path: root/arch/powerpc/boot/dts/kuroboxHG.dts
2008-04-17[POWERPC] fsl: Convert dts to v1 syntaxKumar Gala
2007-12-12[POWERPC] FSL: Added aliases node to device treesKumar Gala
Added aliases nodes for kurobox, 83xx, 85xx, and 86xx platforms. This included added labels and cell-index properties for serial and pci nodes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11[POWERPC] FSL: I2C device tree cleanupsKumar Gala
* Removed device_type = "i2c" * Added missing second I2C controller on MPC8548 CDS, MPC8544 DS * Added #address-cells, #size-cells, and cell-index where missing Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-14[POWERPC] DTS cleanupKumar Gala
Removed the following cruft from .dts files: * 32-bit in cpu node -- doesn't exist in any spec and not used by kernel * removed built-in (chrp legacy) * Removed #interrupt-cells in places they don't need to be set * Fixed ranges on lite5200* * Removed clock-frequency from i8259 pic node, not sure where this came from * Removed big-endian from i8259 pic nodes, this was just bogus Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-14[POWERPC] linkstation updatesGuennadi Liakhovetski
1. Fix RTC type - it is a rs5c372a, not rs5c372b 2. Configure both UART interrupts edge-triggered 3. Add a license header to ls_uart.c 4. Check for running on linkstation in a late_initcall() function. Needed for multiplatform builds, even though linkstation doesn't support them yet 5. Remove unneeded #include from linkstation.c Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-07[POWERPC] Remove dtc build cruft from DTS filesJosh Boyer
The patch below removes the dtc incantation instructions from the in-kernel DTS files. It's not needed, and is prone to being out-of-date most of the time. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: David Gibson <david@gibson.dropbear.id.au>
2007-07-26[POWERPC] Fix RTC and device tree on linkstation machinesGuennadi Liakhovetski
This fixes the RTC on linkstation ppc machines again, and updates the device tree: add rtc nodes on i2c, remove bogus 0-size cache-line declarations, rename interrupt-controller nodes, remove erroneous interrupt-parent line, accidentally introduced by a recent patch. Signed-off-by: G. Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-17[POWERPC] Removed hardcoded phandles from dtsKumar Gala
Remove explicit phandles and move to using references that autogenerate the phandles when needed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-24[POWERPC] Fix comment typo in Kurobox device treeGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-09[POWERPC] Remove unused, undocumented #cpus property from cpus nodeStuart Yoder
The #cpus property is unused and undocumented and is therefore being removed. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-16[POWERPC] Delete boot-cpu property from all DTS filesTimur Tabi
The 'linux,boot-cpu' property is obsolete, so remove it from all of the DTS files and from booting-without-of.txt. The boot CPU is actually defined in the device tree header, and U-Boot sets that field. The device tree compiler also complains if the property exists. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Linkstation / kurobox supportGuennadi Liakhovetski
Support for the Kurobox(HG)/LinkStation-I NAS systems by Buffalo Technology, should be also applicable to the PPC TeraStation family. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
