path: root/arch/powerpc/boot/dts/mpc8315erdb.dts
2008-02-05[POWERPC] 83xx: configure USB clock for MPC8315EKim Phillips
SCCR USB bits are in a different location on the mpc8315. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] 83xx: Clean up / convert mpc83xx board DTS files to v1 format.Paul Gortmaker
This patch converts the remaining 83xx boards to the dts-v1 format. This includes the mpc8313_rdb, mpc832x_mds, mpc8323_rdb, mpc8349emitx, mpc8349emitxgp and the mpc836x_mds. The mpc8315_rdb mpc834x_mds, mpc837[789]_*, and sbc8349 were already dts-v1 and only undergo minor changes for the sake of formatting consistency across the whole group of boards; i.e. the idea being that you can do a "diff -u board_A.dts board_B.dts" and see something meaningful. The general rule I've applied is that entries for values normally parsed by humans are left in decimal (i.e. IRQ, cache size, clock rates, basic counts and indexes) and all other data (i.e. reg and ranges, IRQ flags etc.) remain in hex. I've used dtc to confirm that the output prior to this changeset matches the output after this changeset is applied for all boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] 83xx: Add the MPC8315E RDB dtsKim Phillips
Add the dts for the MPC8315E Reference Development Board (RDB). The board is a mini-ITX reference board with 128M DDR2, 8M flash, 32M NAND, USB, PCI, gigabit ethernet, SATA, and serial. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
