path: root/arch/parisc
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Generic ioremap_page_range: parisc conversionHaavard Skinnemoen
Convert parisc to use generic ioremap_page_range() Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] LOG2: Implement a general integer log2 facility in the kernelDavid Howells
This facility provides three entry points: ilog2() Log base 2 of unsigned long ilog2_u32() Log base 2 of u32 ilog2_u64() Log base 2 of u64 These facilities can either be used inside functions on dynamic data: int do_something(long q) { ...; y = ilog2(x) ...; } Or can be used to statically initialise global variables with constant values: unsigned n = ilog2(27); When performing static initialisation, the compiler will report "error: initializer element is not constant" if asked to take a log of zero or of something not reducible to a constant. They treat negative numbers as unsigned. When not dealing with a constant, they fall back to using fls() which permits them to use arch-specific log calculation instructions - such as BSR on x86/x86_64 or SCAN on FRV - if available. [akpm@osdl.org: MMC fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Howells <dhowells@redhat.com> Cc: Wojtek Kaniewski <wojtekka@toxygen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert pariscJosef Sipek
2006-12-07[PATCH] elf: Always define elf_addr_t in linux/elf.hMagnus Damm
Define elf_addr_t in linux/elf.h. The size of the type is determined using ELF_CLASS. This allows us to remove the defines that today are spread all over .c and .h files. Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Cc: Daniel Jacobowitz <drow@false.org> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] mm: arch do_page_fault() vs in_atomic()Peter Zijlstra
In light of the recent pagefault and filemap_copy_from_user work I've gone through all the arch pagefault handlers to make sure the inc_preempt_count() 'feature' works as expected. Several sections of code (including the new filemap_copy_from_user) rely on the fact that faults do not take locks under increased preempt count. arch/x86_64 - good arch/powerpc - good arch/cris - fixed arch/i386 - good arch/parisc - fixed arch/sh - good arch/sparc - good arch/s390 - good arch/m68k - fixed arch/ppc - good arch/alpha - fixed arch/mips - good arch/sparc64 - good arch/ia64 - good arch/arm - fixed arch/um - good arch/avr32 - good arch/h8300 - NA arch/m32r - good arch/v850 - good arch/frv - fixed arch/m68knommu - NA arch/arm26 - fixed arch/sh64 - fixed arch/xtensa - good Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[NET]: PARISC checksum annotations and cleanups.Al Viro
* sanitized prototypes, annotated * kill shift-by-16 in checksum calculation Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-27[PATCH] vmlinux.lds: consolidate initcall sectionsAndrew Morton
Add a vmlinux.lds.h helper macro for defining the eight-level initcall table, teach all the architectures to use it. This is a prerequisite for a patch which performs initcall synchronisation for multithreaded-probing. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> [ Added AVR32 as well ] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] remove bogus arch-specific syscall exportsAl Viro
2006-10-07[PARISC] More pt_regs removalMatthew Wilcox
Remove pt_regs from ipi_interrupt and timer_interrupt. Inline smp_do_timer() into its only caller, and unify the SMP and non-SMP paths. Fixes a profiling bug. Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-07[PARISC] Make firmware calls irqsafe-ish...Kyle McMartin
There's no reason why we shouldn't be using _irqsave instead of _irq for any of these calls. fwiw, this fixes the "start_kernel(): bug: interrupts were enabled early" message displayed on bootup recently. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-07[PA-RISC] Fix boot breakageMatthew Wilcox
Conditionals were the wrong way around. Turns out I was booting the wrong kernel when testing the original fix. Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-07[PARISC] Use set_irq_regsMatthew Wilcox
Actually set the irq_regs pointer. Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-06Build fixes for struct pt_regs removalMatthew Wilcox
2006-10-05[PA-RISC] Fix time.c for new do_timer() calling conventionMatthew Wilcox
do_timer now wants to know how many ticks have elapsed. Now that we have to calculate that, we can eliminate some of the clever code that avoided having to calculate that. Also add some more documentation. I'd like to thank Grant Grundler for helping me with this. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
2006-10-05[PA-RISC] Fix must_check warnings in drivers.cMatthew Wilcox
Panic if we can't register the parisc bus or the root parisc device. There's no way we can boot without them, so let the user know ASAP. If we can't register a parisc device, handle the failure gracefully. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
2006-10-05[PA-RISC] Fix parisc_newuname()Matthew Wilcox
The utsname virtualisation broke parisc_newuname compilation. Rewrite the implementation to call sys_newuname() like sparc64 does. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
2006-10-05[PA-RISC] Remove warning from pci.cMatthew Wilcox
max() doesn't like comparing an unsigned long and a resource_size_t, so make the local variables resource_size_t too. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
2006-10-05[PA-RISC] Fix filldir warningsMatthew Wilcox
filldir_t now takes a u64, not an ino_t. Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-05[PA-RISC] Fix sys32_sysctlMatthew Wilcox
When CONFIG_SYSCTL_SYSCALL isn't defined, do_sysctl doesn't exist and we fail to link. Fix with an ifdef, the same way sparc64 did. Also add some minor changes to be more like sparc64. Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/confighLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/configh: Remove all inclusions of <linux/config.h> Manually resolved trivial path conflicts due to removed files in the sound/oss/ subdirectory.
2006-10-04[PARISC] Kill wall_jiffies useAndrew Morton
wall_jiffies and jiffies are now equal, so this is a noop... Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Honour "panic_on_oops" sysctlHelge Deller
Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Export clear_user_page to modulesMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Fix CONFIG_DEBUG_SPINLOCKMatthew Wilcox
Joel Soete points out that we refer to pa_tlb_lock but only define it if CONFIG_SMP which breaks a uniprocessor build with CONFIG_DEBUG_SPINLOCK enabled. No module refers to pa_tlb_lock, so we can delete the export. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Fix HPUX compat compile with current GCCMatthew Wilcox
GCC no longer allows a cast as lvalue; fix the same way fs/readdir.c was Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Fix iounmap compile warningMatthew Wilcox
iounmap's argument needs to be both const and volatile, otherwise we'll get warnings that we're discarding pointer qualifiers Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Add hardware found in the rp8400Matthew Wilcox
2006-10-04[PARISC] Allow nested interruptsJames Bottomley
Our prior mode of operation didn't allow nested interrupts because it makes the interrupt code much simpler. However, nested interrupts are better for latency. This code uses the EIEM register to simulate level interrupts and thus achieve nesting. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Further updates to timer_interrupt()Grant Grundler
This version (relative to the current tree): o eliminates "while (ticks_elapsed)" loop. It's not needed. o drop "ticks_elapsed" completely from timer_interrupt(). o Estimates elapsed cycles (based on HZ) to see which kind of math we want to use to calculate "cycles_remainder". o Fixes a bug where we would loose a tick if we decided we wanted to skip one interrupt. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] remove halftick and copy clocktick to local var (gcc can optimize ↵Grant Grundler
usage) Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Rewrite timer_interrupt() and gettimeoffset() using "unsigned" math.Grant Grundler
It's just a bit easier to follow and timer code is complex enough. So far, only tested on A500-5x (64-bit SMP), ie: gettimeoffset() code hasn't been tested at all. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Add new function to start local Interval Timer, start_cpu_itimer()Grant Grundler
I couldn't find where the itimer was getting started for slave CPUs. CPU 0 (master) itimer was started in time_init() (arch/parisc/kernel/time.c). start_cpu_itimer() code was striped from time_init(). Slaves now start their itimer in smp_cpu_init(). This is a first step towards making gettimeoffset() work for SMP. Next step will be to determine the CR16 (cycle counter) offsets for each CPU relative to the master (CPU 0). Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Prevent processor_probe() from clobbering cpu_data[0]Grant Grundler
processor_probe() shouldn't clobber cpu_data[0] cpu_data[0].it_value (used by timer_interrupt()) is already set. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] [BUGFIX] nullify branch delay slot of the jump back toKyle McMartin
intr_restore in intr_do_preempt. This prevents the execution of an unwanted insn... Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Allow overriding personality with sys_personalityKyle McMartin
And now suddenly, linux32 works on parisc... Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Switch is_compat_task to use TIF_32BITKyle McMartin
Stop using PER_LINUX32 to designate processes needing compaterizing. Convert is_compat_task to use TIF_32BIT and set TIF_32BIT in binfmt_elf32.c Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] parisc specific kmap API implementation for pa8800James Bottomley
This patch fixes the pa8800 at a gross level (there are still other subtle incoherency issues which can still cause crashes and HPMCs). What it does is try to force eject inequivalent aliases before they become visible to the L2 cache (which is where we get the incoherence problems). A new function (parisc_requires_coherency) is introduced in asm/processor.h to identify the pa8x00 processors (8800 and 8900) which have the issue. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Fix up parisc irq handling for genirq changesKyle McMartin
Clean up enough to get things compiling again in the interim. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Abstract shift register left in .SKyle McMartin
Abstract existing shift register left macros as shift register right are. This lends itself to a nice clean up of some #ifdef blocks in entry.S Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Remove variables decls duplicated from asm-generic/sections.hKyle McMartin
2006-10-04[PARISC] PA7200 also supports prefetch for readKyle McMartin
It seems PA7200 processors also suppress traps on loads to %r0. This means we can prefetch for read on these cpus. Of course, we can't support prefetch for write, since that requires LOAD DOUBLEWORD which was added with PA2.0 Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-10-03Attack of "the the"s in archMatt LaPlante
The patch below corrects multiple occurances of "the the" typos across several files, both in source comments and KConfig files. There is no actual code changed, only text. Note this only affects the /arch directory, and I believe I could find many more elsewhere. :) Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] rename the provided execve functions to kernel_execveArnd Bergmann
Some architectures provide an execve function that does not set errno, but instead returns the result code directly. Rename these to kernel_execve to get the right semantics there. Moreover, there is no reasone for any of these architectures to still provide __KERNEL_SYSCALLS__ or _syscallN macros, so remove these right away. [akpm@osdl.org: build fix] [bunk@stusta.de: build fix] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: switch to using uts namespacesSerge E. Hallyn
Replace references to system_utsname to the per-process uts namespace where appropriate. This includes things like uname. Changes: Per Eric Biederman's comments, use the per-process uts namespace for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c [jdike@addtoit.com: UML fix] [clg@fr.ibm.com: cleanup] [akpm@osdl.org: build fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] nsproxy: move init_nsproxy into kernel/nsproxy.cSerge E. Hallyn
Move the init_nsproxy definition out of arch/ into kernel/nsproxy.c. This avoids all arches having to be updated. Compiles and boots on s390. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: add nsproxySerge E. Hallyn
This patch adds a nsproxy structure to the task struct. Later patches will move the fs namespace pointer into this structure, and introduce a new utsname namespace into the nsproxy. The vserver and openvz functionality, then, would be implemented in large part by virtualizing/isolating more and more resources into namespaces, each contained in the nsproxy. [akpm@osdl.org: build fix] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] kill wall_jiffiesAtsushi Nemoto
With 2.6.18-rc4-mm2, now wall_jiffies will always be the same as jiffies. So we can kill wall_jiffies completely. This is just a cleanup and logically should not change any real behavior except for one thing: RTC updating code in (old) ppc and xtensa use a condition "jiffies - wall_jiffies == 1". This condition is never met so I suppose it is just a bug. I just remove that condition only instead of kill the whole "if" block. [heiko.carstens@de.ibm.com: s390 build fix and cleanup] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
