path: root/arch/parisc
2010-08-10parisc: pass through '\t' to early (iodc) consoleKyle McMartin
commit d9b68e5e88248bb24fd4e455588bea1d56108fd6 upstream. The firmware handles '\t' internally, so stop trying to emulate it (which, incidentally, had a bug in it.) Fixes a really weird hang at bootup in rcu_bootup_announce, which, as far as I can tell, is the first printk in the core kernel to use a tab as the first character. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05parisc: clear floating point exception flag on SIGFPE signalHelge Deller
commit 550f0d922286556c7ea43974bb7921effb5a5278 upstream. Clear the floating point exception flag before returning to user space. This is needed, else the libc trampoline handler may hit the same SIGFPE again while building up a trampoline to a signal handler. Fixes debian bug #559406. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26Revert "parisc: Set PCI CLS early in boot."Greg Kroah-Hartman
This reverts the following patch, which shouldn't have been applied to the .32 stable tree as it causes problems. commit 5fd4514bb351b5ecb0da3692fff70741e5ed200c upstream. Set the PCI CLS early in the boot process to prevent device failures. In pcibios_set_master use the new pci_cache_line_size instead of a hard-coded value. Signed-off-by: Carlos O'Donell <carlos@codesourcery.com> Reviewed-by: Grant Grundler <grundler@google.com> Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12parisc: Set PCI CLS early in boot.Carlos O'Donell
2010-01-18untangle the do_mremap() messAl Viro
This backports the following upstream commits all as one patch: 54f5de709984bae0d31d823ff03de755f9dcac54 ecc1a8993751de4e82eb18640d631dae1f626bd6 1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f f106af4e90eadd76cfc0b5325f659619e08fb762 097eed103862f9c6a97f2e415e21d1134017b135 935874141df839c706cd6cdc438e85eb69d1525e 0ec62d290912bb4b989be7563851bc364ec73b56 c4caa778157dbbf04116f0ac2111e389b5cd7a29 2ea1d13f64efdf49319e86c87d9ba38c30902782 570dcf2c15463842e384eb597a87c1e39bead99b 564b3bffc619dcbdd160de597b0547a7017ea010 0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301 f8b7256096a20436f6d0926747e3ac3d64c81d24 8c7b49b3ecd48923eb64ff57e07a1cdb74782970 9206de95b1ea68357996ec02be5db0638a0de2c1 2c6a10161d0b5fc047b5bd81b03693b9af99fab5 05d72faa6d13c9d857478a5d35c85db9adada685 bb52d6694002b9d632bb355f64daa045c6293a4e e77414e0aad6a1b063ba5e5750c582c75327ea6a aa65607373a4daf2010e8c3867b6317619f3c1a3 Backport done by Greg Kroah-Hartman. Only minor tweaks were needed. Cc: David S. Miller <davem@davemloft.net> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-30parisc: fix unwind with recent gcc versionsHelge Deller
kernel unwinding is broken with gcc >= 4.x. Part of the problem is that binutils seems very sensitive to where the unwind information is stored. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-17fcntl: Use consistent values for F_[GS]ETOWN_EXStephen Rothwell
These values were only introduced during this release cycle, so it is still early enough to get them right. alpha uses the same values that are in asm-generic/fcntl.h, so just remove them. parisc uses the values interchanged for no apparent reason, so remove them to give us consistency across all architectures. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-28parisc: Fix linker script breakage.Helge Deller
2009-09-28parisc: convert to asm-generic/hardirq.hChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: Make THREAD_SIZE available to assembly files and linker scripts.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: correct use of SHF_ALLOCJulia Lawall
SHF_ALLOC is suitable for testing against the sh_flags field, not the sh_type field. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: rename parisc's vmalloc_start to parisc_vmalloc_startHelge Deller
building kernel 2.6.32(pre), gives this compiler warning: /linus-linux-2.6/mm/vmalloc.c: In function 'pcpu_get_vm_areas': /linus-linux-2.6/mm/vmalloc.c:2104: warning: 'vmalloc_start' is used uninitialized in this function The reason is, that the code in mm/vmalloc defines a local variable called vmalloc_start, which is already defined as global variable in parisc's code. To avoid this kind of problems in future, I suggest to rename the parisc variable to parisc_vmalloc_start. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: includecheck fix: signal.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: arch/parisc/kernel/signal.c: linux/compat.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: HAVE_ARCH_TRACEHOOKKyle McMartin
Let 'er rip. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: add skeleton syscall.hKyle McMartin
Needed for lib/syscall.c when HAVE_ARCH_TRACEHOOK. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: stop using task->ptrace for {single,block}step flagsKyle McMartin
task->ptrace flags belong to generic code, so instead thief some TIF_ bits to use. Somewhat risky conversion of code to test TASK_FLAGS instead of TASK_PTRACE in assembly, but it looks alright in the end. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: split syscall_trace into two halvesKyle McMartin
Instead of fiddling with gr[20], restructure code to return whether or not to -ENOSYS. (Also do a bit of fiddling to let them take pt_regs directly instead of re-computing it.) Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: add missing TI_TASK macro in syscall.SKyle McMartin
LDREG 0(%r1),%r1 really wants to be accessing thread_info.task, instead of hardcoding the 0. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: tracehook_signal_handlerKyle McMartin
This makes parisc call the standard tracehook_signal_handler hook in <linux/tracehook.h> after setting up a signal handler. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-27parisc: tracehook_report_syscallKyle McMartin
This makes parisc use the standard tracehook_report_syscall_entry and tracehook_report_syscall_exit hooks in <linux/tracehook.h>. To do this, we need to access current->thread.regs, and to know whether we're entering or exiting the syscall, so add this to syscall_trace. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-24parisc: Remove useless altinstructions code copied from x86.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: linux-parisc@vger.kernel.org Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24parisc: Clean up linker script using new linker script macros.Tim Abbott
This patch has the (likely harmless) side effect of moving .data.init_task inside the _edata. It also changes the alignment of .data.init_task from 16384 to THREAD_SIZE, which can in some configurations be larger than 16384. I believe that this change fixes a potential bug on those configurations. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: linux-parisc@vger.kernel.org Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24fcntl: add F_[SG]ETOWN_EXPeter Zijlstra
In order to direct the SIGIO signal to a particular thread of a multi-threaded application we cannot, like suggested by the manpage, put a TID into the regular fcntl(F_SETOWN) call. It will still be send to the whole process of which that thread is part. Since people do want to properly direct SIGIO we introduce F_SETOWN_EX. The need to direct SIGIO comes from self-monitoring profiling such as with perf-counters. Perf-counters uses SIGIO to notify that new sample data is available. If the signal is delivered to the same task that generated the new sample it can augment that data by inspecting the task's user-space state right after it returns from the kernel. This is esp. convenient for interpreted or virtual machine driven environments. Both F_SETOWN_EX and F_GETOWN_EX take a pointer to a struct f_owner_ex as argument: struct f_owner_ex { int type; pid_t pid; }; Where type is one of F_OWNER_TID, F_OWNER_PID or F_OWNER_GID. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Tested-by: stephane eranian <eranian@googlemail.com> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Roland McGrath <roland@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cpumask: remove arch_send_call_function_ipiRusty Russell
Now everyone is converted to arch_send_call_function_ipi_mask, remove the shim and the #defines. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-22mm: add MAP_HUGETLB for mmaping pseudo-anonymous huge page regionsArnd Bergmann
Add a flag for mmap that will be used to request a huge page region that will look like anonymous memory to user space. This is accomplished by using a file on the internal vfsmount. MAP_HUGETLB is a modifier of MAP_ANONYMOUS and so must be specified with it. The region will behave the same as a MAP_ANONYMOUS region using small pages. The patch also adds the MAP_STACK flag, which was previously defined only on some architectures but not on others. Since MAP_STACK is meant to be a hint only, architectures can define it without assigning a specific meaning to it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: David Rientjes <rientjes@google.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: define MADV_MERGEABLE and MADV_UNMERGEABLEHugh Dickins
The out-of-tree KSM used ioctls on fds cloned from /dev/ksm to register a memory area for merging: we prefer now to use an madvise(2) interface. This patch just defines MADV_MERGEABLE (to tell KSM it may merge pages in this area found identical to pages in other mergeable areas) and MADV_UNMERGEABLE (to undo that). Most architectures use asm-generic, but alpha, mips, parisc, xtensa need their own definitions: included here for mmotm convenience, but we'll probably want to split this and feed pieces to arch maintainers. Based upon earlier patches by Chris Wright and Izik Eidus. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Izik Eidus <ieidus@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: Chris Zankel <chris@zankel.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: use INSTALLKERNEL to select customized installkernel scriptSam Ravnborg
Replace the use of CROSS_COMPILE to select a customized installkernel script with the possibility to set INSTALLKERNEL to select a custom installkernel script when running make: make INSTALLKERNEL=arm-installkernel install With this patch we are now more consistent across different architectures - they did not all support use of CROSS_COMPILE. The use of CROSS_COMPILE was a hack as this really belongs to gcc/binutils and the installkernel script does not change just because we change toolchain. The use of CROSS_COMPILE caused troubles with an upcoming patch that saves CROSS_COMPILE when a kernel is built - it would no longer be installable. [Thanks to Peter Z. for this hint] This patch undos what Ian did in commit: 0f8e2d62fa04441cd12c08ce521e84e5bd3f8a46 ("use ${CROSS_COMPILE}installkernel in arch/*/boot/install.sh") The patch has been lightly tested on x86 only - but all changes looks obvious. Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Russell King <linux@arm.linux.org.uk> [arm] Acked-by: Paul Mundt <lethal@linux-sh.org> [sh] Acked-by: "H. Peter Anvin" <hpa@zytor.com> [x86] Cc: Ian Campbell <icampbell@arcom.com> Cc: Tony Luck <tony.luck@intel.com> [ia64] Cc: Fenghua Yu <fenghua.yu@intel.com> [ia64] Cc: Hirokazu Takata <takata@linux-m32r.org> [m32r] Cc: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Cc: Kyle McMartin <kyle@mcmartin.ca> [parisc] Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc] Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Cc: Thomas Gleixner <tglx@linutronix.de> [x86] Cc: Ingo Molnar <mingo@redhat.com> [x86] Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits) PCI hotplug: clean up acpi_run_hpp() PCI hotplug: acpiphp: use generic pci_configure_slot() PCI hotplug: shpchp: use generic pci_configure_slot() PCI hotplug: pciehp: use generic pci_configure_slot() PCI hotplug: add pci_configure_slot() PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation PCI: Clear saved_state after the state has been restored PCI PM: Return error codes from pci_pm_resume() PCI: use dev_printk in quirk messages PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset() PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle PCI Hotplug: acpiphp: find bridges the easy way PCI: pcie portdrv: remove unused variable PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support ACPI PM: Replace wakeup.prepared with reference counter PCI PM: Introduce device flag wakeup_prepared PCI / ACPI PM: Rework some debug messages PCI PM: Simplify PCI wake-up code ... Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree scanning having been moved and merged for the 32- and 64-bit cases. The 'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-15Merge branch 'agp-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: agp/intel: remove restore in resume agp: fix uninorth build intel-agp: Set dma mask for i915 agp: kill phys_to_gart() and gart_to_phys() intel-agp: fix sglist allocation to avoid vmalloc() intel-agp: Move repeated sglist free into separate function agp: Switch agp_{un,}map_page() to take struct page * argument agp: tidy up handling of scratch pages w.r.t. DMA API intel_agp: Use PCI DMA API correctly on chipsets new enough to have IOMMU agp: Add generic support for graphics dma remapping agp: Switch mask_memory() method to take address argument again, not page
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-11Merge branch 'next' into for-linusJames Morris
2009-09-09PCI: remove pcibios_scan_all_fns()Alex Chiang
This was #define'd as 0 on all platforms, so let's get rid of it. This change makes pci_scan_slot() slightly easier to read. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09KEYS: Add missing linux/tracehook.h #inclusionsDavid Howells
Add #inclusions of linux/tracehook.h to those arch files that had the tracehook call for TIF_NOTIFY_RESUME added when support for that flag was added to that arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]David Howells
Implement TIF_NOTIFY_RESUME for most of those architectures in which isn't yet available, and, whilst we're at it, have it call the appropriate tracehook. After this patch, blackfin, m68k* and xtensa still lack support and need alteration of assembly code to make it work. Resume notification can then be used (by a later patch) to install a new session keyring on the parent of a process. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> cc: linux-arch@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2009-08-28parisc: fix warning in traps.cGrant Grundler
On Tue, Aug 18, 2009 at 01:45:17PM -0400, John David Anglin wrote: > CC arch/parisc/kernel/traps.o > arch/parisc/kernel/traps.c: In function 'handle_interruption': > arch/parisc/kernel/traps.c:535:18: warning: operation on 'regs->iasq[0]' > may be undefined Yes - Line 535 should use both [0] and [1]. Reported-by: John David Anglin <dave@hiauly1.hia.nrc.ca> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-05net: implement a SO_DOMAIN getsockoptionJan Engelhardt
This sockopt goes in line with SO_TYPE and SO_PROTOCOL. It makes it possible for userspace programs to pass around file descriptors — I am referring to arguments-to-functions, but it may even work for the fd passing over UNIX sockets — without needing to also pass the auxiliary information (PF_INET6/IPPROTO_TCP). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: implement a SO_PROTOCOL getsockoptionJan Engelhardt
Similar to SO_TYPE returning the socket type, SO_PROTOCOL allows to retrieve the protocol used with a given socket. I am not quite sure why we have that-many copies of socket.h, and why the values are not the same on all arches either, but for where hex numbers dominate, I use 0x1029 for SO_PROTOCOL as that seems to be the next free unused number across a bunch of operating systems, or so Google results make me want to believe. SO_PROTOCOL for others just uses the next free Linux number, 38. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05Merge git://git.infradead.org/~dwmw2/iommu-agp into agp-nextDave Airlie
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-02parisc: Set correct bit in protection flagsJohn David Anglin
Signed-off-by: John David Anglin <dave@hiauly1.hia.nrc.ca> Signed-off-by: Helge Deller <deller@gmx.de>
