path: root/arch/powerpc/boot/dts/mpc8272ads.dts
2008-04-17[POWERPC] fsl: Convert dts to v1 syntaxKumar Gala
2007-10-11[POWERPC] mpc8272ads: Remove muram from the CPM reg property.Scott Wood
This is described by the muram node now. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-04[POWERPC] cpm: Describe multi-user ram in its own device node.Scott Wood
The way the current CPM binding describes available multi-user (a.k.a. dual-ported) RAM doesn't work well when there are multiple free regions, and it doesn't work at all if the region doesn't begin at the start of the muram area (as the hardware needs to be programmed with offsets into this area). The latter situation can happen with SMC UARTs on CPM2, as its parameter RAM is relocatable, u-boot puts it at zero, and the kernel doesn't support moving it. It is now described with a muram node, similar to QE. The current CPM binding is sufficiently recent (i.e. never appeared in an official release) that compatibility with existing device trees is not an issue. The code supporting the new binding is shared between cpm1 and cpm2, rather than remain separated. QE should be able to use this code as well, once minor fixes are made to its device trees. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-04[POWERPC] mpc82xx: Update mpc8272ads, and factor out PCI and reset.Scott Wood
1. PCI and reset are factored out into pq2.c. I renamed them from m82xx to pq2 because they won't work on the Integrated Host Processor line of 82xx chips (i.e. 8240, 8245, and such). 2. The PCI PIC, which is nominally board-specific, is used on multiple boards, and thus is used into pq2ads-pci-pic.c. 3. The new CPM binding is used. 4. General cleanup. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-14[POWERPC] DTS cleanupKumar Gala
Removed the following cruft from .dts files: * 32-bit in cpu node -- doesn't exist in any spec and not used by kernel * removed built-in (chrp legacy) * Removed #interrupt-cells in places they don't need to be set * Fixed ranges on lite5200* * Removed clock-frequency from i8259 pic node, not sure where this came from * Removed big-endian from i8259 pic nodes, this was just bogus Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-22[POWERPC] Whitespace cleanup in arch/powerpcScott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-10[POWERPC] dts: kill hardcoded phandlesVitaly Bordug
Removed explicit linux,phandle usage. Using references and labels now in PQ and PQ2 boards currently supported in arch/powerpc. Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-03-09[POWERPC] Remove unused, undocumented #cpus property from cpus nodeStuart Yoder
The #cpus property is unused and undocumented and is therefore being removed. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-16[POWERPC] Delete boot-cpu property from all DTS filesTimur Tabi
The 'linux,boot-cpu' property is obsolete, so remove it from all of the DTS files and from booting-without-of.txt. The boot CPU is actually defined in the device tree header, and U-Boot sets that field. The device tree compiler also complains if the property exists. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] Fix kernel build errors for mpc8272ads and mpc8560adsVitaly Bordug
Recent update of asm-powerpc/io.h caused cpm-related stuff to break in the current kernel. Current patch fixes it, as well as other inconsistencies expressed, that do not permit targets from working properly: - Updated dts with a chosen node with interrupt controller, - fixed messed device IDs among CPM2 SoC devices, - corrected odd header name and fixed type in defines, - Added 82xx subdir to the powerpc/platforms Makefile, missed during initial commit, - new solely-powerpc header file for 8260 family (was using one from arch/ppc, this one cleaned up from the extra stuff), in fact for now a placeholder to get the board-specific includes for stuff not yet capable to live with devicetree peeks only - Fixed couple of misprints in reference mpc8272 dts. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] cpm2: CPM2 interrupt controller fixVitaly Bordug
This contains important fixes for the CPM2 PIC code. Eliminated CPM_IRQ_OFFSET, pulling the respective interrupt numbers from the interrupt mapping. Updated devicetree files to reflect that. Changed direct IC-related IO accesses to the IO accessors. Fixed all the sense values to keep coherency with ipic. In the current code, CPM2 stuff will have no IRQs and hence could be hardly usable. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-03POWERPC: Added devicetree for mpc8272ads boardVitaly Bordug
This adds current dts file used with MPC8272ADS, introducing new mdio bitbang defines, as well as fully-CPM2-SoC board design. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
