[ Upstream commit a674c7d470bb47e82f4eb1fa944eadeac2f6bbaf ]
It is not implemented on the kmcoge4 hardware and if not disabled it
leads to error messages with the corenet32_smp_defconfig.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Scott Wood <oss@buserror.net>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights:
- PowerNV PCI hotplug support.
- Lots more Power9 support.
- eBPF JIT support on ppc64le.
- Lots of cxl updates.
- Boot code consolidation.
Bug fixes:
- Fix spin_unlock_wait() from Boqun Feng
- Fix stack pointer corruption in __tm_recheckpoint() from Michael
Neuling
- Fix multiple bugs in memory_hotplug_max() from Bharata B Rao
- mm: Ensure "special" zones are empty from Oliver O'Halloran
- ftrace: Separate the heuristics for checking call sites from
Michael Ellerman
- modules: Never restore r2 for a mprofile-kernel style mcount() call
- Fix endianness when reading TCEs from Alexey Kardashevskiy
- start rtasd before PCI probing from Greg Kurz
- PCI: rpaphp: Fix slot registration for multiple slots under a PHB
from Tyrel Datwyler
- powerpc/mm: Add memory barrier in __hugepte_alloc() from Sukadev
Bhattiprolu
Cleanups & fixes:
- Drop support for MPIC in pseries from Rashmica Gupta
- Define and use PPC64_ELF_ABI_v2/v1 from Michael Ellerman
- Remove unused symbols in asm-offsets.c from Rashmica Gupta
- Fix SRIOV not building without EEH enabled from Russell Currey
- Remove kretprobe_trampoline_holder from Thiago Jung Bauermann
- Reduce log level of PCI I/O space warning from Benjamin
Herrenschmidt
- Add array bounds checking to crash_shutdown_handlers from Suraj
Jitindar Singh
- Avoid -maltivec when using clang integrated assembler from Anton
Blanchard
- Fix array overrun in ppc_rtas() syscall from Andrew Donnellan
- Fix error return value in cmm_mem_going_offline() from Rasmus
Villemoes
- export cpu_to_core_id() from Mauricio Faria de Oliveira
- Remove old symbols from defconfigs from Andrew Donnellan
- Update obsolete comments in setup_32.c about entry conditions from
Benjamin Herrenschmidt
- Add comment explaining the purpose of setup_kdump_trampoline() from
- Merge the RELOCATABLE config entries for ppc32 and ppc64 from Kevin
Hao
- Remove RELOCATABLE_PPC32 from Kevin Hao
- Fix .long's in tlb-radix.c to more meaningful from Balbir Singh
Minor cleanups & fixes:
- Andrew Donnellan, Anna-Maria Gleixner, Anton Blanchard, Benjamin
Herrenschmidt, Bharata B Rao, Christophe Leroy, Colin Ian King,
Geliang Tang, Greg Kurz, Madhavan Srinivasan, Michael Ellerman,
Michael Ellerman, Stephen Rothwell, Stewart Smith.
Freescale updates from Scott:
- "Highlights include more 8xx optimizations, device tree updates,
and MVME7100 support."
PowerNV PCI hotplug from Gavin Shan:
- PCI: Add pcibios_setup_bridge()
- Override pcibios_setup_bridge()
- Remove PCI_RESET_DELAY_US
- Move pnv_pci_ioda_setup_opal_tce_kill() around
- Increase PE# capacity
- Allocate PE# in reverse order
- Create PEs in pcibios_setup_bridge()
- Setup PE for root bus
- Extend PCI bridge resources
- Make pnv_ioda_deconfigure_pe() visible
- Dynamically release PE
- Update bridge windows on PCI plug
- Delay populating pdn
- Support PCI slot ID
- Use PCI slot reset infrastructure
- Introduce pnv_pci_get_slot_id()
- Functions to get/set PCI slot state
- PCI/hotplug: PowerPC PowerNV PCI hotplug driver
- Print correct PHB type names
Power9 idle support from Shreyas B. Prabhu:
- set power_save func after the idle states are initialized
- Use PNV_THREAD_WINKLE macro while requesting for winkle
- make hypervisor state restore a function
- Rename idle_power7.S to idle_book3s.S
- Rename reusable idle functions to hardware agnostic names
- Make pnv_powersave_common more generic
- abstraction for saving SPRs before entering deep idle states
- Add platform support for stop instruction
- cpuidle/powernv: Use CPUIDLE_STATE_MAX instead of MAX_POWERNV_IDLE_STATES
- cpuidle/powernv: cleanup cpuidle-powernv.c
- cpuidle/powernv: Add support for POWER ISA v3 idle states
- Use deepest stop state when cpu is offlined
Power9 PMU from Madhavan Srinivasan:
- factor out power8 pmu macros and defines
- factor out power8 pmu functions
- factor out power8 __init_pmu code
- Add power9 event list macros for generic and cache events
- Power9 PMU support
- Export Power9 generic and cache events to sysfs
Power9 preliminary interrupt & PCI support from Benjamin Herrenschmidt:
- Add XICS emulation APIs
- Move a few exception common handlers to make room
- Add support for HV virtualization interrupts
- Add mechanism to force a replay of interrupts
- Add ICP OPAL backend
- Discover IODA3 PHBs
- pci: Remove obsolete SW invalidate
- opal: Add real mode call wrappers
- Rename TCE invalidation calls
- Remove SWINV constants and obsolete TCE code
- Rework accessing the TCE invalidate register
- Fallback to OPAL for TCE invalidations
- Use the device-tree to get available range of M64's
- Check status of a PHB before using it
- pci: Don't try to allocate resources that will be reassigned
Other Power9:
- Send SIGBUS on unaligned copy and paste from Chris Smart
- Large Decrementer support from Oliver O'Halloran
- Load Monitor Register Support from Jack Miller
Performance improvements from Anton Blanchard:
- Avoid load hit store in __giveup_fpu() and __giveup_altivec()
- Avoid load hit store in setup_sigcontext()
- Remove assembly versions of strcpy, strcat, strlen and strcmp
- Align hot loops of some string functions
eBPF JIT from Naveen N. Rao:
- Fix/enhance 32-bit Load Immediate implementation
- Optimize 64-bit Immediate loads
- Introduce rotate immediate instructions
- A few cleanups
- Isolate classic BPF JIT specifics into a separate header
- Implement JIT compiler for extended BPF
Operator Panel driver from Suraj Jitindar Singh:
- devicetree/bindings: Add binding for operator panel on FSP machines
- Add inline function to get rc from an ASYNC_COMP opal_msg
- Add driver for operator panel on FSP machines
Sparse fixes from Daniel Axtens:
- make some things static
- Introduce asm-prototypes.h
- Include headers containing prototypes
- Use #ifdef __BIG_ENDIAN__ #else for REG_BYTE
- kvm: Clarify __user annotations
- Pass endianness to sparse
- Make ppc_md.{halt, restart} __noreturn
MM fixes & cleanups from Aneesh Kumar K.V:
- radix: Update LPCR HR bit as per ISA
- use _raw variant of page table accessors
- Compile out radix related functions if RADIX_MMU is disabled
- Clear top 16 bits of va only on older cpus
- Print formation regarding the the MMU mode
- hash: Update SDR1 size encoding as documented in ISA 3.0
- radix: Update PID switch sequence
- radix: Update machine call back to support new HCALL.
- radix: Add LPID based tlb flush helpers
- radix: Add a kernel command line to disable radix
- Cleanup LPCR defines
Boot code consolidation from Benjamin Herrenschmidt:
- Move epapr_paravirt_early_init() to early_init_devtree()
- cell: Don't use flat device-tree after boot
- ge_imp3a: Don't use the flat device-tree after boot
- mpc85xx_ds: Don't use the flat device-tree after boot
- mpc85xx_rdb: Don't use the flat device-tree after boot
- Don't test for machine type in rtas_initialize()
- Don't test for machine type in smp_setup_cpu_maps()
- dt: Add of_device_compatible_match()
- Factor do_feature_fixup calls
- Move 64-bit feature fixup earlier
- Move 64-bit memory reserves to setup_arch()
- Use a cachable DART
- Move FW feature probing out of pseries probe()
- Put exception configuration in a common place
- Remove early allocation of the SMU command buffer
- Move MMU backend selection out of platform code
- pasemi: Remove IOBMAP allocation from platform probe()
- mm/hash: Don't use machine_is() early during boot
- Don't test for machine type to detect HEA special case
- pmac: Remove spurrious machine type test
- Move hash table ops to a separate structure
- Ensure that ppc_md is empty before probing for machine type
- Move 64-bit probe_machine() to later in the boot process
- Move 32-bit probe() machine to later in the boot process
- Get rid of ppc_md.init_early()
- Move the boot time info banner to a separate function
- Move setting of {i,d}cache_bsize to initialize_cache_info()
- Move the content of setup_system() to setup_arch()
- Move cache info inits to a separate function
- Re-order the call to smp_setup_cpu_maps()
- Re-order setup_panic()
- Make a few boot functions __init
- Merge 32-bit and 64-bit setup_arch()
Other new features:
- tty/hvc: Use IRQF_SHARED for OPAL hvc consoles from Sam Mendoza-Jonas
- tty/hvc: Use opal irqchip interface if available from Sam Mendoza-Jonas
- powerpc: Add module autoloading based on CPU features from Alastair D'Silva
- crypto: vmx - Convert to CPU feature based module autoloading from Alastair D'Silva
- Wake up kopald polling thread before waiting for events from Benjamin Herrenschmidt
- xmon: Dump ISA 2.06 SPRs from Michael Ellerman
- xmon: Dump ISA 2.07 SPRs from Michael Ellerman
- Add a parameter to disable 1TB segs from Oliver O'Halloran
- powerpc/boot: Add OPAL console to epapr wrappers from Oliver O'Halloran
- Assign fixed PHB number based on device-tree properties from Guilherme G. Piccoli
- pseries: Add pseries hotplug workqueue from John Allen
- pseries: Add support for hotplug interrupt source from John Allen
- pseries: Use kernel hotplug queue for PowerVM hotplug events from John Allen
- pseries: Move property cloning into its own routine from Nathan Fontenot
- pseries: Dynamic add entires to associativity lookup array from Nathan Fontenot
- pseries: Auto-online hotplugged memory from Nathan Fontenot
- pseries: Remove call to memblock_add() from Nathan Fontenot
cxl:
- Add set and get private data to context struct from Michael Neuling
- make base more explicitly non-modular from Paul Gortmaker
- Use for_each_compatible_node() macro from Wei Yongjun
- Frederic Barrat
- Abstract the differences between the PSL and XSL
- Make vPHB device node match adapter's
- Philippe Bergheaud
- Add mechanism for delivering AFU driver specific events
- Ignore CAPI adapters misplaced in switched slots
- Refine slice error debug messages
- Andrew Donnellan
- static-ify variables to fix sparse warnings
- PCI/hotplug: pnv_php: export symbols and move struct types needed by cxl
- PCI/hotplug: pnv_php: handle OPAL_PCI_SLOT_OFFLINE power state
- Add cxl_check_and_switch_mode() API to switch bi-modal cards
- remove dead Kconfig options
- fix potential NULL dereference in free_adapter()
- Ian Munsie
- Update process element after allocating interrupts
- Add support for CAPP DMA mode
- Fix allowing bogus AFU descriptors with 0 maximum processes
- Fix allocating a minimum of 2 pages for the SPA
- Fix bug where AFU disable operation had no effect
- Workaround XSL bug that does not clear the RA bit after a reset
- Fix NULL pointer dereference on kernel contexts with no AFU interrupts
- powerpc/powernv: Split cxl code out into a separate file
- Add cxl_slot_is_supported API
- Enable bus mastering for devices using CAPP DMA mode
- Move cxl_afu_get / cxl_afu_put to base
- Allow a default context to be associated with an external pci_dev
- Do not create vPHB if there are no AFU configuration records
- powerpc/powernv: Add support for the cxl kernel api on the real phb
- Add support for using the kernel API with a real PHB
- Add kernel APIs to get & set the max irqs per context
- Add preliminary workaround for CX4 interrupt limitation
- Add support for interrupts on the Mellanox CX4
- Workaround PE=0 hardware limitation in Mellanox CX4
- powerpc/powernv: Fix pci-cxl.c build when CONFIG_MODULES=n
selftests:
- Test unaligned copy and paste from Chris Smart
- Load Monitor Register Tests from Jack Miller
- Cyril Bur
- exec() with suspended transaction
- Use signed long to read perf_event_paranoid
- Fix usage message in context_switch
- Fix generation of vector instructions/types in context_switch
- Michael Ellerman
- Use "Delta" rather than "Error" in normal output
- Import Anton's mmap & futex micro benchmarks
- Add a test for PROT_SAO"
* tag 'powerpc-4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (263 commits)
powerpc/mm: Parenthesise IS_ENABLED() in if condition
selftests/powerpc: exec() with suspended transaction
powerpc: Improve comment explaining why we modify VRSAVE
powerpc/mm: Drop unused externs for hpte_init_beat[_v3]()
powerpc/mm: Rename hpte_init_lpar() and move the fallback to a header
powerpc/mm: Fix build break when PPC_NATIVE=n
powerpc/powernv/ioda: Fix endianness when reading TCEs
powerpc/modules: Never restore r2 for a mprofile-kernel style mcount() call
powerpc/ftrace: Separate the heuristics for checking call sites
powerpc: Merge 32-bit and 64-bit setup_arch()
powerpc/64: Make a few boot functions __init
powerpc: Re-order setup_panic()
powerpc: Re-order the call to smp_setup_cpu_maps()
powerpc/32: Move cache info inits to a separate function
powerpc/64: Move the content of setup_system() to setup_arch()
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- remove most of_platform_populate() calls in arch code. Now the DT
core code calls it in the default case and platforms only need to
call it if they have special needs
- use pr_fmt on all the DT core print statements
- CoreSight binding doc improvements to block name descriptions
- add dt_to_config script which can parse dts files and list
corresponding kernel config options
- fix memory leak hit with a PowerMac DT
- correct a bunch of STMicro compatible strings to use the correct
vendor prefix
- fix DA9052 PMIC binding doc to match what is actually used in dts
files
* tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits)
documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations
xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table"
xtensa: Fix build error due to missing include file
MIPS: ath79: Add missing include file
Fix spelling errors in Documentation/devicetree
ARM: dts: fix STMicroelectronics compatible strings
powerpc/dts: fix STMicroelectronics compatible strings
Documentation: dt: i2c: use correct STMicroelectronics vendor prefix
scripts/dtc: dt_to_config - kernel config options for a devicetree
of: fdt: mark unflattened tree as detached
of: overlay: add resolver error prints
coresight: document binding acronyms
Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties
of: use pr_fmt prefix for all console printing
of/irq: Mark initialised interrupt controllers as populated
of: fix memory leak related to safe_name()
Revert "of/platform: export of_default_bus_match_table"
of: unittest: use of_platform_default_populate() to populate default bus
memory: omap-gpmc: use of_platform_default_populate() to populate default bus
bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus
Replace the non-standard vendor prefix stm and st-micro with st for
STMicroelectronics. The drivers do not specify the vendor prefixes
since the I2C Core strips them away from the DT provided compatible
string. Therefore, changing existing device trees does not have any
impact on device detection.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Rob Herring <robh@kernel.org>
add qe node to t104xqds.dtsi
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
add qe node to t104xrdb.dtsi
add qe node to t104xd4rdb.dtsi and t1040si-post.dtsi.
Now that the FMAN mac driver has been merged the fman node is relevant.
The kmcoge4 board implements 3 ethernet interfaces, 1 with a RGMII phy
and 2 with fixed 1 Giga SGMII links.
Add support for the Artesyn MVME7100 Single Board Computer.
The MVME7100 is a 6U form factor VME64 computer with:
- A two e600 cores Freescale MPC8641D CPU
- 2 GB of DDR2 onboard memory
- Four Gigabit Ethernets
- Five 16550 compatible UARTs
- One USB 2.0 port
- Two PCI/PCI eXpress Mezzanine Card (PMC/XMC) Slots
- A DS1375 Real Time Clock (RTC)
- 512 KB of Non-Volatile Memory (NVRAM)
- Two 64 KB EEPROMs
- 128 MB NOR and 4/8 GB NAND Flash
This patch is based on linux-4.7-rc1 and has been only boot tested.
Limitations:
This patch covers only models 171 and 173
No plans to support CPLD timers
Know issues:
All four PHYs work in polling mode
Configuration is missing for:
PCI IDSEL and PCI Interrupt definition
Support is missing for:
Cache and memory controllers (which are very similar to the 85xx ones
but right now I don't know if we can re-use their support)
Watchdog, USB, NVRAM, NOR, NAND, EEPROMs, VME, PMC/XMC and RTC
Signed-off-by: Alessio Igor Bogani <alessio.bogani@elettra.eu>
Add usb aliases for consistency with the other platforms.
Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com>
Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
Change USB controller version name to 2.5 in compatible string for T1040
- dts: rename 'ide-disk' to 'disk-activity'
- defconfig: rename 'ADB_PMU_LED_IDE' to 'ADB_PMU_LED_DISK'
Cc: Joseph Jezak <josejx@gentoo.org>
Cc: Jörg Sommer <joerg@alea.gnuu.de>
Signed-off-by: Stephan Linz <linz@li-pro.net>
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata sata_dwc_460ex updates from Tejun Heo:
"Patches to bring sata_dwc_460ex up to snuff.
It was a separate pull request because it depends on dmaengine dw
platform changes which are now in mainline"
* 'for-4.7-dw' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (24 commits)
ata: dwc: add DMADEVICES dependency
powerpc/4xx: Device tree update for the 460ex DWC SATA
ata: sata_dwc_460ex: make debug messages neat
ata: sata_dwc_460ex: supply physical address of FIFO to DMA
ata: sata_dwc_460ex: use devm_ioremap
ata: sata_dwc_460ex: tidy up sata_dwc_clear_dmacr()
ata: sata_dwc_460ex: use readl/writel_relaxed()
ata: sata_dwc_460ex: switch to new dmaengine_terminate_* API
ata: sata_dwc_460ex: add __iomem to register base pointer
ata: sata_dwc_460ex: get rid of incorrect cast
ata: sata_dwc_460ex: get rid of some pointless casts
ata: sata_dwc_460ex: remove empty libata callback
ata: sata_dwc_460ex: correct HOSTDEV{P}_FROM_*() macros
ata: sata_dwc_460ex: get rid of global data
ata: sata_dwc_460ex: add phy support
ata: sata_dwc_460ex: use "dmas" DT property to find dma channel
ata: sata_dwc_460ex: don't call ata_sff_qc_issue() on DMA commands
ata: sata_dwc_460ex: skip dma setup for non-dma commands
ata: sata_dwc_460ex: select only core part of DMA driver
ata: sata_dwc_460ex: DMA is always a flow controller
Fix PCI interrupt map definition from 2 to 4 cells. Move
interrupt-map and interrupt-map-mask and clone interrupts
into the pcie child nodes.
For T1040, T1042, T1023, and T1024, they should use the compatible
string "fsl,qoriq-rcpm-2.1".
Signed-off-by: Chenhui Zhao <chenhui.zhao@nxp.com>
On the t208xrdb and t1040rdb, the SPI device is n25q512ax3
instead of n25q512a.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@freescale.com>
Device tree update for the Applied micro processor 460ex on-chip SATA to use
"dmas" property.
Acked-by: Rob Herring <robh@kernel.org>
Starting with commit <8947e396a829> ("Documentation: dt: mtd:
replace "nor-jedec" binding with "jedec, spi-nor"") we have
"jedec,spi-nor" binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op
according to the datasheets.
This patch adds pcsphy node to FManV3 device tree.
Signed-off-by: Igal Liberman <igal.liberman@freescale.com>
Describe the PHY topology for all configurations supported by each board
Based on prior work by Andy Fleming <afleming@freescale.com>
Signed-off-by: Shruti Kanetkar <Shruti@freescale.com>
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Signed-off-by: Igal Liberman <Igal.Liberman@freescale.com>
Avoid duplication of the interrupt-parent, migrate to 4 interrupt-cells
and set the right clock-frequency for pcie (100 Mhz).
add the missing RAID Engine device node for p5040.
otherwise, the device can not be detected.
Signed-off-by: Xuelin Shi <xuelin.shi@nxp.com>
"Core:
- Ground work for the new Power9 MMU from Aneesh Kumar K.V
- Optimise FP/VMX/VSX context switching from Anton Blanchard
Misc:
- Various cleanups from Krzysztof Kozlowski, John Ogness, Rashmica
Gupta, Russell Currey, Gavin Shan, Daniel Axtens, Michael Neuling,
Andrew Donnellan
- Allow wrapper to work on non-english system from Laurent Vivier
- Add rN aliases to the pt_regs_offset table from Rashmica Gupta
- Fix module autoload for rackmeter & axonram drivers from Luis de
Bethencourt
- Include KVM guest test in all interrupt vectors from Paul Mackerras
- Fix DSCR inheritance over fork() from Anton Blanchard
- Make value-returning atomics & {cmp}xchg* & their atomic_ versions
fully ordered from Boqun Feng
- Print MSR TM bits in oops messages from Michael Neuling
- Add TM signal return & invalid stack selftests from Michael Neuling
- Limit EPOW reset event warnings from Vipin K Parashar
- Remove the Cell QPACE code from Rashmica Gupta
- Append linux_banner to exception information in xmon from Rashmica
Gupta
- Add selftest to check if VSRs are corrupted from Rashmica Gupta
- Remove broken GregorianDay() from Daniel Axtens
- Import Anton's context_switch2 benchmark into selftests from
Michael Ellerman
- Add selftest script to test HMI functionality from Daniel Axtens
- Remove obsolete OPAL v2 support from Stewart Smith
- Make enter_rtas() private from Michael Ellerman
- PPR exception cleanups from Michael Ellerman
- Add page soft dirty tracking from Laurent Dufour
- Add support for Nvlink NPUs from Alistair Popple
- Add support for kexec on 476fpe from Alistair Popple
- Enable kernel CPU dlpar from sysfs from Nathan Fontenot
- Copy only required pieces of the mm_context_t to the paca from
Michael Neuling
- Add a kmsg_dumper that flushes OPAL console output on panic from
Russell Currey
- Implement save_stack_trace_regs() to enable kprobe stack tracing
from Steven Rostedt
- Add HWCAP bits for Power9 from Michael Ellerman
- Fix _PAGE_PTE breaking swapoff from Aneesh Kumar K.V
- Fix _PAGE_SWP_SOFT_DIRTY breaking swapoff from Hugh Dickins
- scripts/recordmcount.pl: support data in text section on powerpc
from Ulrich Weigand
- Handle R_PPC64_ENTRY relocations in modules from Ulrich Weigand
cxl:
- cxl: Fix possible idr warning when contexts are released from
Vaibhav Jain
- cxl: use correct operator when writing pcie config space values
- cxl: Fix DSI misses when the context owning task exits from Vaibhav
Jain
- cxl: fix build for GCC 4.6.x from Brian Norris
- cxl: use -Werror only with CONFIG_PPC_WERROR from Brian Norris
- cxl: Enable PCI device ID for future IBM CXL adapter from Uma
Krishnan
Freescale:
- Freescale updates from Scott: Highlights include moving QE code out
of arch/powerpc (to be shared with arm), device tree updates, and
minor fixes"
* tag 'powerpc-4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (149 commits)
powerpc/module: Handle R_PPC64_ENTRY relocations
powerpc/powernv: Fix OPAL_CONSOLE_FLUSH prototype and usages
powerpc/mm: fix _PAGE_SWP_SOFT_DIRTY breaking swapoff
powerpc/mm: Fix _PAGE_PTE breaking swapoff
powerpc: Add HWCAP bits for Power9
powerpc/powernv: Reserve PE#0 on NPU
powerpc/powernv: Change NPU PE# assignment
powerpc/powernv: Fix update of NVLink DMA mask
powerpc/powernv: Remove misleading comment in pci.c
powerpc: Implement save_stack_trace_regs() to enable kprobe stack tracing
powerpc: Fix build break due to paca mm_context_t changes
MAINTAINERS: Update Scott Wood's e-mail address
powerpc/powernv: Fix minor off-by-one error in opal_mce_check_early_recovery()
powerpc: Fix style of self-test config prompts
powerpc/powernv: Only delay opal_rtc_read() retry when necessary
Also add nodes and properties for thermal management support. Meanwhile
preprocessor support is needed using thermal of framework.
Signed-off-by: Jia Hongtao <hongtao.jia@freescale.com>
Reviewed-by: Scott Wood <scottwood@freescale.com>
p1010rdb uses the irq[4:5] for inta and intb to pcie,
it is active-high, so set it.
Signed-off-by: Zhao Qiang <qiang.zhao@freescale.com>
FMan V3H has 2 different MURAM sizes:
In B4860/4420 the MURAM size is 512KB.
In T4240 and T2080 the MURAM size is 384KB.
The MURAM size in FMan V3H device tree is 384KB.
This patch updates the MURAM size for B4 to 512KB.
Signed-off-by: Harninder Rai <harninder.rai@freescale.com>
Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com>
Signed-off-by: Hou Zhiqiang <B48286@freescale.com>
This file was originally cloned off of the MPC8641D-HPCN reference
platform, which actually had a PHY IRQ line connected. However this
board does not. The bogus entry was largely inert and went undetected
until commit 321beec5047af83db90c88114b7e664b156f49fe ("net: phy: Use
interrupts when available in NOLINK state") was added to the tree.
With the above commit, the board fails to NFS boot since it sits waiting
for a PHY IRQ event that of course never arrives. Removing the bogus
entries from the DTS file fixes the issue.
Cc: Andrew Lunn <andrew@lunn.ch>
- Kconfig: remove BE-only platforms from LE kernel build from Boqun
Feng
- Refresh ps3_defconfig from Geoff Levand
- Emit GNU & SysV hashes for the vdso from Michael Ellerman
- Define an enum for the bolted SLB indexes from Anshuman Khandual
- Use a local to avoid multiple calls to get_slb_shadow() from Michael
Ellerman
- Add gettimeofday() benchmark from Michael Neuling
- Avoid link stack corruption in __get_datapage() from Michael Neuling
- Add virt_to_pfn and use this instead of opencoding from Aneesh Kumar
K.V
- Add ppc64le_defconfig from Michael Ellerman
- pseries: extract of_helpers module from Andy Shevchenko
- Correct string length in pseries_of_derive_parent() from Nathan
Fontenot
- Free the MSI bitmap if it was slab allocated from Denis Kirjanov
- Shorten irq_chip name for the SIU from Christophe Leroy
- Wait 1s for secondaries to enter OPAL during kexec from Samuel
Mendoza-Jonas
- Fix _ALIGN_* errors due to type difference, from Aneesh Kumar K.V
- powerpc/pseries/hvcserver: don't memset pi_buff if it is null from
Colin Ian King
- Disable hugepd for 64K page size, from Aneesh Kumar K.V
- Differentiate between hugetlb and THP during page walk from Aneesh
Kumar K.V
- Make PCI non-optional for pseries from Michael Ellerman
- Individual System V IPC system calls from Sam bobroff
- Add selftest of unmuxed IPC calls from Michael Ellerman
- discard .exit.data at runtime from Stephen Rothwell
- Delete old orphaned PrPMC 280/2800 DTS and boot file, from Paul
Gortmaker
- Use of_get_next_parent to simplify code from Christophe Jaillet
- Paginate some xmon output from Sam bobroff
- Add some more elements to the xmon PACA dump from Michael Ellerman
- Allow the tm-syscall selftest to build with old headers from Michael
Ellerman
- Run EBB selftests only on POWER8 from Denis Kirjanov
- Drop CONFIG_TUNE_CELL in favour of CONFIG_CELL_CPU from Michael
Ellerman
- Avoid reference to potentially freed memory in prom.c from Christophe
Jaillet
- Quieten boot wrapper output with run_cmd from Geoff Levand
- EEH fixes and cleanups from Gavin Shan
- Fix recursive fenced PHB on Broadcom shiner adapter from Gavin Shan
- Use of_get_next_parent() in of_get_ibm_chip_id() from Michael
Ellerman
- Fix section mismatch warning in msi_bitmap_alloc() from Denis
Kirjanov
- Fix ps3-lpm white space from Rudhresh Kumar J
- Fix ps3-vuart null dereference from Colin King
- nvram: Add missing kfree in error path from Christophe Jaillet
- nvram: Fix function name in some errors messages, from Christophe
Jaillet
- drivers/macintosh: adb: fix misleading Kconfig help text from Aaro
Koskinen
- agp/uninorth: fix a memleak in create_gatt_table from Denis Kirjanov
- cxl: Free virtual PHB when removing from Andrew Donnellan
- scripts/kconfig/Makefile: Allow KBUILD_DEFCONFIG to be a target from
Michael Ellerman
- scripts/kconfig/Makefile: Fix KBUILD_DEFCONFIG check when building
with O= from Michael Ellerman
- Freescale updates from Scott: Highlights include 64-bit book3e
kexec/kdump support, a rework of the qoriq clock driver, device tree
changes including qoriq fman nodes, support for a new 85xx board, and
some fixes.
- MPC5xxx updates from Anatolij: Highlights include a driver for
MPC512x LocalPlus Bus FIFO with its device tree binding
documentation, mpc512x device tree updates and some minor fixes.
* tag 'powerpc-4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (106 commits)
powerpc/msi: Fix section mismatch warning in msi_bitmap_alloc()
powerpc/prom: Use of_get_next_parent() in of_get_ibm_chip_id()
powerpc/pseries: Correct string length in pseries_of_derive_parent()
powerpc/e6500: hw tablewalk: make sure we invalidate and write to the same tlb entry
powerpc/mpc85xx: Add FSL QorIQ DPAA FMan support to the SoC device tree(s)
powerpc/mpc85xx: Create dts components for the FSL QorIQ DPAA FMan
powerpc/fsl: Add #clock-cells and clockgen label to clockgen nodes
powerpc: handle error case in cpm_muram_alloc()
powerpc: mpic: use IRQCHIP_SKIP_SET_WAKE instead of redundant mpic_irq_set_wake
powerpc/book3e-64: Enable kexec
powerpc/book3e-64/kexec: Set "r4 = 0" when entering spinloop
powerpc/booke: Only use VIRT_PHYS_OFFSET on booke32
powerpc/book3e-64/kexec: Enable SMP release
powerpc/book3e-64/kexec: create an identity TLB mapping
powerpc/book3e-64: Don't limit paca to 256 MiB
powerpc/book3e/kdump: Enable crash_kexec_wait_realmode
powerpc/book3e: support CONFIG_RELOCATABLE
powerpc/booke64: Fix args to copy_and_flush
powerpc/book3e-64: rename interrupt_end_book3e with __end_interrupts
powerpc/e6500: kexec: Handle hardware threads
"Highlights include a driver for MPC512x LocalPlus Bus FIFO with its
device tree binding documentation, mpc512x device tree updates and some
minor fixes."
This allows new-style clock references to be used, which is needed for
fman. The old clock nodes will be removed and all clock references
converted to new-style once the qoriq-cpufreq driver is updated to stop
depending on the old-style references in cpu nodes.
Add a device tree binding for Freescale MPC512x LocalPlus Bus FIFO and
introduce the document describing that binding.
Signed-off-by: Alexander Popov <alex.popov@linux.com>
To make provision for more than one L2 caches in the system, change the
name from L2 to L2_1; same as in T4 platforms.
* Also remove the L2 entry from common file
"arch/powerpc/boot/dts/fsl/b4si-post.dtsi"
Keep them only in separate files for b4860 and b4420.
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
It makes no sense that some Freescale device tree files are in fsl
directory while some others not. This patch move Freescale device tree
files into fsl folder. To do that the following two steps are made:
- Move Freescale device tree files into fsl folder.
- Update the include path in these files from "fsl/*.dtsi" to "*.dtsi".
Please add "fsl/" prefix when you make dtb using Makefile.
[scottwood: fixed cuImage rule]
In case of B4860 LIODN register for sRIO is not in GUTs block but in
the sRIO register space.
Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com>
This board uses a P5020 chip, and boots just fine using
the corenet_generic code. The device tree is very similar to the
P5020DS, except that there is no Flash memory. The environment is,
instead, stored on an MMC card on the motherboard.
Signed-off-by: Andy Fleming <afleming@gmail.com>
[scottwood: fixed trailing whitespace]
DS26522 is used for tdm, configured by SPI bus.
Add nodes under spi node to t104xd4rdb.dtsi.
While the handling of fsl,pq3-gpio and fsl,mpc8572-gpio is done in the
same driver and the two hardly differ, the latter controller needs a
workaround for an erratum in the gpio_get callback. To make this
difference more explicit remove fsl,pq3-gpio from the list of
compatibles for mpc8572 machines.
Add 1588 timer node in files:
arch/powerpc/boot/dts/bsc9131rdb.dtsi
arch/powerpc/boot/dts/bsc9132qds.dtsi
arch/powerpc/boot/dts/p1010rdb.dtsi
arch/powerpc/boot/dts/p1020rdb-pd.dts
arch/powerpc/boot/dts/p1021rdb-pc.dtsi
arch/powerpc/boot/dts/p1022ds.dtsi
arch/powerpc/boot/dts/p1025twr.dtsi
For P2020RDB-PC, registers' values should be calculated
based on default 1588 reference clock(300MHz) not 250MHz,
and fix this in file:
arch/powerpc/boot/dts/p2020rdb-pc.dtsi
Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com>
In commit 3c8464a9b12bf83807b6e2c896d7e7b633e1cae7 ("powerpc:
Delete old PrPMC 280/2800 support") we got rid of most of the C
code, and the Makefile/Kconfig hooks, but it seems I left the
platform's DTS file orphaned in the tree as well as the boot code.
Here we get rid of them both.
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
Enable the "wake-on-filer" (aka. wake on user defined packet)
wake on lan capability for the eTSEC ethernet nodes.
Cc: Li Yang <leoli@freescale.com>
Cc: Zhao Chenhui <chenhui.zhao@freescale.com>
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
IFC NAND chip select is wrongly mapped to 2 in reg property of
NAND node. Due to this kernel is not able probe NAND flash. Set
chip select to 1 in reg property.
Signed-off-by: Jaiprakash Singh <b44839@freescale.com>
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com>
