2008-01-28 | [POWERPC] 83xx: Clean up / convert mpc83xx board DTS files to v1 format. | Paul Gortmaker | |
This patch converts the remaining 83xx boards to the dts-v1 format. This includes the mpc8313_rdb, mpc832x_mds, mpc8323_rdb, mpc8349emitx, mpc8349emitxgp and the mpc836x_mds. The mpc8315_rdb mpc834x_mds, mpc837[789]_*, and sbc8349 were already dts-v1 and only undergo minor changes for the sake of formatting consistency across the whole group of boards; i.e. the idea being that you can do a "diff -u board_A.dts board_B.dts" and see something meaningful. The general rule I've applied is that entries for values normally parsed by humans are left in decimal (i.e. IRQ, cache size, clock rates, basic counts and indexes) and all other data (i.e. reg and ranges, IRQ flags etc.) remain in hex. I've used dtc to confirm that the output prior to this changeset matches the output after this changeset is applied for all boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> | |||
2008-01-28 | [POWERPC] fsl_spi: stop using device_type = "spi" | Anton Vorontsov | |
Also: - rename "fsl_spi" to "fsl,spi"; - add and use cell-index property, if found; - split probing code out of fsl_spi_init, thus we can call it for legacy device_type probing and new "compatible" probing. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> | |||
2008-01-28 | [POWERPC] 83xx: Add device tree source for Wind River SBC834x board. | Paul Gortmaker | |
This adds the device tree source for the Wind River SBC834x board. It is based on the MPC834x_MDS DTS, with the biggest difference being the lack of BCSR and the PCI2 that the MDS gets via the PIB. That, and this file is also dts-v1 format. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> |
