The at24 driver allows to register I2C EEPROM chips using different vendor
and devices, but the I2C subsystem does not take the vendor into account
when matching using the I2C table since it only has device entries.
But when matching using an OF table, both the vendor and device has to be
taken into account so the driver defines only a set of compatible strings
using the "atmel" vendor as a generic fallback for compatible I2C devices.
So add this generic fallback to the device node compatible string to make
the device to match the driver using the OF device ID table.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
- dts: rename 'ide-disk' to 'disk-activity'
- defconfig: rename 'ADB_PMU_LED_IDE' to 'ADB_PMU_LED_DISK'
Cc: Joseph Jezak <josejx@gentoo.org>
Cc: Jörg Sommer <joerg@alea.gnuu.de>
Signed-off-by: Stephan Linz <linz@li-pro.net>
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
The device_type property is deprecated for the flattened device tree and
the value "ethernet-phy" has never been defined as having a useful
meaning. Neither the kernel nor u-boot depend on it. It should never
have appeared in PHY bindings. This patch removes all references to
"ethernet-phy" as a device_type value from the documentation and the
.dts files.
This patch was generated mechanically with the following command and
then verified by looking at the diff.
sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'`
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Florian Fainelli <f.fainelli@gmail.com>
The Freescale serial port's are pretty much a 16550, however there are
some FSL specific bugs and features. Add a "fsl,ns16550" compatiable
string to allow code to handle those FSL specific issues.
There are two front-panel LEDs on MPC837xRDB and MPC8315RDB boards: PWR
and HDD. After adding appropriate nodes we can program these LEDs from
kernel and user space.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
eSDHC block in MPC837x SOCs reports inverted write-protect state, soon
sdhci-of driver will look for sdhci,wp-inverted properties to decide
whether apply a specific quirk.
So, document the property and add it to device tree source files.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Pierre Ossman <pierre@ossman.eu>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: David Vrabel <david.vrabel@csr.com>
Cc: Ben Dooks <ben@fluff.org>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: <linux-mmc@vger.kernel.org>
Actually, the support is already there, but it requires newer U-Boots
(to fill-in clock-frequency, and setup pin multiplexing).
Though, it appears that on RDB boards USBB pins aren't multiplexed
between USB and eSDHC (unlike MDS boards, where USB and eSDHC share
pctl and pwrfault pins).
So, for RDB boards we can safely setup pinmux and manually fill-in
clock-frequency, thus making eSDHC work even with older u-boots.
U-Boot maps PCI IO at 0xe0300000, while current dts files specify
0xe2000000. This leads to the following oops with CONFIG_8139TOO_PIO=y.
8139too Fast Ethernet driver 0.9.28
Machine check in kernel mode.
Caused by (from SRR1=41000): Transfer error ack signal
Oops: Machine check, sig: 7 [#1]
MPC837x RDB
NIP [00000900] 0x900
LR [c0439df8] rtl8139_init_board+0x238/0x524
Call Trace:
[cf831d90] [c0439dcc] rtl8139_init_board+0x20c/0x524 (unreliable)
[cf831de0] [c043a15c] rtl8139_init_one+0x78/0x65c
[cf831e40] [c0235250] pci_call_probe+0x20/0x30
This patch fixes the issue by specifying the correct PCI IO base
address.
As of commit 404614728f857d0ac63d29c3a29d0cf392a15598 ("Update FSL
esdhc binding"), we use "fsl,esdhc" compatible entry as a base
match. U-Boot will use the same compatible to fixup esdhc nodes.
This patch updates 83xx dts files so that they conform to the new
bindings.
Currently it doesn't matter where the mdio nodes are placed, but with
power management support (i.e. when sleep = <> properties will take
effect), mdio nodes placement will become important: mdio controller
is a part of the ethernet block, so the mdio nodes should be placed
correctly. Otherwise we may wrongly assume that MDIO controllers are
available during sleep.
Suggested-by: Scott Wood <scottwood@freescale.com>
This patch adds pmc nodes to the device tree files so that the boards
will able to use standby capability of MPC837x processors. The MPC837x
PMC controllers are compatible with MPC8349 ones (i.e. no deep sleep).
sleep = <> properties are used to specify SCCR masks as described
in "Specifying Device Power Management Information (sleep property)"
chapter in Documentation/powerpc/booting-without-of.txt.
Since I2C1 and eSDHC controllers share the same clock source, they
are now placed under sleep-nexus nodes.
A processor is able to wakeup the boards on LAN events (Wake-On-Lan),
console events (with no_console_suspend kernel command line), GPIO
events and external IRQs (IRQ1 and IRQ2).
The processor can also wakeup the boards by the fourth general purpose
timer in GTM1 block, but the GTM wakeup support isn't yet implemented
(it's tested to work, but it's unclear how can we use the quite short
GTM timers, and how do we want to expose the GTM to userspace).
Simply add appropriate sdhci nodes.
Note that U-Boot should configure pin multiplexing for eSDHC prior
to Linux could use it. U-Boot should also fill-in the clock-frequency
property (eSDHC clock depends on board-specific SCCR[ESDHCCM] bits).
Signed-off-by: Philippe Reynes <philippe.reynes@isismpp.fr>
This patch adds pcie nodes to the appropriate dts files, plus adds
some probing code for the boards.
Also, remove of_device_is_avaliable() check from the mpc837x_mds.c
board file, as mpc83xx_add_bridge() has the same check now.
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (144 commits)
powerpc/44x: Support 16K/64K base page sizes on 44x
powerpc: Force memory size to be a multiple of PAGE_SIZE
powerpc/32: Wire up the trampoline code for kdump
powerpc/32: Add the ability for a classic ppc kernel to be loaded at 32M
powerpc/32: Allow __ioremap on RAM addresses for kdump kernel
powerpc/32: Setup OF properties for kdump
powerpc/32/kdump: Implement crash_setup_regs() using ppc_save_regs()
powerpc: Prepare xmon_save_regs for use with kdump
powerpc: Remove default kexec/crash_kernel ops assignments
powerpc: Make default kexec/crash_kernel ops implicit
powerpc: Setup OF properties for ppc32 kexec
powerpc/pseries: Fix cpu hotplug
powerpc: Fix KVM build on ppc440
powerpc/cell: add QPACE as a separate Cell platform
powerpc/cell: fix build breakage with CONFIG_SPUFS disabled
powerpc/mpc5200: fix error paths in PSC UART probe function
powerpc/mpc5200: add rts/cts handling in PSC UART driver
powerpc/mpc5200: Make PSC UART driver update serial errors counters
powerpc/mpc5200: Remove obsolete code from mpc5200 MDIO driver
powerpc/mpc5200: Add MDMA/UDMA support to MPC5200 ATA driver
Fix trivial conflict in drivers/char/Makefile as per Paul's directions
Does the same for the accompanying MDIO driver, and then modifies the TBI
configuration method. The old way used fields in einfo, which no longer
exists. The new way is to create an MDIO device-tree node for each instance
of gianfar, and create a tbi-handle property to associate ethernet controllers
with the TBI PHYs they are connected to.
Signed-off-by: Andy Fleming <afleming@freescale.com>
We don't want to encourage the device_type usage. It isn't used in
the code, so we can simply remove it from the dts files.
Acked-by: David Gibson <david@gibson.dropbear.id.au>
MCU is an external Freescale MC9S08QG8 microcontroller, mainly used to
provide soft power-off function, but also exports two GPIOs (wired to
the LEDs and also available from the external headers).
Added the MCU on mpc8349emitx, mpc837xrdb and mpc8315erdb boards.
Modify mpc83xx_add_bridge to get config space register base address from
the device tree instead of immr + hardcoded offset.
83xx pci nodes have this change:
register properties now contain two address length tuples:
First is the pci bridge register base, this has always been there.
Second is the config base, this is new.
This is documented in dts-bindings/fsl/83xx-512x-pci.txt
The changes accomplish these things:
mpc83xx_add_bridge no longer needs to call get_immrbase
it uses hard coded addresses if the second register value is missing
Signed-off-by: John Rigby <jrigby@freescale.com>
delete obsolete device-type property, delete model property
(use compatible property instead), prepend "fsl," to Freescale
specific properties. Add nodes to device trees that are missing them,
and fix broken property values in other trees.
Added DMA nodes for the elo/elo-plus DMA engines.
Renamed the interrupt controller alias in mpc832x_rdb.dts to ipic so that
its the same as all the other boards.
MDIO-less PHYs should use CONFIG_FIXED_PHY driver and appropriate
fixed-link property in the device tree.
If not, ethernet will not work:
e0024520:03 not found
eth1: Could not attach to PHY
IP-Config: Failed to open eth1
Due to chip constraint MPC837x USB DR module can only use
ULPI and serial PHY interfaces. The patch fixes the wrong
type in dts.
This patch fixes USB malfunctioning on the MPC837xE-RDB boards.
Similar patch has been already applied for the MDS boards:
commit 28b958859206b7010d03129611c2e444898e3ee4
Author: Li Yang <leoli@freescale.com>
Date: Thu Mar 6 18:42:26 2008 +0800
[POWERPC] 83xx: Fix wrong USB phy type in mpc837xmds dts
This patch converts the remaining 83xx boards to the dts-v1 format.
This includes the mpc8313_rdb, mpc832x_mds, mpc8323_rdb, mpc8349emitx,
mpc8349emitxgp and the mpc836x_mds.
The mpc8315_rdb mpc834x_mds, mpc837[789]_*, and sbc8349 were already
dts-v1 and only undergo minor changes for the sake of formatting
consistency across the whole group of boards; i.e. the idea being
that you can do a "diff -u board_A.dts board_B.dts" and see something
meaningful.
The general rule I've applied is that entries for values normally
parsed by humans are left in decimal (i.e. IRQ, cache size, clock
rates, basic counts and indexes) and all other data (i.e. reg and
ranges, IRQ flags etc.) remain in hex.
I've used dtc to confirm that the output prior to this changeset
matches the output after this changeset is applied for all boards.
Add the dts files for the MPC838xE Reference Development Board (RDB).
The board is a mini-ITX reference board with 256M DDR2, 8M flash,
32M NAND, USB, PCI, gigabit ethernet, SATA, and serial.
the difference among the three files is the 8377 has two, the 8378
none, and the 8379 has four sata controllers.
partially based on the 8379 mds device trees.
Signed-off-by: Joe D'Abbraccio <ljd015@freescale.com>
