According to the 8349EA ref man, the second PCI PHB IRQ is 67. Thanks to Peter
Van Ackeren for finding this.
This patch converts the remaining 83xx boards to the dts-v1 format.
This includes the mpc8313_rdb, mpc832x_mds, mpc8323_rdb, mpc8349emitx,
mpc8349emitxgp and the mpc836x_mds.
The mpc8315_rdb mpc834x_mds, mpc837[789]_*, and sbc8349 were already
dts-v1 and only undergo minor changes for the sake of formatting
consistency across the whole group of boards; i.e. the idea being
that you can do a "diff -u board_A.dts board_B.dts" and see something
meaningful.
The general rule I've applied is that entries for values normally
parsed by humans are left in decimal (i.e. IRQ, cache size, clock
rates, basic counts and indexes) and all other data (i.e. reg and
ranges, IRQ flags etc.) remain in hex.
I've used dtc to confirm that the output prior to this changeset
matches the output after this changeset is applied for all boards.
Also:
- rename "fsl_spi" to "fsl,spi";
- add and use cell-index property, if found;
- split probing code out of fsl_spi_init, thus we can call
it for legacy device_type probing and new "compatible" probing.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Move mpc834x_mds device tree source forward to dts-v1 format. Nothing
too complex in this one, so it boils down to just adding a bunch of 0x
in the right places and converting clock speeds to decimal.
Remove device_type = "usb" for 83xx SoC USB controller
Signed-off-by: Li Yang <leoli@freescale.com>
Added aliases nodes for kurobox, 83xx, 85xx, and 86xx platforms.
This included added labels and cell-index properties for serial and
pci nodes.
* Removed address fields in ethernet nodes
* Removed #address-cells, #size-cells from gianfar nodes
* Added cell-index to gianfar and ucc ethernet nodes
* Added enet[0..3] labels
* Renamed compatible node for gianfar mdio to "fsl,gianfar-mdio"
* Removed device_type = "mdio"
The matching for gianfar mdio still supports the old "mdio"/"gianfar" combo
but it is now considered deprecated.
* Removed device_type = "i2c"
* Added missing second I2C controller on MPC8548 CDS, MPC8544 DS
* Added #address-cells, #size-cells, and cell-index where missing
Now the rtc class ds1374 driver has been added, remove the old rtc
driver hookup code, add rtc node to device trees, and turn on the
new driver in the defconfigs.
According to booting-without-of.txt, compatible should be "fsl_spi" and
mode "cpu" or "qe" for the fsl SPI controllers.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
cuImage needs to know the logical index of the ethernet devices in order
to assign mac addresses. This adds the needed properties.
Acked-by: David Gibson <david@gibson.dropbear.id.au>
CC: Scott Wood <scottwood@freescale.com>
CC: Kumar Gala <galak@kernel.crashing.org>
CC: Timur Tabi <timur@freescale.com>
Updated the device trees to have the PCI nodes be at the same level as
the SOC node. This is to make it so that the SOC nodes children address
space is just on chip registers and not other bus memory as well.
Also, for PCIe nodes added a P2P bridge to handle the virtual P2P bridge
that exists in the PHB.
Removed the following cruft from .dts files:
* 32-bit in cpu node -- doesn't exist in any spec and not used by kernel
* removed built-in (chrp legacy)
* Removed #interrupt-cells in places they don't need to be set
* Fixed ranges on lite5200*
* Removed clock-frequency from i8259 pic node, not sure where this came from
* Removed big-endian from i8259 pic nodes, this was just bogus
Updated the 83xx & 85xx device tree PCI related compartible property.
Used the following compatible properties:
PCI "fsl,mpc8349-pci"
PCI "fsl,mpc8540-pci"
PCI-X: "fsl,mpc8540-pcix"
PCIe: "fsl,mpc8548-pcie"
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
For the 83xx, 85xx, and 86xx device trees, add a "local-mac-address" property
to every Ethernet node that didn't have one. Add a comment indicating that
the "address" and/or "mac-address" properties are deprecated in DTS files
and will be removed at a later time. Change all MAC address properties to
have a zero MAC address value.
The MPC834x_MDS device tree's PCI non-prefetchable MMIO range was
specified incorrectly. Both the local and bus addresses start at
0x90000000.
The #cpus property is unused and undocumented and is therefore
being removed.
Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com>
* Fixed up top level compatible property for all boards
* Removed explicit linux,phandle usage. Use references and labels now
* Fixed interrupt sense attribute, some interrupts were marked edge, that are level
The MPC834x SYS board has always been called the MPC834x MDS since its public
release. Removed all references to SYS and replaced with MDS. Additionally
renamed the .dts to match the defconfig (mpc834x_mds*).
