Add support for adding "status = disabled" to an SSI node to incidate that it
is not wired on the board. This replaces the not-so-intuitive previous method
of omitting a codec-handle property.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch adds needed nodes and properties to support suspend/resume
on the MPC8610HPCD boards.
There is a dedicated switch (SW9) that is used to wake up the boards.
By default the SW9 button is routed to IRQ8, but could be re-routed
(via PIXIS) to sreset.
With 'no_console_suspend' kernel command line argument specified, the
board is also able to wakeup upon serial port input.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Scott Wood <scottwood@freescale.com> [dts]
This patch adds spi and mmc-spi-slot nodes, plus a gpio-controller for
PIXIS' sdcsr bank that is used for managing SPI chip-select and for
reading card's states.
Cc: Kumar Gala <galak@gate.crashing.org>
Cc: David Brownell <david-b@pacbell.net>
Between the addition of the ecm/mcm law nodes and the fact that the
get_immrbase() has been using the range property of the SoC to determine
the base address of CCSR space we no longer need the reg property at
the soc node level. It has been ill specified and varied between device
trees to cover either the {e,m}cm-law node, some odd subset of CCSR
space or all of CCSR space.
The cell-index property isn't used on PCI nodes and is ill defined.
Remove it for now and if someone comes up with a good reason and
consistent definition for it we can add it back
The Freescale Serial Synchronous Interface (SSI) is an audio device present on
some Freescale SOCs. Various implementations of the SSI have a different
transmit and receive FIFO depth, but are otherwise identical. To support
these variations, add a new property fsl,fifo-depth to the SSI node that
specifies the depth of the FIFOs.
Also update the MPC8610 HPCD device tree with this property.
Manual fixup of conflicts on:
arch/powerpc/include/asm/dcr-regs.h
drivers/net/ibm_newemac/core.h
The Freescale Elo DMA driver binds to all DMA channels in the device tree that
are compatible with "fsl,eloplus-dma-channel". This conflicts with the sound
drivers for the MPC8610 HPCD. On this board, the SSI uses two DMA channels and
therefore those channels are not available for general purpose use. We
change the compatible properties for these channels "fsl,ssi-dma-channel".
This works because the sound drivers don't actually check the compatible
property when it grabs channels.
Add the fsl,playback-dma and fsl,capture-dma properties to the Freescale
MPC8610 HPCD device tree. These properties connect the SSI nodes to the
DMA nodes for the DMA channels that the SSI should use. Also update the
ssi.txt documentation.
These properties will be needed when the ASoC V2 version of the Freescale
MPC8610 device drivers are merged into the mainline.
For Freescale 8xxx devices that use an MPIC, the interrupt numbers in
the device tree must be 16 greater than the values documented in the
reference manual. In these chips, the MPIC is wired to use the first
16 numbers for external interrupts, but the documentation numbers
internal interrupts from 0.
In the MPC8610 HPCD device tree, the interrupt properties for the DMA
channels for DMA2 were not the adjusted values. This fixes that.
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
The ULI "Super South Bridge" contains ISA bridge to the legacy
devices, such as Super IO mouse/keyboard/floppy disk controllers,
parallel port, i8259 interrupt controller and so on.
i8259 is disabled on the MPC8610HPCD, and other peripherals are not
traced out. So we use only RTC.
i8259 PIC is disabled on MPC8610HPCD, and ULi IDE is configured to use
PCI sideband interrupt that is specified in the device tree.
Current HPCD's device tree specify that IDE interrupt is low to high
sensitive, but in practice ULi IDE throws active-high interrupts (not
active-low as all normal PCI devices).
arch/powerpc/sysdev/fsl_soc.c
Removed clock-frequency, big-endian, and built-in props as they aren't
specified anywhere. Also added compatible = "chrp,open-pic" in the
places it was missing.
This patch enable the MSI on 8610hpcd board.
Through the msi-available-ranges property, All the 256
msi interrupts can be tested on this board.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
The node for DMA2 in the MPC8610 HPCD device tree has the wrong compatible
properties. This breaks the DMA driver and the sound driver.
This patch adds device tree nodes for NOR and NAND flashes and places
board-control node inside the localbus.
defconfig and board file updated appropriately.
This patch adds pcie node which is resposible for PCI-E x8 slot
functioning. Though, this was tested using only x1 SKY2 NIC.
The following features are supported:
plane 0 works as a regular frame buffer, can be accessed by /dev/fb0
plane 1 has two AOIs (area of interest), can be accessed by /dev/fb1 and /dev/fb2
plane 2 has two AOIs, can be accessed by /dev/fb3 and /dev/fb4
Special ioctls support AOIs
All /dev/fb* can be used as regular frame buffer devices, except hardware
change can only be made through /dev/fb0. Changing pixel clock has no effect
on other fbs.
Limitation of usage of AOIs:
AOIs on the same plane can not be horizonally overlapped
AOIs have horizonal order, i.e. AOI0 should be always on top of AOI1
AOIs can not beyond phisical display area. Application should check AOI geometry
before changing physical resolution on /dev/fb0
required command line parameters to preallocate memory for frame buffer diufb.
optional command line parameters to set modes and monitor
video=fslfb:[resolution][,bpp][,monitor]
Syntax:
Resolution
xres x yres-bpp@refresh_rate, the -bpp and @refresh_rate are optional
eg, 1024x768, 1280x1024, 1280x1024-32, 1280x1024@60, 1280x1024-32@60, 1280x480-32@60
Bpp
bpp=32, bpp=24, or bpp=16
Monitor
monitor=0, monitor=1, monitor=2
0 is DVI
1 is Single link LVDS
2 is Double link LVDS
Note: switching monitor is a board feather, not DIU feather. MPC8610HPCD has three
monitor ports to swtich to. MPC5121ADS doesn't have additional monitor port. So switching
monirot port for MPC5121ADS has no effect.
If compiled as a module, it takes pamameters mode, bpp, monitor with the same syntax above.
Signed-off-by: York Sun <yorksun@freescale.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Also fixed a few minor indent problems as well.
Update the MPC8610 HPCD files to support the audio driver. Update
booting-without-of.txt with information on the SSI device.
Added aliases nodes for kurobox, 83xx, 85xx, and 86xx platforms.
This included added labels and cell-index properties for serial and
pci nodes.
* Removed device_type = "i2c"
* Added missing second I2C controller on MPC8548 CDS, MPC8544 DS
* Added #address-cells, #size-cells, and cell-index where missing
Signed-off-by: Xianghua Xiao <x.xiao@freescale.com>
