commit 3c229b3f2dd8133f61bb81d3cb018be92f4bba39 upstream.
Fix a long-existing small nasty bug in the map_pages() implementation which
leads to overwriting already written pte entries with zero, *if* map_pages() is
called a second time with an end address which isn't aligned on a pmd boundry.
This happens for example if we want to remap only the text segment read/write
in order to run alternative patching on the code. Exiting the loop when we
reach the end address fixes this.
Cc: stable@vger.kernel.org
Signed-off-by: Helge Deller <deller@gmx.de>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Commit 24587380f61d ("parisc: Add MADV_HWPOISON and MADV_SOFT_OFFLINE") added
the necessary constants to handle hardware-poisoning. Those were needed to
support the page deallocation feature from firmware.
But I completely missed to add the relevant fault handler code. This now
showed up when I ran the madvise07 testcase from the Linux Test Project,
which failed with a kernel BUG at arch/parisc/mm/fault.c:320.
With this patch the parisc kernel now behaves like other platforms and
gives the same kernel syslog warnings when poisoning pages.
A poisoned or migrated hugepage is stored as a swap entry in the page
tables. On architectures that support hugepages consisting of
contiguous page table entries (such as on arm64) this leads to ambiguity
in determining the page table entry to return in huge_pte_offset() when
a poisoned entry is encountered.
Let's remove the ambiguity by adding a size parameter to convey
additional information about the requested address. Also fixup the
definition/usage of huge_pte_offset() throughout the tree.
Link: http://lkml.kernel.org/r/20170522133604.11392-4-punit.agrawal@arm.com
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Steve Capper <steve.capper@arm.com>
Cc: James Hogan <james.hogan@imgtec.com> (odd fixer:METAG ARCHITECTURE)
Cc: Ralf Baechle <ralf@linux-mips.org> (supporter:MIPS)
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Mark Rutland <mark.rutland@arm.com>
When a process runs out of stack the parisc kernel wrongly faults with SIGBUS
instead of the expected SIGSEGV signal.
This example shows how the kernel faults:
do_page_fault() command='a.out' type=15 address=0xfaac2000 in libc-2.24.so[f8308000+16c000]
trap #15: Data TLB miss fault, vm_start = 0xfa2c2000, vm_end = 0xfaac2000
The vma->vm_end value is the first address which does not belong to the vma, so
adjust the check to include vma->vm_end to the range for which to send the
SIGSEGV signal.
This patch unbreaks building the debian libsigsegv package.
Register gr[0] holds the PSW in interrupt context. It's absolutely
unlikely that the compiler will use register zero in a get_user() call,
but better BUG on such a case in fixup_exception() anyway.
The firmare in most parisc machines maintains a Page Deallocation Table (PDT)
which holds a list of physical memory addresses where hardware detected memory
errors (single bit and double bit errors).
This patch adds the missing PDC firmware calls and the logic to read the PDT
from firmware, report all current PDT entries and exclude the reported bad
memory from being used by Linux.
The last users have been migrated off by commits d19f5e41b344 ("parisc:
Clean up fixup routines for get_user()/put_user()") and 554bfeceb8a2
("parisc: Fix access fault handling in pa_memcpy()").
Al Viro noticed that userspace accesses via get_user()/put_user() can be
simplified a lot with regard to usage of the exception handling.
This patch implements a fixup routine for get_user() and put_user() in such
that the exception handler will automatically load -EFAULT into the register
%r8 (the error value) in case on a fault on userspace. Additionally the fixup
routine will zero the target register on fault in case of a get_user() call.
The target register is extracted out of the faulting assembly instruction.
This patch brings a few benefits over the old implementation:
1. Exception handling gets much cleaner, easier and smaller in size.
2. Helper functions like fixup_get_user_skip_1 (all of fixup.S) can be dropped.
3. No need to hardcode %r9 as target register for get_user() any longer. This
helps the compiler register allocator and thus creates less assembler
statements.
4. No dependency on the exception_data contents any longer.
5. Nested faults will be handled cleanly.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Cc: <stable@vger.kernel.org> # v4.9+
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc fixes and cleanups from Helge Deller:
"Nothing really important in this patchset: fix resource leaks in error
paths, coding style cleanups and code removal"
* 'parisc-4.11-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Remove flush_user_dcache_range and flush_user_icache_range
parisc: fix a printk
parisc: ccio-dma: Handle return NULL error from ioremap_nocache
parisc: Define access_ok() as macro
parisc: eisa: Fix resource leaks in error paths
parisc: eisa: Remove coding style errors
<linux/sched/debug.h>
We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/debug.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
to <linux/sched/mm.h>
We are going to split more MM APIs out of <linux/sched.h>, which
will have to be picked up from a couple of .c files.
The APIs that we are going to move are:
arch_pick_mmap_layout()
arch_get_unmapped_area()
arch_get_unmapped_area_topdown()
mm_update_next_owner()
Include the header in the files that are going to need it.
We want to do a pr_cont() here and not a pr_warn().
Fixes: b391667eb45a ("parisc: Report trap type as human readable string")
We have a generic implementation for quite some time already. If there
is any arch specific information to be printed then we should add a
callback called from the generic code rather than duplicate the whole
show_mem.
The current code has resulted in the code duplication and the output
divergence which is both confusing and adds maintainance costs.
Let's just get rid of this mess.
Link: http://lkml.kernel.org/r/20170117091543.25850-4-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> [UniCore32]
Acked-by: Helge Deller <deller@gmx.de> [for parisc]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull rodata updates from Kees Cook:
"This renames the (now inaccurate) DEBUG_RODATA and related
SET_MODULE_RONX configs to the more sensible STRICT_KERNEL_RWX and
STRICT_MODULE_RWX"
* tag 'rodata-v4.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
arch: Rename CONFIG_DEBUG_RODATA and CONFIG_DEBUG_MODULE_RONX
arch: Move CONFIG_DEBUG_RODATA and CONFIG_SET_MODULE_RONX to be common
Both of these options are poorly named. The features they provide are
necessary for system security and should not be considered debug only.
Change the names to CONFIG_STRICT_KERNEL_RWX and
CONFIG_STRICT_MODULE_RWX to better describe what these options do.
Signed-off-by: Laura Abbott <labbott@redhat.com>
Acked-by: Jessica Yu <jeyu@redhat.com>
Add a leading line break else printed line gets too long.
Show the real trap name when the kernel crashes.
Commit 4fe9e1d957e4 ("parisc: Drop bootmem and switch to memblock")
switched to the memblock allocator, but missed to zero-initialize the
newly allocated memblocks. This lead to crashes on some machines like
the rp3410.
Fixes: 4fe9e1d957e4 ("parisc: Drop bootmem and switch to memblock")
This file was only including module.h for exception table related
functions. We've now separated that content out into its own file
"extable.h" so now move over to that and avoid all the extra header
content in module.h that we don't really need to compile this file.
Cc: linux-parisc@vger.kernel.org
Memblock is the standard kernel boot-time memory tracker/allocator. Use it
instead of the bootmem allocator. This allows using kmemleak, CMA and
other features.
When faulting on some trap, the kernel currently reports in dmesg:
do_page_fault() command='perl' type=6 address=0xbe400403 in libcrypt-2.24.so[f9086000+9000]
vm_start = 0x00922000, vm_end = 0x00aed000
With this change the trap type additionally gets reported as human readable
string which makes it simpler to recognize the type of problem:
trap #6: Instruction TLB miss fault, vm_start = 0x00922000, vm_end = 0x00aed000
We always have vma->vm_mm around.
Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com
Handling exceptions from modules never worked on parisc.
It was just masked by the fact that exceptions from modules
don't happen during normal use.
When a module triggers an exception in get_user() we need to load the
main kernel dp value before accessing the exception_data structure, and
afterwards restore the original dp value of the module on exit.
Noticed-by: Mikulas Patocka <mpatocka@redhat.com>
Mostly direct substitution with occasional adjustment or removing
outdated comments.
Switch to the generic extable search and sort routines which were introduced
with commit a272858 from Ard Biesheuvel. This saves quite some memory in the
vmlinux binary with the 64bit kernel.
There are few things about *pte_alloc*() helpers worth cleaning up:
- 'vma' argument is unused, let's drop it;
- most __pte_alloc() callers do speculative check for pmd_none(),
before taking ptl: let's introduce pte_alloc() macro which does
the check.
The only direct user of __pte_alloc left is userfaultfd, which has
different expectation about atomicity wrt pmd.
- pte_alloc_map() and pte_alloc_map_lock() are redefined using
pte_alloc().
[sudeep.holla@arm.com: fix build for arm64 hugetlbpage]
[sfr@canb.auug.org.au: fix arch/arm/mm/mmu.c some more]
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Set IORESOURCE_SYSTEM_RAM in flags of resource ranges with
"System RAM", "Kernel code", "Kernel data", and "Kernel bss".
Note that:
- IORESOURCE_SYSRAM (i.e. modifier bit) is set in flags when
IORESOURCE_MEM is already set. IORESOURCE_SYSTEM_RAM is defined
as (IORESOURCE_MEM|IORESOURCE_SYSRAM).
- Some archs do not set 'flags' for children nodes, such as
"Kernel code". This patch does not change 'flags' in this
case.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: linux-mips@linux-mips.org
Cc: linux-mm <linux-mm@kvack.org>
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/1453841853-11383-7-git-send-email-bp@alien8.de
PA-RISC doesn't have atomic instructions to modify page table entries, so it
takes spinlock in the TLB handler and modifies the page table entry
non-atomically. If you modify the page table entry without the spinlock, you
may race with TLB handler on another CPU and your modification may be lost.
Protect against that with usage of purge_tlb_start() and purge_tlb_end() which
handles the TLB spinlock.
Cc: stable@vger.kernel.org # v4.4
Pull parisc update from Helge Deller:
"This patchset adds Huge Page and HUGETLBFS support for parisc"
Honestly, the hugepage support should have gone through in the merge
window, and is not really an rc-time fix. But it only touches
arch/parisc, and I cannot find it in myself to care. If one of the
three parisc users notices a breakage, I will point at Helge and make
rude farting noises.
* 'parisc-4.4-2' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Map kernel text and data on huge pages
parisc: Add Huge Page and HUGETLBFS support
parisc: Use long branch to do_syscall_trace_exit
parisc: Increase initial kernel mapping to 32MB on 64bit kernel
parisc: Initialize the fault vector earlier in the boot process.
parisc: Add defines for Huge page support
parisc: Drop unused MADV_xxxK_PAGES flags from asm/mman.h
parisc: Drop definition of start_thread_som for HP-UX SOM binaries
parisc: Fix wrong comment regarding first pmd entry flags
Adjust the linker script and map_pages() to map kernel text and data on
physical 1MB huge/large pages.
This patch adds huge page support to allow userspace to allocate huge
pages and to use hugetlbfs filesystem on 32- and 64-bit Linux kernels.
A later patch will add kernel support to map kernel text and data on
huge pages.
The only requirement is, that the kernel needs to be compiled for a
PA8X00 CPU (PA2.0 architecture). Older PA1.X CPUs do not support
variable page sizes. 64bit Kernels are compiled for PA2.0 by default.
Technically on parisc multiple physical huge pages may be needed to
emulate standard 2MB huge pages.
This patch fixes some bugs and partly cleans up the parisc uapi header
files to what glibc defined:
- compat_semid64_ds was wrong and did not take the endianess into
account
- ipc64_perm exported userspace types which broke building userspace
packages on debian (e.g. trinity)
- ipc64_perm needs to use a 32bit mode_t on 64bit kernel
- msqid64_ds and semid64_ds needs unsigned longs for various struct members
- shmid64_ds exported size_t instead of __kernel_size_t
And finally add some compile-time checks for the sizes of those structs
to avoid future breakage.
Runtime-tested with the Linux Test Project (LTP) testsuite.
Cc: <stable@vger.kernel.org> # 3.18+
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Craig Estey noticed that we didn't checked for in_atomic() in our page fault
handler like other architectures. This commit adds this check by using
faulthandler_disabled() which includes a check for pagefault_disabled() and
in_atomic().
Reported-by: Craig Estey <cae370@gmail.com>
the handler
Introduce faulthandler_disabled() and use it to check for irq context and
disabled pagefaults (via pagefault_disable()) in the pagefault handlers.
Please note that we keep the in_atomic() checks in place - to detect
whether in irq context (in which case preemption is always properly
disabled).
In contrast, preempt_disable() should never be used to disable pagefaults.
With !CONFIG_PREEMPT_COUNT, preempt_disable() doesn't modify the preempt
counter, and therefore the result of in_atomic() differs.
We validate that condition by using might_fault() checks when calling
might_sleep().
Therefore, add a comment to faulthandler_disabled(), describing why this
is needed.
faulthandler_disabled() and pagefault_disable() are defined in
linux/uaccess.h, so let's properly add that include to all relevant files.
This patch is based on a patch from Thomas Gleixner.
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: schwidefsky@de.ibm.com
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-7-git-send-email-dahi@linux.vnet.ibm.com
We would want to use number of page table level to define mm_struct.
Let's expose it as CONFIG_PGTABLE_LEVELS.
Tested-by: Guenter Roeck <linux@roeck-us.net>
Drop code to create HP-UX gateway page and syscall entry code.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
alloc_bootmem and related function always return zeroed region of
memory. Thus a memset after calls to these functions is unnecessary.
The following Coccinelle semantic patch was used for making the change:
expression E,E1;
E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...)
... when != E
- memset(E,0,E1);
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Pull parisc fixes from Helge Deller:
"There are two patches in here:
The first patch greatly improves latency and corrects the memory
ordering in our light-weight atomic locking syscall.
The second patch ratelimits printing of userspace segfaults in the
same way as it's done on other platforms. This fixes a possible DOS
on parisc since it prevents the syslog to grow too fast. For example,
when the debian acl2 package was built on our debian buildd servers,
this package produced lots of gigabytes in syslog in very short time
and thus filled our harddisks, which then turned the server nearly
completely unaccessible and unresponsive"
* 'parisc-3.15-4' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Improve LWS-CAS performance
parisc: ratelimit userspace segfault printing
Ratelimit printing of userspace segfaults and make it runtime
configurable via the /proc/sys/debug/exception-trace variable. This
should resolve syslog from growing way too fast and thus prevents
possible system service attacks.
Cc: stable@vger.kernel.org # 3.13+
Convert to the use of this_cpu_ptr().
Signed-off-by: Christoph Lameter <cl@linux.com>
Commit 4b59e6c47309 ("mm, show_mem: suppress page counts in
non-blockable contexts") introduced SHOW_MEM_FILTER_PAGE_COUNT to
suppress PFN walks on large memory machines. Commit c78e93630d15 ("mm:
do not walk all of system memory during show_mem") avoided a PFN walk in
the generic show_mem helper which removes the requirement for
SHOW_MEM_FILTER_PAGE_COUNT in that case.
This patch removes PFN walkers from the arch-specific implementations
that report on a per-node or per-zone granularity. ARM and unicore32
still do a PFN walk as they report memory usage on each bank which is a
much finer granularity where the debugging information may still be of
use. As the remaining arches doing PFN walks have relatively small
amounts of memory, this patch simply removes SHOW_MEM_FILTER_PAGE_COUNT.
[akpm@linux-foundation.org: fix parisc]
Acked-by: David Rientjes <rientjes@google.com>
Cc: James Bottomley <jejb@parisc-linux.org>
When building a 64bit kernel sometimes functions in the .init section were not
able to reach the standard kernel function. Main reason for this problem is,
that the linkage tables (.plt, .opd, .dlt) tend to become pretty huge and thus
the distance gets too big for short calls.
One option to avoid this is to use the -mlong-calls compiler option, but this
increases the binary size and introduces a performance penalty.
Instead, with this patch we just lay out the binary differently. Init code is
stored first, followed by text, R/O and finally R/W data. This means, that init
and text code is now much closer to each other, which is sufficient to reach
each other by short calls.
This patch fixes most of the Linux Test Project testcases, e.g. fstat05.
Clean up code to send correct signal on invalid memory accesses:
Send SIGBUS instead of SIGSEGV for memory accesses outside of mmap'ed
areas
This fixes the mmap13 testcase from the Linux Test Project.
Provide a macro ASM_EXCEPTIONTABLE_ENTRY() to create exception table
entries and convert all open-coded places to use that macro.
This patch is a first step toward creating a exception table which only
holds 32bit pointers even on a 64bit kernel. That way in my own kernel
I was able to reduce the in-kernel exception table from 44kB to 22kB.
The attached change defers the initialization of the variables tsk, mm
and flags until they are needed. As a result, the code won't crash if a
kernel probe is done with a corrupt context and the code will be better
optimized.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
The FAULT_FLAG_WRITE flag has been set based on uninitialized variable.
Fixes a regression added by commit 759496ba6407 ("arch: mm: pass
userspace fault flag to generic fault handler")
Signed-off-by: Felipe Pena <felipensp@gmail.com>
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
