* remove #cpus from mpc8544ds.dts (not used anywhere else)
* remove memreserve from mpc8568mds.dts (not needed)
Add the device tree node for the DMA engine on 8544, publish
the device and enable the driver in the defconfig.
Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de>
The ULI based boards had the interrupt maps for USB on the ULI incorrectly
set.
Also, the MPC8572DS was missing the interrupt-map-mask for the 3rd PCIe
controller.
Added aliases nodes for kurobox, 83xx, 85xx, and 86xx platforms.
This included added labels and cell-index properties for serial and
pci nodes.
* Removed address fields in ethernet nodes
* Removed #address-cells, #size-cells from gianfar nodes
* Added cell-index to gianfar and ucc ethernet nodes
* Added enet[0..3] labels
* Renamed compatible node for gianfar mdio to "fsl,gianfar-mdio"
* Removed device_type = "mdio"
The matching for gianfar mdio still supports the old "mdio"/"gianfar" combo
but it is now considered deprecated.
* Removed device_type = "i2c"
* Added missing second I2C controller on MPC8548 CDS, MPC8544 DS
* Added #address-cells, #size-cells, and cell-index where missing
The interrupt map for the PCI PHB that had the ULI1575 was not correct
on the boards that have it.
* 8544 DS:
- Fix interrupt mask
- Be explicit about use of INTA for on chip peripherals
* 8572 DS/8641 HPCN:
- Expand interrupt map for PCI slots to cover all functions
Updated the device trees to have the PCI nodes be at the same level as
the SOC node. This is to make it so that the SOC nodes children address
space is just on chip registers and not other bus memory as well.
Also, for PCIe nodes added a P2P bridge to handle the virtual P2P bridge
that exists in the PHB.
Removed the following cruft from .dts files:
* 32-bit in cpu node -- doesn't exist in any spec and not used by kernel
* removed built-in (chrp legacy)
* Removed #interrupt-cells in places they don't need to be set
* Fixed ranges on lite5200*
* Removed clock-frequency from i8259 pic node, not sure where this came from
* Removed big-endian from i8259 pic nodes, this was just bogus
The interrupt routing in the device trees for the ULI M1575 was
inproperly using the interrupt line field as pci function. Fixed
up the device tree's to actual conform for to specification and
changed the interrupt mapping code so it just uses a static mapping
setup as follows:
PIRQA - IRQ9
PIRQB - IRQ10
PIRQC - IRQ11
PIRQD - IRQ12
USB 1.1 OCHI (1c.0) - IRQ12
USB 1.1 OCHI (1c.1) - IRQ9
USB 1.1 OCHI (1c.2) - IRQ10
USB 1.1 ECHI (1c.3) - IRQ11
LAN (1b.0) - IRQ6
AC97 (1d.0) - IRQ6
Modem (1d.1) - IRQ6
HD Audio (1d.2) - IRQ6
SATA (1f.1) - IRQ5
SMB (1e.1) - IRQ7
PMU (1e.2) - IRQ7
PATA (1f.0) - IRQ14/15
Took the oppurtunity to refactor the code into a single file so we
don't have to duplicate these fixes on the two current boards in the
tree and several forth coming boards that will also need the code.
Fixed RTC support that requires a dummy memory read on the P2P bridge
to unlock the RTC and setup the default of the RTC alarm registers to
match with a basic x86 style CMOS RTC.
Moved code that poked ISA registers to a FIXUP_FINAL quirk to ensure
the PCI IO space has been setup properly before we start poking ISA
registers at random locations.
Add global-utilities node with has-rstcr on MPC8544 DS and MPC8568 MDS
boards so they are able to reset properly.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
The MPC8544 dts needed to set the new phy-connection-type to rgmii-id
for the Vitesse PHY on the board to work properly.
Add basic support for the PCIe PHB and enable the ULI bridge.
Signed-off-by: York Sun <yorksun@freescale.com>
Make the interrupt numbers match the OpenPIC spec intead of the
Freescale docs which distinguish between internal and external interrupts.
Now we can use the interrupt number directly to find the register offset
associated with it.
Adding memory-controller and l2-cache-controller entries to be used by EDAC
as of_devices for MPC8541 CDS, MPC8544 DS, MPC8555 CDS, and MPC8568 MDS.
This patch provides the basic MPC8544 DS platform code and config.
Follow-up patches will add peripherals such as PCI and SATA.
Signed-off-by: Xianghua Xiao <x.xiao@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
