copy_page_asm but didn't see any significant performance improvement on rp3440.
I'm not sure if these are routines are significantly faster than memset and/or
memcpy, but they are there for further performance evaluation.
TLB purge operations on PA 1.X SMP machines are now serialized with the help of
the new tlb_lock() and tlb_unlock() macros, since on some PA-RISC machines, TLB
purges need to be serialized in software. Obviously, lock isn't needed in UP
kernels. On PA 2.0 machines, there is a local TLB instruction which is much
less disruptive to the memory subsystem. No lock is needed for local purge.
Loops are also unrolled in flush_instruction_cache_local and
flush_data_cache_local.
The implementation of what used to be copy_user_page (now copy_user_page_asm)
is now fixed. Additionally 64-bit support is now added. Read the preceding
comment which I didn't change. I left the comment but it is now inaccurate.
This is the first patch in a series of 4, with which the page cache flushing of
parisc will gets fixed and enhanced. This even fixes the nasty "minifail" bug
(http://wiki.parisc-linux.org/TestCases?highlight=%28minifail%29) which
prevented parisc to stay an official debian port. Basically the flush in
copy_user_page together with the TLB patch from commit
7139bc1579901b53db7e898789e916ee2fb52d78 is what fixes the minifail bug.
This patch still uses the TMPALIAS approach. The new copy_user_page
implementation calls flush_dcache_page_asm to flush the user dcache page
(crucial for minifail fix) via a kernel TMPALIAS mapping. After that, it just
copies the page using the kernel mapping. It does a final flush if needed.
Generally it is hard to avoid doing some cache flushes using the kernel mapping
(e.g., copy_to_user_page and copy_from_user_page).
This patch depends on a subsequent change to pacache.S implementing
clear_page_asm and copy_page_asm. These are optimized routines to clear and
copy a page. The calls in clear_user_page and copy_user_page could be replaced
by calls to memset and memcpy, respectively. I tested prefetch optimizations
in clear_page_asm and copy_page_asm but didn't see any significant performance
improvement on rp3440. I'm not sure if these are routines are significantly
faster than memset and/or memcpy, but they are there for further performance
evaluation.
pa_pdc_cell has been allocated in this function and so should be
freed before leaving from the error handling cases.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This comment describes incredibly subtle code, so it should be right!
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 into stable-3.8
PARISC fixes on 20130213
This is a couple of patches, one to fix a broken build with HPUX compatibility
and the other to solve a coherency problem we've been seeing in our TLB where
setting a page read only occasionally fails to trigger a COW because of a
stale writeable TLB entry.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
