path: root/arch/powerpc/boot/dts/mpc866ads.dts
2008-04-17[POWERPC] fsl: Convert dts to v1 syntaxKumar Gala
2007-12-13[POWERPC] 8xx: Convert mpc866ads to the new device binding.Scott Wood
Verified on mpc866ads. This version has muram and brg nodes added to dts to get the things work. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
2007-09-14[POWERPC] DTS cleanupKumar Gala
Removed the following cruft from .dts files: * 32-bit in cpu node -- doesn't exist in any spec and not used by kernel * removed built-in (chrp legacy) * Removed #interrupt-cells in places they don't need to be set * Fixed ranges on lite5200* * Removed clock-frequency from i8259 pic node, not sure where this came from * Removed big-endian from i8259 pic nodes, this was just bogus Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-10[POWERPC] dts: kill hardcoded phandlesVitaly Bordug
Removed explicit linux,phandle usage. Using references and labels now in PQ and PQ2 boards currently supported in arch/powerpc. Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-03-09[POWERPC] Remove unused, undocumented #cpus property from cpus nodeStuart Yoder
The #cpus property is unused and undocumented and is therefore being removed. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-16[POWERPC] Delete boot-cpu property from all DTS filesTimur Tabi
The 'linux,boot-cpu' property is obsolete, so remove it from all of the DTS files and from booting-without-of.txt. The boot CPU is actually defined in the device tree header, and U-Boot sets that field. The device tree compiler also complains if the property exists. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Acked-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] Add mpc866ads board-specific bits to arch/powerpcVitaly Bordug
This add support of the Freescale mpc86xads reference board to arch/powerpc. Supported SMC1 and SMC2 (UART and serial console), FEC 100Mbps Ethernet, SCC1 Ethernet (10Mbps hdx) Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
