path: root/arch/powerpc/boot/dts/mpc8541cds.dts
2008-04-17[POWERPC] 85xx: Convert dts to v1 syntaxKumar Gala
2007-12-12[POWERPC] FSL: Added aliases node to device treesKumar Gala
Added aliases nodes for kurobox, 83xx, 85xx, and 86xx platforms. This included added labels and cell-index properties for serial and pci nodes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-12[POWERPC] FSL: enet device tree cleanupsKumar Gala
* Removed address fields in ethernet nodes * Removed #address-cells, #size-cells from gianfar nodes * Added cell-index to gianfar and ucc ethernet nodes * Added enet[0..3] labels * Renamed compatible node for gianfar mdio to "fsl,gianfar-mdio" * Removed device_type = "mdio" The matching for gianfar mdio still supports the old "mdio"/"gianfar" combo but it is now considered deprecated. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11[POWERPC] FSL: I2C device tree cleanupsKumar Gala
* Removed device_type = "i2c" * Added missing second I2C controller on MPC8548 CDS, MPC8544 DS * Added #address-cells, #size-cells, and cell-index where missing Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-11[POWERPC] 85xx: Add cpm nodes for 8541/8555 CDSScott Wood
We don't use any CPM devices on these boards, but the muram node on these chips is different from the 8560, so it's helpful to people working with custom boards based on these chips. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-14[POWERPC] Move PCI nodes to be sibilings with SOC nodesKumar Gala
Updated the device trees to have the PCI nodes be at the same level as the SOC node. This is to make it so that the SOC nodes children address space is just on chip registers and not other bus memory as well. Also, for PCIe nodes added a P2P bridge to handle the virtual P2P bridge that exists in the PHB. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-14[POWERPC] DTS cleanupKumar Gala
Removed the following cruft from .dts files: * 32-bit in cpu node -- doesn't exist in any spec and not used by kernel * removed built-in (chrp legacy) * Removed #interrupt-cells in places they don't need to be set * Fixed ranges on lite5200* * Removed clock-frequency from i8259 pic node, not sure where this came from * Removed big-endian from i8259 pic nodes, this was just bogus Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-23[POWERPC] Update PCI nodes in the 83xx/85xx boards device treeRoy Zang
Updated the 83xx & 85xx device tree PCI related compartible property. Used the following compatible properties: PCI "fsl,mpc8349-pci" PCI "fsl,mpc8540-pci" PCI-X: "fsl,mpc8540-pcix" PCIe: "fsl,mpc8548-pcie" Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-03[POWERPC] Fix up interrupt senses for MPC85xx boardsKumar Gala
The PHY is active-low on the MPC85xx CDS and the 8560 ADS just had the wrong sense for the internal PCI and CPM interrupts. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-03[POWERPC] Reworked interrupt numbers for OpenPIC based Freescale chipsKumar Gala
Make the interrupt numbers match the OpenPIC spec intead of the Freescale docs which distinguish between internal and external interrupts. Now we can use the interrupt number directly to find the register offset associated with it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-03[POWERPC] Fix MAC address entries for 83xx, 85xx, and 86xx device treesTimur Tabi
For the 83xx, 85xx, and 86xx device trees, add a "local-mac-address" property to every Ethernet node that didn't have one. Add a comment indicating that the "address" and/or "mac-address" properties are deprecated in DTS files and will be removed at a later time. Change all MAC address properties to have a zero MAC address value. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-05-17[POWERPC] 85xx: Add device nodes for error reporting devices used by EDACKumar Gala
Adding memory-controller and l2-cache-controller entries to be used by EDAC as of_devices for MPC8541 CDS, MPC8544 DS, MPC8555 CDS, and MPC8568 MDS. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-03-09[POWERPC] Remove unused, undocumented #cpus property from cpus nodeStuart Yoder
The #cpus property is unused and undocumented and is therefore being removed. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-17[POWERPC] 85xx: Cleaned up platform dts filesKumar Gala
* Fixed up top level compatible property for all boards * Removed explicit linux,phandle usage. Use references and labels now * Fixed phy-phandles for TSEC3/4 in mpc8548cds.dts Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-08-23[POWERPC] Add 85xx DTS files to powerpcAndy Fleming
Added the mpc85xx family of dts files to the powerpc tree Signed-off-by: Paul Mackerras <paulus@samba.org>
