Drop code to create HP-UX gateway page and syscall entry code.
Signed-off-by: Helge Deller <deller@gmx.de>
alloc_bootmem and related function always return zeroed region of
memory. Thus a memset after calls to these functions is unnecessary.
The following Coccinelle semantic patch was used for making the change:
expression E,E1;
E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...)
... when != E
- memset(E,0,E1);
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Commit 4b59e6c47309 ("mm, show_mem: suppress page counts in
non-blockable contexts") introduced SHOW_MEM_FILTER_PAGE_COUNT to
suppress PFN walks on large memory machines. Commit c78e93630d15 ("mm:
do not walk all of system memory during show_mem") avoided a PFN walk in
the generic show_mem helper which removes the requirement for
SHOW_MEM_FILTER_PAGE_COUNT in that case.
This patch removes PFN walkers from the arch-specific implementations
that report on a per-node or per-zone granularity. ARM and unicore32
still do a PFN walk as they report memory usage on each bank which is a
much finer granularity where the debugging information may still be of
use. As the remaining arches doing PFN walks have relatively small
amounts of memory, this patch simply removes SHOW_MEM_FILTER_PAGE_COUNT.
[akpm@linux-foundation.org: fix parisc]
Acked-by: David Rientjes <rientjes@google.com>
Cc: James Bottomley <jejb@parisc-linux.org>
When building a 64bit kernel sometimes functions in the .init section were not
able to reach the standard kernel function. Main reason for this problem is,
that the linkage tables (.plt, .opd, .dlt) tend to become pretty huge and thus
the distance gets too big for short calls.
One option to avoid this is to use the -mlong-calls compiler option, but this
increases the binary size and introduces a performance penalty.
Instead, with this patch we just lay out the binary differently. Init code is
stored first, followed by text, R/O and finally R/W data. This means, that init
and text code is now much closer to each other, which is sufficient to reach
each other by short calls.
Prepare for killing free_all_bootmem_node() by using free_all_bootmem().
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Prepare for removing num_physpages and simplify mem_init().
Concentrate code to modify totalram_pages into the mm core, so the arch
memory initialized code doesn't need to take care of it. With these
changes applied, only following functions from mm core modify global
variable totalram_pages: free_bootmem_late(), free_all_bootmem(),
free_all_bootmem_node(), adjust_managed_page_count().
With this patch applied, it will be much more easier for us to keep
totalram_pages and zone->managed_pages in consistence.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: <sworddragon2@aol.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Address more review comments from last round of code review.
1) Enhance free_reserved_area() to support poisoning freed memory with
pattern '0'. This could be used to get rid of poison_init_mem()
on ARM64.
2) A previous patch has disabled memory poison for initmem on s390
by mistake, so restore to the original behavior.
3) Remove redundant PAGE_ALIGN() when calling free_reserved_area().
Change signature of free_reserved_area() according to Russell King's
suggestion to fix following build warnings:
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default]
free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL);
In file included from include/linux/mman.h:4:0,
from arch/arm/mm/init.c:15:
include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *'
extern unsigned long free_reserved_area(unsigned long start, unsigned long end,
mm/page_alloc.c: In function 'free_reserved_area':
>> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default]
In file included from arch/mips/include/asm/page.h:49:0,
from include/linux/mmzone.h:20,
from include/linux/gfp.h:4,
from include/linux/mm.h:8,
from mm/page_alloc.c:18:
arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int'
mm/page_alloc.c: In function 'free_area_init_nodes':
mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds]
Also address some minor code review comments.
Make sure that we really return -1 (instead of 0x00ff) as node id for
page frame numbers which are not physically available.
This finally fixes the kernel panic when running
cat /proc/kpageflags /proc/kpagecount.
Theoretically this patch now limits the number of physical memory ranges
to 127 instead of 254, but currently we have MAX_PHYSMEM_RANGES
hardcoded to 8 which is sufficient for all existing parisc machines.
This patch fixes few build issues which were introduced with the last
irq stack patch, e.g. the combination of stack overflow check and irq
stack.
Furthermore we now do proper locking and change the irq bh handler
to use the irq stack as well.
In /proc/interrupts one now can monitor how huge the irq stack has grown
and how often it was preferred over the kernel stack.
IRQ stacks are now enabled by default just to make sure that we not
overflow the kernel stack by accident.
Add framework and initial values for more fine grained statistics in
/proc/interrupts.
Use common help functions to free reserved pages.
On large systems with a lot of memory, walking all RAM to determine page
types may take a half second or even more.
In non-blockable contexts, the page allocator will emit a page allocation
failure warning unless __GFP_NOWARN is specified. In such contexts, irqs
are typically disabled and such a lengthy delay may even result in NMI
watchdog timeouts.
To fix this, suppress the page walk in such contexts when printing the
page allocation failure warning.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Same code, except: The alignment of init_thread_union is handled via
the linker script, so no point to have it with the data structure. The
extra asm(".data") looks like a leftover from an asm to C conversion
and is pointless.
Use the generic version.
Move the page table data to parisc/mm/init.c and get rid of
parisc/../init_task.c
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Link: http://lkml.kernel.org/r/20120503085035.150896946@linutronix.de
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Architectures that implement their own show_mem() function did not pass
the filter argument to show_free_areas() to appropriately avoid emitting
the state of nodes that are disallowed in the current context. This patch
now passes the filter argument to show_free_areas() so those nodes are now
avoided.
This patch also removes the show_free_areas() wrapper around
__show_free_areas() and converts existing callers to pass an empty filter.
ia64 emits additional information for each node, so skip_free_areas_zone()
must be made global to filter disallowed nodes and it is converted to use
a nid argument rather than a zone for this use case.
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6:
[PARISC] wire up syncfs syscall
[PARISC] wire up the fhandle syscalls
[PARISC] wire up clock_adjtime syscall
[PARISC] wire up fanotify syscalls
[PARISC] prevent speculative re-read on cache flush
[PARISC] only make executable areas executable
[PARISC] fix pacache .size with new binutils
When a DISCONTIGMEM memory range is brought online as a NUMA node, it
also needs to have its bet set in N_NORMAL_MEMORY. This is necessary for
generic kernel code that utilizes N_NORMAL_MEMORY as a subset of N_ONLINE
for memory savings.
These types of hacks can hopefully be removed once DISCONTIGMEM is either
removed or abstracted away from CONFIG_NUMA.
Fixes a panic in the slub code which only initializes structures for
N_NORMAL_MEMORY to save memory:
Backtrace:
[<000000004021c938>] add_partial+0x28/0x98
[<000000004021faa0>] __slab_free+0x1d0/0x1d8
[<000000004021fd04>] kmem_cache_free+0xc4/0x128
[<000000004033bf9c>] ida_get_new_above+0x21c/0x2c0
[<00000000402a8980>] sysfs_new_dirent+0xd0/0x238
[<00000000402a974c>] create_dir+0x5c/0x168
[<00000000402a9ab0>] sysfs_create_dir+0x98/0x128
[<000000004033d6c4>] kobject_add_internal+0x114/0x258
[<000000004033d9ac>] kobject_add_varg+0x7c/0xa0
[<000000004033df20>] kobject_add+0x50/0x90
[<000000004033dfb4>] kobject_create_and_add+0x54/0xc8
[<00000000407862a0>] cgroup_init+0x138/0x1f0
[<000000004077ce50>] start_kernel+0x5a0/0x840
[<000000004011fa3c>] start_parisc+0xa4/0xb8
[<00000000404bb034>] packet_ioctl+0x16c/0x208
[<000000004049ac30>] ip_mroute_setsockopt+0x260/0xf20
Cc: stable@kernel.org
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Currently parisc has the whole kernel marked as RWX, meaning any
kernel page at all is eligible to be executed. This can cause a
theoretical problem on systems with combined I/D TLB because the act
of referencing a page causes a TLB insertion with an executable bit.
This TLB entry may be used by the CPU as the basis for speculating the
page into the I-Cache. If this speculated page is subsequently used
for a user process, there is the possibility we will get a stale
I-cache line picked up as the binary executes.
As a point of good practise, only mark actual kernel text pages as
executable. The same has to be done for init_text pages, but they're
converted to data pages (and the I-Cache flushed) when the init memory
is released.
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from
meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which
resulted in build warnings on all architectures that implement their own
versions of show_mem():
lib/lib.a(show_mem.o): In function `show_mem':
show_mem.c:(.text+0x1f4): multiple definition of `show_mem'
arch/sparc/mm/built-in.o:(.text+0xd70): first defined here
The fix is to remove __show_mem() and add its argument to show_mem() in
all implementations to prevent this breakage.
Architectures that implement their own show_mem() actually don't do
anything with the argument yet, but they could be made to filter nodes
that aren't allowed in the current context in the future just like the
generic implementation.
Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
building kernel 2.6.32(pre), gives this compiler warning:
/linus-linux-2.6/mm/vmalloc.c: In function 'pcpu_get_vm_areas':
/linus-linux-2.6/mm/vmalloc.c:2104: warning: 'vmalloc_start' is used
uninitialized in this function
The reason is, that the code in mm/vmalloc defines a local variable called
vmalloc_start, which is already defined as global variable in parisc's code.
To avoid this kind of problems in future, I suggest to rename the parisc
variable
to parisc_vmalloc_start.
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()")
modified nr_free_pages() to return 'unsigned long' instead of 'unsigned
int'. This made the casts to 'unsigned long' in most callers superfluous,
so remove them.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chris Zankel <zankel@tensilica.com>
arch/parisc/mm/init.c: In function 'free_initmem':
381: warning: passing argument 1 of 'memset' makes pointer from integer without a cast
Doing an IPI with local interrupts off triggers a warning. We
don't need to be quite so ridiculously paranoid. Also, clean up
a bit of the code a little.
This patch fixes a long outstanding bug on 32bit parisc linux kernels
which prevented us from using 32bit PTE table entries (instead of 64bit
entries of which 32bit were unused).
The problem was caused by this assembler statement in the L2_ptep
macro in arch/parisc/kernel/entry.S:447:
EXTR \va,31-ASM_PGDIR_SHIFT,ASM_BITS_PER_PGD,\index
which expanded to
extrw,u r8,9,11,r1
and which has undefined behavior since the length value (11) extends
beyond the leftmost bit (11-1 > 9).
Interestingly PA2.0 processors seem to don't care and just zero-extend
the value, while PA1.1 processors don't.
Fix this problem by detecting an address space overflow with ASM_BITS_PER_PGD
and adjusting it accordingly. To prevent such problems in the future,
some compile time sanity checks in arch/parisc/mm/init.c were added.
Since the page table now only consumes half of it's old size, we can
use the freed memory to harmonize 32- and 64bit kernels and let both
map 16MB for the initial page table.
- convert a few "if (xx) BUG();" to BUG_ON(xx)
- remove a few printk()s, as we get a backtrace with BUG_ON() anyway
free_area_init_node() gets passed in the node id as well as the node
descriptor. This is redundant as the function can trivially get the node
descriptor itself by means of NODE_DATA() and the node's id.
I checked all the users and NODE_DATA() seems to be usable everywhere
from where this function is called.
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
There are a lot of places that define either a single bootmem descriptor or an
array of them. Use only one central array with MAX_NUMNODES items instead.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Kyle McMartin <kyle@parisc-linux.org>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Andy Whitcroft <apw@shadowen.org>
It's not even passed on to smp_call_function() anymore, since that
was removed. So kill it.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Needed by ext4 when built as a module.
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
arch/parisc/kernel/perf_asm.S: build fix
parisc: remove -traditional from assembler flags
parisc: use conditional macro for 64-bit wide ops
parisc: Remove ioctl.h content picked up from <asm-generic/ioctl.h>.
arch/parisc/kernel/unaligned.c: use time_* macros
parisc: remove redundant display of free swap space in show_mem()
drivers/parisc: replace remaining __FUNCTION__ occurrences
parisc: new termios definitions
parisc: fix trivial section name warnings
show_mem() has no need to print the amount of free swap space manually because
show_free_areas() does this already and is called by the former.
The two outputs only differ in text formatting:
printk("Free swap = %lukB\n", ...);
printk("Free swap: %6ldkB\n", ...);
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Grant Grundler <grundler@parisc-linux.org>
PA-RISC to aid debugging prints out the zonelists setup by the system. A
bad call to node_zonelist() breaks at compile-time. This patch fixes it.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Adrian Bunk <bunk@kernel.org>
Filtering zonelists requires very frequent use of zone_idx(). This is costly
as it involves a lookup of another structure and a substraction operation. As
the zone_idx is often required, it should be quickly accessible. The node idx
could also be stored here if it was found that accessing zone->node is
significant which may be the case on workloads where nodemasks are heavily
used.
This patch introduces a struct zoneref to store a zone pointer and a zone
index. The zonelist then consists of an array of these struct zonerefs which
are looked up as necessary. Helpers are given for accessing the zone index as
well as the node index.
[kamezawa.hiroyu@jp.fujitsu.com: Suggested struct zoneref instead of embedding information in pointers]
[hugh@veritas.com: mm-have-zonelist: fix memcg ooms]
[hugh@veritas.com: just return do_try_to_free_pages]
[hugh@veritas.com: do_try_to_free_pages gfp_mask redundant]
Acked-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Currently a node has two sets of zonelists, one for each zone type in the
system and a second set for GFP_THISNODE allocations. Based on the zones
allowed by a gfp mask, one of these zonelists is selected. All of these
zonelists consume memory and occupy cache lines.
This patch replaces the multiple zonelists per-node with two zonelists. The
first contains all populated zones in the system, ordered by distance, for
fallback allocations when the target/preferred node has no free pages. The
second contains all populated zones in the node suitable for GFP_THISNODE
allocations.
An iterator macro is introduced called for_each_zone_zonelist() that interates
through each zone allowed by the GFP flags in the selected zonelist.
Cc: Hugh Dickins <hugh@veritas.com>
This patchset adds a flags variable to reserve_bootmem() and uses the
BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions
between crashkernel area and already used memory.
This patch:
Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE.
If that flag is set, the function returns with -EBUSY if the memory already
has been reserved in the past. This is to avoid conflicts.
Because that code runs before SMP initialisation, there's no race condition
inside reserve_bootmem_core().
[akpm@linux-foundation.org: fix powerpc build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: <linux-arch@vger.kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
zone_to_nid returns int, always.
Spelling fixes in arch/parisc/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (78 commits)
[PARISC] Use symbolic last syscall in __NR_Linux_syscalls
[PARISC] Add missing statfs64 and fstatfs64 syscalls
Revert "[PARISC] Optimize TLB flush on SMP systems"
[PARISC] Compat signal fixes for 64-bit parisc
[PARISC] Reorder syscalls to match unistd.h
Revert "[PATCH] make kernel/signal.c:kill_proc_info() static"
[PARISC] fix sys_rt_sigqueueinfo
[PARISC] fix section mismatch warnings in harmony sound driver
[PARISC] do not export get_register/set_register
[PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation code
[PARISC] convert to use CONFIG_64BIT instead of __LP64__
[PARISC] use CONFIG_64BIT instead of __LP64__
[PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macro
[PARISC] more ENTRY(), ENDPROC(), END() conversions
[PARISC] fix ENTRY() and ENDPROC() for 64bit-parisc
[PARISC] Fixes /proc/cpuinfo cache output on B160L
[PARISC] implement standard ENTRY(), END() and ENDPROC()
[PARISC] kill ENTRY_SYS_CPUS
[PARISC] clean up debugging printks in smp.c
[PARISC] factor syscall_restart code out of do_signal
Fix conflict in include/linux/sched.h due to kill_proc_info() being made
publicly available to PARISC again.
- additionally update my copyright timestamps
Remove in-source externs, linux/init.h is included in all cases.
This is a fixups for "Dynamic kernel command-line" patch.
It also includes some uml __init fixups so that we can __initdata also its
command_line.
Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com>
1. Rename saved_command_line into boot_command_line.
2. Set command_line as __initdata.
Remove ZONE_DMA remains from parisc so that kernels are build without
ZONE_DMA.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Matthew Wilcox <willy@debian.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
The `simple' way of walking and checking PageReserved is broken on
discontigmem, instead we need to check each range explicitly.
(Also rename a few things so they make more sense.)
There are many places where we need to determine the node of a zone.
Currently we use a difficult to read sequence of pointer dereferencing.
Put that into an inline function and use throughout VM. Maybe we can find
a way to optimize the lookup in the future.
