* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
arch/parisc/kernel/perf_asm.S: build fix
parisc: remove -traditional from assembler flags
parisc: use conditional macro for 64-bit wide ops
parisc: Remove ioctl.h content picked up from <asm-generic/ioctl.h>.
arch/parisc/kernel/unaligned.c: use time_* macros
parisc: remove redundant display of free swap space in show_mem()
drivers/parisc: replace remaining __FUNCTION__ occurrences
parisc: new termios definitions
parisc: fix trivial section name warnings
show_mem() has no need to print the amount of free swap space manually because
show_free_areas() does this already and is called by the former.
The two outputs only differ in text formatting:
printk("Free swap = %lukB\n", ...);
printk("Free swap: %6ldkB\n", ...);
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Grant Grundler <grundler@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
PA-RISC to aid debugging prints out the zonelists setup by the system. A
bad call to node_zonelist() breaks at compile-time. This patch fixes it.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Adrian Bunk <bunk@kernel.org>
Filtering zonelists requires very frequent use of zone_idx(). This is costly
as it involves a lookup of another structure and a substraction operation. As
the zone_idx is often required, it should be quickly accessible. The node idx
could also be stored here if it was found that accessing zone->node is
significant which may be the case on workloads where nodemasks are heavily
used.
This patch introduces a struct zoneref to store a zone pointer and a zone
index. The zonelist then consists of an array of these struct zonerefs which
are looked up as necessary. Helpers are given for accessing the zone index as
well as the node index.
[kamezawa.hiroyu@jp.fujitsu.com: Suggested struct zoneref instead of embedding information in pointers]
[hugh@veritas.com: mm-have-zonelist: fix memcg ooms]
[hugh@veritas.com: just return do_try_to_free_pages]
[hugh@veritas.com: do_try_to_free_pages gfp_mask redundant]
Acked-by: Christoph Lameter <clameter@sgi.com>
Acked-by: David Rientjes <rientjes@google.com>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Currently a node has two sets of zonelists, one for each zone type in the
system and a second set for GFP_THISNODE allocations. Based on the zones
allowed by a gfp mask, one of these zonelists is selected. All of these
zonelists consume memory and occupy cache lines.
This patch replaces the multiple zonelists per-node with two zonelists. The
first contains all populated zones in the system, ordered by distance, for
fallback allocations when the target/preferred node has no free pages. The
second contains all populated zones in the node suitable for GFP_THISNODE
allocations.
An iterator macro is introduced called for_each_zone_zonelist() that interates
through each zone allowed by the GFP flags in the selected zonelist.
Cc: Hugh Dickins <hugh@veritas.com>
This patchset adds a flags variable to reserve_bootmem() and uses the
BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions
between crashkernel area and already used memory.
This patch:
Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE.
If that flag is set, the function returns with -EBUSY if the memory already
has been reserved in the past. This is to avoid conflicts.
Because that code runs before SMP initialisation, there's no race condition
inside reserve_bootmem_core().
[akpm@linux-foundation.org: fix powerpc build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: <linux-arch@vger.kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
zone_to_nid returns int, always.
Spelling fixes in arch/parisc/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (78 commits)
[PARISC] Use symbolic last syscall in __NR_Linux_syscalls
[PARISC] Add missing statfs64 and fstatfs64 syscalls
Revert "[PARISC] Optimize TLB flush on SMP systems"
[PARISC] Compat signal fixes for 64-bit parisc
[PARISC] Reorder syscalls to match unistd.h
Revert "[PATCH] make kernel/signal.c:kill_proc_info() static"
[PARISC] fix sys_rt_sigqueueinfo
[PARISC] fix section mismatch warnings in harmony sound driver
[PARISC] do not export get_register/set_register
[PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation code
[PARISC] convert to use CONFIG_64BIT instead of __LP64__
[PARISC] use CONFIG_64BIT instead of __LP64__
[PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macro
[PARISC] more ENTRY(), ENDPROC(), END() conversions
[PARISC] fix ENTRY() and ENDPROC() for 64bit-parisc
[PARISC] Fixes /proc/cpuinfo cache output on B160L
[PARISC] implement standard ENTRY(), END() and ENDPROC()
[PARISC] kill ENTRY_SYS_CPUS
[PARISC] clean up debugging printks in smp.c
[PARISC] factor syscall_restart code out of do_signal
Fix conflict in include/linux/sched.h due to kill_proc_info() being made
publicly available to PARISC again.
- additionally update my copyright timestamps
Signed-off-by: Helge Deller <deller@gmx.de>
Remove in-source externs, linux/init.h is included in all cases.
This is a fixups for "Dynamic kernel command-line" patch.
It also includes some uml __init fixups so that we can __initdata also its
command_line.
Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com>
Cc: Jeff Dike <jdike@addtoit.com>
1. Rename saved_command_line into boot_command_line.
2. Set command_line as __initdata.
Remove ZONE_DMA remains from parisc so that kernels are build without
ZONE_DMA.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Matthew Wilcox <willy@debian.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
The `simple' way of walking and checking PageReserved is broken on
discontigmem, instead we need to check each range explicitly.
(Also rename a few things so they make more sense.)
There are many places where we need to determine the node of a zone.
Currently we use a difficult to read sequence of pointer dereferencing.
Put that into an inline function and use throughout VM. Maybe we can find
a way to optimize the lookup in the future.
Fix array initialization in lots of arches
The number of zones may now be reduced from 4 to 2 for many arches. Fix the
array initialization for the zones array for all architectures so that it is
not initializing a fixed number of elements.
Add __start_rodata and __end_rodata to sections.h to avoid extern
declarations. Needed by s390 code (see following patch).
[akpm@osdl.org: update architectures]
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Andi Kleen <ak@muc.de>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
More work towards supporing multiple page sizes on 64-bit. Convert
some assumptions that 64bit uses 3 level page tables into testing
PT_NLEVELS. Also some BUG() to BUG_ON() conversions and some cleanups
to assembler.
Signed-off-by: Helge Deller <deller@parisc-linux.org>
I think it's time to enable free_initrd_mem() again...
set_page_count usage outside mm/ is limited to setting the refcount to 1.
Remove set_page_count from outside mm/, and replace those users with
init_page_count() and set_page_refcounted().
This allows more debug checking, and tighter control on how code is allowed
to play around with page->_count.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Use CONFIG_DEBUG_KERNEL to catch kernel code which tries to access
__init data after it is freed. When CONFIG_DEBUG_KERNEL is not set
this also cleans up a WARN_ON at boot time. Also remove some dead
code from mm/init.c
Add the parisc version of the "mark rodata section read only" patches.
Based on code from and Signed-off-by Arjan van de Ven
<arjan@infradead.org>, Ingo Molnar <mingo@elte.hu>, Andi Kleen <ak@muc.de>,
Andrew Morton <akpm@osdl.org>, Linus Torvalds <torvalds@osdl.org>.
Drop the unused do_check_pgt_cache routine from mm/init.c and its
prototype in asm/pgalloc.h
Make flush_tlb_all_local take a void * so it doesn't have to be cast
when using on_each_cpu(). This becomes a problem when on_each_cpu
is a macro.
Also remove the prototype of flush_tlb_all_local from .c files.
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
max_low_pfn was not being set in arch/parisc/mm/init.c, causing severe
problems whenever anything tried to use BLK_BOUNCE_HIGH. Set it to
max_pfn like other similar architectures do.
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
Make flush_data_cache_local, flush_instruction_cache_local and
flush_tlb_all_local take a void * so they don't have to be cast
is a macro (as it is in current -mm).
Also move the prototype of flush_tlb_all_local into tlbflush.h and
remove its declaration from .c files.
Flag a whole bunch of things as __read_mostly on parisc. Also flag a few
branches as unlikely() and cleanup a bit of code.
pgdat->node_size_lock is basically only neeeded in one place in the normal
code: show_mem(), which is the arch-specific sysrq-m printing function.
Strictly speaking, the architectures not doing memory hotplug do no need this
locking in show_mem(). However, they are all included for completeness. This
should also make any future consolidation of all of the implementations a
little more straightforward.
This lock is also held in the sparsemem code during a memory removal, as
sections are invalidated. This is the place there pfn_valid() is made false
for a memory area that's being removed. The lock is only required when doing
pfn_valid() operations on memory which the user does not already have a
reference on the page, such as in show_mem().
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
This patch effectively eliminates direct use of pgdat->node_mem_map outside
of the DISCONTIG code. On a flat memory system, these fields aren't
currently used, neither are they on a sparsemem system.
There was also a node_mem_map(nid) macro on many architectures. Its use
along with the use of ->node_mem_map itself was not consistent. It has
been removed in favor of two new, more explicit, arch-independent macros:
pgdat_page_nr(pgdat, pagenr)
nid_page_nr(nid, pagenr)
I called them "pgdat" and "nid" because we overload the term "node" to mean
"NUMA node", "DISCONTIG node" or "pg_data_t" in very confusing ways. I
believe the newer names are much clearer.
These macros can be overridden in the sparsemem case with a theoretically
slower operation using node_start_pfn and pfn_to_page(), instead. We could
make this the only behavior if people want, but I don't want to change too
much at once. One thing at a time.
This patch removes more code than it adds.
Compile tested on alpha, alpha discontig, arm, arm-discontig, i386, i386
generic, NUMAQ, Summit, ppc64, ppc64 discontig, and x86_64. Full list
here: http://sr71.net/patches/2.6.12/2.6.12-rc1-mhp2/configs/
Boot tested on NUMAQ, x86 SMP and ppc64 power4/5 LPARs.
Signed-off-by: Martin J. Bligh <mbligh@aracnet.com>
infrastructure for it.
Let it rip!
