path: root/arch/powerpc/boot/dts/ep8248e.dts
2008-04-17[POWERPC] ep8248e: Reference SMC parameter RAM base in the device tree.Laurent Pinchart
This patch modifies the Embedded Planet EP8248E device tree to reference the SMC paramater RAM base register instead of the parameter RAM allocated by the boot loader. The cpm_uart driver will allocate parameter RAM itself, making the serial port initialisation independent of the boot loader. The patch adds the parameter RAM allocated by the boot loader in the CPM muram node, making it available to the kernel. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-23[POWERPC] 82xx: Embedded Planet EP8248E supportScott Wood
This board is also resold by Freescale under the names "QUICCStart MPC8248 Evaluation System" and "CWH-PPC-8248N-VE". Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
