path: root/arch/powerpc/boot
2012-12-18Merge remote-tracking branch 'agust/next' into nextBenjamin Herrenschmidt
Brings some 52xx updates. Also manually merged tools/perf/perf.h. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-12-06powerpc: mpc5200: Add a3m071 board supportStefan Roese
This patch adds the MPC5200B based a3m071 board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-11-26Merge remote-tracking branch 'kumar/next' into nextBenjamin Herrenschmidt
Freescale updates from Kumar
2012-11-25powerpc/dma/raidengine: add raidengine deviceXuelin Shi
The RaidEngine is a new Freescale hardware that used for parity computation offloading in RAID5/6. This patch adds the device node in device tree and related binding documentation. Signed-off-by: Harninder Rai <harninder.rai@freescale.com> Signed-off-by: Naveen Burmi <naveenburmi@freescale.com> Signed-off-by: Xuelin Shi <b29237@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-10-25powerpc/mpc5200: move lpbfifo node and fix its interrupt propertyAnatolij Gustschin
The LPB FIFO interrupt is a peripheral interrupt, thus its L1 cell has to be 2 instead of 3. Fix it and while at it, move the lpbfifo node to the common dtsi file. This patch fixes the irqdomain warning: ... WARNING: at kernel/irq/irqdomain.c:766 Modules linked in: NIP: c00587fc LR: c0058e0c CTR: c0014e54 REGS: c7837c10 TRAP: 0700 Tainted: G W (3.7.0-rc1-00003-g6e51414) MSR: 00029032 <EE,ME,IR,DR,RI> CR: 82cd8322 XER: 00000000 TASK = c7834000[1] 'swapper' THREAD: c7836000 GPR00: 00000001 c7837cc0 c7834000 c7806080 000000d7 c7837d20 00000003 c7837cec GPR08: c7837ce8 00000000 00000000 00000008 82cd3342 00000000 c0003f88 00000000 GPR16: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c7850ec0 GPR24: c782b010 00000000 00000001 c7852900 00000003 c7df5be0 c7806080 000000d7 NIP [c00587fc] irq_linear_revmap+0x2c/0x4c LR [c0058e0c] irq_create_mapping+0x28/0x124 Reported-by: Stefan Roese <sr@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-10-25powerpc/pcm030: add pcm030-audio-fabric to dtsEric Millbrandt
Add a node for the pcm030-audio-fabric ASoC driver Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-10-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "Some highlights in addition to the usual batch of fixes: - 64TB address space support for 64-bit processes by Aneesh Kumar - Gavin Shan did a major cleanup & re-organization of our EEH support code (IBM fancy PCI error handling & recovery infrastructure) which paves the way for supporting different platform backends, along with some rework of the PCIe code for the PowerNV platform in order to remove home made resource allocations and instead use the generic code (which is possible after some small improvements to it done by Gavin). - Uprobes support by Ananth N Mavinakayanahalli - A pile of embedded updates from Freescale folks, including new SoC and board supports, more KVM stuff including preparing for 64-bit BookE KVM support, ePAPR 1.1 updates, etc..." Fixup trivial conflicts in drivers/scsi/ipr.c * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits) powerpc/iommu: Fix multiple issues with IOMMU pools code powerpc: Fix VMX fix for memcpy case driver/mtd:IFC NAND:Initialise internal SRAM before any write powerpc/fsl-pci: use 'Header Type' to identify PCIE mode powerpc/eeh: Don't release eeh_mutex in eeh_phb_pe_get powerpc: Remove tlb batching hack for nighthawk powerpc: Set paca->data_offset = 0 for boot cpu powerpc/perf: Sample only if SIAR-Valid bit is set in P7+ powerpc/fsl-pci: fix warning when CONFIG_SWIOTLB is disabled powerpc/mpc85xx: Update interrupt handling for IFC controller powerpc/85xx: Enable USB support in p1023rds_defconfig powerpc/smp: Do not disable IPI interrupts during suspend powerpc/eeh: Fix crash on converting OF node to edev powerpc/eeh: Lock module while handling EEH event powerpc/kprobe: Don't emulate store when kprobe stwu r1 powerpc/kprobe: Complete kprobe and migrate exception frame powerpc/kprobe: Introduce a new thread flag powerpc: Remove unused __get_user64() and __put_user64() powerpc/eeh: Global mutex to protect PE tree powerpc/eeh: Remove EEH PE for normal PCI hotplug ...
2012-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull the trivial tree from Jiri Kosina: "Tiny usual fixes all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) doc: fix old config name of kprobetrace fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc btrfs: fix the commment for the action flags in delayed-ref.h btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID vfs: fix kerneldoc for generic_fh_to_parent() treewide: fix comment/printk/variable typos ipr: fix small coding style issues doc: fix broken utf8 encoding nfs: comment fix platform/x86: fix asus_laptop.wled_type module parameter mfd: printk/comment fixes doc: getdelays.c: remember to close() socket on error in create_nl_socket() doc: aliasing-test: close fd on write error mmc: fix comment typos dma: fix comments spi: fix comment/printk typos in spi Coccinelle: fix typo in memdup_user.cocci tmiofb: missing NULL pointer checks tools: perf: Fix typo in tools/perf tools/testing: fix comment / output typos ...
2012-09-27Merge remote-tracking branch 'agust/next' into nextBenjamin Herrenschmidt
mpc5xxx updates from Anatolij
2012-09-14powerpc/mpc5200: add dts files for ifm camera machinesAnatolij Gustschin
Add common o2d dtsi file to reuse it for other configurations. Add machine compatible string to mpc5200 simple platform file. Add dts files for O2D, O2I, O2MNT, O2DNT2, O2D300 and O3DNT boards. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-09-12powerpc/p5040: fix dtb build warning of p5040ds.dtbShaohui Xie
Device node adt7461 was wrongly added in p5040ds.dts, it should be added into i2c instead of localbus, when build p5040ds.dtb, a warning will dump: Warning (reg_format): "reg" property in /localbus@ffe124000/nand@2,0/adt7461@4c has invalid length (4 bytes) (#address-cells == 1, #size-cells == 1) This was introduced by: commit ea6b1ba692bcb5f6e39f409a78cf8b04fdf23baa Author: Jia Hongtao <B38951@freescale.com> Date: Tue Aug 28 10:00:55 2012 +0800 powerpc: add adt7461 thermal monitor support to applicable boards Add thermal monitor support to following boards: P1022DS, MPC8536DS, P2041RDB, P3041DS, P4080DS, P5020DS, P5040DS Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc/8544ds: add partition table for norflashWang Dongsheng
create partition table for norflash. Signed-off-by: Wang Dongsheng <Dongsheng.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc: add adt7461 thermal monitor support to applicable boardsJia Hongtao
Add thermal monitor support to following boards: P1022DS, MPC8536DS, P2041RDB, P3041DS, P4080DS, P5020DS, P5040DS Signed-off-by: Jia Hongtao <B38951@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc/e5500: Add Power ISA properties to comply with ePAPR 1.1Olivia Yin
power-isa-version and power-isa-* are cpu node general properties defined in ePAPR. If the power-isa-version property exists, then for each category from the Categories section of Book I of the Power ISA version indicated, the existence of a property named power-isa-[CAT], where [CAT] is the abbreviated category name with all uppercase letters converted to lowercase, indicates that the category is supported by the implementation. This patch update all the e5500 platforms. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Olivia Yin <hong-hua.yin@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc/e500mc: Add Power ISA properties to comply with ePAPR 1.1Olivia Yin
power-isa-version and power-isa-* are cpu node general properties defined in ePAPR. If the power-isa-version property exists, then for each category from the Categories section of Book I of the Power ISA version indicated, the existence of a property named power-isa-[CAT], where [CAT] is the abbreviated category name with all uppercase letters converted to lowercase, indicates that the category is supported by the implementation. The patch update all the e500mc platforms. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Olivia Yin <hong-hua.yin@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc/e500v2: Add Power ISA properties to comply with ePAPR 1.1Olivia Yin
power-isa-version and power-isa-* are cpu node general properties defined in ePAPR. If the power-isa-version property exists, then for each category from the Categories section of Book I of the Power ISA version indicated, the existence of a property named power-isa-[CAT], where [CAT] is the abbreviated category name with all uppercase letters converted to lowercase, indicates that the category is supported by the implementation. The patch update all e500v2 platforms. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Olivia Yin <hong-hua.yin@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc/85xx: introduce support for the Freescale / iVeia P1022RDKTimur Tabi
The Freescale / iVeia P1022RDK reference board is a small-factor board with a Freescale P1022 SOC. It includes: 1) 512 MB 64-bit DDR3-800 (max) memory 2) 8MB SPI serial flash memory for boot loader 3) Bootable 4-bit SD/MMC port 4) Two 10/100/1000 Ethernet connectors 5) One SATA port 6) Two USB ports 7) One PCIe x4 slot 8) DVI video connector 9) Audio input and output jacks, powered by a Wolfson WM8960 codec. Unlike the P1022DS, the P1022RDK does not have any localbus devices, presumably because of the localbus / DIU multiplexing restriction of the P1022 SOC. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc/85xx: Add support for P5040DS boardTimur Tabi
Add support for the Freescale P5040DS Reference Board ("Superhydra"), which is similar to the P5020DS. Features of the P5040 are listed below, but not all of these features (e.g. DPAA networking) are currently supported. Four P5040 single-threaded e5500 cores built Up to 2.4 GHz with 64-bit ISA support Three levels of instruction: user, supervisor, hypervisor CoreNet platform cache (CPC) 2.0 MB configures as dual 1 MB blocks hierarchical interconnect fabric Two 64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving support Up to 1600MT/s Memory pre-fetch engine DPAA incorporating acceleration for the following functions Packet parsing, classification, and distribution (FMAN) Queue management for scheduling, packet sequencing and congestion management (QMAN) Hardware buffer management for buffer allocation and de-allocation (BMAN) Cryptography acceleration (SEC 5.0) at up to 40 Gbps SerDes 20 lanes at up to 5 Gbps Supports SGMII, XAUI, PCIe rev1.1/2.0, SATA Ethernet interfaces Two 10 Gbps Ethernet MACs Ten 1 Gbps Ethernet MACs High-speed peripheral interfaces Two PCI Express 2.0/3.0 controllers Additional peripheral interfaces Two serial ATA (SATA 2.0) controllers Two high-speed USB 2.0 controllers with integrated PHY Enhanced secure digital host controller (SD/MMC/eMMC) Enhanced serial peripheral interface (eSPI) Two I2C controllers Four UARTs Integrated flash controller supporting NAND and NOR flash DMA Dual four channel Support for hardware virtualization and partitioning enforcement Extra privileged level for hypervisor support QorIQ Trust Architecture 1.1 Secure boot, secure debug, tamper detection, volatile key storage Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc/85xx: add Freescale P5040 SOC and SEC v5.2 device treesKim Phillips
Add device tree (dtsi) files for the Freescale P5040 SOC. Since this SOC introduces SEC v5.2, add the dtsi file for that also. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-12powerpc/85xx: remove P1020RDB and P2020RDB CAMP device treesTimur Tabi
We only need two examples of CAMP device trees in the upstream kernel. Co-operative Asymmetric Multi-Processing (CAMP) is a technique where two or more operating systems (typically multiple copies of the same Linux kernel) are loaded into memory, and each kernel is given a subset of the available cores to execute on. For example, on a four-core system, one kernel runs on cores 0 and 1, and the other runs on cores 2 and 3. The devices are also partitioned among the operating systems, and this is done with customized device trees. Each kernel gets its own device tree that has only the devices that it should know about. Unfortunately, this approach is very hackish. The kernels are trusted to only access devices in their respective device trees, and the partitioning only works for devices that can be handled. Crafting the device trees is a tricky process, and getting U-Boot to load and start all kernels is cumbersome. But most importantly, each CAMP setup is very application-specific, since the actual partitioning of resources is done in the DTS by the system designer. Therefore, it doesn't make a lot of sense to have a lot of CAMP device trees, since we only expect them to be used as examples. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-09-07powerpc: Fix build dependencies for c files requiring libfdt.hMatthew McClintock
Several files in obj-plat depend on libfdt header file. Sometimes when building one can see the following issue. This patch adds libfdt as dependency to those object files | In file included from arch/powerpc/boot/treeboot-iss4xx.c:33:0: | arch/powerpc/boot/libfdt.h:854:1: error: unterminated comment | In file included from arch/powerpc/boot/treeboot-iss4xx.c:33:0: | arch/powerpc/boot/libfdt.h:1:0: error: unterminated #ifndef | BOOTCC arch/powerpc/boot/inffast.o | make[1]: *** [arch/powerpc/boot/treeboot-iss4xx.o] Error 1 | make[1]: *** Waiting for unfinished jobs.... | BOOTCC arch/powerpc/boot/inflate.o | make: *** [uImage] Error 2 | ERROR: oe_runmake failed | ERROR: Function failed: do_compile (see /srv/home/pokybuild/yocto-autobuilder/yocto-slave/p1022ds/build/build/tmp/work/p1022ds-poky-linux-gnuspe/linux-qoriq-sdk-3.0.34-r5/temp/log.do_compile.2167 for further information) NOTE: recipe linux-qoriq-sdk-3.0.34-r5: task do_compile: Failed Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-01powerpc: remove four unused files from .gitignorePaul Bolle
Commit 4f3865fb57a04db7cca068fed1c15badc064a302 ("zlib_inflate: Upgrade library code to a recent version") removed infblock.c, infblock.h, infcodes.c, and infcodes.h from the tree. Remove their entries in powerpc's .gitignore file too. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-08-10powerpc/p4080ds: dts - add usb controller version info and port0Shengzhou Liu
Add the missing usb controller version info and port0, which is required during setup usb phy. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-26powerpc/85xx: P3041DS - change espi input-clock from 40MHz to 35MHzShaohui Xie
Default CoreNet Coherency Bus (CCB) frequency on P3041 is 750MHz, but espi cannot work at 40MHz with this CCB frequency, so we need to slow down the clock rate of espi to 35MHz to make it work stable at the CCB frequency. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-26powerpc/85xx: Fix pci base address error for p2020rdb-pc in dtsTang Yuantian
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-12powerpc/85xx: Add phy nodes in SGMII mode for MPC8536/44/72DS & P2020DSJia Hongtao
In SGMII riser card different PHY chip are used with different external IRQ from eTSEC. To support PHY link state auto detect in SGMII mode we should add another group of PHY nodes for SGMII mode. For MPC8572DS IRQ6 is used for PHY0~PHY1, IRQ7 is used for PHY2~PHY3. For MPC8544DS and MPC8536DS IRQ6 is used for PHY0~PHY1. For P2020DS IRQ5 is used for PHY1~PHY2. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jia Hongtao <B38951@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-11powerpc/85xx: Rename P1021RDB-PC device trees to be consistentXu Jiucheng
The board is really P1021RDB-PC, so rename from p1021rdb.* to p1021rdb-pc.* Signed-off-by: Xu Jiucheng <Jiucheng.Xu@freescale.com> Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/85xx: Add ucc uart support for p1025rdbZhicheng Fan
Add device tree nodes to enable ucc uart support on P1025RDB. Signed-off-by: Zhicheng Fan <B32736@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/85xx: MPC8572DS - Update the MSI interrupts into 4-cell formatJia Hongtao
With 2-cell format interrupts of MSI PCIe ethernet card can not work. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jia Hongtao <B38951@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/85xx: MPC8572DS - Fix eTSEC is not available on core1 of AMP bootJia Hongtao
The issue log on core1 is: root@mpc8572ds:~# ifconfig eth0 10.192.208.244 net eth0: could not attach to PHY SIOCSIFFLAGS: No such device To attach PHY node mdio@24520 should not be disabled in dts of core1. Because all PHYs are controlled through this node as follows: mdio@24520 { phy0: ethernet-phy@0 { interrupts = <10 1 0 0>; reg = <0x0>; }; phy1: ethernet-phy@1 { interrupts = <10 1 0 0>; reg = <0x1>; }; phy2: ethernet-phy@2 { interrupts = <10 1 0 0>; reg = <0x2>; }; phy3: ethernet-phy@3 { interrupts = <10 1 0 0>; reg = <0x3>; }; tbi0: tbi-phy@11 { reg = <0x11>; device_type = "tbi-phy"; }; }; Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jia Hongtao <B38951@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/85xx: Add BSC9131 RDB SupportPrabhakar Kushwaha
BSC9131RDB is a Freescale reference design board for BSC9131 SoC. The BSC9131 is integrated SoC that targets Femto base station market. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements. The BSC9131 SoC includes the following function and features: . Power Architecture subsystem including a e500 processor with 256-Kbyte shared L2 cache . StarCore SC3850 DSP subsystem with a 512-Kbyte private L2 cache . The Multi Accelerator Platform Engine for Femto BaseStation Baseband Processing (MAPLE-B2F) . A multi-standard baseband algorithm accelerator for Channel Decoding/Encoding, Fourier Transforms, UMTS chip rate processing, LTE UP/DL Channel processing, and CRC algorithms . Consists of accelerators for Convolution, Filtering, Turbo Encoding, Turbo Decoding, Viterbi decoding, Chiprate processing, and Matrix Inversion operations . DDR3/3L memory interface with 32-bit data width without ECC and 16-bit with ECC, up to 400-MHz clock/800 MHz data rate . Dedicated security engine featuring trusted boot . DMA controller . OCNDMA with four bidirectional channels . Interfaces . Two triple-speed Gigabit Ethernet controllers featuring network acceleration including IEEE 1588. v2 hardware support and virtualization (eTSEC) . eTSEC 1 supports RGMII/RMII . eTSEC 2 supports RGMII . High-speed USB 2.0 host and device controller with ULPI interface . Enhanced secure digital (SD/MMC) host controller (eSDHC) . Antenna interface controller (AIC), supporting three industry standard JESD207/three custom ADI RF interfaces (two dual port and one single port) and three MAXIM's MaxPHY serial interfaces . ADI lanes support both full duplex FDD support and half duplex TDD support . Universal Subscriber Identity Module (USIM) interface that facilitates communication to SIM cards or Eurochip pre-paid phone cards . TDM with one TDM port . Two DUART, four eSPI, and two I2C controllers . Integrated Flash memory controller (IFC) . TDM with 256 channels . GPIO . Sixteen 32-bit timers The DSP portion of the SoC consists of DSP core (SC3850) and various accelerators pertaining to DSP operations. BSC9131RDB Overview ---------------------- BSC9131 SoC 1Gbyte DDR3 (on board DDR) 128Mbyte 2K page size NAND Flash 256 Kbit M24256 I2C EEPROM 128 Mbit SPI Flash memory USB-ULPI eTSEC1: Connected to RGMII PHY eTSEC2: Connected to RGMII PHY DUART interface: supports one UARTs up to 115200 bps for console display Linux runs on e500v2 core and access some DSP peripherals like AIC Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Akhil Goyal <Akhil.Goyal@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Rajan Srivastava <rajan.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10Revert "powerpc/p3060qds: Add support for P3060QDS board"Timur Tabi
This reverts commit 96cc017c5b7ec095ef047d3c1952b6b6bbf98943. The P3060 was cancelled before it went into production, so there's no point in supporting it. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/85xx: use the BRx registers to enable indirect mode on the P1022DSTimur Tabi
In order to enable the DIU video controller on the P1022DS, the FPGA needs to be switched to "indirect mode", where the localbus is disabled and the FPGA is accessed via writes to localbus chip select signals CS0 and CS1. To obtain the address of CS0 and CS1, the platform driver uses an "indirect pixis mode" device tree node. This node assumes that the localbus 'ranges' property is sorted in chip-select order. That is, reg value 0 maps to CS0, reg value 1 maps to CS1, etc. This is how the 'ranges' property is supposed to be arranged. Unfortunately, the 'ranges' property is often mis-arranged, and not just on the P1022DS. Linux normally does not care, since it does not program the localbus. But the indirect-mode code on the P1022DS does care. The "proper" fix is to have U-Boot fix the 'ranges' property, but this would be too cumbersome. The names and 'reg' properties of all the localbus devices would also need to be updated, and determining which localbus device maps to which chip select is board-specific. Instead, we determine the CS0/CS1 base addresses the same way that U-boot does -- by reading the BRx registers directly and mapping them to physical addresses. This code is simpler and more reliable, and it does not require a U-boot or device tree change. Since the indirect pixis device tree node is no longer needed, the node is deleted from the DTS. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/p2041rdb: add NAND node in device treeShaohui Xie
NAND on p2041 uses CS1 as chip select. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc: remove Wind River SBC8560 supportPaul Gortmaker
This reference board dates back to 2004, and is largely a legacy EOL product. The MPC8560 is a pre e500v2 CPU. The SBC8548 is a more modern, better e500v2 target for people to use as a reference board with today's kernels, should they require one. Removing support for it will also allow us to remove some sbc8560 specific quirk handling in 8250 UART code, and some MTD mapping support. Cc: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/85xx: Add P1024rdb dts supportTang Yuantian
Signed-off-by: Jin Qing <b24347@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/p1010rdb: add EEPROMs to device treeGustavo Zacarias
Add EEPROM to the P1010RDB device tree. The 24c01 acts as a memory SPD so it shouldn't be overwritten without care. The 24c256 is a general purpose memory. Signed-off-by: Gustavo Zacarias <gustavo@zacarias.com.ar> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10Revert "powerpc/85xx: p2020rdb - move the NAND address."Sebastian Andrzej Siewior
This reverts commit 0c00f65653389a408dfbbee7578e671664eea26a. The initial commit was my fault. There are two boards out there: P2020RDB and P2020RDB-PC. I wasn't aware of that and assumed that I have a RDB board in front of me while I the RDB-PC. This patch makes it work for the RDB-PC variant and breaks it for the RDB. Now there is a device tree file available for the RDB-PC which was not there earlier. So with this revert, everything gets back to normal :) Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/82xx: add SPI support for mgcogeHolger Brunck
Add spi support for mgcoge into the platform code and the dts file. Additionaly SPIDEV is switched on in the defconfig and the updates for the newer kernel version are committed. The SPI interface is used to drive the Maxim DS3106 clock chip. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Heiko Schocher <hs@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/p1022ds: Add RTC supportJerry Huang
Add the RTC support into the p1022ds device tree Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-03powerpc: Kill flatdevtree_env.h tooPaul Bolle
Commit 430b01e8f5e524a2bfa50074d97d0bdc2505807b ("[POWERPC] Kill flatdevtree.c") killed the two files including flatdevtree_env.h. It was apparently just an oversight to not kill that header too. Kill it now. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-03powerpc/boot: Only build board support files when required.Tony Breeds
Currently we build all board files regardless of the final zImage target. This is sub-optimal (in terms on compilation) and leads to problems in one platform needlessly causing failures for other platforms. Use the Kconfig variables to selectively construct this board files to build. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-05-26Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc driver specific updates from Olof Johansson: "These changes are specific to some driver that may be used by multiple boards or socs. The most significant change in here is the move of the samsung iommu code from a platform specific in-kernel interface to the generic iommu subsystem." Fix up trivial conflicts in arch/arm/mach-exynos/Kconfig * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits) mmc: dt: Consolidate DT bindings iommu/exynos: Add iommu driver for EXYNOS Platforms ARM: davinci: optimize the DMA ISR ARM: davinci: implement DEBUG_LL port choice ARM: tegra: Add SMMU enabler in AHB ARM: tegra: Add Tegra AHB driver Input: pxa27x_keypad add choice to set direct_key_mask Input: pxa27x_keypad direct key may be low active Input: pxa27x_keypad bug fix for direct_key_mask Input: pxa27x_keypad keep clock on as wakeup source ARM: dt: tegra: pinmux changes for USB ULPI ARM: tegra: add USB ULPI PHY reset GPIO to device tree ARM: tegra: don't hard-code USB ULPI PHY reset_gpio ARM: tegra: change pll_p_out4's rate to 24MHz ARM: tegra: fix pclk rate ARM: tegra: reparent sclk to pll_c_out1 ARM: tegra: Add pllc clock init table ARM: dt: tegra cardhu: basic audio support ARM: dt: tegra30.dtsi: Add audio-related nodes ARM: tegra: add AUXDATA required for audio ...
2012-05-15Merge branch 'drivers/mmc' into next/driversArnd Bergmann
* drivers/mmc: mmc: dt: Consolidate DT bindings Also pulls in the omap/dt-missed-3.4 branch as a dependency. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-15mmc: dt: Consolidate DT bindingsArnd Bergmann
This patch unifies the current DT MMC bindings documentation and code, adds generic MMC DT bindings documentation, and updates .dts files for consistency. [cjb: typo fixes, addition of max-frequency property] Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-03powerpc/44x: Add PCI MSI node for Maui APM821xx SoC and Bluestone board in DTSMai La
Signed-off-by: Mai La <mla@apm.com> Signed-off-by: Josh Boyer <jwboyer@gmail.com>
2012-04-19powerpc/mpc85xx: add MPIC message dts nodeMingkai Hu
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-29powerpc/dts: Removed fsl,msi property from dts.Diana CRACIUN
The association in the decice tree between PCI and MSI using fsl,msi property was an artificial one and it does not reflect the actual hardware. Signed-off-by: Diana CRACIUN <Diana.Craciun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-29powerpc/85xx: add the P1020UTM-PC DTS supportJerry Huang
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-29powerpc/85xx: add the P1020MBG-PC DTS supportJerry Huang
