path: root/arch/parisc
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-28Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: add tty driver to PDC console drivers/parisc/iosapic.c: Remove unnecessary kzalloc cast parisc: remove homegrown L1_CACHE_ALIGN macro arch/parisc: Removing undead ifdef CONFIG_PA20 parisc: unwind - optimise linked-list searches for modules parisc: change to new flag variable drivers/char/agp/parisc-agp.c: eliminate memory leak parisc: kill __do_IRQ parisc: convert eisa interrupts to flow handlers parisc: convert gsc and dino pci interrupts to flow handlers parisc: convert suckyio interrupts to flow handlers parisc: convert iosapic interrupts to proper flow handlers parisc: convert cpu interrupts to proper flow handlers parisc: lay groundwork for killing __do_IRQ parisc: add prlimit64 syscall parisc: squelch warning when using dev_get_stats
2010-10-28parisc: fix compile failure with kmap_atomic changesJames Bottomley
Commit 3e4d3af501cc ("mm: stack based kmap_atomic()") overlooked the fact that parisc uses kmap as a coherence mechanism, so even though we have no highmem, we do need to supply our own versions of kmap (and atomic). This patch converts the parisc kmap to the form which is needed to keep it compiling (it's a simple prototype and name change). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Acked-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: cleanup arch_ptrace() on pariscNamhyung Kim
Add missing __user markup on the argument of put_user(). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: introduce CONFIG_BKL. dabusb: remove the BKL sunrpc: remove the big kernel lock init/main.c: remove BKL notations blktrace: remove the big kernel lock rtmutex-tester: make it build without BKL dvb-core: kill the big kernel lock dvb/bt8xx: kill the big kernel lock tlclk: remove big kernel lock fix rawctl compat ioctls breakage on amd64 and itanic uml: kill big kernel lock parisc: remove big kernel lock cris: autoconvert trivial BKL users alpha: kill big kernel lock isapnp: BKL removal s390/block: kill the big kernel lock hpet: kill BKL, add compat_ioctl
2010-10-21parisc: add tty driver to PDC consoleGuy Martin
This patch adds a tty driver to the PDC console. It allows the use of ports not supported by linux as a console (e.g. serial port on C8000.) The tty driver will not register the ttyB device if PDC console driver has been unregistered. This happens when the early printk console is disabled as it has not been selected as the primary console. Signed-off-by: Guy Martin <gmsoft@tuxicoman.be> Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-21parisc: remove homegrown L1_CACHE_ALIGN macroFUJITA Tomonori
Let's use the standard L1_CACHE_ALIGN macro instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-21arch/parisc: Removing undead ifdef CONFIG_PA20Christian Dietrich
The CONFIG_PA20 ifdef isn't necessary at this point, because it is checked in an outer ifdef level already and has no effect here. Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de> Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-21parisc: unwind - optimise linked-list searches for modulesPhil Carmody
Having many dozens of modules, the searches down the linked list of sections would dominate the lookup time, dwarfing any savings from the binary search within the section. A simple move-to-front optimisation exploits the commonality of the code paths taken, and in simple real-world tests on other architectures reduced the number of steps in the search to barely more than 1. Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-21parisc: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflagsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags: Fix IRQ flag handling naming MIPS: Add missing #inclusions of <linux/irq.h> smc91x: Add missing #inclusion of <linux/irq.h> Drop a couple of unnecessary asm/system.h inclusions SH: Add missing consts to sys_execve() declaration Blackfin: Rename IRQ flags handling functions Blackfin: Add missing dep to asm/irqflags.h Blackfin: Rename DES PC2() symbol to avoid collision Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header Blackfin: Split PLL code from mach-specific cdef headers
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-16parisc: remove big kernel lockArnd Bergmann
The parisc version of the perf code is sufficiently protected by its own spinlock, no need to use the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: linux-parisc@vger.kernel.org
2010-10-14parisc: kill __do_IRQKyle McMartin
2010-10-14parisc: convert iosapic interrupts to proper flow handlersKyle McMartin
Shift the ->end call (cpu eoi) from __do_IRQ into our unmask handler. Also nuke some redundant code. Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-14parisc: convert cpu interrupts to proper flow handlersKyle McMartin
Only major change is renaming functions to match the conventions expected by the generic irq code. Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-14parisc: lay groundwork for killing __do_IRQKyle McMartin
Use proper accessors and handlers for generic irq cleanups. We just call back into __do_IRQ through desc->handler now, and remove the explicit calls. Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-13parisc: add prlimit64 syscallKyle McMartin
2010-10-12Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
We need to revert the temporary hack in 71ebc01, hence the merge.
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-19kbuild: migrate all arch to the kconfig mainmenu upgradeArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-09-14compat: Make compat_alloc_user_space() incorporate the access_ok()H. Peter Anvin
compat_alloc_user_space() expects the caller to independently call access_ok() to verify the returned area. A missing call could introduce problems on some architectures. This patch incorporates the access_ok() check into compat_alloc_user_space() and also adds a sanity check on the length. The existing compat_alloc_user_space() implementations are renamed arch_compat_alloc_user_space() and are used as part of the implementation of the new global function. This patch assumes NULL will cause __get_user()/__put_user() to either fail or access userspace on all architectures. This should be followed by checking the return value of compat_access_user_space() for NULL in the callers, at which time the access_ok() in the callers can also be removed. Reported-by: Ben Hawkes <hawkes@sota.gen.nz> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: <stable@kernel.org>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-14archs: replace unifdef-y with header-ySam Ravnborg
unifdef-y and header-y have same semantic, so drop unifdef-y Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12parisc: fix wrong page aligned size calculation in ioremapping codeFlorian Zumbiehl
parisc __ioremap(): fix off-by-one error in page alignment of allocation size for sizes where size%PAGE_SIZE==1. Signed-off-by: Florian Zumbiehl <florz@florz.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Helge Deller <deller@gmx.de> Tested-by: Helge Deller <deller@gmx.de> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: remove dma_is_consistent APIFUJITA Tomonori
Architectures implement dma_is_consistent() in different ways (some misinterpret the definition of API in DMA-API.txt). So it hasn't been so useful for drivers. We have only one user of the API in tree. Unlikely out-of-tree drivers use the API. Even if we fix dma_is_consistent() in some architectures, it doesn't look useful at all. It was invented long ago for some old systems that can't allocate coherent memory at all. It's better to export only APIs that are definitely necessary for drivers. Let's remove this API. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: parisc: set ARCH_DMA_MINALIGNFUJITA Tomonori
Architectures that handle DMA-non-coherent memory need to set ARCH_DMA_MINALIGN to make sure that kmalloc'ed buffer is DMA-safe: the buffer doesn't share a cache with the others. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: unify dma_get_cache_alignment implementationsFUJITA Tomonori
dma_get_cache_alignment returns the minimum DMA alignment. Architectures defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we can unify dma_get_cache_alignment implementations. Note that some architectures implement dma_get_cache_alignment wrongly. dma_get_cache_alignment() should return the minimum DMA alignment. So fully-coherent architectures should return 1. This patch also fixes this issue. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10tty: Add EXTPROC support for LINEMODEhyc@symas.com
This patch is against the 2.6.34 source. Paraphrased from the 1989 BSD patch by David Borman @ cray.com: These are the changes needed for the kernel to support LINEMODE in the server. There is a new bit in the termios local flag word, EXTPROC. When this bit is set, several aspects of the terminal driver are disabled. Input line editing, character echo, and mapping of signals are all disabled. This allows the telnetd to turn off these functions when in linemode, but still keep track of what state the user wants the terminal to be in. New ioctl: TIOCSIG Generate a signal to processes in the current process group of the pty. There is a new mode for packet driver, the TIOCPKT_IOCTL bit. When packet mode is turned on in the pty, and the EXTPROC bit is set, then whenever the state of the pty is changed, the next read on the master side of the pty will have the TIOCPKT_IOCTL bit set. This allows the process on the server side of the pty to know when the state of the terminal has changed; it can then issue the appropriate ioctl to retrieve the new state. Since the original BSD patches accompanied the source code for telnet I've left that reference here, but obviously the feature is useful for any remote terminal protocol, including ssh. The corresponding feature has existed in the BSD tty driver since 1989. For historical reference, a good copy of the relevant files can be found here: http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741 Signed-off-by: Howard Chu <hyc@symas.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10tty: remove remaining Hayes ESP ioctlsGreg Kroah-Hartman
As Jeff Dike pointed out, the Hayes ESP driver was removed in commit f53a2ade0bb9f2a81f473e6469155172a96b7c38, so these ioctl definitions should also be removed. This cleans up the remaining arch-specific locations of this ioctl value. Thanks to Arnd for pointing these out. Cc: Jeff Dike <jdike@addtoit.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09kmap_atomic: make kunmap_atomic() harder to misuseCesar Eduardo Barros
kunmap_atomic() is currently at level -4 on Rusty's "Hard To Misuse" list[1] ("Follow common convention and you'll get it wrong"), except in some architectures when CONFIG_DEBUG_HIGHMEM is set[2][3]. kunmap() takes a pointer to a struct page; kunmap_atomic(), however, takes takes a pointer to within the page itself. This seems to once in a while trip people up (the convention they are following is the one from kunmap()). Make it much harder to misuse, by moving it to level 9 on Rusty's list[4] ("The compiler/linker won't let you get it wrong"). This is done by refusing to build if the type of its first argument is a pointer to a struct page. The real kunmap_atomic() is renamed to kunmap_atomic_notypecheck() (which is what you would call in case for some strange reason calling it with a pointer to a struct page is not incorrect in your code). The previous version of this patch was compile tested on x86-64. [1] http://ozlabs.org/~rusty/index.cgi/tech/2008-04-01.html [2] In these cases, it is at level 5, "Do it right or it will always break at runtime." [3] At least mips and powerpc look very similar, and sparc also seems to share a common ancestor with both; there seems to be quite some degree of copy-and-paste coding here. The include/asm/highmem.h file for these three archs mention x86 CPUs at its top. [4] http://ozlabs.org/~rusty/index.cgi/tech/2008-03-30.html [5] As an aside, could someone tell me why mn10300 uses unsigned long as the first parameter of kunmap_atomic() instead of void *? Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Russell King <linux@arm.linux.org.uk> (arch/arm) Cc: Ralf Baechle <ralf@linux-mips.org> (arch/mips) Cc: David Howells <dhowells@redhat.com> (arch/frv, arch/mn10300) Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> (arch/mn10300) Cc: Kyle McMartin <kyle@mcmartin.ca> (arch/parisc) Cc: Helge Deller <deller@gmx.de> (arch/parisc) Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> (arch/parisc) Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> (arch/powerpc) Cc: Paul Mackerras <paulus@samba.org> (arch/powerpc) Cc: "David S. Miller" <davem@davemloft.net> (arch/sparc) Cc: Thomas Gleixner <tglx@linutronix.de> (arch/x86) Cc: Ingo Molnar <mingo@redhat.com> (arch/x86) Cc: "H. Peter Anvin" <hpa@zytor.com> (arch/x86) Cc: Arnd Bergmann <arnd@arndb.de> (include/asm-generic) Cc: Rusty Russell <rusty@rustcorp.com.au> ("Hard To Misuse" list) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09pass a struct path to vfs_statfsChristoph Hellwig
We'll need the path to implement the flags field for statvfs support. We do have it available in all callers except: - ecryptfs_statfs. This one doesn't actually need vfs_statfs but just needs to do a caller to the lower filesystem statfs method. - sys_ustat. Add a non-exported statfs_by_dentry helper for it which doesn't won't be able to fill out the flags field later on. In addition rename the helpers for statfs vs fstatfs to do_*statfs instead of the misleading vfs prefix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-07remove needless ISA_DMA_THRESHOLDFUJITA Tomonori
Architectures don't need to define ISA_DMA_THRESHOLD anymore. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: James Bottomley <James.Bottomley@suse.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-08-06Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) sched: Use correct macro to display sched_child_runs_first in /proc/sched_debug sched: No need for bootmem special cases sched: Revert nohz_ratelimit() for now sched: Reduce update_group_power() calls sched: Update rq->clock for nohz balanced cpus sched: Fix spelling of sibling sched, cpuset: Drop __cpuexit from cpu hotplug callbacks sched: Fix the racy usage of thread_group_cputimer() in fastpath_timer_check() sched: run_posix_cpu_timers: Don't check ->exit_state, use lock_task_sighand() sched: thread_group_cputime: Simplify, document the "alive" check sched: Remove the obsolete exit_state/signal hacks sched: task_tick_rt: Remove the obsolete ->signal != NULL check sched: __sched_setscheduler: Read the RLIMIT_RTPRIO value lockless sched: Fix comments to make them DocBook happy sched: Fix fix_small_capacity powerpc: Exclude arch_sd_sibiling_asym_packing() on UP powerpc: Enable asymmetric SMT scheduling on POWER7 sched: Add asymmetric group packing option for sibling domain sched: Fix capacity calculations for SMT4 sched: Change nohz idle load balancing logic to push model ...
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-04parisc: pass through '\t' to early (iodc) consoleKyle McMartin
The firmware handles '\t' internally, so stop trying to emulate it (which, incidentally, had a bug in it.) Fixes a really weird hang at bootup in rcu_bootup_announce, which, as far as I can tell, is the first printk in the core kernel to use a tab as the first character. Cc: stable@kernel.org Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-27time: Kill off CONFIG_GENERIC_TIMEJohn Stultz
Now that all arches have been converted over to use generic time via clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME config option and simplify the generic code. Signed-off-by: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-18Merge commit 'v2.6.35-rc3' into perf/coreIngo Molnar
Merge reason: Go from -rc1 base to -rc3 base, merge in fixes.
2010-06-09arch: Implement local64_tPeter Zijlstra
On 64bit, local_t is of size long, and thus we make local64_t an alias. On 32bit, we fall back to atomic64_t. (architecture can provide optimized 32-bit version) (This new facility is to be used by perf events optimizations.) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-arch@vger.kernel.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09sched_clock: Add local_clock() API and improve documentationPeter Zijlstra
For people who otherwise get to write: cpu_clock(smp_processor_id()), there is now: local_clock(). Also, as per suggestion from Andrew, provide some documentation on the various clock interfaces, and minimize the unsigned long long vs u64 mess. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jens Axboe <jaxboe@fusionio.com> LKML-Reference: <1275052414.1645.52.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
